PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 [166] 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Need a stock *.bin for a '02 M6 F-bod
  2. the Z is killing me
  3. At my wits end w/ lean Codes 171 & 174
  4. RPM Drops...fuel...temp...lights! HELP
  5. Reduced Engine Power Warning
  6. i need to get dyno tuned in Oklahoma area
  7. Some Tuning questions
  8. ECT vs. MAP question tuning experts inside
  9. Couple questions about Edit, please help guys.
  10. What is Code P0120
  11. how does c5 ecm determine KR and amount of timing
  12. Problem with car starting after h/c
  13. OMG I almost busted a nut
  14. DTC P1631 -- how to fix?
  15. Rough Ride after cam install and tuning
  16. rwhp HELP
  17. newbie to tuning, need help
  18. hptuners wot help
  19. Is it BAD to disconnect the Computer while the Battery is still connected?
  20. Anyone know a good site for wiring diagrams?
  21. Car "resets" while driving?
  22. Question for those who tune your own cars.
  23. Upgrading Injectors some questions
  24. need help!!!!! tuning isnt right........
  25. Cags as a window/TPS switch for N20?
  26. timing advance/retard
  27. Need help with figuring out these code problems.
  28. A/F is off
  29. Running lean on the dyno(dyno graph inside)
  30. Error p0366 please help
  31. studder off the line after car is warmed up
  32. LS1Edit getting deeper into set up.
  33. Post your tips on eliminating cam surge here!
  34. Please look at these timing historograms and give opinions
  35. CAGS used for NO MORE MISSED 3-2 shifts?
  36. hypertech broken or not?
  37. LTFT discovery
  38. What happens w/ Locked PCM
  39. Loss of air conditioning after tune?
  40. Crank position sensor relearn
  41. chips/programmers
  42. CAGS pin outs
  43. MAP reading 25 @ WOT?
  44. Predator tuning help. What temp to set cooling fans with 160 degree T-stat?
  45. tuning experts
  46. How do I reset a code?
  47. PCM swap, what are the issues?
  48. Stupid question....can wheel hop/driveline shock cause knock retard...
  49. New to GM PCM's a simple ? or not
  50. Has anybody (including professionals) eliminated cam surge? Is it just a dream?
  51. Pic of Cam Trigger Please
  52. slp speedo recal
  53. Idle good but car runs by itself after tune
  54. School for learning how to tune EFI??
  55. Anyone using FAST standalone transmission controller?
  56. Pulled Codes
  57. LT1 Tuning
  58. Error code #1153
  59. Had codes pulled
  60. Innovative LM-1 Wide band, in order to read rpm must i buy adapter?
  61. Attention - "!EGR" is a BAD thing!
  62. tuning 230+ cams on a4's?
  63. Help! Engine misfiring. Running out of things to change
  64. Odd Error codes, suspect battery / charging system
  65. Dash lit up like a birthday cake...
  66. Trying to defeat knock...log inside...
  67. Changed air filters...LTFTs went up ~8%?
  68. WTF SES comes on a month after torque converter install
  69. Car wont go past 2500rpm, LS1 Edit?
  70. How Much Tuning Will A Z06 Camw/ 1.85 Rockers Need
  71. I Need Help!!!!
  72. PCM is not giving command to shift to OD
  73. Ls1 Gurus I need some help
  74. HELP: Is there a direct plug in for the LS1 FAST or DFI or anything
  75. Need help...Code P0171
  76. Maxed out my MAF
  77. 160 Degree Ther.
  78. Paging Ryan Karasek regarding your Gen7 Standalone
  79. PE table and IFR question
  80. 85mm MAF and Tuning
  81. HP tuners rocks
  82. Throwing same codes
  83. Can VE adjustments make you lean after LTRIMS adjust?
  84. Hopefully last time: LTFT
  85. added 2 degrees to high octane timing table, no KR, but no ET or mph gain. TYPICAL?
  86. 28lb injectors on a 36lb injector tune????
  87. Would any LS1 EDIT Experts mind if I give them a Call to answer some ??
  88. fired up for first time and i have a rough idle
  89. tuning on my own... good idea?
  90. P1133, P1153
  91. Predator tuning....let's see if I am understanding this right...
  92. Black smoke at WOT
  93. CPS Code
  94. P0401 code
  95. SES light activated after tuning
  96. Diablo tuning help!
  97. alright guys got some codes.
  98. Tuner for LT1
  99. question about Strims/Ltrims
  100. any problems moothing timing tables on c5?
  101. check engine light
  102. trouble codes
  103. Code 1626 after column lock fix at dealer
  104. base shift pressure vs torque table?
  105. Ohio Tuners!!!
  106. What is wrong with my idle
  107. ses code
  108. predator tuning
  109. Have EFILiveV6 and HP Tuners, whats the next step?
  110. 90mmLSX and TPIS TB tuning
  111. Tuning questions. inside tuning magicians..
  112. 99 pcm on a 01 motor
  113. SES light - it's baaaaaack
  114. Small problem with cold starting
  115. Big Stuff 3
  116. Question about tune with header's?
  117. maf table ?
  118. FAST crank decoder box is available
  119. calculated load?
  120. tuning questions
  121. tuning problem?
  122. anyone have tune for a 224/228 cam?
  123. Throwing codes
  124. Need alot of help!!
  125. Ready to Tune: What All Do I Need?
  126. errors 133 and 153
  127. SES after replacing o2 sensors, help!
  128. Counting The Cost:
  129. Idle problem, H/C Corvettes
  130. need help with injector scaleing
  131. Dumb dyno question
  132. Were Can I Get A Tune
  133. Don't waste you time on ImportTuners Magazine Wideband O2 shootout article
  134. FTC boundaries wtf?
  135. Removing AIR and EGR
  136. Innovative wideband...feedback?
  137. Unplugging front 02 sensors...open loop?
  138. Are there any HPTuners in Los Angeles / San Gabriel?
  139. Shift Points
  140. do you guys think i should modify my VE table? info w/in
  141. dummy needs help getting 98 to idle
  142. Reset LTRIMS...will it knock until trims are re-learned?
  143. IAC counts always 0? Idle issues after heads/cam
  144. Is HPTuners shiping schedule accurate
  145. throttle tip in
  146. Innovative wideband users: Does the inductive rpm pickup work?
  147. LTFT Boundaries...anybody changing them?
  148. P1136
  149. Still having problem W/ EFILive cutting out on GTO
  150. Hptuners on the way
  151. What map value denote
  152. LTFT's +20
  153. Will this cam work on stock tunning?
  154. Idle Problems...Help!
  155. Calculated VE table...is it enough to smooth?
  156. O2 sensor question...
  157. Mat's VE Tools (Spreadsheets Inside!)
  158. Vibrating driveshaft cause a false misfire?
  159. VE Table
  160. Allow TCC lock during shift.
  161. Where is my Tune??!
  162. map to enable pe
  163. Dry shot tuning, running rich.
  164. Removed jet chip and car is running like CRAP..HELP!
  165. P0420/P0430 Codes...Fuel issue?
  166. Ls1 Safe Mode??
  167. Losing RWHP/RWTQ REALLY need help bad!!!!
  168. LEAN on dyno RICH on street
  169. Air fuel Ratio
  170. 03' GMC YUKON & PREDATOR TUNER
  171. Problems with air inlet temp sensor
  172. Ugh...trying to populate a VE table from HPTuner logs...
  173. Oxygen Sensor
  174. HPTuners is.............
  175. Since h/c, car idles like crap and now a code
  176. Code P0404 P1404 rough idle
  177. Need Help Asap
  178. Stock File
  179. Just about given up on my 231/237
  180. TCS light after Predator and gear swap
  181. accel gen7 global cal file share
  182. Emissions
  183. NoGo...is there any way to apply the VE formula using HPTuners?
  184. Air fuel killin me, Help.........
  185. Any pointers on how to set up my predator tune
  186. Tried NoGo's VE tuning, have some questions
  187. How do you obtain a particular timing number?
  188. Studder after Edit tune
  189. What A/F Ratio has been the sweet spot?
  190. g5x2 and bolt-on tune
  191. help with idle please i think i'm lean
  192. Help!
  193. Denso 02 part number?
  194. clearing codes
  195. best hand held tuner
  196. HP tuner or ls1 edit?
  197. LTrims and a supercharger
  198. My 99 HPtuners for my ws6 work on a Z28??
  199. Newbie tuning questions
  200. Idle Tuning Posative LTrims (MAF or VE)
  201. Question regarding scanmaster.
  202. turning off the SES light....how?
  203. Timing retard problem, Help.
  204. Mail order tuning the G5X3?
  205. How hard is it to mount crank trigger on ATI superdampner pulley?
  206. Any news on the FAST crank box yet? Release date?
  207. Heads going on....Will it change tune?
  208. Can someone make heads or tails of this for me. (408 Stroker ATAP files)
  209. random lean spike
  210. Almost Sticky Worthy GM EFI Website
  211. Is there anything special the dealer (PCM question)
  212. PE tuning Question.
  213. P0200 and some troubleshooting, comments please.
  214. Need to lean out car a bit
  215. Dealer cant reflash my PCM
  216. Getting started with LT1 Edit
  217. !VSS for a conversion
  218. HP Tuners & WIN 95
  219. More Accel Gen 7 Questions
  220. Need Help w/Engine Tune - HPTuners
  221. What kind of 02's are you lt/cam cars using?
  222. who's using a power invertor to power laptop?
  223. Predator Programming for LTs and ORY
  224. PISSED OFF!! help please.
  225. Opinions on my test VE table..inside
  226. HPTuner questions
  227. Yet again.. which tuner
  228. Tech guys, most common knock retard causes??
  229. service engine code po430
  230. LS1Edit guys help me
  231. quick neutral question
  232. Any GP's or vendor discounts for HPTuners VCM Suite?
  233. SES light came on PO300
  234. Tsp 231/237 Mail Order Tune?
  235. Problems with P0410
  236. I may have to break down and buy hptuners
  237. OBDII diagnostic/datalogging?
  238. Hmmm,restrictive exhaust causes screwie Ltrims.
  239. am I missing anything?
  240. Misses, surges, highway speed since lt's and Y
  241. advice on lt fuel
  242. Does 30k miles = SES light?
  243. HELP! SES transmission code - what caused it?
  244. can i send my PCM to someone to get tuned?
  245. Compatibility with non-Gen III TPS/IAC w/ Gen III PCM??
  246. Cam and Crank Triggers
  247. HELP ME BREAK 12s !!!
  248. Any pre-dyno tips?
  249. VE tuning after cam swapping...does anybody change the low-vacuum parts?
  250. LTFTs W/LGs installed. Guru advice?
