PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 [112] 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Any one make a MAP sensor extention?
  2. I would like to use Tunercat
  3. Big problems, 2 dead LS2 PCM's. Hptuners
  4. question about autotap licenses
  5. EFILive
  6. NEED HELP! what does this mean?
  7. E-85 Ethanol Tunning
  8. EFILive and Tech 2
  9. VCM Pinout
  10. 85mm MAF tune?
  11. Gen3Performance.net
  12. Can someone look at my tune? (HP Tuners)
  13. Boost and Auto VE
  14. Gm 3800 driveability issue
  15. Pulling ASR
  16. had my car tuned have a Q....
  17. Need some help integrating LM1 into Flashscan V1
  18. Drivable for a week or so without a tune?
  19. Predator tune adjustments ??
  20. what the hell is kent moore serial data tester
  21. SCT XCalibrator 2 Flash Tool questions
  22. Need some guidance
  23. I think my LM1 took a dump :(
  24. Airflow code
  25. Hptuners w/o EIO, cant use egr or ac
  26. Open/closed loop
  27. XFI vs. BS3
  28. Old Gas
  29. dyno tune in 100% humidity?
  30. Secondary VE?
  31. What is steady state
  32. Wiring lc-1 to simulate narrowband.
  33. average , last and count in histogram
  34. 02 C5 Z Fan Op!
  35. Help, No state!!!!
  36. timing ????
  37. Weird Problem..maybe easy fix??
  38. throttle response dropped
  39. Few things about tuning for a turbo
  40. FAST dual sensor wideband??
  41. P1870 Help! NOT PASSING EMISSIONS!
  42. Power Loss vs. Spark tables
  43. cant get my 408 to idle
  44. Done with Ve ... I think.
  45. Is this a good time to buy tuning software??
  46. 98 SD - max line pressure?
  47. 98 to 99+ pcm
  48. End of Year EFILive/Innovate Specials!!
  49. new 408 please help
  50. Can someone email me their stock factory tune uploaded from predator?
  51. how do I disable my PE
  52. Gary's Tuning 101 Document????
  53. need help with o2's
  54. Need Help With Efi Live
  55. Question on AutoVe Tuning Tutorial (EFIlive)
  56. HP tuner file needed (VCM Suite) for TSP 233/239 cam
  57. When is the V2 going to be fully functional?
  58. What's your max timing in lower rpm's and part throttle on big H/C/90/90 set-ups?
  59. EFI Live?
  60. VE Table = Calculations
  61. Just want to double check what codes to remove
  62. can hptuners scanner show me how total timing is being derived?
  63. Tuning ?'s
  64. Max EGT's for FI? Whats too hot?
  65. Security light on..WTF!?!?!
  66. Letter from Chevrolet
  67. timing on a 408
  68. hp tuners vin question
  69. HP Tuners Guys I need Starting Help
  70. High Idle
  71. Tach signal input wire?
  72. knock sensor failing my emissions test?
  73. 100mm MAF
  74. Anyone Use Nexus A/F Ratio Meter With HP Tuners
  75. Any good tuners in K.C?
  76. VE Table Quick Quetion
  77. A little help please!!!
  78. Where to put wideband bung?
  79. New pcm question?!?
  80. ls1 edit??? anyone
  81. Pcm Tune?
  82. Why do M6 tunes have "shift speeds"
  83. ecm/pcm
  84. the differences in 2000 stock tune vs. 402ci small cam tune
  85. Anyone have a HPtuner file for this?
  86. Mail away for break-in then dyno after OK??
  87. EFI Live .tun file Repository -- Search for tunes, upload tunes! (updated 2012)
  88. Do I have to calibrate LM-1 WideBand everytime I use it?
  89. Can a bad Spark Plug Cause the Rest of the Plugs Fowl out?
  90. LTFT's narrow band
  91. Idleing @ 18-19 AFR is this Right?
  92. EFI University?
  93. 6.2L L92 in LSx GTO?
  94. Wide band help
  95. Hypertech Programmer. VIN Lock.
  96. What VE changes would you make
  97. Using Maf
  98. Stupid Odometer ??
  99. SLP-ZO6 Mass air sensor, resister?
  100. (EFI Live) Questions on auto VE and the black box feature.
  101. Upgrading Injectors
  102. Using a predator Tuner after a (on top of) a dyno tune?
  103. Can EFILive adjust shift firmness?
  104. Stalling at idle with a 1514 code
  105. Ltft
  106. secondary ve ???
  107. Tuner?
  108. Ever wonder what it takes to.................
  109. spikes in AFR at 5300-6200 what could be the problem??
  110. dumb question, but, efilive I or V2 ?
  111. Something wrong with my car. Weird DTCs. Please help!!!
  112. Can't read PCM with BenchTop Harness
  113. timing and pcm?
  114. rev control in ecu
  115. Datalogging OBD2 with knock retard function
  116. spark table for sts car..
  117. 6.o drive by wire
  118. Tuning experts, SD, where do I start?
  119. reflashing computer
  120. How to connect a Z06 MAF to a 2000 C5?
  121. Mail Order or Dyno?
  122. No 99 camaro check engine light unless Actron scanner is plugged in ??
  123. Wiring problems LS1 conversion over to an LT1 camaro
  124. Idle issue...
  125. how to fix OBDII code po440?
  126. what are the benifits of running an OBD1 PCM?
  127. Tach Install
  128. MAF durability
  129. Knock sensor...unplugging same as disabling in PCM?
  130. Got a weird problem.
  131. LS2 Wont Start + LS2 PCM diff 05-06
  132. Thought I'd ask here too...
  133. Best LS1 tuner/tuning shop?
  134. Diablo sport help
  135. Tuning the 07 Silverados w/DOD and AFM?
  136. Timing pulled on 2-3 shift - No KR!
  137. Need HELP with Idle Surge and Pegged Fuel Trims 418 Stroker
  138. Fuel trims question.....
  139. Anyone have a write up on removing engine harness
  140. Can i use a 99 engine harness on my 00???
  141. Anyone talk to Weaver at RWTD ?
  142. Phantom timing retard (not KR)
  143. Question about DTC's (HPTuners)
  144. Any tips on A4 adjustments?
  145. Idle reads lower than HPscanner
  146. Tuning for Nitrous
  147. Tuning software gurus inside to settle this
  148. ODB2 port problem?
  149. scanning with hptuners on multiple vehicles?
  150. Surging with high overlap cams any solution?
  151. Losing power after 3rpm
  152. LS2 Cam sensor
  153. how to turn off the ses light
  154. 2-Step in HP tuners???
  155. P0342 Nightmare! Help...
  156. mail order tuning
  157. Superchips welcomes questions
  158. LS1 to LS2 swap
  159. where to get O2 sensors that holds 100+ octane?
  160. turbo tuning
  161. H/C, Fast90, Cam HPtuners bin out there I could look at?
  162. need help on o2 wire colors
  163. learnning how to tune
  164. tuning questions
  165. Codes po137, p1416
  166. P0172 / P0175 Issue After New Engine Install *HELP*
  167. Spark Retard Question
  168. Check out my VE table please.
  169. How to Fix Stall Wall?
  170. Running very rich at idle??
  171. Any confirmation of successful case learn?
  172. Can anybody confirm that GM map sensor #12580698 will report up to 260kPa?
  173. Has anyone seen or used the new 6mod
  174. is there a way to trick the EGR code?
  175. Street tuning and dyno tuning?
  176. Need A Computer For 6.0
  177. Please help, pcm problems (I think)
  178. Changing from a 2bar map to a 3bar map?
  179. o2 sensor codes
  180. Need help Wiring up PLX M-250 to EFILive
  181. Which Software To Buy?
  182. W/B LSU Sensor Connector Help
  183. Need help with eletrical issue
  184. AutoVE map reading 93 in all cells. Why?
  185. SS is a dog
  186. Aftermarket PCM's
  187. A few tuning questions
  188. big stuff 3 a good choice?
  189. Hp tuner advice
  190. HP tuners question.
  191. quick question...
  192. WTF Code P0118 and Fans are always ON!!!!!!!
  193. HP Tuners for the LT1 POLL :)
  194. Need a tune adding heads?
  195. Rick is the man - Synergy Motorsports
  196. ls1 Edit question
  197. G Tech Pro
  198. anyone have a 228R Tune w/ heads
  199. question for the gods
  200. MAF question
  201. New help with PLX M250 & 02 Sensor Issues
  202. TUNING & SMOG
  203. LS1's with a tune come in
  204. Can someone with a clue HELP
  205. Need a Tune When Changing States?
  206. Speed Density-> Yes or no?
  207. 4l60e Problems.....
  208. SES after using 110 octane..
  209. Car won't start reset PCM car starts.
  210. Hypertech programming gone BAD!!!!
  211. Diff between 98 and 99+ ECM and change over
  212. Need a Little Help with HP Tuners!!!!!
  213. PCM tuning for LT1's with a TURBO....
  214. HPTuners Need Advice on start up file for TFS heads/cam swap!
  215. Please Help 2 Fried Plugs Now what ?
  216. 200mph speedo calibration
  217. Can/Should I turn off this SES code...?
  218. engine code p0155 and p0161
  219. Need a Stcok A4 LT1 file
  220. Problem starting
  221. Does using accessories (12v cig lighter) impact results of logs/results
  222. IFR and Boost Reference Regulator
  223. Complete Speed, Inc. Dynotune & Diablosport
  224. 6.0L LQ9 Short Block on 98-00 LS1 heads/cam/intake
  225. PCM Shift Light
  226. all 98-2002 gm harnesses the same? including truck harnesses?
  227. LTFT Cycle???
  228. O2 sensor delete
  229. No start program
  230. Where can I get a 98 PCM ???
  231. po803
  232. Hpp3
  233. check engine light
  234. Trouble with the LT1 Anti-Theft
  235. Are Predator tuners any good?
  236. pcm logic !
  237. What harness goes to which plug on the PCM?
  238. So um... 91 TPI chip in 93 LT1?
  239. Surging at low speeds!!!
  240. quick question about unplugging pcm
  241. Diablosport u7198 on 98 will it work?
  242. Having problems getting EFI to read AFR
  243. pcm programming for Efans/v8 s-10
  244. Just an FYI for LC-1 owners wanting to use the narrowband output
  245. do i need a retune after bigger injectors?
  246. Turbo vehicle tune...MAF or SD??
  247. TUNING FACILITY!! please read
  248. Is it possible to run dual MAF sensors on turbo setup so it won't max out?
  249. 2bar or 3bar tune
  250. Driveability issue!! Need advice please.
