PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. build near complete - do I need a dyno tune or is a street tune adequate?
  2. Tuners in Kansas, Missouri, and Oklahoma?
  3. Starter tune for a cam install?
  4. Tuners in Oklahoma or Dallas
  5. HELP procharged car no timing log file inside
  6. trex-carb-single plane- timing?
  7. retune when you move a car to a different state?
  8. Diablosport ?
  9. Hptuners bin question
  10. Tuning gurus....have a question
  11. Deleting BCM help on a 96 firebird please.
  12. ECM not communicating with Trans Controller
  13. limitations of my 98 pcm and a few questions
  14. Custom fuel guage calibration?
  15. frost tune questions?
  16. Dyno operator's comment has me puzzled.
  17. IAT Sensor required for Speed Density?
  18. ls1 to ls2 knock sensors
  19. Difference in pcms from 98-02
  20. Time drops on launch and shifts...help
  21. Please HELP!! No Start, No Gauges, No Fuel Prime!
  22. ASR turning off when A/C on?
  23. Getting weird random knock after tune
  24. ODBII How to connect? Serial Data Wire?
  25. Ls2 90mm throttle body questions
  26. Log from 8/21 - Might be lean.
  27. Good wideband kit for a 4th gen ?
  28. 2-3 shift/dropping fuel problem? Please help!
  29. Swapping PCM's??
  30. Wiring issue, possibly bad bcm
  31. EGR sensor?
  32. tach signal
  33. Low Gear Stumble/Lean Problem
  34. Mods to E40 PCM for swap
  35. recently changed plugs & wires now getting code
  36. ODBII Wiring
  37. Why are my STIT's staying at zero?
  38. Going from DBW to cable TB question
  39. PCM Case Needs to be Grounded? WTF?
  40. Need help??? Pulled crankshaft sensor connector off wires...
  41. Ignition/accessory wiring problem
  42. What's this mean and is it bad?
  43. Why does my car keep dying at idle?
  44. Tune Question!
  45. ls1 frankenstein help!!
  46. Trouble with PCM
  47. Handheld tuner and a already set dyno tune...?
  48. Got CEL after A/F Gauge install....Help
  49. H/C/I 98 Z won't idle/ surges
  50. Help wanted!
  51. High LTFT
  52. looking at buying a car maybe a tune problem
  53. lc1 ?
  54. will a handheld tuner solve my problem?
  55. finally got tune after 92 fast install
  56. Help OBD-2 port is not working....
  57. 2011 Camaro SS Support is ready!
  58. 2002 tach signal wire
  59. Would like to learn how to tune.
  60. Inconsistent tune?
  61. green top 42lb inj table needed
  62. how to tune a MAF car????
  63. O2B1S1 stuck in 0.44 - 0.46 range
  64. Wiring diagram/circuit board diagram TCS Switch?
  65. Bad ecu
  66. po327, knock sensor low circuit signal, won't go away
  67. questions regarding vats and bcm.
  68. Getting MAF HZ to come up in histograms
  69. Anyone using the Innovative OT-2/I-Phone App?
  70. Bought new camaro, need some help!!
  71. Running without a MAF
  72. p0133 and p0153
  73. Help, Injector bank 1 showing no activity.
  74. need pinouts gm 19166569 ecu
  75. new be ve tuning question
  76. Idle surging problems, RAF/VE/Spark dialed in
  77. problems passing inspection with 2005 gto
  78. Dyno tuning and wheel hop
  79. Q. security light..
  80. E38 PCM issues.. Showing false speed!
  81. DBW harness into drive by cable?
  82. Oxygen sensor questions
  83. Malfunction Indicator Light....
  84. Car starts and dies now after battery drained dead...
  85. Trans. tuning Question
  86. speed density or dyno tuned?
  87. WTF!!! lost .5 sec. off my ET after upgrades.
  88. OLFA table stock or 1.00 with WB tuning
  89. Good street dyno tune
  90. Thoughts on wideband location??
  91. O2 voltage reading??
  92. Any tuners in the Asheville, NC area?
  93. Wideband is 13.2 wot is that to lean for LS3?
  94. Vortec 4.8 & 5.3 to T56...what about my PCM?
  95. HP Tuners SD tune on future boosted motor
  96. Should I get err tuned?
  97. idle dip
  98. Looking for tune in Midwest
  99. fan settings?
  100. How long does tuning take?
  101. Help with passlock 2007 GMC van 4.8L V8
  102. idle tunning timing
  103. help car keeps dying the heat
  104. So how exactly do our knock sensors work? Im brainstorming here...
  105. anyone have a copy of there tune with a XR281HR 112 LSA
  106. Dyno Tuners in Ohio
  107. trouble deciding...
  108. air bag light, odometer rest
  109. Control Circuit Cylinder #6?
  110. installed '04+ pcv system.....retune necessary?
  111. Diablosport tuner to tune out rear o2 sensors?
  112. VE Tuning Help
  113. Can something in the pcm cause 1 cylinder to run different than the others?
  114. my cam only car dont have street manners ...
  115. How much timing does traction control pull?
  116. Ls2 Turnkey, odd behaviour at idle
  117. toyota swap help
  118. Questions regarding using a different PCM then OEM.
  119. Help..I have a 95 LT1 with a D1SC need tuning help
  120. Can't get all parameters to show(hptuners)
  121. 01' Camaro Engine/pcm in 98' Trans Am
  122. ProCharger Ls1
  123. Idle with A/C Problem
  124. pcm pin for map sensor
  125. IAC Issue
  126. PCM will not connect to HPT
  127. back o2's what do they do and will this fix my problem
  128. First day out, now I have a P0336 Crankshaft Position Sensor code...
  129. Tune Necessary ?
  130. O2 parameters
  131. Online tuning classes???
  132. G-Force Chip?
  133. Lc1 just stays lit when powered up
  134. could this be limp mode?
  135. efi live help pleaseee
  136. LY6 No start no injector pulse
  137. IAC Signal
  138. o2 plug ripped off, need help with which wire goes to which
  139. Jumps to security mode for no reason
  140. what causes . . .
  141. First logged test drive, LOST about config setup HELP !! LOL !!!
  142. Bank 1 & 2 O2's Side Specific
  143. Will TCC Duty Cycle make car gain speed?
  144. P102 code help. Keeps blowing ENG SEN fuse
  145. IAC Trouble
  146. need advice for 402 drivability
  147. Conditions for "ABS INOP" & "TCS OFF" & "BRAKE" warning lights?
  148. Multi cylinder missfire and insuficient switching on both O2s
  149. startup/idle tuning after cam
  150. break in before tune?
  151. IAT Readings "Hot" Normal???
  152. Ls9 tuners please step in
  153. Where can I buy new oxygen sensors?
  154. Drivers side o2 going nuts.
  155. Need a base tune to start tuning from-01 z28
  156. no maf hertz reading on a 2002 gen3 truck computer?
  157. No crank and security light is flashing, help please!!!
  158. any one with window and radio problems cutting off please read
  159. IAT issues?!?
  160. EFI live then HPTuners, same ECM, possible?
  161. Bad crank or cam sensor?
  162. sd tune on a 98 firebird
  163. 98 Engine and 6 speed in a 69 Camaro.
  164. cam swap and using efi live but im lost
  165. GMPP E-Rod LS3 Tuning
  166. Mike Norris Rocks !
  167. u1016 loss of comunication with VCM !!!!
  168. HP tuner credit/license question
  169. Tuning Columbus Ohio
  170. Alternator Wiring
  171. HPT 1.0 help
  172. need help, looked for everything, plz help
  173. LQ4 in G-Body Swap keeps stalling
  174. Possible MAF problems...
  175. Bucking and crappy MPG.
  176. Gauges not working, car doesnt start!
  177. Should I Have The Error Code P1153 Shut Off?
  178. help with a wierd lean spot (log inside)
  179. 4L60E won't shift 1-2 at WOT
  180. HELP!!!Everything works, except speedo after engine swap.
  181. WIll anything read airbag codes?
  182. Datalog software for 96 obd II?
  183. BS3--initial startup (or lack thereof)
  184. 1000rwhp with mas air
  185. Standalone Harness problems
  186. Tune LS1 pcm for LS2 knock sensor setup
  187. P1416 code...replaced one side?
  188. injector bank issue
  189. Another knock sensor thread
  190. L98 conversion, won't run. ?? Checked all
  191. 98 Ls1 fireing order? was it different?
  192. hello help
  193. Help
  194. please help with a tune to get my car running
  195. serial data, which wire???
  196. how do i know if my firebird has a tune on it!!
  197. Very Happy! (TunebyFrost)
  198. hptuner start up bin
  199. Hooking Up 3 Bar MAP Sensor
  200. knock retard
  201. ever since i did my swap i get this
  202. any difference in the LS PCMs for camaro?
  203. Looking for a tuner (BS3) "Houston area"
  204. Base G8 GXP(LS3) w/ Cam Tune
  205. Desperately need E38 TCM wiring Help!
  206. Help with VE Tuning Please!!!
  207. Hp tuners 80lb injectors rich idle....Idea's?
  208. Oil change light? Oil's new
  209. bs3 going from gas to meth?
  210. cruise control
  211. codes after motor swap.
  212. DTC 410 and 412
  213. problems after dyno tune
  214. Help what power inverter do i need for a laptop with no batterie? sine wave question
  215. d585 spark dwell time
  216. LM7 swap... what needs to happen to make it run...
  217. Couple issues, can someone look at my log?
  218. What Fuel Pump and reg. for Boost
  219. Boost controller
  220. Another LC-1 to hpt question
  221. O2 sensor question Speed Density
  222. drive by wire 2000 5.3
  223. Chicago Area Tuner Search
  224. Help with my Tune, check out the logs
  225. Cam Position Sensor
  226. 99 truck to 99 vette ecu?
  227. No Spark
  228. New Alternator Charge System Fault
  229. 2003 LS-1 STock Vet- Tuner
  230. how to get service engine soon light out?
  231. HP tuner license question
  232. Fan wiring
  233. question about tuning wot at track or street?
  234. need help adjusting my idle (dbw)
  235. No power to OBD Port and fuse is fine
  236. ECM or Boost controller
  237. Want to buy HPtuners
  238. PCM wont send sigal to Alt.
  239. Digital or Analog - Tach Output
  240. LTFT & Possible Fuel Pump Issues
  241. 98 PCM update to 2001 PCM
  242. ? wiring vss to abs sensor
  243. tune in missouri
  244. Another speedometer question
  245. Help Me Please!!!!!!!
  246. Oxygen sonsor question
  247. tps problem
  248. Help!
  249. OLSD, CLSD, CLOSED, OPEN, MAF???? a good read
  250. LC-1 not working
