- Service Vehicle Light
- Hptuner ?
- high comp. and timing
- check engine light on codes are...need help figuring out why
- False Knock on start up
- What operating system for HP tuners
- New to tuning, questions on setup
- quick M6 to A4 question..
- Knock Sensors?
- Right bank wont fire.HELP NEEDED
- P1153?
- logging shift torque
- FAST XFI Experts COME IN!!!
- what does this code mean
- Would you drive this 200 miles to the tuner?
- does frost offer a discount for a retune?
- anybody know hat the KOEO and KOER tests actually test
- Newb switching to 3-bar SD Tune... questions
- what's best tune Maf or Mafless ?
- LS6 Wire Harness to Coil/injector Plug ?
- WTB HP Tuner Pro and Wideband
- Maf or map tune ?
- Top 5 tuners in dfw??
- 2010 Camaro PCM Swap
- Tuning/wideband placement questions
- Rearend Change
- Transmission shifting 1>2>1>2>1>2 @ WOT
- need some help
- Emissions delete?
- C5 Idle Relearn?
- need some help with DTC's
- PO118 engine coolant temp sensor problem
- Injctor size base tune?
- timing curve, carburator?
- wideband o2 location?
- good tuner in the n.c.-s.c area
- Jeff @ JR racing
- P0300 random miss fire slightly modified 4.8L
- LS3 swap failed smog.
- Please Help. LC-1 through EGR on 01 car...
- Injectors flow rate for 1999 camaro
- PCM Help
- Thanks For Your Time Geoff!
- Street Dyno (Redhardtopsupra's newest blog)
- need stock tune
- Surging Idle. I'm out of ideas and need your help.
- Hpt?
- What extent of tuning do I need?
- ABS Problem
- Fuel pressure accuracy via OBD-II?
- 02 TA How to Adjust Timing Table with HP Tuners
- What frequency is the GM LS1 Knock sensor looking for?
- Any Tuning Schools Around IL?
- Splicing 02 sensors
- EGR P0405 Poor Performance
- Cold start, won't hold steady idle, stalls at stops.
- LC1 and HPTuners
- Best Wide Band Controller to use with HP tuners Pro
- RPM Surging after cam install and tune
- ls1 will not idle, help
- Predator Instruction Manual 5.7 ls1 Z28 unit
- Idle Question
- Wide Band Controller?
- 2002 TA Vats Disable with HP Tuiners??
- Tuning a GTO with Magnacharger using HP Tuners
- SLP tune....just the tune files
- What to Do?
- Quick PCM lock question..
- does anyone have the wiring diagram for the 3 and 5 wire maff
- longterm fuel trim
- Tuning book, Noobie learning
- Who is the best with tuning FAST ecu?
- 02 sensor error codes, fronts same as rear?
- PCM question????
- fuel trim issues where to start? closed loop
- Where to start? Trying to learn EFI.
- 03 LQ4 w/DBW, which ECM?
- Scan tool for evap sensors
- 02 TA Replaced Radio now Vats is stopping car from starting???
- 2009 CTSV started while computer was uploaded and waiting for performance data.
- Swapping in some Ford SVO 30# red top injectors, what changes to make in HP Tuners?
- Need help 98 to 02 PCM swap
- Trigger wheel help (megasquirt install)
- LS3 mated to a T56 using a TBSS OS E67 ECM and Harness
- Hptuner using different hardware on same car?
- DLC Connection Issues
- IFR Table
- Any tuners in Wichita Kansas?
- 100% b2 ltft
- Any tuners in Wa?
- 2006 GTO LS2 ECM wiring questions - what are these things?
- Stroker tune question
- Readiness monitors...HELP.
- v6 to v8 question
- superchips
- How do I change shift points with Diablo
- Sensor Readings
- How do I tell if I bricked my PCM?
- BMW PCM flashing?
- Idling problem
- LS3 MAF Table...
- P0410
- Stumbling issue
- I need a CAN bus expert- Want to run a Lotus Elise dash with LS3 computer
- Having to disconnect injector plugs to start
- P0300 on pretty much Stock 4.8
- TREX tune
- wth is wrong with my car??
- HP Tuners Alabama!!!
- can anyone check an EFIlive tune
- random misfire confusion
- The Tuning School Learn-at-Home Course
- bogging down issue
- got my aldl usb cable, still cant figure out whats up with my car
- 2002 Tahoe electric fan?
- need help with trouble codes on a buddies car!!
- e 85 flex fuel conversion
- i need a engine harness
- car wont start it only cranks...
- Dyno near by
- VVT rev limiter from comp cams
- Passing OBD2 emissions with EVAP code?
- using HPT , bit of bucking
- Help: E85
- Does anybody do HP or dyno tunes in the KC area?
- using available licenses with efilive
- Mechanical Engineering and Tuning
- Anyone have the GL1 OBD-II to iPhone/iTouch cable
- proscan obd link problems please help
- 2010 camaro PE mode?
- Good tuners in OC, CA
- PO171 & PO174 I'm outta ideas
- HPT not downloading
- CalEditor is THE MAN!!!!!!
- Wideband placement
- Fuel cutoff comes on early, but only in second gear
- crate LS3 into 2002 camaro, PCM questions
- Auto Meter Air Fuel Ratio Gauge - Good Choice?
- Need to tune my swap, but no OBDII port how do I go about it
- Help needed in troubleshooting problem
- Will Error P1637 Prevent Car from Starting?
- E40 06 GTO 2.5bar tuning
- Rear O2's Question
- Tune is next on the list, who should I go with?
- most bang for your buck?
- Diablosport and 85mm maf question.
- Can you identify this PCM?
- Reflash and no start up
- 98 pcm and harness
- ls2 ... what sensors will work on my engine?
- got some codes need help figuring out
- Ls1 Edit/Scanner help a noob
- Mass sensor LS7
- 2003 Corvette LS1 PCM questions
- Ls1 Wont start, drove fine yesterday, today cranks but not firing
- 3 bar tune question with 411 pcm
- Previous Tune???? Diablosport??
- 98 to 02 PCM Swap and Keep Traction Control???
- Make '411 E85 capatable for Fbody?
- Help!! Need LS1 Edit Stock tune for 02 M6
- Data Logging - Problem with hardware/software/other?
- Running Rich
- Ls3 pcm
- tune rechecked, still maf code. ecm bad?
- How to Data log 97 OBII
- Tuning after head swap?
- Engine harness for L92 in a 94 TA???
- (VID) Misfire w/o DTC .... **Confused**
- diablo tunner
- DTC 463 and 507 after LT and magnaflow exhaust install
- Help!!!! IM New I Need Help With My PCM
- Idling at 3k RPM
- speedometer help
- P0102, P0121, P0803 Help Please!
- Piston Protection & TVS2300 tune
- ducks in order for tune
- PCM History / Overview website?
- efi emissons stuff
- 98 ls1 help
- Wideband 02 location
- Engine Speed Signal Pin 10
- good tuners
- NEED SUM OBD2 or OBD1 HELP
- NC Fbody owners come on i! Need recommendations.
- Help wiring up LC1
- strange misfire problem
- CMR tuning
- Looking to get a tune ?
- Help! I screwed something up trying to delete A4 DTCs for M6
- LTFT Question
- Car idles higher on startup, please help
- 97-98 ECM and 85mm MAF
- made my own V dash. check it out
- Ported throttle body and tuning
- BS3 and factory tach problem(99 trans am)
- '99 Suburban 5.3L - Code P0404
- need help new to efi
- 2002 ta 408 f1a
- Rob Raymer at AutoMotion, THANKS!
- Do I need a New PCM or one already programmed?
- c5 corvette tuning question
- Tachometer not working on 2000 Camaro
- Best tuning mods for a stock car
- Backfiring help!
- tuning a 98 pcm with edit
- vac leak + maf delete tune = smooth idle??
- Tuning a 93 Z28
- 02 ss ck engine light after headers, pcm reprogram
- 98 to 99+ PCM Question
- VE Table Value Over 100%
- 5 "not ready" codes WTF! cant pass OBD2 inspection
- Innovate Questions
- Best Tuner to disable the misfire code in 2002 TA?
- Ecm tunning for a swap
- Calibrating Autometer Wideband?
- No codes but car stumbles, voltage drops when slowing down
- Keep throwing P0154 and car misses
- Tune only ls2 questions
- misfire issues
- Mail order tune - "Saved data"?
- Diablo fan settings
- 102mm NW Tuning Question?
- Any PID's for determining misfire?
- Would unplugged knock sensors reduce power?
- P0327 Code ?
- Looking for a good tuner
- LC-1 through 02 sensor
- MAF question
- How to wire an LC-1 for portable tuning
- newbie question
- what coils do I have? Which will work best with AEM?
- Best tune for a friend?
- help car wont start dtc codes thrown
- Using fuel trims to do a quick tune
- VVT compatable computers
- Help with Cam position adjustment
- looking for a cam tune for 98 z with a4 efi live
- Need AEM UEGO Serial Cable
- Need tuning advice for a turbo Lt1 impala
- TAQ cables no more?
- PCM/BCM crashed, no start?
- help with p0300 please
- Move to megasquirt?
- E10 AFR different?
- Whats the purpose of PE
- threaded IAT and 3-bar MAP Sensors
- what is the best afr for a stock ls1
- Abit rusty can somebody run down tuning for me
- Auto tap, EFI Live and HP Tuners
- Swap efi live tune to hp tuners.
