PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 [110] 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Cam Tuning Question (gas mileage)
  2. TPS / Trans C5 question
  3. OK Tuner Guys !!!!!!!
  4. So my converter isnt staying locked....
  5. Idle hunt
  6. who can take a look at this lt1 data log?
  7. 99+ ecm/harness swap in 98 thread anyone.
  8. vortech ls1 edit tune
  9. Question?
  10. C5 corvette Throttle position sensor help
  11. Heeelpp!!
  12. Air Fuel Gauge
  13. Code P1336? Help
  14. bad gas milage
  15. is this a tunning issue... *VIDEO*
  16. 402 first start no idle warm
  17. will someone look at my tune.
  18. Crankshaft position sensor
  19. updated EFI live now i cant scan
  20. AEM AC pressure question
  21. ls2 wiring harness
  22. 454 LSX, LS7 heads and Kenne Bell SC and PCM?
  23. ls6 maf into a 2000 camaro?
  24. cluster panel going nuts
  25. Just bought with Hypertech...
  26. Got my wideband today
  27. Differences between LS2 and LS7 PCM
  28. Question About Tuner Please Help
  29. tune question
  30. HPT, enabling high resolution rear speed signal
  31. Afr tuning with a wideband
  32. HP Tuner switch to credit system
  33. TCS off light coming on?
  34. For those tired of the airbag light...
  35. G tech performance meter
  36. Throwing code P0420
  37. LSx 402 bins?
  38. question about the actual stock pcm programming
  39. thinking about buying hptuners
  40. Wiring
  41. multi postion tuners
  42. how do i convert a pcm from obd2 to obd1 and a4 to m6
  43. anybody else find themselves spending time on redhardsupras blog?
  44. Will a Motor Plate or Dual Valve Springs trip the Knock Sensors?
  45. OL idle tunning and DFCO
  46. newb question
  47. Swapping Wiring Harness
  48. wide band = 12.5
  49. s/c tune
  50. tuning help blinking ses
  51. Need some clarification on BS3
  52. IAC problem...
  53. Care to give me suggestions to attempt fixing my LC-1 before I return it?
  54. need second opinion
  55. Mobile LC1?
  56. wideband help
  57. Different PCM's same year
  58. Wideband permanent install?
  59. Idle question
  60. Alternator Output Question
  61. my p0135 problem...
  62. Question about SCT
  63. FAST and DEltq system
  64. care to look at my tune? need help on cold starts
  65. Changed injector table and now minor probs
  66. Desifer this for me..
  67. F.A.S.T. 90/90 > no tune ... how hard can I run it?
  68. sporatic knock
  69. Can't Decide on Which hptuners os
  70. What to do to my tune?
  71. MAF question ???
  72. lm-1 and hpt
  73. Head-aches and ill after a tune.
  74. Newb to A4's and 3K stall with 3.42's . . . Little Help?
  75. DiabloSport 2 step
  76. P0157 Sensor 2 Bank 2
  77. Anyone have EFI live tune for my combo? heads/cam
  78. Tune "worth it" on a stock car?
  79. O2 sensor and slip on collectors
  80. i need help with a diablo predator programmer
  81. i need with diablo predator programmer
  82. switchable tune
  83. Got a problem....
  84. 6.0 Popping
  85. bad maf?
  86. dyno tune in orlando area
  87. Gear vs Speed calculator (macro and non-macro)
  88. fuel pressure
  89. need some advice
  90. Injector flow rate identifacation!
  91. NO Rear 02 sims = high LTFT ???
  92. whats with my lt1edit
  93. coil pack testing question
  94. VE LTFTs
  95. Computer problem?
  96. AFR question
  97. MS3 and Max timing
  98. Ghost in the Machine
  99. HPT RTT question
  100. Maf High frequency
  101. code p0300 random mutiple missfire..help
  102. 42 lb injector problems
  103. hp tuners+zex 150 wet kit
  104. I need to know how to fix these codes please!
  105. For those of you who live in cold climates...
  106. SD Tune STILL poping through exhaust around 3k
  107. LC-1 simulating narrowband and setting codes
  108. battery relocation
  109. Using Predator to change Camaro Timing
  110. Mail order tune ok just for LT's?
  111. Widebands and TD's...how many?
  112. EFILive and adverse OIL GAUGE READINGS???
  113. code p0300 random mutiple missfire..help
  114. o2 Sensors???
  115. lc1 gauge?
  116. can I remove this wire?
  117. Ls1 shiftpoints????
  118. Autotap and wideband
  119. crank sensor??
  120. Accel Gen 6
  121. Air/Fuel gauge install???
  122. EFI Live VIN# reprogramming
  123. Check out efilive RTACS in action
  124. Mercruiser BBC EFI in a car?
  125. Can HP Tuners modify an LS1 Edit tune?
  126. predator broken?
  127. Reseting predator
  128. What causes KR
  129. SES Problems with 2000 Camaro
  130. P0430
  131. I need someone that can tune
  132. Tech 2 question
  133. Have a .hpt file...but no way to read...can anyone help?
  134. MS4 tune file
  135. weird P0704 - w??
  136. Has anybody ever heard of this??????
  137. Help with tons o codes?????
  138. Predator Tuning Problem??(trans)
  139. LM-1 and Hp tuners..help!!
  140. Where is the IFR calculator??
  141. New EFILive Tutorials
  142. Tuning Issue?
  143. Power programmer on a 6 speed question?
  144. code p0300 random mutiple missfire
  145. Megasquirt please help!
  146. Idle problems...
  147. Any tips on SD tuning a T-Rex cammed car?
  148. Knock Sensor adjustment
  149. Gas Analyzers for tuning?
  150. What do ya think?
  151. EFILive Auto-Cal?
  152. PCM relearn
  153. Maggie Z06 'tuned' what a joke -HPtuners log att.
  154. Help! SES P1614
  155. Anyone interested in the AEM EMS?
  156. crank relearn for pcm?
  157. ls1edit crashes, searched, found nada...
  158. Wideband with STD Interface
  159. misfire question?
  160. looking for a procharger bin for a 05 C6 A4
  161. Problem with HP Tuner 2.1.16
  162. Idle graph
  163. To those who have the AeroForce Interceptor
  164. Ms3 PP heads
  165. What A/F should I use for wot??
  166. wbo2 opinios
  167. rotten eggs
  168. Sd Tuned/snow Meth Controller (maf)
  169. car idels fine almost!!
  170. Wideband and what?
  171. USB -> serial converter issue
  172. Knock sensor low voltage
  173. Cold start and KR help with HP Tuners
  174. Tach not working
  175. car runs like poo
  176. HP Tuners VCM Suite 2.1.16 Released!
  177. Wide band commander help
  178. HP Tuner Narrowband O2 Tune Help please..
  179. help me please
  180. can u use mutiple tuning programs on the same PCM?
  181. DTC reset
  182. Portable WB opinion.
  183. hypertech lost now tuning with hp tuner?
  184. Tuned for n2o, but I removed the n2o. Would a handheld move my timing back to stock?
  185. kind off a newbie quiestion on a dyno tune
  186. Relacement PCM ?'s
  187. Help with ditching SLP MAF for stock unit
  188. Convertor Box and Stock ECM
  189. P0161
  190. 99 ls1 automatic into 02 ls1 6speed.
  191. autometer tach is way off help please!!!
  192. Help with voltometer
  193. rpm drops when ctuch is in
  194. EFILive Training classes to begin March 10th 2007
  195. Cluster question
  196. GMS Fuego
  197. narrow band
  198. Quick Help - Throttle Screw
  199. Iat
  200. best tuner for 1998 z28
  201. Does the PCM monitor the low oil level sensor?
  202. Temp Gauge Crazy
  203. Spark Advance
  204. HPT wont read LC1 correctly
  205. speed inc electronics page
  206. Dynamic and Maf
  207. How is it possible idel
  208. A/C compressor at WOT?
  209. Air Flow Decay and Delay Hptuners
  210. Base Running Airflow Hptuners
  211. How can i go from dual fans to a single fan with HPtuners?
  212. PIN remover?
  213. texas speed mail order tune
  214. Stock O2's - higher reading before or after cat??
  215. quick ?
  216. BUYING AFTER MARKET MAF'S (if u are, tune the MAF table before runnin ur car
  217. tuning question
  218. new to tuning
  219. Better to tune with the stock MAF maxed? Or with the new LPE MAF?
  220. MAF VS Speed Density Tune!
  221. diablo tuner question...
  222. Interesting Read
  223. AeroForce Tech?
  224. anybody played with leaning things out during cruise for gas mileage?
  225. Where to mount PLX wb o2 on LG Long Pros
  226. 83% throttle at WOT
  227. Went from stick to auto-now how do I dyno this car properly?
  228. tuners
  229. CR3 files
  230. Predator question?
  231. hypertech
  232. Can too low of timing hurt?
  233. NEW PRODUCT: MSD Dashhawk
  234. Tuning for manual transmission in 00-04 truck ?
  235. EFI Live Flash Scan V1 For Sale
  236. What Did I Get Myself Into? :(
  237. Raise Idle Air or Adjust TB screw?
  238. 4l80e speedo issue
  239. Predator -- go negative on slope, means need to go positive in PE ??
  240. what does the security light mean?
  241. LS1 Edit HELP! Comm Error?
  242. VATS & lt1 edit???
  243. ABS light on!?!?!?!
  244. PCM keeps reverting to low octane table
  245. Car dies when load hits when first put in gear and can't figure out the fix....
  246. swapping pcm ?'s
  247. Injector Tuning...
  248. Air/Fuel Question
  249. Cheapest place to find wideband 02 sensor
  250. Pcm Pins
