- Need help tuning a Vette. Reduced Engine Power Code
- Wester's computer programming
- Lock out module?
- Will removing the AIR tubes require programing
- Does anyone have a 2000 hypertech fs
- Stalling after high RPM to stop
- SUPERCHIP PROGRAMMERCamaro 5.7L LS1 1999-2002 2725 Not required +32HP +17ft/lb ?
- o2 Sims ?
- Bench harness and LS1 edit unlimited
- Is a HPP3 really necessary??
- Hunting idle and unusually hard lope
- Low coolant light....
- Predator
- Tuners- Help With Idle Surge On Big Cam A4
- VE pid in EFILive 6.3
- What can I safely set my shift points at? (Hypertech and Cam)
- cags bypass
- The EFI live tunning thread- share info about it.
- Codes Galore....
- Converted from M6 to 200-4R, will I need any tuning whatsoever?
- Please Help!
- PO420 Catalyst Low
- How Much
- warrenty on LS1edit cable.
- If the O2 codes are edited out....
- How far will a computer correct afr?
- LS1Edit question
- Do I need tuning when swapping injectors?
- Security Kill switch
- IAC counts?
- check coolant light on?
- Dumb question about timing....
- spark timing behavior question
- hypertech worth it...
- Computer Swap HELP
- Superchip vs Hypertech III
- Speed limiter on F-body????
- wideband o2 sensor on stock pcm
- MTI Dyno Tuning or FastChips (edd Wright)
- Low Idle
- How do you put on a mail order tune?
- LM1 users, I need a log
- code 1153??
- Pull fuses to prevent engine startup?
- Engine Diagnostic Display dash mounted?
- For an A$ to TH400 conversion, what PCM changes?
- SES light? P1416?
- How I used EFILive to capture LM-1 Wide band O2 data
- Gm PCM Tune Up?
- SES fan relay control circuit.
- Flashing SES light need help..
- Any news on the TunerCat tuner
- EFILive and FlashScan EXCLUSIVE at TSFBA.com
- Car idles too high
- Tuning for TC lock-up
- Speed Calibration on car with LS1 Edit
- help please, what does this code mean?
- When you program using Edit, does it reset the PCM trouble codes?
- Is all this normal before tuning?
- A/F ratio
- Can my speedo be this far off?
- what makes your run rich?
- Having trouble wiring in an LED for my SLP line lock, need help!
- class project on tuning, need some help please
- Ve tuning question
- Any one own a Superchips tuner?
- 224 112lsa in a auto
- Granatelli High Flow Calibrated MAF
- Lengthen maf wires?
- maft tuning question (PLEASE HELP)
- Crank position Sensor?
- Does HPP3 Clear DTC's Now?
- Re-Installed my GMAF - what to look for?
- MAF Identification
- Thanks to Scott at Proauto.com
- EFIlive? Why no LS1/LS6 data
- Guage Cluster Question..
- Help with Delivered Torque
- Help, Flashing SES light
- pROGRAMMING
- ABS delete.....
- Low voltage MAF - Surging HELP
- bank 1 and 2 going lean
- Tuning Q's for new SS
- Who delete's KR
- Little electrical gremlin, need help.
- Misfire Problems
- Canadian-to-American
- nitro daves dyno tune?
- programming a programmer
- Dyno Tune ?????
- Air to Fuel
- Anybody know if there's a Fordish version of LS1 edit?
- Does leaning out fuel ratio with predator save gas milage?
- What's wrong with my car?
- New PCM package!!
- Big cams, 346cid, idle issues...
- HPTuners....LS1Edit competition....
- digimoto diagnostic software
- What do ya'll think?
- Teach me how to change front 02 sensors.
- P0122 code help!
- Where could I spice into for power only when the key is on?
- surging and missing at low rpms...
- Symptoms of bad front o2's?
- generic plugs cause knock?
- For a turbo can, say, why would the MAF now fuel right if it's not maxed?
- Mods: Make This a Sticky. LS1 Edit Table Definition and Help Guide
- LS1 Edit Software
- 231/237 cold idle great, hot idle ??
- Cranks but won't start ...W.T.F.??
- How do I get ride of any and all toque limits? LS1 Edit
- Injector sizing for 38lb gm ls1 edit.
- LS1 Edit, WOT shift Firmness Mods, how?
- How do I turn off the rear O2 Sensors?
- Low Trac light with no TCS?
- high idle...trouble shooting ideas please
- Close to stock numbers here
- TCS turned off on its own ...
- Stock Ls1 with auto....
- If you stall right after cold start, REAL hard to restart?
- idle fuel trim help
- usb autotap?
- TSP mail order tune vs. dyno tune.
- anybody got a engine harness diagram?
- idle problems, hanging @ 2000 rpm?
- Help!! getting a 1514 on a supercharged vette.
- What constitutes as abuse
- LTFT andWOT fuel relation?
- Stock shift points-Did search
- What's the best tuning program/software for me?
- BIG PROBLEM misfires like a SOB!
- Help! M6 4.10's Predator!!!!
- Autometer question
- Ls1 edit mistake
- Help me identify this PCM
- Ses Light Need Help
- Info On GEN 7 ls1 in high performance pontiac magazine
- Can Accel DFI Gen VII interchange transmissions by itself?
- serious tune
- question about gm tech 2
- Best Price on ECM Programming
- LS1Edit not reading
- Has anyone ever heard of this scanner???
- Should I get a tune after I get cats?
- wide band product
- What laptop for efilive & edit
- Looking for a good referance book on PIDs
- Weird LTFT
- Emissions readyness Status
- 2002 Motor w/ 98 PCM/Harness
- Injector Offsets- Accel 32lb...
- Atap F/s...
- Tuning
- Old MAFTranslator, I'm still running mine
- Trim cell 15 versus cell 22 at WOT
- Hotcam in A4, needs help with cold start surging
- Shift points with HPP3
- Why not use an 85mm MAF
- LS1Edit shift points/3.73's need help.
- Predator/LS1 Edit Tuning Questions for LS1 Electric Fans?
- Wideband A/F idea - cheap & data logging
- should I get a programmer?
- How do you reset the service engine soon light?
- Rear O2 sensor question
- Should i get a DIABLO tuner??
- revs up when i put brakes on!!
- EDIT,PE delay RPM???
- Needing slight explanations on differences in software
- PE vs RPM multiplier question.
- LS1 Edit
- How To Hook Up Hawker Battery?????
- Will MAFT adjust for Idle/Part throttle?
- O2 Heater Performance DTCs help.
- Misfires in internally stock engine?
- ASR Removal...
- Can you replace the front O2s wiht the rear ones?
- Something Interesting for PCM Tuning
- I dont know what to do?!?!
- Cluster Guage went out/ would it cause this?
- Engine missing!!!!!!!!!!!
- Anyone tried EFIlive V6 on a OBDII LTI? accurate?
- LS1 Edit tuning with a Dyno sheet
- LT1 Dyno Tuning in Houston or Surrounding Areas
- Predator Custom Tune Capabilities
- Any Good Tunners In Illinois??? For a LS1??
- Mail order PCM??
- Rapid Motorsports
- Timing has a mind of its own???
- How About a Sticky or Thread Explaining the Purpose of Each Edit Table?
- tuning help needed, car dies after wot runs
- Dyno in what gear?
- Fuel Additive / Higher Octane Fuel & Knock Retard...?
- Any way to Delete TM in A4
- I need Stock TRruck PCM Flash files -
- help me decide
- Help with EFIlive log file
- Used Diablosport Predator or LS1 Edit
- ECU pinouts needed
- Marbles after head install???
- looking for...
- Spark Advance Dip to -10 degrees
- Check Engine Code
- ls1 edit worth it?
- Rev Limiter?
- Fan Settings
- Idle surging (cold/hot/etc) take a look at my efilive log jpg
- Anyone run Gen 7 on a n/a stroker yet?
- Bank 2 Sensor 1
- Opinion after tuning with HPP3
- LS1 EDIT HOW DO I LOCK UP MY converter
- What shops in TX tune w/ wide-band O2 & dyno?????
- Dyno / Tuner at Portland OR Area?
- Stock #s for 98 Vette A4
- Edit gurus quick question
- MAF g/cyl way up after ported tb and head swap?
- HPP3 worth the money
- Low idle
- Does a Dead Battery = Lost Program
- QUICK! Reset the PCM ? or Battery?
- TPS % 100&TPS V=4.3 versus TPS % 100& TPSV=4.71
- Lean Condition After LT + ORP Install
- who has had their car tuned at ap-engineering in detroit?
- Autotap for USB and other updates!
- Dyno tune Dallas area??
- BayArea,ca Dyno shops
- Will hypertech proggrammer do the trick?
- Interesting Show on TV
- Anyone use these or know if they work??
- cam tuning
- New predator?
- Please explain this DTC!!
- Random misfire???
- P0239, TCS light on??
- p0300, random multiple cylinder misfire
- Will I need tuning?
- any shops in detroit that dyno tunels LS1's?
- Need to find a good tuner
- Need help deciding..
- SRS Light help!!
- Fernco Bellow now SES
- WOT and gms/cyl question
- should i get a tune...?
- hot starts with 231/237
- Running Rich..
- HPP3 question
- efi live
- i thought i would pass inspection
- New predator with 160 t-stat
- $$ no issue-best tuner in TX?
