- Why does it studder when shifting at low RPM?
- SES and check gauges light wont go off with no codes
- Another tuning question... VE Tables
- 2007 5.3 Silverado speed limiter
- 2005 Chevy Z71 5.3 Something Not right
- Help, Holley HP going 9.0afr on brake.
- Troubleshooting Cooling Fans
- TPS reads 26% and 1.8 volts when closed???
- newb ? about hp tuners
- PCM or opti problem
- IAC motor question
- LTFTs after filling gas tank
- Flashed VCM w/o key in the ignition
- MAF Tune Problem
- Need help!!! Driver side O2 keep adding fuel for unknown reason....
- experienced tuners need to hire for help on Torquer V2 issue
- Tuning issues...L Trim and S Trim
- Retune?
- cartridge maf & IAT
- Does anyone have a VE table for a 427 with a fairly large cam that they could share?
- Just pulled the trigger on hpt pro!
- do i need a tune from ls1 to a 6.0
- Looking for a good tuner in the STL area
- Just got a used Hp Tuner Pro what to do?
- wire harness ?
- P0300 code but car runs fine
- Anyone have a diagram of what wire goes to what on a 98 harness
- TSP 224 CAM VE values at idle strange
- E85 Help
- Video: What type of rev limiter is this?
- stalling trying to idle
- Need to richen my SD tune (EFI live)
- My brand new Innovate Wide band Inop.
- IAC screw pic?
- 4.8 dbw to dbc
- can some one look at my tune please? ls3 top end 408 with ls3 injectors
- Big thank you to Steve Williams at Frost.
- 383 LT1 TunerPro Datalogs...PLEASE HELP!!!
- Can I run a wideband instead of a front o2 sensor?
- low rpm/ light throttle surging
- HELP: A/F dropping to 7.4?
- need a tuner
- PCM Placement
- Quick question on hc tuned ls1
- tuning and ls1 work
- Trick Flow 515 kit/Random Misfire
- Need help understanding a STFT problem!
- Will I be ok with out a re-tune
- issues with tune
- HyperTech Max Energy Tuner
- holly EFI anyone running
- can't find an IFR converter.
- Help with custom tune
- Dtc p0118
- kc metro tuning
- im getting ready to tune my car
- Tune Going Lean - Out of The Blue???
- 1998 a4 to 1999ss m6 complete swap questions
- Advice requested please.
- Do you think my tune is off?
- 98 PCM Bad?
- Can HPtuners be used with an Ipad to tune a car?
- What are the dangers of tuning your own vehicle?
- Tuners or people who live in altitude come in
- How to tune for 5.3L + T56
- Need a tuner in Mpls/StPaul Area
- hp tuners to diablosport question
- Plug change now flashing ses
- edcmat-l1 tuning in Chicago 8/28-29
- 0bd2 to usb cable
- Help with a green wire to the MAP ?
- What Wideband Do You Use/Recommend?
- Truck randomly shuts off/afr bouncing around all while cruising.
- Holley hp efi spark modifiers
- Lean Spikes
- Cutting off at 110!?
- hp tuner mpv1?
- 94 Formula A4 Question
- Wiring up a "tow haul" switch and using it as a drop gear button..
- Do I need to find another tuner??
- corrected dyno # = crank hp???
- Diablosport Trinity
- Help with Innovate LC1: Error 8
- P0102 fault sensor
- ASR light on
- need good tuner in Southeast for speed density...
- Master Engine Tuner Magazine update
- need info on FAST XIM setup
- Dead PCM?? Help please!!!
- can low voltage cause TPS codes? P0121
- p2138/p1516 help. Bad pcm? Update
- shift points with power programmer???
- idle issues, no codes, would like some help
- Z71 bog.
- adjust idle or retune?
- Check out my vid, weird idle issue
- tune in tulsa oklahoma needed....
- Megasquirt ?
- data for DEKA/Siemens 60 lb injectors?
- 98 PCMs
- Tuning bigger injectors
- PO704 Low Input Clutch Switch Error
- tach not working
- ls1 stand alone harness - help me identify the oxygen sensor connector, harness side
- HP Tuners.....Tired of the rip off.
- Removed EGR and AIR
- need some help guys. multiple codes.
- Las Vegas Tuners
- Efi live help
- oveheats in 3bar tune but not in 1 bar?
- HPTuners/LS3 injector swap runs VERY lean
- P0336 help
- Installing a New Holley Dominater, Few ?'s about the BCM
- Anyone in Long Island, NY w EFI or TunerCat ?
- codes:p0103,p0412,p0418 help
- Question about injector wiring...
- Throwing Codes
- Who to tune my 6.0 s10?
- LS2 won't start after Battery replaced reset vats to off?
- Overheating--poor (rich) tune?
- About to get Frosted
- preset tunes and switch in between them
- Truck is giving me hell!!!!
- Looking for a "basic" scanner
- Knock sensor question?
- Critique my 1st logs from VE/MAF Tuning
- My chuck cow experience.
- 04 GTO taction control / Skipping
- Where Can I buy Efi Live Tunes for my 2000 Z28
- Just found out I have a 94-95 PCM in my 97 z28.. help
- LM1 hookup
- Negative voltage at knock sensor wtf, is this correct?
- HELP - No cam signal -
- Need help with speedo settings
- LS1 running very rich after street tune
- need complete system of coil packs and how the ECU fires them
- occasional high idle
- TC or tune
- iac setting on hp tuner
- aps tuning okc???
- Help!!!!!!
- best tuner in Colorado?
- Tuning issues...
- Need help - Knock sensor, retard, recorded w/ Livedata
- PCM Needed for LS2 Drive By Cable Conversion??
- How much timing at freeway cruise speeds
- ignition problem
- How long does it take to veiw after posting a tune in HP Tuners bin file Repository
- egr ground wire has voltage ?
- Any Tuners in Arkansas?
- looking for a hp tuner for 98 ws6..does anyone make one?
- the tuning school advanced books
- 97 lt1 with vortec distributor and 0411 pcm WILL NOT START
- p0200 code help
- how long to wait after getting a tune and going to track to test car
- holley efi injector tuning question
- p0353 cyl 3 no fuel or spark
- Anyone have a copy of Pantera EFI Software?
- What to adjust for bracket racing
- tuning
- LT none EGR headers flash or chip?
- p0135 and p0300 stumped
- No response from knock sensor
- good hp tuner in okc area
- Looking for TSP Tune?
- 93lt1 383 tuning help needed..
- Unplugging purge solenoid for tuning.
- Fuel pump 12V circuit partial short to 5V - 99 Trans Am
- DBW pedaling not working
- HP tuners - do you need credits to read and log a PCM?
- PCM Communication Failure/ VATS problem
- problems tunning FIC 114# injectors, ready to give up.
- Tuning in Southern California!!! Ready now.
- tech2 clone
- IAT Sensor Placment In A CAI
- What can or can't be tuned?
- looking for some advice on my setup
- Aftermarket harness options
- looking for a 98 to 99+ pcm re-pin diagram
- 2013 GM Gas support now available!
- Holley Dominator Harness Question. Help Needed ASAP!
- mail order question??
- Wiring harness
- dbw pedal question
- need tuning help asap :(
- False knock? And your opinion on how I'm doing so far.
- E67 Pinout; Anyone Have One?
- Knock Issue - 10* upon entering PE (LS7 swap)
- Need a Tune in California
- Tuner in KC? First tune.
- crank relearn ? / bad coil drivers ?
- Someone to tune?
- some tips for me to start tuning
- Push button start corvette
- tons of problems with hptuners and first startup. help!
- what should may air fuel ratio be
- who to get a tune from in MI for 24x conversion
- Still dead at key
- Newb with question about tuning
- any tuners around lewisville texas
- 5.3 swap feels weird
- Frost is a fraud to some
- I think I toasted my MAF
- Dead at the key
- car runs hot,like 208 to 210??is that normal?
- scanner powers up but cant communicate with pcm??
- Does anyone know of a how to to repin my 98 harness for 99up ecm??
- any tune experts that can help me?
- idle issue...
- Sanity Check Please
- 1600+ HP Vette using the stock pcm + HPTuners
- CHanges required to go from a 2001 5.3L to a 2009 5.3L
- tuner chip for 2000 camaro
- Need a good tuner near midland tx
- Can I use T56 on a PCM that came out of a A4?
- OBDII to OBDI question
- p0332
- have a chance to buy a 6.2 out of an escalade. couple questions
- 98 z28 tune egr and detonation ?
- Self Learning Systems
- Pcm
- GEN3 Vs. GEN 4 PCM's, am I missing anything
- LS3 C5 Vette in LIMP, after a small repair. WTF!?
- need someone with hp tuners in fla
- Racepak with stock computer
- cant find a tuner for a 98 ws6
- Slight misfire/hesitation at idle after ls1 swapout
- Aeroforce Interceptor wiring
- Altitude re-tune?
- trans help
- need a tuner in the Fresno Ca area
- Hitting Wall At 5000 RPM
- What Truck PCM To Use?
- MAF and O2 issues?
- C5 Z06 vs C5 Vette program?
- vette tuning. tb issue?
- Dyno tuner Oklahoma area?
- Tuning VE on HOT days?
- newbie to tuning
- Pcm question
- Wideband analog equation help?
- What is the real difference in these systems?
- Car wont idle after being stored
- wideband sensor question
- Flashing Check Engine Light
- Bad ecu???
- Howdy :)
- Wideband stopped working. Help Please
- Traction control
