PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 [86] 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. which is better
  2. help with vats and other wiring
  3. Knock Sensor
  4. risk?
  5. How much would you pay for extra gas mileage?
  6. Pictures of widebands or a/f guages in car
  7. low oil light!??
  8. 160* T-stat?
  9. New LS7 crate engine won't start
  10. Just checking
  11. Cam Position Sensor Malfunction
  12. DTC P0135, 0155, problems with 02-sensor heater
  13. Dtc 1336.
  14. New Shift Speed / Shift Points
  15. new L99 / LS3 tuning
  16. TC locking
  17. 6.0/5.3 Head idle help! HP Tuners
  18. pcm trouble HELP!!!
  19. Insufficient Switching Sensor 1 or Bank 1 Sensor 1
  20. Upping the boost...Where do it tune for this?
  21. MAP pinout to use Innovate 02 Sensor???
  22. Aftermarket fuel pump
  23. Need some wideband help
  24. Tuning Nirous question
  25. tuning question
  26. VE master...maximum RPM ability?
  27. Help ! Cam Pickup Problem !
  28. MAF Affecting Lockup?!?
  29. Dam Flashing Security Light!!! Help Please!
  30. Wiring harness
  31. Anyone a SCT dealer need to get retune ASAP
  32. Help,Down On Power and Don't smell like a Rolling Gas Station.
  33. Need a tuner in alabama or Tn.
  34. TRans Issue- No Codes on Predator
  35. FI help w/T76 2Bar
  36. h/c/i ls1 Stalling hard off line HELP
  37. TCI trans controller help
  38. lt1 tune
  39. HP tuners Problem
  40. Tuning Q?
  41. Houston dyno tune
  42. Tune wideband with STFTs
  43. help with O2 sensor or something else?
  44. Hypertech Power Programmer
  45. blowing ENG SEN fuse
  46. How are relays rated?
  47. Locked PCM?
  48. Its like my tune dissapeared WTF???
  49. Help me set my timing curve please! 236/236 110 cam,
  50. EFILive tuner in VA?
  51. VSS Output with Autometer Speedo
  52. Anyone know that this code is? PO-420.
  53. Service engine soon light is flashing????
  54. Injector/VE scaling?!?
  55. Max Timing for idle??LT1
  56. Deleting O2 codes p1133 p1153, will the car run in open loop???
  57. pcm recaliberating?
  58. Code Reseet
  59. White smoke at idle!
  60. it keeps dying
  61. dtc 0748
  62. Brake Light On!
  63. Question for you???
  64. Is 15.5 to 16.5 acceptable for Cruise?
  65. Intermittant rpm / cutting out problem. (HELP PLZ)
  66. mail order tune for procharger
  67. LS1 Tune maybe Vengeance Vindicator cam?
  68. best wideband
  69. Timing Question
  70. Used tuning software
  71. What kind of maf is this?
  72. HIGH idle when map sensor is plugged in?
  73. Procharger Tune
  74. BAD somthing?
  75. 96lb. injectors and AEM driver...tuning?
  76. Can a Diablosport tuner for a 00 LS1 be a normal ODB2 reader/code clearer?
  77. Indiana LSX tuner
  78. TunerCat Tuning: Info and Help
  79. DTC and O2 problems
  80. Fuel pressure logging
  81. mail order tune..
  82. Car has no start condition
  83. Spark advance surge/O2 readings? (VCM Scan Prtscn inside)
  84. Where to set shift points while installin hypertech?
  85. maf code (lt1)
  86. Flashscan v1/Data logging
  87. LS1Edit fun----How do you convert injector lb/hr to gm/sec????
  88. Measure your 0-60 times, etc with your IPod!
  89. Formato Tuning and Porting in Gettysburgh PA - 8/22 -8/25
  90. Throttle body wiring??
  91. A/F for idle and WOT
  92. SES Light after cleaning engine?
  93. SD tune with hp tuners quick question
  94. P0131 & P0151 at WOT
  95. Change fuel pressure - Change VE - BS3
  96. injectors shutting off
  97. CA 91 Octane With predator and mods safe?
  98. Need help from the pros!!!!!!!!!!!!!!!!
  99. Lean at cruise bucking, what to do?
  100. Is the WBO2 on the LC1 the same as all the others for connectivity?
  101. Having Detination At WOT,FUEL?
  102. Car fires right up cold, but hard to start when warmed up
  103. slew of codes, help!
  104. I Need Help! P1133 Code?
  105. 8.1L MEFI-4b tunning help needed
  106. tuned..but still stalls
  107. Need a stock tune for a 99Z28 (LS1Edit)
  108. HP Tuners question help
  109. LS1Edit & HP Tuners Compatiable
  110. ses comes on more and more
  111. tach on dash not working
  112. HELP! cooling fans not working!
  113. How to set up SD tune?
  114. Gauges cluster
  115. RPM Oscillation
  116. how to datalog LS3 08 vette for free?
  117. Hey yall i have LS1 edit please clarify this program for me
  118. IAT High Voltage Code
  119. Just starting out with EFI Life. need some suggestions.
  120. Is there anyway I can fake Front 02 readings? Read me.
  121. T56 Reverse Lockout
  122. Car Will Not Idle After Tune
  123. What Scan for Newbe?
  124. Please take a look at my tune for TTi stage 1
  125. Default Please take a look at my tune for TTi stage 1
  126. What can be done with this cable?
  127. How do you decide
  128. How fast should o2s switch
  129. Help with head and cam
  130. free tune?
  131. TTi stage 1 and 42/60 lbs injectors
  132. Need help troubleshooting 2004 GTO after cam swap
  133. O2 sims, code, or something like that.
  134. LT1 PCM Fried. Need Help.
  135. HP Tuners Torque MGMT question
  136. P0704
  137. 02`s....ugh...and codes
  138. Diablo Predator
  139. Check engine light, P0133?
  140. Good Dyno tune needed for LS-1 swap
  141. service vehicle light P0200....
  142. Car won't run after mail-order tune
  143. Wait For Me Tune ????
  144. Lean Cruise Options
  145. Innovate LM1 vs LM2
  146. Need a tune
  147. Misfires ~1500 rpms, seems to happen most in #1
  148. Why is my abs inop light on after gear change?
  149. Front 02 delete?
  150. 408 turbo
  151. Damn Now How can I hook up My LM1 WB to my Interface?
  152. 9 engine codes can someone help me
  153. megasquirt vs. stock ecu?
  154. code tune out question
  155. Help..
  156. Can I hook a PLX SM-AFR wideband to the stock 02 sensors?
  157. engine power whilst decelerating
  158. H/C swap = Idle hang?
  159. First Time This Happened! HELP!!!
  160. Looking to buy hp tuners pro?
  161. VE master users quick question
  162. LS1 computer controlling an LT1?
  163. Possible fried VCM?
  164. Change to MAF 85mm -> DTC p0171 & p0174
  165. H02s switching problems
  166. First time tuning....take a look at my log
  167. Best Wideband?
  168. Car running like absolute crap after driving in water.
  169. 5.3 auto into a 00 v6 f body with electronic throttlebody
  170. New thread with dyno pics and new tuning questions
  171. Throttle position sensor A !!! problem
  172. exhaust leaks causing lean codes?
  173. Tune a stock 04 GTO
  174. ? About 8.1l Torque Management System
  175. Running rich all of a sudden well actually since like a month ago.
  176. Tuning School learn @ home + Live Class in Columbus OH Aug 16th & 17th
  177. compression change vs tuning
  178. Afterstart enrichment (choke)
  179. Possible to eliminate electronic throttle in ecm?
  180. Fix your P1133 / P1153 codes
  181. Shift Settings?
  182. po174 and bad gas?
  183. hand held tuner
  184. Rev-limit question
  185. Is This a Tuning Problem?
  186. Fuel Injector offset question
  187. Rev Limiter - Bad Tune
  188. Big Stuff 3 and factory functionality?
  189. Boltons and 125 wet shot. Need a tune.
  190. Shift firmness?
  191. LS1 Hot Cam... now Codes?
  192. VE table
  193. Need Assistance
  194. idle problem.
  195. AFR went from 12.8 to 10.1 on it's own!!
  196. How do i log data with LS1edit?
  197. Sonsors HELP, need fuel rail kit.
  198. Log says car is running CL at WOT...is it lying?
  199. Vehicle Explorer diagnostic s/w over USB
  200. LS1 Edit Software
  201. Can Someone Please Get My Car To Idle??? Tune Inside
  202. Help HPT not working And All Kinds of Codes
  203. EFI Live V2
  204. Rich condition both banks
  205. 402 stroker ms4 tune check please
  206. DesktopDyno 2003
  207. ? about TPS sensor readings
  208. Tuning? for high compression on a daily driver
  209. !EGR and Measured NOx
  210. code deleted question.
  211. Insufficient catalyst code
  212. How do you log WBO2 lambda instead of AFR?
  213. Mail in tune adiquite???
  214. Scanner setup help?
  215. Settings for FAST 50lb LS7 Injectors?
  216. A6 Shift problems with Yank 3200
  217. dumb question
  218. Have a engine code
  219. 98 to 99 tuning issues
  220. Flash between 2 tunes...
  221. Looking for tune: TunerCatssss
  222. Dynojet WB & EFI-liveV2
  223. Built 4l60 slipping on 2-3 shift
  224. LS7 tune
  225. Autotap v1.11 or DOS wanted
  226. Alternator overcharging (new alternator )
  227. How Much Am I Leaving On The Table?!?
  228. Need Help With Security
  229. Just got my jet dst.
  230. cam swap concerns!!!
  231. Shipping my car, need to LOWER performance
  232. Need help to make AFR commanded low res PID
  233. ? about EFI Live
  234. crappy tune???? experienced tuners help!
  235. Lc-1 Install
  236. Need help SLP MAF falls on its face at 6000
  237. hptuners reading low cyl airmass?
  238. nooob tuner questions?
  239. Electronic Problem??
  240. what else
  241. how can i check the diablo to
  242. locked ecm
  243. Handheld a waste for my mods?
  244. How to hook up a narrow band gauge??/
  245. wideband problems....
  246. Datamaster Dyno?
  247. Please help logging Wideband with EGR and logging boost HP TUNERS
  248. HPT Guys How Can I turn off My Evap system?
  249. Hot vs Cold Air temp - tuning Q's
  250. just ordered hp tuners
