PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 [171] 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Help, SES light
  2. Modifying spark timing?
  3. Location of 02 Bung: Wideband
  4. Need tuning advice on injectors
  5. odd tuning issue came up...need help
  6. Fans wont turn on
  7. predator cust tune - do I install like canned tune?
  8. Just Washed My Car - Won't Start??
  9. so confussed! someone help!
  10. Runs perfect! Then dies?!
  11. Flashing SES...help!!??
  12. Just Got DynoSim . . .
  13. ls1 file
  14. How much from tuning???
  15. John at Speartech
  16. help
  17. need help -SeS-
  18. HP Tuners?
  19. Reset P0300, nothing yet
  20. NOT an LS1, but still need some help????
  21. Predator
  22. Hpp3 ???
  23. Those who have LS1Edit and HP Tuner ...
  24. Using Ls1edit With Turbos
  25. Where to get QD Electronic Cleaner?
  26. anti theft
  27. Transmission tuning
  28. Is this a bad maf?
  29. Cheapest/easiest way to tune an LS1?
  30. Best HPP3 settings? What is your set up?
  31. hpp3 --> tuning shift points and rev limit
  32. oil change SES light
  33. Speedo correction??
  34. VE tuning, good idea for any modded vehicle?
  35. hp tuners
  36. can a dealer program for gears/converter
  37. will tuning help?
  38. any positive uses for EGR?
  39. MAF problem solved
  40. Early autotap version 1.03 question (not gm enhanced).....
  41. SES light...
  42. Received my HP Tuners package today
  43. EFI Log...
  44. WOT timing at 15*...
  45. HP tuner for 98s?
  46. Opinions Please
  47. hpp3 strictly for tuning Torque Cnvertr
  48. Can you program ECU for different Tranny?
  49. EFI Live not connecting...
  50. installing a new PCM
  51. LS1 Wiring Diagram
  52. who got tracking for hptuner?
  53. Looking for edit file
  54. Exhaust temp gauge sensor mounting.
  55. computer for boosted car
  56. Predator timing question
  57. Speed Density vs. MAF system?
  58. Superstar Tuners... I need some help PLEASE!
  59. If you are running FAST or Gen7 right now please post in here!
  60. Quick Question
  61. Changing to LS6 Intake, What tuning needs to be DONE?
  62. fuel filter question
  63. A new code thrown
  64. LS1Edit tuners, comments on this A/F?
  65. Please Help, Huge Problems!!
  66. (c5) LS1 Edit help
  67. advise on ls1-edit plz
  68. LS1 Edit - High Octane vice Low Octane Tables ?
  69. The answer to most of the check engine threads.
  70. Check Engine Light
  71. just got a-tap, where can i learn all the lingo?
  72. guage cluster is possessed!
  73. throttle position codes
  74. Base (stock) real data, feedback needed
  75. Missfires are driving me CRAZY!!!! on a cammed 98 SS
  76. can ls1 edit or other be reversed?
  77. Hwlp with surging
  78. Some Important LS1 HP Tuner Questions
  79. Please Help - Dash Problem
  80. Why doesn't TQ management just die?
  81. PCM and Wiring harness Diagram
  82. Please help me diagnose SES problem
  83. can i use a maft and timing tuner togather?
  84. Help! fuel issues and O2/knock codes...
  85. WOT Timing values?
  86. Flashscan Update - 19 March
  87. logging iac with efi-live?
  88. Where to get all the necessary LS1 edit equipment
  89. Another lame question
  90. ls1edit vs. HPP3
  91. Tuning basics?
  92. Tuners - Need Opinions on Data Logging Software
  93. PCM reprogramming for 4L80E swap.
  94. maf code
  95. Peculiar Truck MAF - or normal?
  96. Will a LS1Edit program for a '01 work with a '99?
  97. I have a question on changing TC lockup.
  98. How many Tuners are working on MAFless tuning out there?
  99. Question on timing file for nos
  100. Sounds Crazy....
  101. Ls1 edit questions
  102. Predator 1.04 progress?
  103. KR Problem- Help
  104. What triggers the Cam position sensor??
  105. SES light
  106. Idle and part throttle tuning?
  107. HP tuners
  108. Tuning the TReX
  109. When's MAFT switch between base and WOT?
  110. Ported MAF with resistor mod and LTRIMs?
  111. misfires
  112. MAF readings, what do they mean?
  113. Need stock 99 c5 A4 3.15 file
  114. Code PO410? HELP!
  115. hypertech? ls1edit? dyno tuning? what do i do? (e-newbie)
  116. Help! Failed emissions.....
  117. Primary fuel correction = MAF tables or VE?
  118. fast- wideband o2 set up dont make sense to me.-->>>
  119. SES-Bank 1 and 2 system to rich
  120. LS1 Edit crashed - PCM gone!
  121. For Sale EFILive V5 Professional for GM LS1/LS6
  122. need help!! po138 code!
  123. Will bad O2 sensors cause a lean condition?
  124. Z06 tuned with edit problem
  125. rear O2 sensor-- what voltage can i feed it?
  126. STFT verses 02 Volts
  127. MAF Driven Load?
  128. HELP!!! Scanner works but ATAP won't read anything from my car......
  129. Dfi Gen 7 Vs Fast System
  130. Flashing SES
  131. VE Table Cracked
  132. VE Table Cracked
  133. VE Table Cracked
  134. HPP3 throwing a code - questions
  135. how hard is it to tune with HP tuning...
  136. Any warranty issues with predator??
  137. Any warranty issues with predator??
  138. Have 99 LS1edit can I have carputing add a 00
  139. Can the Diablo do this?
  140. knock sensors..
  141. Ok I got an Innovative wideband, now what's the easiest/cheapest way to tune the a/f?
  142. Anyone notice the new 'tune' menu in EFI live ver 6?
  143. PE vs RPM changes: are they really needed in the lower RPMs?
  144. Autotap logging results after cam install Need Tuning?
  145. USB ---> Serial Adapter
  146. Anybody know how to convert an F-Body MAF to Z06 or vice versa?
  147. Is there a better way to tune a car that maxes the MAF at 3700rpm beside PE?
  148. after my Vig3200 install
  149. GGW Guages gone wild
  150. Got a cam from cmotorsports.com, they tuned for it for only $150!
  151. What should I do?
  152. Can you buy a used predator and get it reflashed
  153. Help with trouble codes and warranty info
  154. LS1 to Z06 MAF Sensor Conversion
  155. Which ECU do I buy for 382 Stroker?
  156. O2 Codes after header install
  157. Help with O2 B1S2 as wideband input
  158. WOT LTFT question when using Predator
  159. c0056 code? help please
  160. best place to get 98 pcm tuned
  161. Atap questions
  162. Help with P0133 and P0153 ?!?!?!??!?
  163. Tuning out the maf?
  164. No power to my Autotap?
  165. Snap On MTG2500?????
  166. low timeing
  167. low timing
  168. need help!!!
  169. effects of part throttle tuning on WOT
  170. After boost idle stays at 1500 until I come to complete stop. How to fix?
  171. Trouble codes
  172. pcm cost ??
  173. 91 vette pcm plus 496 big block
  174. Anyone get their LS1 tuned at Livernois Motorsports/Speedworks?
  175. Part Throttle Timing in LS1 Edit
  176. Predator tuning for headers
  177. c5 tune need help
  178. What is the stock rev limiter?? 99SS M6
  179. Buying a new computer, do I need dealer flash before LS1Edit???
  180. HPP3 and LS1edit...can they be used together?
  181. LS1 Edit program into a Predator?
  182. Wideband convertor box for Autometer gauges? Think this works?
  183. GEN7, HP Tuners etc...need an answer
  184. Cam tuning ?$
  185. GMS Diablo Sport Programmer Pro and Cons
  186. new to edit just got today any suggestions
  187. No lockout for Reverse P0803
  188. Can inconsistent O2 reading SES light be tuned out?
  189. What would make idle 25 higher than set value?
  190. Code 0430: Where do I start? HELP!?!?!
  191. code P0420???Please help!
  192. Code 0751... HELP!
  193. have predator will travel...but
  194. LS1 stops while driving along
  195. can anyone diagnose thsi problem
  196. Attn: HP Tuners
  197. hypertech power programmer (code 6)
  198. auto taped car: throwing codes P0157 & P1153
  199. Turning down the burst knock
  200. Tuning for a new converter
  201. Good temp sender Location?
  202. Transmission tuning with LS1 Edit
  203. Efi live vs AutoTap vs LS1edit vs HPtuner
  204. vats and efilive
  205. How will a disconnected O2 affect the accuracy of wideband AFR measurements?
  206. EFI LIve crank relearn Problems
  207. New Cam and LT's what to tune?
  208. MAF and SD - from gameover
  209. Tuning issue or injectors?
  210. Hard start, Diagnostion needed. HELP
  211. A/F questions
  212. Need IFR table for 28.8 inj. from Z06
  213. Autotap/Windows XP
  214. Clearing the pcm
  215. New scan tool on the market...
  216. Need shift tabel help auto w/ 4.10s
  217. Idle questions
  218. Trying to get a hold of AP-Engineering in MI
  219. adjusting tranny shift points and what not
  220. Car died! Dashboard madness
  221. how long does it take PCM to learn?
  222. need help with shift points and TCC stuff..
  223. Need help with Idle surge problem
  224. How you get your car to run open loop all the time?
  225. PCM Pin Assignments
  226. Tuner Cat software ???
  227. How do you program Ls1 after Cam install?
  228. uneven ltrims solved
  229. New TunerCat
  230. 2001 different from 2002
  231. O2 reading question...
  232. Paging Paul Blackmore, Anyone GTO datalogging
  233. Autotap good enough...
  234. LS1Edit? Dyno/wideband a must?
  235. still pinging and kr dammit
  236. P1810- Manifold Pressure Switch?
  237. Running rich
  238. Huh? Removed rear O2's w/ no SES light...
  239. NOS-Wet or Dry?????????
  240. Decreased Timing
  241. 90 degree bend right after MAF - Can our MAF's handle that?
  242. PCM not ready
  243. Shift Points after converter and gears
  244. Rev limiter Question..
  245. Is there a fix for the GMAF?
  246. What is LS1 Edit?:
  247. LS1 Edit What is it?:
  248. o2sensor
  249. diablo sport programmer question?
  250. Please evaluate, how do these numbers sound after tuning?
