PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 [108] 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. FAST 90/90, IAC steps vs area?
  2. HPtuner OS ID mismatch
  3. Jeremy Formato Tuning and Porting in Gainsville 3/22/07
  4. Inline fuel pump wire?
  5. WHATS the safest best tune to do for fi??
  6. AEM UEGO gauge, analog output formula
  7. anyone seen one of these?
  8. No Tuners in Charlotte, NC area??
  9. dtc 41 code igntion control circuit open
  10. Connecting car to Laptop!!!
  11. Redline Motorsports hosting EFI Live class May 5th!
  12. Why is KR coming in on high rpm in 2nd gear?
  13. wideband O2 question
  14. looking for a tunner in (714)
  15. 65lb injectors wont idle.
  16. P0343 - I've searched the forum with no luck!
  17. Check my idle tuning approach please
  18. p0608
  19. MS3 Cam Running Rich
  20. Gauges in one Dash
  21. can EFIlive and my LM1 read different AFR values?
  22. TCC what it means
  23. basic stock just got efi live
  24. reading injector duty cycle
  25. tuning sugestions plz
  26. LC-1 Hookup question
  27. codes, o2 sensor P0135 and P1258
  28. 1 problem down a few more to go.
  29. Is it worth a dyno tune?
  30. Software speak the same language?
  31. running cam on slp tune
  32. I'm confused. HPTuners gurus help please
  33. No code after removing EGR - so far.
  34. Desensitizing the knock sensor
  35. HPT 42# injector table?
  36. Stock tune sucks
  37. Tuning my A4 car...
  38. couldnt find anybody else who had this problem
  39. Car choking?!?!?
  40. After head swap question
  41. Car won't start
  42. Need a little help wiring up my lc-1
  43. Need Tune For Sts??
  44. PLX Wide Band Problem can you help ?
  45. Programmer purchase advice
  46. Clearing PCM codes...
  47. auto VE problem
  48. ENG SEN fuse....
  49. PLX Wideband (Group Purchase)
  50. o2 woes
  51. 99 pcm fuel pump relay control
  52. car doesnt want to idle after normal driving...
  53. Tapping a PCM wire to hook up a navigation unit
  54. NJ Inspection (OBDII check and Hypertech)
  55. hypertech + grantelli mafs = bad combo?
  56. Any Handheld tuners to save 2 different settings?
  57. tune for headers
  58. Denali Wont Start
  59. Buddy's throwing codes
  60. Ls1 Edit Remove/add?
  61. VE Cell Question
  62. Turbo tune
  63. Need Help Throwing Codes After Head Cam Install.
  64. Z06 LS6 Tune vs CTS-V LS6 Tune
  65. tuning for stall
  66. LS1edit question
  67. BCM Question??
  68. Ecu
  69. ses light
  70. wow! this has really stump me and many others
  71. DTC codes ?
  72. Can I have your tune? :)
  73. why am I blowing Engine Control Fuses?
  74. MAF - vertical or horizontal ??
  75. Tuning question
  76. diagnostic connector
  77. Ls2 Autove Tuning With Wideband O2
  78. Easy to use tuning software?
  79. LS1 01-02 12200411 specs wanted
  80. ECT Problem Please Help
  81. 232/236 112LSA, anyone have a VE and Spark table
  82. Best )2 sensors for a H/C nitrous car
  83. LS1 with Megasquirt
  84. 98 PCM question
  85. BS3 tune for stock LS1 2 bar needed!!
  86. You got to br F@#$#@$# Kidding me!!
  87. Is my problem in the tune?
  88. Open Loop, Speed Density users chime in please.
  89. Tuning
  90. IAC Stuck at 300 - 02 C5
  91. Problem
  92. Has anyone run into P0102 MAF low frequency?
  93. looking for a 2003 silverado 6.0L auto tranny bin...
  94. Car stuck in open loop when idling
  95. fbody wiring on gto pcm??
  96. Tuning Help!!!
  97. Is there a table that references TPS
  98. Strange idle, bad sensor?
  99. looking for a reputalbe shop to send my RR and laptop to for software download
  100. Speed Density Tuning w/LS1 Edit
  101. Intermittent Lack Of Power. Help Please!
  102. Low RPM Boost Stumble
  103. Can you PLEASE...
  104. Crank Signal
  105. 25rwhp how much % more fuel
  106. texas speed mail tune
  107. Help with some o2 codes
  108. Passenger side O2 sensor been unpluged for months!!
  109. Bizzare issue's
  110. AutoVE tuning MS4 cam.....
  111. I need a nitrous tune - running way lean - any suggestions???
  112. 3 wire to 5 wire maf wiring diagram?
  113. SD vs. MAF car feels much better, but why?
  114. Disable po757 DTC
  115. Need Help Please!!!
  116. standalone harness and ecm programing?
  117. roadrunner and efi live update... HELP
  118. T-Rex tune??????
  119. FAST Dual Wideband Mounting??
  120. Tune for power
  121. Permanently Installing LM-1
  122. kr at wot.need tuning input
  123. LC-1 Problems HELP!
  124. Help, car running EXTREMELY lean...
  125. misfire below 3000, then above 3000 car runs awesome???
  126. Is there anyway to make EFI Live read an LS1Edit file???
  127. Stupid Tunning ?
  128. More Tuning Questions!!!!
  129. Shift Light Problem?
  130. Finally bought EFILive V2 for my TB SS
  131. I'm an idiot! Did I hurt my motor???
  132. Cam sensor code and hard starting with new LS7
  133. Wideband Commander not talking to laptop?
  134. TPS Idle Voltage Fluctuates?
  135. Need Help Wiring up Sm-AFR to EFILive V2
  136. MAP sensor bad during tuning
  137. P342 what to do?
  138. shouldnt i be able to download a tune to a RR...
  139. looking for tune or program to tune turbo lt1
  140. car/truck tunes
  141. Best Fan Settings
  142. need 98ss v-9 tuned in colorado
  143. Turning off MAf codes?
  144. idle tuning, ls1 edit. Sorry for asking, i searched though :)
  145. Auto tap cable won't fit laptop???
  146. Hptuners Sd Tune
  147. Did i mess up my PCM?
  148. In car dignostics??
  149. handheld tunners
  150. Anyone running 3BAR?
  151. SLP Predator custom tune question?
  152. Why do a lot of Pro Tuners turn the P1336 enabler off?
  153. bogging after i turn the car off??wtf
  154. baterry gauge not reading properly???
  155. Car won't start
  156. Anyone able to burn PROMs?
  157. Ls2 402 idle problem
  158. LC-1 and what guage??
  159. Switching Computers
  160. Big Stuff 3 Tuning LS7
  161. LT1 OBD2 pcm questions...
  162. Bogging out 2-3k rpm
  163. Maximum MAF output frequency = ?
  164. P0133 and P0153 codes being thrown please help!
  165. Need some help with hesitation during acceleration
  166. BOSCH WB02 for bs3 Part #?
  167. will swapping MAF's affect the tune?
  168. Wanting to log runs...newbie
  169. Tuning for slp maf
  170. O2 signature?
  171. Asap
  172. Ignition Configuration for MS2 and GM DIS
  173. Quick question about logged DTC's
  174. Help deciding on which tuner program for me
  175. 1st gear shift point off
  176. I Need Help
  177. Need Specific info with LS1 Edit
  178. BS3: who has set one up and fired...
  179. new pcm on older car?
  180. Firehawk T/A wierd power seat issue??
  181. Rich or Lean
  182. how bad is this?
  183. IAC Sensor Bad?
  184. IAT sensor?
  185. High octane timing tuning
  186. EFILive in the April Issue of GMHTP
  187. air pump fuse blowing
  188. P0174
  189. Park/neutral perfect, in gear off
  190. Anyone know anything about tuning software called SCT Flash
  191. Using torque sensor to simulate dyno
  192. What comes next tuning for cam?
  193. Individual selectable tunes?
  194. How to test faulty fuel injector??
  195. Timing tuner wire got melted.
  196. Bogging down
  197. Does Stock Maf Have Screen?
  198. Need some help with LT4
  199. 2004 GTO computer questions
  200. Predator torque management
  201. What spray to Clean Mass Air Sensor
  202. Dead on decel
  203. WHat AFR should you be seeing on...
  204. Ass backwards IFR table???
  205. Millivolts
  206. Hp tuners, with Zex wet kit
  207. Timing Dial??
  208. Ls1 Post LT install problems
  209. ok i tried everything about the ect sensor circut high
  210. WOT timing?
  211. Vaccum leak?
  212. predator or dyno tune?
  213. Car falls on its face
  214. Q:STFT LTFT Lean/Rich Condition
  215. Torque management M6???????
  216. Can a BIG cam Cold Start & drive like stock
  217. ???01 ecm swap to a 02???
  218. problems with converting to 3 bar steup
  219. timing help
  220. How to tell if cam sensor and crank sensor are bad??
  221. knock sensor turned on ses light, need input
  222. tuning th400
  223. Can read all of table in HP Tuner
  224. False knock
  225. BS3 car falls on its face above 3500 rpm...
  226. MAF Translator question
  227. 2bar map voltage to psi table = same for all 2 bar maps?
  228. SES light flashing
  229. O2 reading problems?
  230. Starting/idle problem - new setup ETP 215, 36#, 233/239 & LT's
  231. electronics problems (interior & alarm related)
  232. flasing a4 tune to a m6
  233. several issues with the car
  234. O2 simms discontinued...wtf??
  235. Abs Inop, Brake Light, Tcs
  236. what happened
  237. WTF! now car wont start
  238. Open Loop SD Tuning - Engine Damage?
  239. Some quick advise on these codes
  240. Engine Bogs Down
  241. VATS question??
  242. Roaring during cold start
  243. Knock sensor wiring pinch
  244. I do not get idle tuning.
  245. What A/F is considered lean for ls1 and wideband ?
  246. my car is showing a dtc code 26
  247. Flashing lower hp tune for hight hp tune
  248. driver side spark plugs black, passenger plugs OK???
  249. first tune was HP can 2nd tune LS1 edit?
  250. Injector Pulse Time
