PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. tcs light and throttle pedal
  2. Looking for HP Tuners software
  3. Hp tuners?
  4. Another tuner thread :O
  5. Tunning for Z06 MAF
  6. IAT question (ditch the intercooler or no)
  7. lq4 swap into 94 z28 won't idle
  8. High idle
  9. Ls2 SD tune help - VE overshooting
  10. voltage tuning?
  11. Log of 2nd Gear Pull with DiabloSport Tune C5 Z06
  12. Mail order tune
  13. lambda help
  14. Tuner in Montgomery area
  15. Scan tool???
  16. High idle rpm help.....
  17. ls6 with 4l60e tranny swap
  18. Question: Which ECM for swap
  19. How to pick used PCM for my 99 Camaro LS1 6MT?
  20. Trouble code help??
  21. Engine themostat temp choices
  22. Some help before purchasing the Holley Dominator EFI for the LS1
  23. E38 spark tables
  24. P59 PCM and 4L60E to 4L80E swap
  25. Someone want to share their timing map?
  26. HP EFI Idling issue and hesitation/ death with throttle
  27. low rpm ve help please
  28. low and high octane timing tables
  29. Diagnostic Reading Help
  30. How to change fuel/air with hptuner
  31. what to change in tuning to add tps and iac?
  32. TCM Question
  33. When to switch to a aftermarket ECU?
  34. spark advance question !! help !!
  35. electrical problems!
  36. Knock sensor settings 2005 vs 2007
  37. Is re-pinning needed on '01 harness and tune on an '03 pcm?
  38. No rpm in HPT scanner
  39. alternator help
  40. setting up wide band with hpt pro
  41. trouble finding tables
  42. tps voltage
  43. This is why Holley ECU is better than Stock PCM
  44. Any benefit from switching from 2000 ECU to a 2002?
  45. Superchip Flashpaq = amazing gains, but runs rich
  46. No power during wide open throttle ***help help help***
  47. IAT Sensor repair
  48. A/F and reading it properly.
  49. tunung out AFM!!!
  50. formula dies after car warms up.
  51. hp tuners writing calibration failed, need help
  52. Won't idle after battery disconnect/reconnect
  53. Two of everything. What do I need to controll it all?
  54. Having problems please help
  55. weird ve numbers
  56. Tuning Newb with a few questions..5.3 swap
  57. misfires....#5 & #8 clues?
  58. Good Tuners in Phoenix, AZ
  59. HP Tuners website down?
  60. 6.0 turbo bin file
  61. rear 02 sensor on a 2000 ls1 camaro problem
  62. Knock Sensor Level vs RPM vs Cyl
  63. how to switch from E85 to 114 questions.
  64. is PCM year specific to the Harness pinout?
  65. Why is my Idle still lean? AEM WB
  66. 2 codes pop up have no clue??
  67. Noob with basic HP Tuners Question
  68. P0137 help, what's real cause?
  69. LS2 TB upgrade on Maggied LS6 probs
  70. Is 2001 v6 body harness the same as v8?
  71. new to tuning, have hptuners, and 0101 code
  72. security light stays on
  73. After Headers, Runs Like Crap
  74. cam sensor pigtail
  75. Gen 4 HP Tuners (stock tune)
  76. PCM Bricked?constant, ign,and ground?
  77. Pcm swap. Will my miles and vats still function?
  78. Closed/Open Loop and PE Tuning
  79. LY6 no fuel no spark. Need Help!!!
  80. Need help. I have hp tuners
  81. Just logged on to HP tuners for the first time, pretty cool stuff!
  82. HP tuner advice needed
  83. Can a tune cause lean codes???
  84. 4l60 swap to 4l80 is there anything different about tuning
  85. Tuning spark advance?
  86. C6 2005 LS2 Stock KR @ WOT now
  87. 98 camaro SS electrical issue
  88. If you're a mechanic, this MAY be easy for you, quick question..
  89. 2000 5.3 silverado issue.
  90. holley hp with stock computer?
  91. Thinking of installing a 2bar map sensor to datalog boost in HPTUNERS, will thiswork?
  92. Speed Density tune......should I do it....?
  93. Performance tuner for lacrosse super help!
  94. E38 PCM Tuning Help
  95. E38 Tuning Help
  96. Both O2 Sensors Stopped Working?
  97. Adding 3bar MAP to 0411pcm with HP tuners
  98. Stock 05 Vette tune AC disable
  99. Ecu repair
  100. Torquer v2 tune help?
  101. Hp Tuners
  102. Look over my tune?
  103. new hptuners with a few questions
  104. Help Wiring gear selector switch into PCM
  105. obd2 wire yellow or green
  106. Can someone look at my datalog of idle?
  107. Best 42LB Injectors for Driveability/ Easiest to Tune?
  108. p0161 after new o2 sensors?
  109. Injector scaling doesn’t match up?
  110. LT1 to LS1 Swap - Ignition Fuse
  111. o2 switching without trims?
  112. Should I learn to tune my own car or should I pay to have it tuned?
  113. e38 fuel line pressure sesning pinout
  114. 2014 Chevy SS tuning question.............
  115. change timing for higher CR?
  116. just want to make sure I read this correct
  117. no spark
  118. tune for 42lb injectors 92mm fast setup.
  119. Anyone else get bad results w/ idle scan?
  120. Holley HP vs FAST EZ 2.0
  121. Updating 1999 Silverado to newer OS using EFI Live?
  122. LS1 Turbo Tuning Troubles...
  123. Help hp tuners pro,pid help
  124. hp tuner guys
  125. Motec m130 ecu on turbo bike.
  126. No shift
  127. Please explain
  128. 95 camaro 5.3 swap questions.
  129. stock lq9 tune with cable throttle body
  130. versa fueler help
  131. backfire issues under normal driving
  132. How do you hold 3rd gear
  133. GN IAT sensor help.
  134. Need help with Hp tuner scan (unable to create log)
  135. Hot start issue after short cooldown
  136. HELP- '00 SS Bolt Ons & Diablo Predator U7198
  137. Help finding race car body harness
  138. Intermittent idle drop and occasional stall in traffic e.t.c.
  139. Local or mail order?
  140. Won't start or idle
  141. knock sensors out of service to test
  142. elm327 bluetooth scan help!
  143. good mail order base tuner
  144. Looking for HotCam .bin file for HP Tuners
  145. Low RPM wot stumbling
  146. Rev limiters and shift light
  147. tuners in the Utah, Idaho area??? twin turbo TA
  148. Tuners in Phoenix or Havasu?
  149. Newb EFI Live tuning question
  150. CEL light No Worky
  151. Ls1 no closed loop
  152. No vss signal to speedo or solus scanner
  153. PCM difference
  154. LAMBDA help
  155. new to tuning - buying used handheld? mail order tunes?
  156. Idle overspeed and "lumpy" idle
  157. No crank and no OBD data
  158. Injector Help
  159. Main Spark Advance ?
  160. tranny tune issues need some insight.
  161. Need advice: electronic management system
  162. need help with tune!!
  163. olsd tuning maxed ve table
  164. ???tuning guide????
  165. CA Smog issue with custom tune
  166. s10 harness
  167. Whats the magic "turn on" voltage for alternator
  168. 2 1/16" Multi-Gauge?
  169. timing retard on 408
  170. Hp tuners tuning?
  171. Car has a hard time running after sitting, but runs perfect if reflashed.
  172. e38 pcm vvt and dbc
  173. #1 injector troubles
  174. Copying to secondary ve table
  175. Ls1 or vortec ecm cleaning or painting.
  176. Stupid question. How do I post my tune?
  177. 85mm maf limit
  178. E38/LSA/6L90 or E67/LSA/6L90 ?
  179. ls6 throwing P0175 & P0172
  180. Harness install question
  181. Pcm tuner near virginia??
  182. 2002 Trans Am, LS3 won't start on first try, starts on 2nd time everytime
  183. Harness reworked dealers or persons
  184. Fast intake tuning
  185. Gen 3 harness on Gen 4 motor?
  186. HP Tuners 2 BAR SD Tune boost fueling issue
  187. 1995 4l60 tuning
  188. Not getting commanded timing at cruise...
  189. AIR tuned out, got code 1416
  190. do these ground at the same point?
  191. Hard start, won't rev up, 5.3 swap
  192. Upgraded to latest version of HP tuners - Now missing Ignition Timing Advance in Scan
  193. Big Thank You to Jeremy Formato @ Fasterproms
  194. car running very lean??
  195. Cadillac CTS-V error codes after replacing fuel pump
  196. whats need to run an 06 harness on a 03 ?
  197. VE table change much with head swap?
  198. any ideas old man here just tired of trying!!
  199. Question about my ALDL OBD cable
  200. Mail Order Tune?
  201. possible tune issue?
  202. de pinning stock harness. help
  203. can i write a complete file from a gto to a camaro pcm?
  204. Backfiring intermitantly on cranking/ cam sensor problems
  205. Stumped on an issue......
  206. dead cylinder 8
  207. why are my stft's staying so lean
  208. Timing/ wideband
  209. Can I tell if my car has been tuned?
  210. bad pcm?
  211. Went to 2 bar now stft bank 1 missing hptuners
  212. Table to chart
  213. Help With Code
  214. Hp tuner
  215. timing question
  216. Holley E85 Base Tune
  217. Castech 706 head cracks
  218. Bad sensor/Vacumm leak/Bed injector?
  219. ECU Tuning Service
  220. 2006 Z06 big cam random misfire at idle
  221. Fresh build throwing P0327,P0332,PO155,PO135
  222. Hesitation Stumble at take off
  223. Gen III Flex fuel Write-up
  224. tunercat tuning for LT1 4L60E to 4L80E swap
  225. SD tune - Hot Georgia summer
  226. Gen III Flex fuel
  227. Need tuning advice ASAP
  228. Wrong injector data?
  229. LS1 vs LS2 Cam Sensor, which is better?
  230. recommend me a laptop for HP tuners please
  231. Running terrible after trans install.
  232. Ve table tuning opinion
  233. Help please! Engine install and multiple issues
  234. 01 Camaro SS No Start HELP Please !!! :(
  235. Holley HP EFI Wideband Bouncing
  236. First start up tune
  237. O2/Airflow mode config
  238. Switched to 2 bar OS car wont run at all!
  239. Swap to 6.0 from 5.3
  240. STFT way off all the sudden.
  241. 98 ls1 pcm
  242. Alcohol % PID
  243. Question on gray wire from tps or ect to trans
  244. Question on HP tuners OS and PCM's
  245. Seafoam threw a p0327 on my 98 t/a
  246. What's the cheapest one can get the Tech II for these days?
  247. LAMBDA help
  248. Idle AFR?
  249. AFR Error Histogram
  250. Tachometer problems ?
