- looking for a good dyno tuner in mass
- Hpp3
- Any Diablo mounting ideas/car holder?
- HPP3 questions
- Newbie moving up to LS1Edit. Remove HPP3 first?
- A/F with predator
- Tuning individual cells..
- Setting P0332 & P0507, what are these and how do I fix it?
- Traction control kicks off/on by itself
- AZZHAULER runs bank1 off of the LM1!
- where to get ls1edit?
- Think I messed up my LS1Edit tune w/ Diablo
- ls1 edit?
- GMS/Diablo users within...
- What table takes care of this???
- LS1.Edit; downloaded file now can't re-connect??
- Good tuner/installer needed in Ga.
- LS1Edit newbie tip
- Something isn't righ...
- Newbie Autotap questions (creating config, helpful perameters)
- EGR removal
- LTFT's +20 on Bank 2 after Removing Cats.
- Innovate LM-1 users
- LS1M wideband help..
- Anybody know about LT1 Fbody MAF tables vs. ls1?
- Help Needed with O2's
- Gen VII or try stock pcm first?
- Just bought ATAP...How to output files to EXcel??
- Brake Torque Timing Table??
- Rear defroster trouble
- random misfire code wtf? P0300
- Tuner can't get LS1 Edit to connect. WTF?
- Getting 42# SVO's to idle.....
- Smoothing out truck timing curve?
- Any cure for surging/jerking effect when cruising at low RPMs/steady speed?
- Dynamic Air PID - EFILive
- Can I program the car to prevent misshifts? Check this out.
- WTF is going on??
- I have idle problems! Throttle position?
- Torque Managment question.
- Autotap code question on a 96 Z71 Tahoe???
- Part throttle tuning question
- LS1 Timing Tuner
- Any updates on AEM, or discuss using the race box
- how to "fix" factory tach?
- Service vechile light?
- NXL kit EDIT question
- ok, here are my logs...
- tuning for headers?
- Best way to replace Knock sensors and what parts are needed
- Heavy rims make a difference in rear wheel numbers?
- Detonation @ 4800 RPM
- 02 sensors???
- High or Low Octane tables w/ ATAP
- noob question
- EFI Live Connection Question?
- where can I find
- Tuning with Granatelli???
- Car won't start?
- Gen 7 Piggg back my A$$
- P.O. 342 Code After Heads Cam Swap..Pinched Wire??
- mech or elec gauges??
- New member (need Help)
- ABS question
- SES code list?
- Tach wire from the PCM on an LT1 car?
- Accel Gen 7 for Sale
- What does a Scan Master do looking to upgrade from HPP3
- USB to Serial Adapter? I need one for PDA Scan tool
- MAF Vs. Vibrations.
- Help on HPP3 shift points with 3.73 gears?
- Cheapest Place to get '02 Knock Sensors and Harness??
- Steps to reduce hydrocarbons for emissions test???
- EFI live information
- Just put a 9" in the car...
- Emissions question - add timing to idle?
- SES Light???
- IS THERE ANY WAY TO FIX A MAF SENSOR GONE BAD.
- Should EFIlive display slight A/F fluctuations?
- "Oil Change" light is on, how to turn it off?
- LS1 Edit
- Log file review please!!!
- Idle question
- Rich @ Idle vs. Injector Offset
- will turning off COT with cats on the car kill them?
- Tweaking dynotune on the street
- How to remove Vin from HPP3
- Take timing out for a cam ?????
- What parameters are needed to initiate a WOT downshift?
- Car runs great sometimes....sometimes it stutters
- will this work?
- 99 and 02 MAF's are different? According to GM they are.
- How EXACTLY are LTFT's calculated?
- Formula for gms/cyl different for different cubic inches?
- Pros or Experts Needed, Tuning on a draw through MAF S/C?
- 12-17% to much fuel.
- 2002 Z06 injectors
- Stock tach quit working
- Screwdriver tuning the SLP85mm MAF
- Problems w/ car????
- Knock Learn??
- Enable Torque Management
- just installed my EFI Livev5
- torque management
- Is the new Accell DFI right for my car?
- RPMs float ~2k when clutch goes in. LS1 Edit Solution?
- codes?
- Atap Log for my '03 Z...Take a look
- Dying at stops after intercooler project
- How to turn these codes off?
- Ideas on my laptop tray
- TPS Voltage
- Injector offset w/svo's whos done it, interesting results?
- 5000-5500 RPM stumble - KR
- Anyone using Predator and LS-1 edit?
- A4 RPM Shift Points / Diablo Programmer
- Y not disable rear O2's with LS1edit?
- Does TC lockup in 3rd gear at WOT?
- EFIlive/Autotap not working
- ? ABOUT KNOCK RETARD
- P327 code
- EFI Live v5 maf conversion function question
- No misfires and have a flashing ses light...
- Tip > Removed your AIR system? > Remove the fuse too
- Bosch O2's ???
- MAF Question
- Ls6 tuning
- rubber gaskets on pcm
- Can ATAP do Tranny Diagnostic?
- Does less than a 1/2 tank =low octane advance by pcm
- ls1edit and "drive be wire" question
- PCM
- Quick dyno/afr question
- best spark plug wires?
- Reprogramming after heads and cam
- Help with tuning
- HPP3 help.
- Lap top computer stand for our cars?
- Do I need tuning?
- C5 and cam, what is idle relearn for M6...
- Hydro carbon limit is 60PPM - WTF?
- Really lean in open loop paging ...NoGo or someone
- Pulling a Knock Sensor Code
- Hanging idle ? any cure for it?
- LS1edit? Tuning? Advice please...
- Closest dyno/LS1 edit tunning from Jacksonville FL?
- P101 CODE
- running really lean at idle and at end of 1/4.. someone help
- PCM speeding up car by itself??????
- Tech II question
- Autotap Log Help (NoGo)
- EFI Live STD vs. PRO?
- whats the best tuner for a 98 ls1 with basic free mods?
- Is a reprogramming via LS1Edit considered...
- predator and maft help at wot
- Bullets replacing cats, O2 sim question
- Ses light engine knock sensor
- LS1 Edit in Florida?
- P0172 & P0175 anyone here cure these?
- ??????ls1 edit or not?????
- Granettlei VS Slp MAF
- P0102 Mass or Volume Air Flow Circuit Low Input?
- Granatelli(sp?) MAF Shorted out(maybe??)
- Please help with L Trims
- Is it worth upgrading to EFILive?
- Help me Tune with Predator
- PCM
- MAFT worth 80 bucks?
- Can I drive the car with out front O2's temporarily
- Need tuning going from 26# to 29# injectors??
- What to get first
- VERY INTERESTING thread on dyno tuning vs real world
- DIABLO TUNER 98?
- SLP MAF SENSOR
- Shift firmness questions any one help..
- NoGo help with tuning of maf sensor..
- Clearing the previous fault code in PCM after the repair?
- if I am throwing codes for being too rich?
- Anyone know a website for C5 pcm wiring?
- Anyone downloaded a custom tune to your Predator?
- JET PERFORMANCE CHIPS
- LAUNCHING HELP BY TIMING REDUCTION
- Anyone tried the stage 2 chip?
- Well it matter if u take of your themostat?
- Will the car still run right without rear O2's?
- Turning on Fans with LS1 Edit
- uneven ltrims
- Throwing Codes.....
- Autotap and Pulsewidth.
- H/C car - failed inspection!
- SES Light > No Autotap > Can Autozone check the code ?
- MAFT tuning and O2 code questions
- Fried my Cats!
- PCM Flash
- Timing help needed, NoGO and Chris B please give insight.
- Best location for wideband o2 sensor?
- My idle is messed up...help!
- NEED HELP ADJUSTING SHIFT POINTS WITH LS1 EDIT
- lt1 edit compatable with ed wright program?
- More Performance
- C0035,C0056,C0550
- motor felt like it didnt want to rev over 5500 in 4th?! help
- need yalls opinions....
- Diablo or Hypertech??
- o2 bank 1 and bank 2 #1 pcm wire ?????
- O2's Tell me the difference
- Need to go back to stock tune after LS1 Edit
- diablo wot for stock engine?
- OK, misfires. *DELETED*
- 02s
- best stand alone computer setup for an ls1?
- LS1 Edit .... where can I purchase
- Car stumbling, What could be causing it?
- SES light came on......4 tripped codes...HELP!!
- Home Made O2 Sims?
- Th400 swap and timing wont see what it is supposed to. HELP!
- ls1 edit ? about o2's
- turn key engine- crock o' $H*t
- Car stays at 2000RPM out of gear
- Injector Offset for Lucas 42's
- LINK ecu
- Predator scanning question
- 42lb.Bosch/SVO Injectors
- Guys with the Predator Programmer
- dyno tuning
- Did PCM reset.What to expect?
- Edit and A Tapp/EFI Live
- TPS relearn
- does predator log any data or is it only "real time"
- how to convert MAF gms/sec to lbs/min?
- Innovative wideband users...
- So the GEN 7 DFI can be run as a standalone?
- Reduced Engine Power
- Help me analyze my O2 readings and Fuel Trims
- diablo tuning
- How does the pcm determine barometric pressure?
- PCM Bad?? How to find out??
- question for those of you with a wideband
- NEWBIE ?
- Why does the belt keep jumping off
- Diagnose SES Problem
- want to buy edit
- MSD Programmable Digital 7
- Special Pricing on GEN7DFI
- Formula for shift points
- Beginner's guide to tuning
- Is this worth it? Or Just a HOAX?
- Extremely weird LT's
- Help me diagnose this KR issue
- Full custom tune??? (Dyno)
