View Full Version : PCM Diagnostics & Tuning
- Ls1Edit Updates
- Need Dyno-Tune for a New Cam in DFW, Texas
- got a few problems, need help.
- Diagnostic Link/Port/ALDL is not working???
- Low-Coolant light.......
- New Cam (Large) and now P0106.. anyone got any ideas?
- Retune after exhaust mod?
- EGR Simulator or AIR simulator?
- Do cammed 98's want LESS timing?
- Will my AutoTap (models AT1, AT2, AT12) work on '00s, '01s, and '02s???
- rigging up a shift light?
- HESCO > Questions concerning this new LS1 Dyno tuner in Alabama
- High octain timing table for 98-99 cars?
- what tunning could be needed for a cam swap?
- What causes these codes, and how do I get rid of them?
- Question about EFILive and my VIN
- knock retard questions
- Oh my God
- few ls1 edit questions
- Auto Tap will not connect
- P0405 Code after LS6 Intake install
- IAC counts at zero before and after drilling the TB?
- Custom Burnt Chip
- SES light problems
- LS1/LS6 PCM ??
- Why is the LS1 slow to rev down?
- Would this work?
- How much timing made the most power for you?
- strange O2 readings
- What do you think?
- What do these sensor readings mean?
- SLP 85mm MAF-MAFT dipswith 4
- Which version of ATap to get?
- 2000 CHEVY TRUCK program help
- Ltrims positive= reduced timing?
- SES and TCS OFF lights on
- ATAP plugged in = No Volume
- Any way to lower timing?
- EFILive help. :) LTRIMS +20 someone's RICH!
- 1998 to 2000
- craaaaazzzyyy stuff goin' on...
- idol problem
- Hypertech after tuning?
- using the HPP3
- maybe you guys know?
- ABS INOP light?? what da?
- P0410 Need some help with this....
- $13,000 for LS1Edit 97-03???WTF
- Looking for central / southern Cal EDIT tuners
- code po300
- Timing issues after MAF change
- TB mod ....
- throttle body questions
- Help > AMS's LS1 Edit will not recognize my [early] 98 TAs PCM
- O2 simms same as deleting rear O2s with LS1edit?
- What do you do with LS1 edit when you sell your car or get a different one?
- Service engine light
- Problem with HPP3
- Can I swap PCM's with a friend
- Driving car without tunning "?"
- ltft +25 at idle
- timing dip in table?????
- what gauge wire should I use for??
- Question on MAF Table
- How you know if you maxed out your MAF
- Engine Sensor Fuse blown
- turning mass air around throws code?
- Can I use LS1Edit without a dyno?
- Dyno Tuning???
- need help with an SES Code please
- Anyone using www.obd-2.com software
- No trip codes after Disconnecting AIR & pump?
- Increasing shift firmness
- where to buy ls1 edit???????
- Will I need tuning with headers and TC?
- Dyno Results From MTI DYno! Thanks MTI!
- LS1 edit while out of the car?
- ses1153- insufficient switching.....
- Will I need tuning??
- A/F ratio and high altitude
- Big Cam / Misfire tuning question
- A/F Guage o2 Sensor?
- How to tune for a bigger fuel pump (walbro)?
- SES light, knock sensor???
- HPP3 Good or Bad?
- Dyno chart request
- Tuning (Who's the best in Texas)????
- who does the best mail-in programming
- Old question revisited..... To correct your LTFTs......
- P1518 PCM to TAC serial data circuit
- Just got LS1 Edit, how do i tune heads/cam car?
- ported t.b=loss in power
- What do you get from this AutoTap read out?
- who here can flow a MAF?
- MAFT Help
- SES----P1153
- Deleting EGR w/ls1 edit and emmisions testing
- MAFT tuning
- Ls1 edit, 2 different computers at once?
- reprogram
- HELP???? ABS INOP/TCS/Brake light on
- Still getting misfire codes
- Throwing code! please help!
- LS1 editing
- ls1 edit for duramax
- Failed dyno tune
- Is There a Way to Reprogram an HPP3 to Stock ....?
- Ltft's, where should they be at?
- HELP...WTF CANT FIND TACH WIRE
- anybody try to "disect" thier LS1edit package?
- TUNING MY 01 zo6
- Rear O2 qustion?
- Predator tuning / data worksheet
- Aftermarket Engine Management System?
- NEED PROGRAMING FOR NEW CAM
- O2 sensors
- O2 sensors
- O2 extentions???
- Hypertech with a slp mass air???
- Predator real time monitoring - handy setup
- HELP!! my car wont start
- Z06 dyno'd, It needs tuning!
- extending MAFT wires...
- Lterms at 25% at idle
- what actually happens when you disconnect the IAC?
- PCM bench programming cable
- Need 02/03 Z06 MAF Table
- how much can stock pcm handle
- Difference in MAFT Versions???
- Oh boy just got it (ls1&efi)
- reduced power mode
- HELP??SES LIGHT FROM HEADER INSTALL
- Why is it that....
- EFILive V5 5.26.6 (Build 452) is available
- Which should I get, LS1Edit or Predator?
- PCM- If I swap out, does it have to be flashed for my truck?
- Diablo Tuning with Tr224
- Need instructions for MAFT
- How long for the computer to learn w/edit
- Dynomometer differences??!
- Tell me how to program a 2nd remote to my 98 Z
- Anybody using a Carchip????
- Whats the phone # for carputing?? I see nothing but email
- Has anyone READ a PCM with EDIT.......
- pcmcia card or usb adapter for laptop?
- HELP MY T1 IDLE IN A4
- pcm tuning rapid or eastside?
- Need help with wiring gauges..
- PCM/Tuning ??
- Different MAFT versions?
- Just out of curisoity...
- WOT Fuel Tunning
- LS1-Edit for Gear change
- 98 LS1 Computer Reflash
- detonation
- Gauges
- Running rich and timing too low, cause?
- Perfecting the LTFT's
- NEED HELP
- A/F ratio ? - dyno graph inside
- codes ??
- User manual for LS1Edit
- Really weird - Anyone wanna take a guess? I am baffled
- Anyone mounted Scanmaster by fog switch /dash plaque is?
- Can MAFT and HPP3 be used at the same time
- Knock Sensor codes 327 332?
- MAFT & GM's hotcam
- ATap basics. What do my values mean?
- How to create a pivot table?
- Autotap upgrade questions....
- Eng Sensor Fuse under the hood???????
- ls1edit help please?!?!?!
- Somebody explain the theory behind...
- Surging @ Idle
- WOT tuning question (PE vs RPM)
- Flickering Shift light
- Autotap Numbers.. Please help me interpret
- Will computer lean mixture on WOT after some time?
- car in garage, wires every where, tach needle D.O.A,... please help
- Making o2 simms
- Autometer tach in V6 car
- How to set up MAFT
- SCANMASTER
- Things you can tell just by looking at her (Predator)
- Will an HPP3 function on a reworked PCM?
- preditor questions / opinions
- Bad turn signal switch?? Help please!!
- MAFless/Speed density tuning questions within
- Pics of installed O2 Sims?
- Dynatech LT's, cat delete, true dual, dynomax bullets.. NO GAIN??
- 42# Lucas injectors???
- Shift Points
- just got a P0440 code.
- Tuning problems with LS1edit
- Air/Fuel Gauge install ?????
- Educate me on this.
- Which Should I buy LS1 Edit or Autotap
- AutoZone o2's ????
- Need help with LS1edit Tuning
- LS1-Edit version?
- Diagnostic Program
- what to do with ATAP after H/I install
- HPP3-HELP!!!!
- New to Autotap/help TB Mod.
- O2 Issues please help
- Custom Tuning or Predator
- 3.73 Gears/Predator
- Predator fans settings
- Cali WS6 vs. Illinois WS6
- A/F ? on wideband
- Idle Air in Gear neutral cells??
- Tuning the IFR and need advice
- predator dyno #
- Rev limit by temp???
- TB Bump Stop
- Its been asked before.... but lets see if we can get a final answer.
- Is this the right formula to tune my MAF table right?
- How to tune A/F ratio with Predator?
- Autotap/LS1 Edit.
- HELP!!!! fried my computer
- Predator/3.73 gears
- Lts and STs with diablo?
- SES light = Messed up CATS?
- Autotap and LS1Edit
- LTrims parameter
- What do I need to do to get another PCM to work with my car?
- tuning with B1 cam?
- Can i tell if trans line pres has been altered with auto tap
- L-Trims average?
- engine idle @ 1250
- Tuning for bigger injectors, how?
- Results database?
- I swear the SLP 85mm just helped my idle/warm starts
- Need Help Tuning for #40 injectorsWith LS1 edit
- How do knock sensors work?
- Predator on a M6
- PE/RPM table tuning
- flooding?????
- Injector Offset table - experts inside please
- How to dyno a A4???
- Base Timing Park ?'s
- "cruise control" effect?
- What do I need to delet codes??
- Tuning timing, need help/getting some knock
- Predator & deleting Torque Management
- Erratic dyno curves
