PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 [102] 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. wester tune
  2. IAT insanely high?
  3. what wideband parts for HP tuners?
  4. Please Help, Limp Mode, Security, BCM?? Whats going on
  5. Help. Check engine light on MAF voltage low
  6. dyno-tuning needed
  7. Help with EGR PID
  8. EFI Live or HP tuner?
  9. Car not running right after header install
  10. Anyone tried these O2's? Any tuning issues w/them?
  11. i need a handheld for 98 ta
  12. Failed Emission: "Not Ready"
  13. Wideband Ratings- Article
  14. Any advantage to 2 wideband o2 units?
  15. tps low voltage, also 2.4% when closed???
  16. What tables should be tranfered tunes between two incompatable OS's?
  17. LC1 WB Wiring question
  18. Okay, stickys didnt help, need LT1 tuning help
  19. Weird O2 readings during datalogging...
  20. if you are running any megasquirt in here plz.
  21. HELP! URGENT! I've got errors during a full reflash. What what should I do?
  22. Crappy Throttle Responce During Warmup
  23. Idle help- EFIlive
  24. 2004 Trailblazer
  25. rear 02 function
  26. Where to put WB o2 bung?
  27. Any writeup for HPT 3 bar setup?
  28. Fuel Trims are different for banks 1 & 2
  29. New Cam and and T/C = Tune ??
  30. PLX Wide Band GP
  31. 02 Sensor question..
  32. Intermitent cylinder 1 misfire PLEASE HELP!!!
  33. Reset pcm after o2 install?
  34. Wild AFR after cam install!!!
  35. Can a Handheld disable O2 and smog pump codes or do I need a local tuner???
  36. what the heck is up with my VE table?
  37. ODBII on but not reading
  38. Torque Management
  39. Help-big injector bog off the line!!!!
  40. A/F Gauge Install Assistance please..Need to find a wire!
  41. Any tips on tuning a HUGE cam????
  42. Want some help with the diablo
  43. ASR tunning
  44. which after market EMS
  45. Predator, Torque Managment
  46. new motor tune question?
  47. verdict on o2 sensor replacements?
  48. Deleting codes
  49. Need help, car threw some codes..!
  50. ASA Coil Tables
  51. I have KR from a Roll.
  52. weiand intake night mare any 1 use these?
  53. 2004 Chevy 2500HD 4x4 Tune issues.
  54. WTF?? Broke my shit today!!!!
  55. timing and octane any one want to talk
  56. LS7vLS1 Spark Dwell time.
  57. ses codes after cam
  58. Is my WBC control module bad? Description inside.
  59. running lean
  60. Stupid car not making sense..cam and idle problems.
  61. What would cause a diagnostic tool to not link up?
  62. Security Light??
  63. D@MN STUPID F*#& PLUG!!!!! :cry:
  64. OBDII scanner not powering on
  65. does this look normal
  66. need P0724 help
  67. po106
  68. LS1 need help tuning timing
  69. Cold Motor Problem HPT Guys in Here Please
  70. Map readings at idle? 65kpa
  71. tuning needed for slp 85mm MAF?
  72. P0103
  73. Tuning VE table with LM1 issues/questions
  74. U1000 Help
  75. High Idle in gear?
  76. A/F ratio problem
  77. security light flashing
  78. Someone with a AFR clue come in
  79. Can a diablo.....
  80. Help Please
  81. Best values for Power Enrich Fuel Multiplier vs. RPM
  82. BS3 Troubleshooting Line Pressure
  83. can someone post a file for me to look at? any file works .bin please
  84. 1971 Chevelle LS1 H/C pics and vids
  85. 3 Tune device
  86. Pcm
  87. Engine Temp->Fan Settings, etc.
  88. Tuning for 2 step rev limiter & trans brake
  89. Base Running Airflow: Ported TB has a lower RAF than Stock,why?
  90. LS6 install, need to re-tune??
  91. 9 Widebands Tested within, Innovate wins accuracy
  92. I need a tune. help
  93. p0172, p0175, somebody help a girl diagnose the problem...purty PLEASE :)
  94. Hesitation/Cutting out during first couple minutes of driving & funky idle
  95. Steady State Hi/Low
  96. How important is the speedo to your tune...
  97. MAF g/sec vs. dynamic airflow g/sec
  98. Maf
  99. Tuning 4.2L TB
  100. Problem Getting EFILIVE V2 to work on my car
  101. 3 Bar Issues
  102. BS3 w/aftermaket gauges
  103. O2 sensors????
  104. Analyze my freescan datalog please!
  105. How long do wideband sensors last?
  106. hptuners engine torque pid
  107. Help: 2k idle and hesitation
  108. Warning Lights Problems....PLEASE HELP
  109. HP Tuners: to throw off the speedometer
  110. Idle Problem -- Help
  111. Stock Tune
  112. what the hell is causing this restriction with my tune???
  113. OBD II plugin problem
  114. EFILive and PLX SM-AFR Wiring questions
  115. Is it really worth it having the programmer?
  116. p0122
  117. People Who Know BS3
  118. Any temp/mobile type widebands out that can just go up tailpipe and not mount in car?
  119. what is the best "tuning program" for supercharged lt1
  120. Problem with Lc1/Hptuners, HELP!
  121. Where can I buy LT-1 edit software at
  122. [B]I need help with this throuble code!![/B]
  123. Need some help
  124. -40 degree coolant reading. no o2 readings
  125. GMMG tuning
  126. NOOB Ques on PCM location
  127. hypertech quick question.
  128. P1133 and P1153 Codes
  129. timing cells to tune on n2o
  130. hptuners/vats
  131. 4L60E Wiring
  132. BS3 users
  133. Just intalled cam and have zero throtle response
  134. change to bin
  135. LS1 RX7 not running right
  136. Tuning VE with wideband?
  137. Compatibility Issue with Granetelli MAF and Diablo Predator
  138. Deleted EGR but no SES?
  139. MAF tuning theory
  140. Anyone else with TPS issues? code 0121
  141. Help...speedo quit working...
  142. e 85 and a ls1
  143. o2 sensor code, but which o2???
  144. Enabling tach?
  145. MAF not reading..4 other codes HELP!!!
  146. Any one hear of The Horse Power House Bowling green ky
  147. HELP! Code P0174!
  148. problems ?
  149. m6 pcm to a4?
  150. Is there a way to switch between 2 tunes?
  151. Misfire at Idle and almost 4* of KR
  152. HP Tuners Question
  153. 87 octane tune?
  154. Trans Speed Sensor wire?
  155. LTFT's stay stuck at -15 flash after flash
  156. Surging idle
  157. Get rid of knock sensors - yes or no?
  158. How you do VE
  159. pcm pin outs lost in sapce
  160. cars pissing me off
  161. Speed density????
  162. Strange engine cut out at 6k rpm's
  163. ~~Bad gas messed up my O2's?~~
  164. Converted to E85
  165. LC1, where are you mounting them and how are your 2 grounds configured.
  166. 58 -> 26 RELUCTOR ADAPTER/TRANSLATOR
  167. 98 tuner question
  168. Megasquirt and tuning in the UK
  169. Settings for Cooling Fans On/Off and Temps
  170. HP Tuners Scanner Map Sensor
  171. ses perforamnce question?
  172. bought the 6ls now car runs like crap
  173. O2 Problem/Question
  174. megasquirt or hpt for turbo setup?????
  175. Tune with converter swap?
  176. Chaning out pcms
  177. code PO3OO
  178. No start, battery charged, PCM replaced last year....
  179. Please help... get gears or get it tuned?
  180. Harlan 2 step, or something similar...
  181. Low Voltage in all 4 o2s?
  182. Ses 327
  183. What would cause LTFT Bank 2 to always read -100?
  184. Can I modify Active Fuel Mgt. with EFI Live?
  185. 5 different codes SES
  186. KR, KR, and more KR!!!
  187. on obII port what reads the rpm?
  188. Still throwing p0102 & p0118 after changing parts + hesitation after washing engine
  189. locked tuners
  190. looking for a wideband
  191. 2nd gear start
  192. Which year OS to use for 2-bar SD ?
  193. A/c Codes
  194. Mr. Gibbs has a new tune
  195. buy software or have shop tune
  196. TPS Sensor Voltage? HELP!
  197. Can I tune this? "Help ASAP"
  198. problems with datamaster
  199. IAC reading 310 all time!!
  200. could this be whats wrong?
  201. HP Tuners auto tune
  202. Harness Qs for LS1/S10 swap
  203. Ok hptuners and b1 cam...221/221/558/558/114lsa.
  204. Something I don't understand about tuning VE?
  205. Trans Tuning
  206. This might be a stupid question
  207. Why does my idle hang at 1300 rpms?
  208. Best Tuner For My Needs??
  209. Know of a good tuner?
  210. IAT Heat soak?
  211. Bad o2?
  212. Pinging under throttle blip
  213. Tired of reading about VE!!!
  214. 4200 Stall Swap Question
  215. HP tuner question
  216. MAF questions??
  217. map issue
  218. MSD tunable ignition
  219. Another tuning question???
  220. symptoms of crank relearn?
  221. Tune after porting TB?
  222. hpt not = to lm1
  223. [HPTuners] Strange Fueling
  224. 2 lc1's + 2 vehicles + 1 eio
  225. I've Run Out Of Ideas....
  226. pcm trouble
  227. Vinci/Crane Cams Powermax vs DiabloSport Predator
  228. Unlimited E38, E67, T43, and T42 streams $5990
  229. swapping ls1
  230. A4 tuning help
  231. Problem reading my car's VIN
  232. How much Knock Retard is accaptable
  233. can't tune my car
  234. Problems remain w/surging @ wot after cam swap & tuning
  235. LS1 Timing guru's,.. got a question
  236. Harness to ECU pins
  237. Help Car is acting very funny!
  238. Yet another theory on how to tune...
  239. EFI Live Scan Tool Versatility
  240. Techies..I need your help
  241. Car still won't idle correctly even after tuning IAC and RAF
  242. HELP! My car won't start!!
  243. What wideband to use?
  244. HELP!! Lost tune? (I read the sticky that says it can't happen)
  245. How to pull codes with out scan tool?????
  246. Frustration at the track
  247. What is PWM and Where is it in HPT?
  248. "unable to connect to vcm"
  249. I know illl probably get ripped on for this......
  250. Tuning Software
