PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 [117] 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Which computer is the 2002 Camaro manual
  2. Ok guys I am bamboozled!
  3. here we go again
  4. best way to read rpm's on LM-1
  5. Problem with Tunning or Transmission????
  6. TPS Voltage @ 0% throttle
  7. diagnosis tools and tuning, what are you using?
  8. EFI live and RR question
  9. i need tts datamaster 3.4.1
  10. Rich Condition @ WOT But Only On Bank 2
  11. Advance @ WOT
  12. Brake Shudder --> ABS INOP
  13. I have a dumb question I think
  14. Dude, Where's my Throttal Response ?
  15. help look at my dyno sheet.
  16. Will a tune be worth it...???
  17. NBO2 Stock wiring
  18. FYI on a CKP problem
  19. Desensitizing knock sensors with LS1Edit?
  20. Which Knock sensors do I need???
  21. Car acting wierd
  22. Went bonkers
  23. P1635 low 5v feed circuit one
  24. Open loop/MAF tune
  25. SD tune VS MAF tune which one ?
  26. O2 problem....
  27. stock 02's have different readings
  28. Cab't re-enable closed loop after tuning
  29. jets chip removal
  30. Gains with a full tune
  31. Tuning for a conversion
  32. TPS sensor, ASR, A/C and cam?
  33. Help with AFR
  34. Programer???
  35. ok i have searched with no stright up anwsers
  36. wont fire!
  37. intermittent P0332 question
  38. P0103 code MAF
  39. Idle tuning
  40. bolt ons only what to tune?
  41. P0102 ???
  42. Different LTFT readings bank to bank - what to do?
  43. What is the most $$$ spent on a Dyno Tune?
  44. bad PCM? help
  45. i just installed my upgrade to 2.1 HPtuner?
  46. Tuning for a big cam
  47. Could tune do this?
  48. ECM interchange?
  49. cheatr cam and air fuel ratio.
  50. U1000 trouble codes? Anybody know about them
  51. code p0446
  52. ?enhanced I/O?
  53. whats the most newby compatible tuner
  54. '96 LT1 Scanning questions!
  55. Tuning tips adding 90mm combo/Camaro
  56. HP Tuners question...
  57. ECM and Harness Compatability
  58. 42lb injectors
  59. truck or f car programing ??
  60. Running bad. SES light goes on and off.
  61. code p0412 AIR sys?
  62. EFILive Blowout Sale
  63. P0336 - Crankshaft Position Sensor A Circuit Range/Performance, FIX?
  64. safc2 possible to put on 2000 camaro?
  65. Map Sensor
  66. gtech question
  67. How do you tune for power?
  68. '03 Silverado tune
  69. M6 tune
  70. Vehicular Crossbreeding?
  71. Efi 101
  72. cant get pcm to open loop
  73. 99 z28 is going nutz!
  74. WOT fuel pressure...should it drop?
  75. VE woes...very weird.
  76. MegaSquirt Question
  77. tuning out codes...ex. rear o2's, egr, etc..
  78. need help with two codes, please
  79. Can an ecu lose its tune?
  80. gorilla chipz??
  81. Computer ?
  82. nebie needs help with IAC and i seached
  83. need help, please come in!!!
  84. Map Sensor Problem
  85. Best wide-band and reader for LS1/6/7?
  86. Question about Tuning SD, LTFT's
  87. IAT range?
  88. Misfires, suspect PCM - please help!
  89. Low Input Knock Sensor Bank Two
  90. Clairification on Throttle Cracker and follower
  91. do any programmers delete 02 sensors?
  92. Help, No vehicle power detected
  93. need help *starting with AC on*
  94. Egr
  95. 98 vette wount start
  96. N2O Timing help!!!
  97. Quick ? On O2 Wires
  98. Calibrating WBO2 with LC-1
  99. o2 high voltage (please help)
  100. Is there an IAC reset?
  101. Anyone with a Tech II or better in L.A. Ca.????? (I need a case re-learn)
  102. 9.5:1 CR 346, H/C, D1SC, 14lbs, Alky, 100 octane.....what kind of timing?
  103. Lets talk timing...
  104. Ilde problem
  105. Lean Throttle Transients
  106. Programming navi into vehicle, everything works except navi.
  107. pcm is locked w/ HPT, how to unlock?
  108. Help with off idle hanging or cruise???
  109. Can I do it?
  110. New Tune needed 4 new fuel pump?
  111. dyncylair...whats yours at?
  112. HPtuners EIO malfunction/broke?
  113. VATS on a 98 Camaro ?
  114. Fresh Tune, problems with idle
  115. Anyone near PA 15801 with Tuning Equipment?
  116. LM1 wide-band?
  117. Anyone running carb style intake and carb style TB on stock PCM?
  118. '98 vs. '02 VE tables.
  119. is computer burned again
  120. Higher Wattage O2 Sensor Part #?
  121. Tuning issues with FAST 90 on vette
  122. turn signal flasher pins???
  123. Which one?
  124. Closed Loop and Idle tuning 90mm
  125. power increase from a dynotune?
  126. Lean Cruise Mode?
  127. Grounded out positive terminal on battery..
  128. Does anybody have a good tune for a MS3?
  129. permenant in-cabin wiring for LC1
  130. Please read my dyno sheet
  131. Knock Real or false?
  132. Hot starts with FAST 90/90 (Corvette) ?
  133. LS1 wiring harness.. Where does connector PED 14 plug into?
  134. TC tune question
  135. superchips question
  136. No More O2 Sims From Casper
  137. Hp tuner question
  138. Help with warm start up
  139. Fuel trim cell @ 19 (idle) while at WOT and TPS shows 99.6%....
  140. spark for my 402 cid
  141. wide band readings
  142. does anyone sell a data link splitter?
  143. hptuners and some questions concerning turbos
  144. exhaust leaks?
  145. [B]Had SES code read, anyone know how to fix?[/B]
  146. afr behind cat, look lean to u........
  147. Oxygen Sensor Problems
  148. GM 02 sensor Connectors
  149. AEM wideband sensor mounting
  150. Who's running Open Loop with a MAF?
  151. Hp Tuners, Manual?
  152. TPS VOLTS at idle
  153. Will not start
  154. Is this a bad O2 sensor?
  155. How much HP and Torque?
  156. cooling fans turn on temp
  157. service engine light NOT ses
  158. SD vs. MAF pro-con??
  159. Scanner only?....Search not working for me
  160. Feedback on FAST wb dual sensor guage.
  161. DTC's all over the place!!
  162. Dies After 20 sec.s
  163. wideband VE tuning done, car won't idle now
  164. Scanner
  165. What do y'all think of my VE and Desired AF?
  166. Sponsors Fuel Economy Tunes, are they for real or BS?
  167. OLMA= Trims maxed positive
  168. dialing in IFR for new injectors, post cam
  169. New Tranny & TC, Now shifting 400 rpm's Lower?
  170. Could somebody look at my file and tell me what you think?
  171. Please Help! Code 1515 and 1516
  172. tune or no tune
  173. anyone from pa???
  174. AFR's ?
  175. LC-1 cable used with LM prog - need help
  176. MAP Sensor Question
  177. good tuning software for beginner
  178. Dtc Help!!!! No Scanner
  179. O2 codes won't go away!!!
  180. Do these codes affect anything?
  181. speedo calibration?
  182. 2005 Cammed GTO A4 Fuel Trim Cell 37 Issue
  183. question about wot multiplyer
  184. Iat Guage Turned Red???
  185. IAT and boosted horsepower?
  186. rpms hang at high speeds and low speeds
  187. losing tune due to battery?
  188. OS sytem change? using HPtuners
  189. Big Stuff 3
  190. new pcm
  191. timing retards during shifting at wot while shifting gears and will not readvance
  192. Car dies, won't idle - HPT Log included
  193. is anyone really good a conversions? for like speedos?
  194. SES light went on but no code showed up
  195. My AFR is off cause of my cam
  196. SES Code; EGR valve
  197. Tuner near Omaha, Nebraska
  198. Which O2 is bank 2 sensor 2?
  199. Z06 MAF Sensor Safe to Use w/o Tune?
  200. Rich Decel leads to lean bucking?
  201. p0440 evap system code..
  202. New Tune Needed?
  203. Where to buy fuel and N20 pressure sensors for LM-1's?
  204. Hyperteching a LS1Edited computer...
  205. Looking for .bin
  206. Car will not idle at start up!
  207. Hitting every cell in the VE during log?
  208. Terms: Fuel Trim Cell and TCC Slip RPM?
  209. Maf ?
  210. Knock Retard. How much is O.K.?
  211. is there a efilive sponser i can talk to?
  212. swapped headers now won't go closed loop
  213. Why do LTFT's go to 25 at WOT??
  214. i need help. i messed up
  215. New sub $200 WB option
  216. Having smog problems??
  217. oh to changed vehicle speed pulse width?
  218. F13 tune
  219. Predator tuning... 2.73 --> 3.42 gear install, A4 downshift points messed up?
  220. Broke map connector need help
  221. Hey, TSP Tq II guys w/ longtubes, what AFR and Spark everyone dialing in?
  222. misfire and o2 codes
  223. TUNING ISSUES...Could it be this?
  224. TUNING ISSUES...Could it be this?
  225. 42# injectors tuning question?
  226. Misfire at cylinder 5.
  227. a4 pcm on a m6
  228. Tuning question
  229. NEED HELP WITH A/F & SHIFT LIGHT Wireing?
  230. Wot??
  231. My tripometer resets when i start
  232. EFI live users
  233. lt1 edit or megasquirt?
  234. car starts then shuts off. help please
  235. 2004 ProCharged GT, Predator tune
  236. HP tuners for LT1?
  237. timing?
  238. EFI-Live: Can I see your HOTCAM tunes?
  239. SD AutoVE and then swith back to MAF?
  240. idle issues... PCM is freakin out
  241. S-Trims have jumped to -40%!!
  242. black smoke
  243. Lean idle = leaking headers?
  244. Basic turbo tuning questions
  245. Mediocre Performance?
  246. How mad will a MAF code throw off a car?
  247. p1683?? WTH is this?
  248. Gen 7 DFI/Innovate LM-1 wide band/Accel DFI dual sync distributor
  249. ht111 tuner help
  250. LS1 coil pack control pin driver
