PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 [78] 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. DiabloSport Hand-Held Tuner Question
  2. looking for a pic/file of a timing table
  3. Tach is Still Off After Swap, What do i need to do ?
  4. need some help tuning ve table (raise or lower)
  5. Flashing SES light(Misfire)...Disable?
  6. what can i do with this software? is it full tuning software?
  7. Hptuners help! A4 to t56 tune
  8. How does one completely delete the knock sensors in EFILive?
  9. Predator STS tuning needed
  10. computer
  11. TCI or PCS tranny controller
  12. Megasquirt Setup
  13. Locations for for car tuning?
  14. Is there any way to correct for a descreened MAF?
  15. Got my HPtuners to scan, but not write... help?
  16. Truck won't go WOT after 80E swap
  17. ls6 tuning
  18. Am I correct on my tuning order?
  19. 1st gear very very short. Is something wrong ?
  20. Autometer WB sensor part #?
  21. converter locking in 2nd & 3rd @ WOT...HPTuners
  22. My car is running super rich! help needed
  23. bbc using ls1 pcm and harness..possible
  24. Audible ping but nothing on scanner
  25. Initial Scan Take a look
  26. EFI Live TCC Help
  27. 02??
  28. drive on untuned?
  29. Temp gauge what circut where to tap in?
  30. Idle routines not kicking in everytime. HELP!!!
  31. PCM/tuning help - big mix of stock parts
  32. Weird issues after injector swap/tune
  33. past threads on big cam tuning. please help.
  34. Megasquirt features
  35. Options when DTC P0601 (and/or) Crank Position Sensor
  36. car will turn over but will not start!!!
  37. Narrow band af guage
  38. Engine Temp Whats Normal?
  39. Engine running lean
  40. NO2 Backfire
  41. car key locked out
  42. Starter Problem, please help!!!
  43. Help asap
  44. perks of 6ls and stock computer together?
  45. Crank Position Sensor Damage
  46. Older F.A.S.T. system EDist ignition delete
  47. Help after intake swap please..
  48. O2 sensor question
  49. Xfi FAst questions..
  50. It is gonna take a genius HELP!
  51. 414ci LS3 stroker...throwing a P0120 TPS code...
  52. Better to Drive with Suspected Bad MAF connected or unplugged?
  53. Stepping Down
  54. Help P0153?
  55. Questions about what to do for Upgrading with my HPT?
  56. HP Tuners VCM Suite 2.22
  57. Anyone want to help me out?
  58. Flashscan V2 or HP Tuners ?
  59. my farewell
  60. Can i use low inpadence injectors with factory PCM?
  61. o2 causing ses light
  62. HPT bin file for bolt ons car?
  63. P0101 DTC - MAF Out Of Range - Need Help Troubleshooting!
  64. Some general info about tuning from Fasterproms, basic to advanced
  65. SES light on???
  66. Check engine code???
  67. Good Tuner Shop
  68. RAFIG on 2002 Z06 (Stetting Desired Airflow table)??
  69. LS1 Edit tuned, retune with HP tuners/EFI Live???
  70. Crank Learn with HP Tuners
  71. WOT shifting...
  72. Mail Order Tune Suggestion
  73. Any one here have any knowledge with GM Kent Moore tools?
  74. how to pull out the pins on the pcm plug
  75. Dreaded P0351 & P0358
  76. Strange HPT issue w/ AFR, fuel trims -8.6 yet AFR is over 16 at idle
  77. gmpp computer
  78. Emissions Prob Help Please o2 sensor heater readiness
  79. 1998 vortec 350 timing
  80. Datalog is Weird, Any Ideas?
  81. 60lb. high-imp Injector setup
  82. Can ANYBODY figure this OUT!
  83. Will it run??
  84. Extreme noob! Help!
  85. No power at fuse box
  86. Is my PCM jacked up?
  87. Help!!!!!!!!!!!!!!!!!!!!!!!!!????
  88. How to solve the problem
  89. Whats a good wideband for tuning a carb?
  90. need help ASAP
  91. Changing gear ratio, what needs to be done?
  92. Ok here's my problem. Do I order a handheld or not?
  93. Crank Position Sensor Question
  94. IATs in the red and fuel trim too
  95. Help on info about a Diablo Sport
  96. idle kpa 60
  97. Anyone have info on the Innovate LM-1 trade-in program
  98. O2 sensor info..
  99. 4L60E: temp vs. resistance
  100. ses light codes p0113, p1404
  101. Please help guys. Detonation
  102. wot shift rpm vs wot shift speed tables
  103. SES light on
  104. HUD DTC on 2000 TA? WTF?
  105. Efi life starting point
  106. The Tuning School
  107. scan tool prices
  108. Difference between a "tune-up" and a "tune"?
  109. mail order tune vs. dyno tune
  110. Tuning an 03 Z71 Tahoe
  111. Tuning new AFM engines for mileage
  112. Big Stuff 3 tuner
  113. P0200 Code, could use help
  114. Is there a max speed limit programed into PCM?
  115. hollowed out my cats not getting ses light wtf???
  116. Dyno tuning
  117. check engine and low oil light help!
  118. why after gettin gears is good to get the tune
  119. Placement of new style MAF sensor
  120. General Tuning/Timing Question
  121. another bad trans or electrical?
  122. Tune Help AC Idle
  123. sorry P1637
  124. Tuning trouble??
  125. ECM that uses wide band?
  126. Please help.... ASAP
  127. code P1137???
  128. weird throttle problem
  129. cord question
  130. Anybody dd t rex cam mpg?
  131. MAF elctrical output reading..........
  132. Any well know tuners near Idaho?
  133. Would replacing intake manifold cause P1153 code?
  134. need help turning off the ses light
  135. Limp mode with no MIL?
  136. Lt1 problems datamaster file attached!
  137. Mail order tuners????
  138. Anyone tuned by......
  139. Any tuners in socal (SFV or SCV)???
  140. Help with 91 silverado 6.0 swap
  141. new cam throwing misfire code
  142. 2 BAR Turbo Tuning! Help....
  143. O2 sensors on 2007 escalade?
  144. need help near havelock, NC
  145. Best mail order tunes
  146. SES light during high rpm shifts-->
  147. Msd 6010?
  148. EFILive Scan looses connection..
  149. ecm swaps
  150. Are GMPP ECU's re-mappable
  151. jet Dynamic Spectrum Tuners
  152. diablo u7193 for sale.
  153. Dyno tuner around Boise
  154. typical LTFT at idle
  155. opinions: megasquirt or stock pcm
  156. PVC Delete
  157. Charging system issue, alt dropping out under WOT load
  158. Help Electrical Car Dying
  159. Bad Computer?
  160. Looking for tuner in s.c. Or n.c.
  161. what are.....
  162. cost of dyno tuning?
  163. Replacing bad PCM means using more credits? (HP Tuners)
  164. Security light stays elimuminated all the time?
  165. dyno tuner?
  166. Wire Harnesses
  167. Planning on HPT + Innoative wideband... questions
  168. PCM burning up my alternator?
  169. efi live of hp tuners
  170. Tuner in KY
  171. why won't it shift at my rpm 2-3
  172. Wideband really needed with HPtuners?
  173. Big problems! Step inside
  174. LC-1 Error Code 9
  175. Philly Area Dynos
  176. slow rev
  177. Something seriously wrong with my car..
  178. tps high input anyone know how to fix??
  179. HP Tuners Question
  180. Should I turn all the tq abuse modes off?
  181. Trifecta Tuning
  182. Hp Tuners where to get cheap
  183. Autometer AF Guage
  184. Engine computer seal
  185. maf ????
  186. Weird Idle
  187. Need your .02 please
  188. ????tuning????
  189. Need Speedometer Recalibrated
  190. need a datalogger
  191. TCC problems after new trans, converter, and gears. Hptuners
  192. Changes needed for boost ref fpr
  193. Could a bad alternator cause a surging idle?
  194. diablo question
  195. Long Term Fuel Trims Split
  196. hp limits on hp tuners and stock ecu
  197. 95 A4 PCM just fried - how to swap?
  198. What can be tuned for transmission/rear? What should I ask?
  199. efilive tuners near Canton, ohio
  200. Vista?HP Tuners
  201. what should i expect to pay for a tune?
  202. th400 neautral safty sw?
  203. Tune near Pittsburgh Pa or Cleveland OH?
  204. Is the car tunable with this code?
  205. car holds rpm after tune
  206. t56 to th350/400 with a transbrake?
  207. Need Tune!
  208. C5 Tune headers no cats
  209. o2 sensors
  210. wierd one
  211. Tune going weird?
  212. Need Help!!
  213. P-0135
  214. Converting 4l60e to 80e settings in VCM
  215. HPT on a Dell Inspiron Mini
  216. LT1. to BIN. file ....HOW??
  217. efi live help
  218. TB changes, idle code
  219. HELP - SD tuning w/HPT
  220. HPT - No signal from O2's.
  221. Need help with accel dfi for LT1 questions
  222. Rich idle - 42# injectors
  223. Speed Density tune
  224. Timing Question??
  225. Is there someone who can hack into my comp and help me???
  226. Heres a nice guide to codes'
  227. Emissions question... drive cycle
  228. Random "miss" HELP!
  229. 5.3 Truck Harness Compatible with LS1 Engine?
  230. mail order pcm
  231. trac on, gas stuck=me in the ditch
  232. Maf tuning question
  233. Too many things not ready to pass inspection
  234. Emissions
  235. Who has HPtuners in stock?
  236. ******Gettysburg Tuning and Porting March 27- April 4******
  237. Stock MAP sensor ??
  238. more damn comp/gauge problems
  239. weird idle problem
  240. why do headers / ypipe require a tune?
  241. will my l92 headed 370 run on 6.0 tune???
  242. diablosport question
  243. tuner
  244. 99 pcm in a 2001?
  245. NO (PPM) Failing Smog Tests
  246. CONTACT # for Harlin engineering
  247. Need help! Please read my logs and share advice
  248. New tune after Trickflows
  249. Base vs Main Spark Tables (HPTuners)
  250. Harlin 2step question
