PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 [200] 201 202 203
  1. Can't get rid of the SES light , help
  2. I'm happy with new Ed Wright Tuning
  3. chip vs ls1-edit
  4. PCM Selection
  5. MAF Low Freq.. and O2's Slow response?
  6. LS1 Edit Tuner
  7. Tuning my WS6
  8. What can I do about an SES, low knock sensor?
  9. First ATAP Got some ???s
  10. hypertech problem...
  11. eliminating surging with LS1EDIT???
  12. should ltrims go lean or rich with throttle?
  13. Ok, WTF is + 25% ltrims rich or lean
  14. Vehicle Explorer Scan Tool vs. AutoTap???
  15. Security Light?
  16. Anyone ever hear of a SUPERFLOW chassis dynometer?
  17. How high is too high? (rev limiter ?)
  18. LS1 in a 87 Formula Firebird???
  19. help ls1 edit
  20. getting LS1 edit tune 2morrow- please help
  21. PCM 1998 c5 and 1999 Z28 Interchangable?
  22. Deleting THe EGR out of the computer???
  23. Dyno numbers
  24. How does this setup sound for changing the Hi & Low Octane tables...............
  25. TPS Voltage via ATAP
  26. minimum requirements for laptop w/LS1edit
  27. so guys, which gauges do you think are the most important for each application??
  28. Should I tune the SVOs or MAF first?
  29. Autotap help. first time user
  30. Oil pressure readings used for anything?
  31. My trip-meter resets itself whenever I start the car...
  32. maft tunning got me all screwed up...
  33. Stroker Tuning Question,
  34. How to monitor fuel pressure?
  35. Auto Tap Vs LS1edit opinions wanted
  36. LTERM fuel trims @ idle????
  37. Can you use LS1 edit to...
  38. autotap functions
  39. atap to check pushrods?
  40. GM 02 Sensor's vs Everyone else's ??
  41. VATS died and the car won't start...
  42. doing throttle stop grind mod-help with readings??
  43. PCM says one thing, WB O2 says another: Tuning out a PIG rich setup
  44. Tuning not needed? Lucky guy inside...
  45. too much timing
  46. I think my 1 week old LS1 edit cable just died
  47. increasing idle w/ A/C on w/ LS1edit, where is it done?
  48. How do you disable the knock retard relearn
  49. Is it possible to turn tranny codes/functions off completely with an a4 and LS1-edit
  50. I need the tables for an uncalibrated 85mm PACE MAF and Tables for Lucas 42.5#
  51. MAFT tuning question
  52. LS1Edit: Anyone change AFR setting??
  53. security light
  54. ls-1 edit system
  55. Flashing SES light
  56. finally hooked a wideband O2 up on the dyno...
  57. Why does my fuel cells change from 22 to 15 at WOT???
  58. LS1 edit for the 01's any time soon?
  59. Do 6spd cars utilize torque management?
  60. Ok, what's the final word on + or - LTFT?
  61. O2 readings
  62. LS1 edit. Can you lock the fuel/timing maps?
  63. throttle body drill mod
  64. Which MAF is better/ Pace 85mm/vv or SLP 85mm
  65. tranny dosnīt shift at WOT, PCM related, cannot fix with LS1 edit???
  66. what all should I change on ls1 edit..please read
  67. Do I need to change the injector 'offset' when installing SVO 30 lb using LS1-edit..
  68. How to Calc gm/cyl?
  69. Are my O2 Sensors or Heaters Bad: Will Autotap tell me?
  70. Center console makes a great mouse pad
  71. Air fuel and auto tap
  72. ses-code p0410
  73. Problems I might experience with a HPP3 ???
  74. What is considered the "perfect AFR" ???
  75. Anyone in York, Lancaster, Harrisburg, Balt. area
  76. Computer Tuning
  77. LS1 Edit Software Error Message
  78. HPP3 question....going back to stock...???
  79. Are C5 LS1 PCMs interchangable with Fbody LS1 PCMs?
  80. Where the heck did you mount your MAFT on your SS???
  81. KR help
  82. Resetting the SES light...
  83. why MAFT and PCM tuning?
  84. New Dyno numbers... and some interesting info about the Dual Dual
  85. Dip switch settings for MAFT and GMAF?
  86. ls1 edit and maft question
  87. O2s were .980...How much HP did I leave on the table
  88. LS1-edit ?????????????
  89. Why does HPP3 screw up the ecm?
  90. p1415, p1133
  91. W/ LS1 Edit, if PCM fails, can I reflash my spare and use it with LS1 Edit?
  92. Just installed 30lb SVO injectors. Need help!!!
  93. How does the MAF work?
  94. will LS1 Edit fix.....
  95. Shifting problem. TM or shift solenoid???
  96. Dash Light
  97. Ed Wright tuning???
  98. Dealer says they cannot reflash compter, wtf?
  99. Need help with 2002 computer tuning
  100. LS1 edit for 01s+02s
  101. Question about Tuners who use LS1 Edit
  102. sensor or plug that is on the driver side in front of the header
  103. Codes P1133 and 1153 Fuel Trims locked
  104. MAFT question here
  105. rear 02's interchangable?
  106. Question on monitoring WOT O2 with Atap
  107. Autotap or Scanmaster?? which one to get?
  108. Problem After Dyno Pull
  109. OBD-II Scanner Question
  110. Scanmaster question...what is CEL?
  111. Shift Points with Hypertech?
  112. Cannot get a-tap to connect.....WTF
  113. timing low please help
  114. Seems my question was deleted by MISTAKE...
  115. Any power to be gained tuning a stock engine
  116. Help - I'm running pig rich at the track. (long)
  117. Autotap questions
  118. Where to get an after market service manual for the C5?
  119. Good test to see if your laptop will work with LS1-Edit within
  120. LS1 Edit/ Custom PCM
  121. ATAP question
  122. LS1 edit???
  123. Does ecm use oil pressure?
  124. Atap shows 1-2 deg KR near the top of 4th for a very short time.
  125. Any reasoning on why TM would increase..
  126. hypertech problems ecm screwed. HELP!
  127. question about LS1 edit capabilities
  128. Please help, car is ultra rich(long)
  129. Help - Need to Convert From MAFT Settings To LS1Edit
  130. how long did you wait....
  131. Need checklist for ls1edit, first time user!!
  132. Harlen shift light & Atap
  133. How much to pay friend for tuning w/ ls1 edit??
  134. Will this Laptop work with A-Tap/LS1 Edit?
  135. IF YOUR SCAN READ....WHAT WOULD YOU DO?
  136. LS1 Edit
  137. LTFT's 25% & WOT 02's .935
  138. Quick !Cags question...
  139. New to OBD II
  140. Need some MAFT help
  141. Help with some bad knock
  142. LS1 edit and MAFT questions
  143. all those that had lockup probs and used LS1edit, did you...
  144. Help w/ SES code.
  145. as a general rule . . .
  146. My EGR reading is 00, is this right?
  147. sensor questions- cam position sensor?
  148. HPP3 Settings
  149. deleting codes
  150. logging WB O2 info in your PCM
  151. WOT A/F varies depending on what gear I'm in???
  152. Set SES code P0171/P0174 ??
  153. Idle A/F "learns" to 14.2 ??
  154. Which Cells for LTFT Averages?
  155. My IAC # is mid 90s what to do
  156. In the 12's
  157. can KO box or KR desensitizers damage anything?
  158. ls1edit question, how does it learn your vin#
  159. HELP !!!!! LS1 edit and A-Tap problem
  160. Speedo messed up after HPP3 programming.
  161. Reducing knock retard sensitivity??
  162. Which diagnostic/programming tool should I get?
  163. What is the best timing advance numbers for power??
  164. LS1 edit to richen at WOT below 4krpms
  165. Getting LTRIM Averages
  166. KR help question
  167. computer guru's come on in
  168. ATAP/LS1 EDIT- Is a 100MHz laptop fast enough?
  169. newby ltrim help
  170. LS1 edit for 01 is available - Need some tuning advice
  171. maft??
  172. Paging Ryan Karasek
  173. jet chips/modules
  174. Problems with starting the car when engine is hot
  175. Revonator
  176. Cruise Ltrims at +9 / WOT 02's at .906 - Should I adjust base
  177. How much do Ltrims affect HP?
  178. Discussion time...Is it better to tweak MAF flow or Injector flow to get LTRMs to "0"
  179. Is Autotap needed for LS1 Edit?
  180. First day using LS1Edit
  181. What is P0420 TWC System Low Efficiency?
  182. Ed Wright tuning > Do these changes look about right?
  183. Locked PCM's..
  184. Palm & OBD II Scanner.Help-
  185. Getting ready to use LS1 Edit...Need help with shift points.
  186. o2 sensors interchangeable
  187. Time for some custom tuning.... Help me, I'm lost!!!
  188. car wont start, need immediate help
  189. P0440 - Evap System?
  190. Where is the best location for WB o2 sensor
  191. p3027 trouble code help......
  192. Laptop for LS1 Edit and Autotap???
  193. Turbo 400 Swap.SES light on and asr not working need help.
  194. Question 'bout O2 Sensors
  195. Guys, help talk me into or out of LS1 Edit...
  196. Help, Tuning issues
  197. ATAP Reults before using LS1 Edit
  198. How high will hypertech let me raise my speed limiter ?
  199. Just received my LS1 Edit Cables
  200. MSD Window Switch issue/problem
  201. Cure Mild Surge at Idle Via Timing??
  202. Computer Guru's-Can a Stone Age lap top be upgraded?
  203. Where did that one post go about A-tap/Air Fuel Ratio?
  204. Confused about AutoTap numbers
  205. Can we get a list of LS1 Edit items
  206. Fuel Trim Cells...
  207. Weather Dependency on calculated load questions (timing table)
  208. ignorant question before buying LS1-edit.. Is it fairly easy to learn?
  209. Hypertech
  210. Maft, Scanmaster and A/F help...
  211. Paging Ragtop 99...
  212. TCC Threshold in LS1 Edit
  213. Air/Fuel, Scanmaster + MAFT help...
  214. Anyone using an FJO WB Setup
  215. pcm code p0133 slow o2 response
  216. Need some PCM advice - Getting MTI tuning.
  217. Need help for tune the car... Anyone??
  218. Getting a B1 with stock heads.....
  219. Anyone have Stage 2 program???
  220. 1999/A4-shifts by MPH or RPM?
  221. I have a "security" light but they car still starts at all times. Whats up?
  222. Ltrims are jacked up...
  223. What's the current wait on LS1Edit?
  224. MAFT adjusting lean....or too lean?
  225. Jet Ls1 Power Module ?
  226. WB O2 site
  227. GM PASS Key idea...
  228. Help :( I need a Schematic or Diagram for the pathway of the PINK MAF POWER WIRE :(
  229. ATAO MAP sensor voltage high?
  230. LS1 Edit dyno tuners south of Jacksonville, FL
  231. SES Code Help????
  232. Paper Clip
  233. Question about enrichment...
  234. Should I set TQ managment higer or delete it?
  235. Vapor lock?
  236. Sending my pcm out today! Here is my list...have some questions
  237. Can 1.0 knock cause -4 degrees of timing retard?
  238. Best way to tune after header install
  239. Wideband tuning on the dyno with an MAF-T vs. LS1Edit?
  240. Does my timing seem too low to you?
  241. Security light stays on, car wont start
  242. Intermittent DTC code........
  243. ls1 Edit ?
  244. My closed loop A/F is normally 14.7 but goes to 14.2 at idle, does yours?
  245. another code delete question....
  246. ABS and TC lights
  247. My A/F Ratio is 11.5 - 11.6 how do I
  248. Automatic windows
  249. NEED HELP BADLY :( MAFT and NO change to O2's/A/F with 12degrees at WOT :(((
  250. I'm upgrading from A-Tap to EASE ?? Where best to get it?
