PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. 98 trans am dies on WOT
  2. cant smog due to kill switch
  3. HP tuners VCM scanner not scanning LS1
  4. EOI stock cam to ls9
  5. Lq9 ls9 cam 80mm ld850 stock com rich idle
  6. lq4 id850 ls9 cam issues
  7. p0300 replaced 5 things still won't idle or run without pressing gas
  8. p0300 replaced 5 things still won't idle or run without pressing gas
  9. PCM Swap question
  10. Hey guys need some help
  11. GMPP harness connector removal
  12. HP and boost controller questions.
  13. Rpm loss random
  14. Gen III 2003 Truck PCM
  15. EFI Live Tune File Repository?
  16. problem using copy label function
  17. Tuning idle/false knock
  18. 2014 chevy volt
  19. Advice please: new combo with new timing table and target afr tables
  20. t56 to 4l80e tune
  21. VAT Issue?
  22. Repinned 98 harness to 99 +
  23. Wiring Harness
  24. PCM Tuning, Harness, and Emissions: Where to Start?
  25. E67 Terminals
  26. Limited throttle output on first start-E40 LS2
  27. Thinking of switching to EFI Live from HPT
  28. 2008 GMC Z71 1500 runs like its only got 4 cylinders working.
  29. LS376 Crate Motor Electronic Throttle Test and General Startup Advice
  30. PLEASE HELP / Fuel Issues: Pump primes but can not keep idle & dies
  31. Need help with 04 gto no crank no start !!
  32. 5.3 80e swap trans tune issue
  33. LS Tach Signal to Racepak IQ3S
  34. ve tuning
  35. PCM Questions
  36. Ran my car at track, can anyone take a look at my log files?
  37. 408 2005 gto
  38. Stock ls3 tuning for swap help please!
  39. Ls pcm and efi live w/cos5
  40. TH350 Gear Vendors No Button Shifting?
  41. IAT varies too much to be used in SD tune?
  42. 05 GTO New ECU
  43. Anything wrong spacing the o2 sensor out of direct exhaust flow?
  44. Cant get above 1300rpm??
  45. Throttle weirdness
  46. F body wiring questions
  47. Hi fan reference question
  48. Change AFR to dirty up intake valves
  49. brain damage, setting up main VE vs RPM vs MAP histogram in HPT
  50. DBC to DBW
  51. Should these 2 codes be disabled? U0121 u0140
  52. Advice on ECM
  53. LS1 WOT accel fright
  54. Looking for HpTuners Bin File LS3 6L90
  55. Tune Issue I Think
  56. E85, timing and egt data
  57. Need somebody to tune PCM
  58. turbo 5.3 rich under load
  59. Readiness monitors
  60. afr% error help
  61. Msd 2 step issues
  62. 4.8 issues got me scratchin my head
  63. Help with wideband selection
  64. Canister purge solenoid logic....question
  65. Buying HP tuners but was warned off by somebody..
  66. Tuning newb!
  67. Flex fuel and 3 bar map what ecu
  68. No tach signal
  69. Hand held tuner vs tuner
  70. Throttle Cracker disabled due to hanging RPM, now RPM drops too fast!
  71. RPM cut on stock PCM (3bar OS p01 computer)
  72. looking for a 2005 chevy avalanche OS!
  73. Help 2005 CTS v magnacharger, intake, header and exhaust
  74. 2003 LQ4 Dual cooling fans always grounded
  75. New used pcm
  76. Connection problem to 02 Camaro with HPtuners
  77. 2002 Camaro Z28 just dies at 70-80 MPH
  78. Mast Motorsports M90 DBW tuning
  79. Timing Drops to 14 Degrees from 27 Degrees No Knock?
  80. VE table issue
  81. Differences between a manual and automatic computers?????
  82. High IAC After New Injectors
  83. PCM and Innovate ECF-1 flex fuel gauge with one sensor
  84. Budget build advice needed
  85. Boost builder Holley HP EFI
  86. Messed Up BAD!!
  87. Looking for a new laptop for HP tuners
  88. Stft trim help
  89. Low Dyno number and trap speed for Build
  90. Bad wideband? Or is the fueling actually changing?
  91. Holley HP efi issue
  92. Hp tuners start up issue. Any ideas?
  93. Scan tool?
  94. Rev limit changed?
  95. cadillac
  96. Need tuning
  97. Car will randomly be low on power.
  98. chevrolet 5.3 2011 m0del
  99. 4l80e not shifting at commanded wot rpm
  100. Wideband install questions
  101. Going back to stock. Anyone on here do stock re-flashes?
  102. 99 ws6 FLEX fuel conversion.
  103. troubles after tune
  104. Base tune: lq4/lsa 24x on 0411
  105. Ms3 Gold box in a 2005 (gen 4) GTO with a gen 3 LM7
  106. Hi guys
  107. Why would a tech 2 abort an evap test?
  108. 98 trans am - reverting back FROM 99 harness ECM
  109. 12v wiring VS 5v (crank/cam sensor)
  110. AutoVE with 160 deg stat
  111. Flex Fuel Fourth-Gen
  112. Anyone have an installer file for HPT v3.3?
  113. No start when hot.
  114. LS2 - Long time to start
  115. Stalling after P0418 and Disabling AIR
  116. EROD ECM tuned for a 416 stroker ?
  117. LS1 to LS6 intake manifold swap & tune
  118. MS3 1-wire oil pressure sensor
  119. LS 7 computer
  120. ls1 swap questions.
  121. 214/228 custom cam tuning
  122. ISO tuner Mid to Northern Indiana
  123. help setting up hptuners and aem wideband please
  124. Weird issue, high fuel trims (misfires?)
  125. Hp tunner and ABS
  126. ECU/Timing issue
  127. Chris@HPTuners 6.2L swap in an EL Camino 4000 rpm rev limiter help
  128. Injectors not getting power at fuse block
  129. P1153 after intake manifold R&R
  130. 88 RX7 with 24x 6.0 built to the moon swap.
  131. holley 160cc injectors
  132. Pontiac 455
  133. Have a couple of codes on scanner
  134. Supercharged TVR needs some attitude
  135. ls2 controller 19166570 can bus lines
  136. Fuel/air off
  137. What sensors to get?
  138. Sacramento dyno tune or in vehicle tune recommendation needed
  139. Tuner Needed in NJ
  140. Aem wideband hookup
  141. Possible Tune issues
  142. HPT editor not connected but scanner connects?
  143. ve tuning
  144. Black Box 98-00 XDF file needed
  145. OPEN loop rough idle, smooth closed loop idle....?
  146. Melted harness on passenger side?
  147. cam swap, driving while un-tuned?
  148. 02 pcm in 98 fbody fuel gauge help?
  149. Turbo 6.0 running, what base tune?
  150. Rough idle, random RPM spikes in S-10 swap
  151. E38 tuning help
  152. 5.3 swap into s10
  153. REP p1514
  154. Noticed some bucking with new 3.73s - tune changes?
  155. Trimalyzer
  156. Turbo lq4 ignition timing
  157. After reaching operating temp, gunshots coming from exhaust
  158. Lean code bank 2?
  159. Tired of half ass tuners
  160. Who can unlock my PCM
  161. Cold Start Tuning
  162. Tune touch up? Opinions?
  163. O2 sensor
  164. Tuner needs western Ohio
  165. Never starts on first try
  166. Looking for a good Dyno in south Florida! Anyone use lashway
  167. High idle & IAC Help
  168. HPTuners SD VE Tuning with Wideband - Commanded AFR stuck at 14.7 for cruise?
  169. Please recommend a TUNER near TOLEDO,OH
  170. Unsuccessful in finding LS2 injector data in gen3 ECM format
  171. Request for EFILIVE tune file. 2500 manual truck
  172. Left bank way hotter than Right bank
  173. STFT Enabled?
  174. opinions please, on new wideband
  175. code p0300 after tune
  176. Operating error reading on OBD2
  177. New 402 Build
  178. Fresh rebuild - Tuning - 42 lb injectors
  179. 8 pin connector for HP Tuners mvpi pro analog input
  180. Connecting an LC-2 Wideband to HPTuners MVPI - How??
  181. LS2 setting Timing Buttons for MSD 6010?
  182. Do i need to get my pcm reflashed when i replace my fuel rail?
  183. Tuner in Nashville tn
  184. Electrical + PCM gurus.......
  185. Positive fuel trims before starting engine
  186. 99 Formula 5.7L cylinder 3 misfire
  187. P59 PCM running a Ls3.ls7 card style maf
  188. VSS question
  189. New 5.3 swap, P0300 code, need advice
  190. Low power slow responce
  191. 2000 LS1 Idle Log
  192. Chevy 5.3 gt45 Turbo cam Decap injectors need help with
  193. Need ECU/EFI advice for BMW swap
  194. Please help me fix these codes
  195. Which platform "GMT800" or "Fbody" for DBW -> DBC In Hptuners?
  196. Help 99 gmc 3500 5.7 4l80e
  197. Heat soak | IAT Plastic vs Brass
  198. ADVICE For A TUNER ON MY 2007 6.3 SS Trailblazer
  199. 4.8 turbo tune help
  200. Ls tuning in ms
  201. Knock sensor help
  202. VATS Bypass question
  203. 411 pcm swap issues HELP
  204. Need New VSS Ideas
  205. No Injector pulses
  206. Start-up Tune Suggestions....
  207. E38 Vats
  208. Wideband Sensor Inquiry
  209. ls1 5.7 w/lq4 harness pcm ect help
  210. Mail order tune for cam and head car?
  211. What needs adjusted in HP tuners when swapping injectors?
  212. 3 bar pcm
  213. TPS issues with BBK throttle body
  214. Help wiring Aem 30-4900 on efi live?
  215. help diagnosing lq4 knock retard
  216. HP Tuner
  217. compression bump no retune
  218. 5.7 Tuning issue
  219. 1999 Camaro SS cooling fans inop
  220. E38 PCM / Corvette Pedal / LSA DBW TB
  221. 2002 camaro tune and Diablo tuner questions
  222. 0411 operated LS3 422 - Base Tune source
  223. Z06 ignition curve
  224. FAST vs HPTUNER
  225. decapped injector scaling
  226. L96 wrangler conversion running lean p0171, p0174
  227. Smoking and smells like gas
  228. Infinity 58 lb injector data
  229. Ls1 vss
  230. Holley Dominator EFI questions...advice needed
  231. 4l60e laggy soft shifts
  232. Looking for a tuner in Northern California
  233. Crazy swap issue. Need some help
  234. 4.8 turbo 80lbs injectors hpt help
  235. Need help diagnosing 'bucking' or power cut out
  236. Service Engine Soon Codes
  237. Dyno Tune or Mail Order?
  238. What Wideband O2 for HP Tuners???
  239. Camaro Speedometer Help
  240. tunerstudio and ls1's
  241. P2138 - various opinions...
  242. Clutch pedal travel sensor on a gen 4 f-body
  243. TPS not reaching to spec
  244. need efi live remote tuner
  245. ECM problems
  246. Need info on purchasing an LT1 Tech 1 Diag scan tool?
  247. LSA Swap wont start
  248. Built 6.0 for 25$
  249. 2006 Pontiac GTO Help!!!!
  250. work in progress
