PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 [193] 194 195 196 197 198 199 200 201 202 203
  1. What should minimum and maximum temperature for misfire detection be set at?
  2. Deleting CAGS w/ LS1 Edit?
  3. GM Tech 2 Question
  4. AIRBAG light..
  5. Correct way to delete TM?
  6. MAF x 118% and this is what i got....
  7. O2 sims alternative
  8. Where to find best info on Auto Tap ...
  9. New to ls1 edit and autotap ??
  10. Pinging with lite throttle???
  11. Custom Tuning
  12. carputing phone number???
  13. longest 02 senser
  14. What parameter do I need to use to determine IAC count?
  15. Tuning source in Louisville, KY?
  16. P0300 code??
  17. M6 to A4 conversion....
  18. High Octane Timing table- why lower at higher gms/cyl
  19. New LS1 Tuning will be out soon!!
  20. computer question....
  21. Where to buy AutoTap?
  22. SES light
  23. What do you need to tune
  24. Continous Problem
  25. What are you all paying for LS1Edit?
  26. Can't connect using LS1edit or autotap
  27. Shift points for 98 LS1 camaro
  28. Help troubleshoooting codes...
  29. What's the difference between LS1 Edit and the MAF Translator?
  30. Stall conv. question
  31. Do I need Atap for LS1 Edit?
  32. Do I need Atap for LS1 Edit?
  33. Anyone else using Ease ?
  34. What in PCM do I need to change for 30lb injectors
  35. Can we start a list of cool things to do with LS1 Edit (code deletion, etc...)?
  36. Need more info before buying LS1 Edit
  37. LTFT's and Atap Log Suggestions.
  38. spe proflash program for trucks?
  39. Is the latest ATAP software working properly??
  40. Scanmaster ?'s
  41. timing with racing fuel
  42. big brother black box
  43. LS1 Jet Performance Chip??
  44. how to fix this with edit
  45. MAFT Confusion? ver 5.2
  46. Pinging at 910-940 02 voltage and 21-23 degrees timing
  47. LS1 Edit, opend a test file now it will not open mine!!
  48. temp gauge accuracy........
  49. Will a Granatelli MAF work on a 01 Silverado truck...
  50. reseting my ecu
  51. rs-232 port
  52. AFR with EFI Live
  53. Any help with EASE appreciated
  54. Part number for stock pcm?
  55. PCM tuning vs Warranty and data logging?'s>>>
  56. Tried to order a Knock Out Box... No luck...
  57. LS1 pinging
  58. What size resister to retard timing?
  59. Went to the Dyno with LS1 edit. Help.
  60. best a/f with mods
  61. EFI live anyone using it? figure it out?
  62. best tuning for h/c ........
  63. where to shift with cam?
  64. Installed my KO box and now my ASR is jacked????
  65. PCM Problems? PLEASE HELP!!!
  66. LS1 Output
  67. Should i mess with the timing?
  68. trans program????
  69. LS1edit vs HPP3 shift point settings....
  70. Does anybody use this scanning software?
  71. Does anybody use this scanning software?
  72. LS1edit vs. HPP3 vs. Diablo
  73. LS1Edit cable dies...
  74. chicago suburbs
  75. DTC P0106 anyone ever get it?
  76. Quick LS1 Edit question
  77. Quick LS1 Edit question
  78. Shift Points and Tire Height???
  79. HPP III Question
  80. HPP III Question
  81. HPP3 power tuning on '01-'02 LS-1's
  82. How exactly does IAT Temps affect the PCM
  83. Will turning off "knock learn" disable the knock sensors?
  84. too slow for MOE
  85. How to richen Ltrims via Fuel Injector tables?
  86. speed control
  87. Why do these maf cars run lean/rich?
  88. **Update** LS1 Edit unable to get program my rpm limiter past 6300 rpms in 2nd gear
  89. O2's at .92, ltrms at +15. What maft settings should I make?
  90. What is the proper injector scaling for 30 lb SVO injectors?
  91. I'm getting LS1 Edit done....Should I have them eliminate TM and lower Shift points??
  92. trouble
  93. Anyone know EXACTLY what has to happen to for the PCM to switch to LOW Octane map
  94. What is the best tuneing software??
  95. Hooker Longtubes are on but need help with autotap readings
  96. Which software or re-programmer?
  97. Code 1336 - crankshaft position learn procedure
  98. simple fuel question
  99. Setting Fan temp w/o HPP3???
  100. Ls1 Edit Idle Problems.. How to fix stalling/no start with big cam
  101. Ls1 Edit Idle Problems.. How to fix stalling/no start with big cam
  102. Ls1 Edit Idle Problems.. How to fix stalling/no start with big cam
  103. Strange fuel delivery problem
  104. Anyone on the Gulf coast do dyno Tunning..
  105. HPP3 .... Is is worth it ?
  106. BCM
  107. random idle relearn?? WTF??
  108. HELP! tuning on entire new setup
  109. High IAC counts,High idle ,MAFT.how do i fix??
  110. Reading MAF with EFILive ?
  111. Is it OK to raise the entire timing table?
  112. LTFT'S at 25%. How to lower with edit??
  113. Autotap expert in the Bay Area?
  114. after car warms up the rpms drop really slowly?
  115. LTs at -11
  116. Questions about MAFT tuning
  117. Technical Questions on Timing, O2 values
  118. O2 sensor going out? (P0154)
  119. edit model question
  120. Observations on IAC & Timing at Idle
  121. sending pcm in programming ,,help....
  122. should i change idle speed if cam is stock?
  123. EDIT??? ASAP
  124. Autotap ??
  125. My car won't take LS1edit
  126. EFILive and Negative Oil Pressure !!
  127. whats up with my IAC's? gone from 30's to 60's
  128. LTFT-02 Excel file update
  129. Ltrims +25% i need help!
  130. What will a ported throttle body do to A/F?
  131. Fuel Cell 13 = 100% TPA?
  132. What exactly is ....... PCM Question
  133. Locking TC on a dyno w/ LS1 Edit?
  134. computer basics for dummies?
  135. Its final, mileage is stored in the cluster only, I checked it out....
  136. knock learn, total retard
  137. LIMITING DEVICE
  138. will MAFT work on other vehicles
  139. How to richen up Ltrims and put O2s at zero?
  140. Any AutoTap expert members in Houston area that could Tap my car before Sat.?
  141. Timing and Horsepower ???'s
  142. Help! O2's way off from each other.
  143. tune theory question....fat = more timing?
  144. more ponies
  145. BBK TB and IAC count
  146. EFI Live
  147. Secondary Air Injection (AIR) System Bank 1
  148. Does the 98's require a different cable?
  149. ah! got ls1edit but no software!
  150. P0141 & P0161
  151. I think I am going about tuning backwards--after LT install..
  152. High RPM Mixture Richness
  153. HPP3 power tuning
  154. ses light...
  155. SES: low 02 activity
  156. adjustable knock desenstizer
  157. spare PCM, and LS1edit.
  158. What the F*$k!!!!
  159. 11.7 A/F at WOT
  160. what should IAC and idle be w/ an m6 w/ head and a tr224 cam?
  161. Where can I buy ls1 edit?
  162. Timeing ?
  163. IAC too low?
  164. Please-Who has passed OBD-II Emissions scan with heads and cam?
  165. fuel trim
  166. ses light
  167. change oil light?
  168. Any one in Hampton Roads area who can ls1edit?
  169. Sony Clie and Autotap
  170. Injector Offset reference values website?
  171. EFILive owners help please
  172. Shift point question?
  173. Edit for A/F Ratio??
  174. Who has damaged there PCM with LS1 EDIT?
  175. Anything I can do for tuning w/o ls1 edit
  176. Blown Ls1 Edit file?
  177. IAT Changing a/f ratio
  178. ?? about electric fan setting?
  179. Can I lock the TC with LS1 EDIT or do I need a Lock up switch?
  180. Very LEAN even though O2s were .890s!!!
  181. NEED HELP>>>PLEASE
  182. UPDATE: Torque Management & LS1 Edit
  183. LTrims problems after LT's!
  184. how to clear pcm?
  185. service engine soon light?
  186. PCM updates
  187. Computer tuning?
  188. Car Programming
  189. Lost power with gears & SLPs 85m MAF
  190. how can headers make you rich- ECM keeps a/f at 14.1:1 ??
  191. no matter what i do i cant lean out my 02's
  192. Dyno-Jet vsMustang Dyno
  193. Dyno numbers with wideband and Edit tuning from today...
  194. Help with AutoTap readings.. 3 WOT runs..
  195. Trans shake on deceleration with cam ??
  196. How to delete EGR and AIR?
  197. Positive Pressure vs. Temperature
  198. Spark plugs?
  199. car slowed down after mods and re-programming. WTF?
  200. need laptop for fast net and auto tap, know NOTHING about them
  201. FYI: LS1Edit, This is what I did.
  202. Problem found tuning a supercharger
  203. Easiest A/F adjust w/edit
  204. Torque Management Removal
  205. Where can I get a reasonably priced computer for 01 SS?
  206. Now the car wont start, unless i floor the pedal
  207. Torque Management on a M6??
  208. 9psi with 100 octane. Set timing to what?
  209. Need Basic Pinging Info
  210. SLP MAFs Ever Cause Tuning/Deontation Problems?
  211. For anyone who forced the computer into open loop at idle
  212. GM Tech II
  213. which kr sensor is which?
  214. Fastest way to learn LS1 edit?
  215. MAFT translator pluss ?
  216. Weak dyno numbers !!!!
  217. Flashing SES light......HELP!!!
  218. Will editing the MAF table mess with idle and start ups?
  219. For those interested in self PCM Reprogramming and Hacking
  220. Diablo Predator Thread
  221. Anyone with experiences with the Knock Out Box???
  222. Using LS1 edit to richen/lean out the car is it better to scale the MAF or injectors?
  223. Damn, Am I running Pig Rich or what....
  224. Misfire - HELP running out of ideas
  225. Just go Edit and already troubles getting started..
  226. GM Tech II
  227. new cam and ls1 edit car is a dog, HELP!!
  228. Car is now popping-backfiring at idle? any suggestions?
  229. what should be changed with edit????
  230. 13.38 at 109.54mph with ls1 edit
  231. AutoTap for Windows V2.03 Available for Download
  232. need some ltft numbers
  233. what afr for max power on LS6
  234. What tuning for heads/cam on M6
  235. Techs please help
  236. Regarding O2 simms and LS1 Edit
  237. 76 Racing fuel
  238. Ls1edit - Hotcam STILL WONT IDLE in A4..
  239. PCM wire code question
  240. Ported MAF ends causing incorrect load readings and KR.
  241. Can someone share a good working SVO 30# LS1 edit file?
  242. PCM Firm Shift Mod
  243. How to set Rev Limiter with LS1edit?
  244. Set base timing with LS1 edit?
  245. Do I need Auto -Tap???
  246. "Incorrect Checksum" Problem with EFILIVE V5
  247. what does LS1edit have that EFI live doesn't for performance tuning?
  248. Ltrims Min and Max
  249. blower / turbo people. where do you start pulling timing?
  250. Swaping pcm's
