View Full Version : PCM Diagnostics & Tuning
- adjusting for bigger injectors with ls1-edit
- No serial port. How do I use Atap??
- is anybody in ga or al dyno programming with ls1edit
- LS1 Edit for an 01......
- Trans reprograming
- Can any old"Joe" use it?
- Compared Hypertech "Power Tuning" to stock...
- Is Ed locking his programming now?
- Where to adjust cold idle A/F in LS1Edit??
- desktop PC's and LS1 edit?
- Is it possible to purchase LS1 edit locked to 2 pcms; one for 00 and other for an 02?
- Using the Hypertech to adjust shift points after custom tune
- DC - DC power supply for PC's
- LS1 Edit TCS thought!
- Where, and how do I go about custom tuning?
- Using ATAP, any way to tell if custom programming will benefit me?
- got my pcm programmed
- ported SLP maf and MAF calibrations
- Can someone explain gm/cyl..in the ignition tab
- something started smoking
- FLash problems..maybe
- swapping A4 to M6 - what all (computer-wise) must be done?
- AutoTap Help Please?
- who in tx has ls1 edit?
- Drill throttle blade or wait for Edit?
- Compare to 2nd file in LS1Edit problem.
- How many of you guys have dip at 0.12 gm/cyl on spark adv
- Cost for Dealer to Flash a Backup PCM???
- Computer Tuning?
- LS1Edit: Same features for PC-Locked Version as Unlimited Version?
- What is wrong with my car
- Torque Management/LS1 Edit question
- Milliamps used on WOT shifts
- dyno in Austin with LS1 edit?
- O2 Sims! Can I make my own?
- LS1 Edit for !EGR?
- Who has a AC-22 performance meter?
- Tuning Question for the gurus
- How long to receive LS1 edit?
- atap work on lt1 cars
- Can LS1 Edit delete the 4l60e in the PCM? I did the TH400 swap.
- Where can I order the LS1 Edit?
- Gains with Ed Wright programming?
- LS1 Edit 01 PCM and 00 Flash
- Price on MTI doing ls1 custom tuning
- OBD2.com
- scanmaster dimensions
- Considering ditching the MAF and O2 sensors and going Speed Density.
- whats the best free LT1 scanner?
- Can LS1 Edit do everything Hypertech can?
- shift points with LS1 EDIT
- Performance Mode pinout (transmission)
- How are you guys measuring RPM with A-tap?
- Wideband O2 sensors with stock PCM
- Standard calibrations for LS1 edit required please !!
- Custom tuning or Ls1 Edit what is the difference
- OBD II code readers
- Open loop operation???
- Ignition advance.... (Chart inside!)
- Need advice on what tables to adjust for PCM tuning
- When will LS1 Edit be available to the '01 cars?
- Just got a Cam
- will cables from LS1 Edit also work on autotap
- tuning or ls1edit (help please)
- pcm question
- Anyone receive their LS1 EDIT yet???????
- Another LS1 Edit post. Would the average Joe have a problem using it?
- Bug in A4 98 Vette files
- LS1 edit and HPP3 questions
- A/F ratio in A-Tap?????
- What gains from LS1-Edit?
- Can the LS1 Edit cable be used for A Tap?
- Individual user LS1 edit?
- S.Cole asserts that Rich LTrims means no enrichment .. ?
- I programmed my own PCM with '98 EDIT
- Found a bug on '98 LS1-EDIT
- program?
- Autotap readings. Good or Bad?
- LT1 Edit cable work with LS1 Edit?
- OBD II trouble codes?
- Dumb question for those who have LS1 Edit...
- For Sale 2000 hpp3 $175/borla y-pipe $100
- HPP3 Calibration error!
- Is it just me.....
- EFIlive V5 demo using Autotap interface
- LS1 edit: Tuning a4s and m6s
- Stock PCM limits?
- Can I delete codes with LS1 Edit???
- Where are the LT1 editor archives and such?
- Can I add a '02 VIN now to LS1 Edit?
- First Impressions of 98 LS1 Edit!
- Looking for Mr. Wright
- How to contact Ed Wright
- LS1 Edit PCM locked version.. lil tidbit
- LS1 Edit Message Board, from LS1 Edit!
- HPP3 RFG tuning...
- Hypertech computer reprogrammer
- LS1 Edit "Updates"
- So is the 98 ls1 edit out?
- Do you think programming will help me???
- LS1 edit carputing # and vin question
- dumb, simple question. question on ls1edit.
- Will LS1 Edit work with Ed Wright tuning?
- Ease ? (Team ZR-1)
- MAFT LTFT's - -4 or +0.2 better?
- Tony Tony Tony! Nineball We need LS1 Edit forum!
- Any DEMO or instruction book on LS1 Edit?
- A4 cam swap reprog
- LS1 Edit
- vig 3200 any issues (ses light)
- LS1-edit with diffrent year models?
- ls1-edit for truck 5.3 pcm?
- questin on LS1-edit
- Can you share tuning files with LS1-Edit?
- Welcome to the New Section!
- ls1 edit ????'s maps etc.
- LS1-EDIT and other custom PCM stuff here!
- Code P0420 Keeps coming up...what is this?
- WOT Timing Q...
- computer programing?
- Superchips Programer.
- Autotap logs before and after hpp3 check it out.
- MAFT to help dyno #'s
- OBDII QUICK SCAN
- Who has used a MAFT wih Pace LS6 MAF?
- I need an Autotap lesson..
- LS1 Edit - Fuel Curve/Map Questions
- What top 4-8 items should I log/view with AutoTap
- Auto Tap vs Auto Xray w/ the PC Link
- HELP HELP HELP!!! threw an SES light!!!
- Do 2001's use correct fuel and spark tables for LS6 intake
- Main difference between Autotap and Scanmaster?
- ? about SES light and autotap readings
- What is the normal maf flow rate for h/c cars?
- Higher O2 #'s w/ autotap. Rich or lean?
- A-tap Experst, please step inside...
- Autotap Data Collection Rate?
- Timing, Etc. Adjustments ?
- Auto tap or Scanmaster
- Help!!! DTC codes: P0401 and P0327!!
- Auto tap questions
- KO Box results>
- looking for atap native files
- PLEASE PLEASE help with my trouble codes!!
- Torque Management??
- Getting Autotap #'s in spreadsheet???
- Need help looking for USB to serial cable for laptop to use AutoTap
- Installed a T1 cam Ported t-body, LS6 intake this weekend. should I reprogram?
- Has anyone seen proven gains from programming on a 4xx rwhp NA 346 ci car?
- Atap help needed, IAC Pos vs. counts.
- dynoed today, 4 degrees knock and too lean
- danm,im computer stupid(maft an Atap
- limp mode??
- Recomendations on ECM Computer Tuning
- A/F on Dynojet vs the track, difference in load?
- I got my IAC counts down but I have a couple ?s
- L Trims vs MAF-T vs PCV system (or the lack thereof)
- PIcked up a Scanmaster today
- To hell with MAF translator!
- ?'s for those who've deleted torque management
- Ed Wright tuning help (long)
- need help tuning with maft....
- Benifits of MAFT on slightly modified SS??
- LS1 Edit
- LS1 EDIT:
- SES - P0141 and P0161?
- LS1 SCANMASTER...OPINIONS???
- Autotap review
- Autotap Log help . Look at this KR
- Atap question
- is this the wire for lockup
- OK, why are we deleting tq management?
- LS1 Edit Update
- 2001 lockup wires
- PCM removal/ installation
- Is Reprogramming needed for a CAM only install?
- EFIlive V5 (OBD-II) another LS1 Edit?
- Autotap: What can I do with it?
- Hypertech
- MY MTI H/C Wideband O2 vs A-tap readings
- Those that have either Atapped or Tech 2'ed
- What Scanning tools are available?
- AutoTap interp Help
- DTC'S AND MAFT?
- LS1 Edit questions
- Ported MAF and MAFT question
- What is the ideal air/fuel ratio?
- Top Speed
- ATAP Question
- 2 a-tap codes
- Pinging at light throttles?
- I want to have a backup PCM - Can any PCM be programed for any car?
- Questions on A-Tap
- P1810 Code?
- Autotap 'd car last night at Atco--->NEED HELP!!!
- WideBand O2 sensors, what do they allow you to do?
- KnockOut Box scores 1st round TKO!!!
- In ATAP 101, they mention fuel cell 1-19, 22
- Tuning with a MAFT 101....
- autotap questions
- MAFT questions??
- Question about pcm tuning...
- Lets talk PCM tuning and LS1-EDIT
- knock retard...
