- HPP3
- wierd thing with MAFT
- P0118=HIGH VOLTAGE ENGINE COOLANT SENSOR
- unsuccessful reflash attempt at dealer, please advise
- Power enrichment?
- Can't get my USB to Serial to work.
- Data Logging at the Strip
- Adjusting fuel at idle and while crusing?
- LS1 Edit + shift points
- 02 Z06 Torque Management
- Y ATAP??
- V2 Ease Pro Scanner tested
- Edit wont change my shifts anymore?
- Which chip is the best
- Ed Wright vs LS1Edit tuning > Who to send the PCM to? (Please Help)
- Autotap & EFILive question
- LSILiveV5 Unit Workaround Didn't work
- ET Streets are 26.5"dia correct? Should I change it in edit?
- Changing Desired Shift Time
- High IAT count/ does it pull timing?
- Ltrim question
- Shift Speed table by TPS% question...
- Question about toggling Engine Diagnostic tests...
- What gauges?
- the LS1Edit software free, like Autotap (can be downloaded from the web)???
- Lost HP from AIC count?
- MAF?
- Why No Battery Charger???
- Does anyone know if perf shift table can be used in LS1 edit?
- when is it time?
- ABS Question
- Help P0756, what do i do ?!
- EFI Live vs. LS1Edit
- Injector offset.xls
- How much line pressure should I add for firmer shifts?
- Stoich Ratio for the LS1 Edit users
- EFILive and MAFT
- Who does dyno tuning in KY,TN,In, or IL?
- How do you know you did it right?
- How long did it take to get your LS1Edit?
- Lack of O2 Sims cause lost performance?
- Scheduling my LS1EDIT with Thunder Racing..
- LS1 edit help
- Can a used 99A4 PCM be used with 01 m6 car?
- Wideband O2 sensor
- HPP3 Power Tuning and Gas Mileage
- How many head/cam cars running more than 26* for max power?
- very Lean air/fuel question
- LS1Edit for 98 and 01..is it possible?
- Questions about LS1 edit and atap...........
- Diablo Predator Test Vehicles Needed!
- LSILiveV5 Units Question
- Hypertech causing a slight ping
- Stock PCM setting info needed::: Predator and other’s please help...
- P1153 HO2S Insufficient Switching Bank 2 Sensor 1
- ED WRIGHT TUNING AND HPP3 ??????
- New tuning product??
- Help! battery went dead while programming hypertech!
- surging and stalling problem
- why do we need the 160 thermastat
- Question on LTFT affect on AFR PE
- FTRA + A/F ratio
- How do you hook up O2 simms, and can rear sensor be used on the front?
- Question about LTFTs and STFTs...
- Injector offset table for Lucas 42's
- What types of parameters would I need to change?
- hepl with 3.42 shift points
- Thanks for the Answers; However...
- Anyone care to give me some beginners advice on LS1 Edit? Please?
- Fuel Pressure Variance From Idle to WOT - How Much?
- Torque Converter Lockup ???
- My A/F Ratio is 9.7 : 1 How much gain can I expect?
- Help cars wont start electronics all messed--
- Atap shows 96% throttle...bad knock...please help
- TCC changes
- EFILive5 User Guide Question
- AutoTap v2.02 O2 Sensor Question
- P0327?
- EFILive 5 - Which O2 PID????
- Dyno, A/F ratio and MAFT
- HPP3
- have edit ????'s on timing
- SES light after Hooker LT install...
- Autotap
- Least amount of timing?
- hypercrap issues
- my log
- do u need the cable for both atap & edit?
- AutoTap and EFI Live
- old log files
- Need an explanation of skip shift
- Okay, what would cause an O2 sensor to have low voltage?
- Ls1Edit tunning with HotCam?
- Another Fuel/MAFT Question??
- tuning question
- How do YOU find LTFT's?
- please help
- *****I'm about to burn my 486 laptop!*****
- Maf range extension?
- Need file 99 Vette A4 3.15 gears.
- swapped mufflers,did i lose power?
- HPP3 only?
- HPP3 - Will it work on my car ?
- NEED HELP FAST!! car wont stay running after head replacement
- Need help with open loop off idle/part throttle tuning
- P0104 and P0107
- IAC Count Clarification: In gear or out?
- Anyone familiar with code PO757???
- HELP SES Light on........................
- How lean is safe?
- Help!! Engine codes ...and misfires...
- ATAP
- next opinion
- Top Speed?
- Sporadic TCS OFF light while driving???
- Want a educated guess for someone's experience w/ LTRIMs
- injector offset
- P0102 & P0121????? how to fix these?
- Shift points and Rev Limiter
- How much will LS1EDIT help me.. info inside.
- Whats up with this torque curve?
- Correction factors & Dyno readings?
- What would cause dip in power at 5400rpms on dyno?
- SES light
- ltrim reading ????
- Can't get Harlan shiftlite to work...What am I doing wrong?
- Someone please help me get to 6400-6600 shifts with EDIT
- discrepancy btwn injector correction factor and excel data
- Does SES light=performance loss???
- how do you reset your pcm???
- Correction Factor for SVO 30# ?
- O-2 Sensor Question
- Shift points problem with Edit
- Knock Retard and Low Timing.
- Deleting Misfire code with Ls1 edit??
- LS1 Edit Will Not Read Stock PCM!
- 02 sims VET testing????
- What are these codes?
- Every so often get p0102 code - MAF Sensor Circuit Low Frequency
- Cheapest place to get LS1edit ???
- ATAP V2.X Users & Upgraders - Your Opinions Please
- Laptop Problem with autotap dos version
- What Results Did You Get From Modding Timing Table?
- 2001 LS1 TUNING
- More power on gas fillup?
- Timing going from 15 to 41...
- Re-tune Stock Engine?
- EFI Live Question
- Timing to low
- Stock Tuning, &Torque Management
- Closest GOOD Custom Tuner to Arizona?
- What all should be changed with a custom tune?
- Is it possible to “lock out” a PCM with LS1 Edit?
- Very minor knock retard ?
- MAF rate- not good indicator of flow? What rate are people getting?
- Does anyone have a pic of where the pcm is at?
- Truck not running right, need help!!
- Question about emission DTC options and LS1 Edit...
- Diablo Programer
- OBD II scan tests for emissions in IL now (question for OBD experts)
- base spark question??
- Gauges
- In dash error code.
- O2 units of measurement for ATAP v2.02?
- P0300 and Spring Breakage
- Dyno and WB tuning near Cedar Rapids Ia
- P1416
- possible to delete or disable knock sensor?
- offset ported MAF line pressure using hpp3??
- what is my stock rear wheel hp?
- Ltrim variation form bank to bank???
- TPS problems, P0121, can't find info anywhere!
- Ls1 edit cable work with Autotap?
- MAFT, LTrims, and my 02'SS!
- Which cylinder is the #2 cylinder?
- need a little help what do these codes mean po1416 po141
- Failed IM240
- Rear O2 Simulators
- More Power for 2002 Corvette LS1
- what a bummer, can't figure out my ignition problem
- Autotap/MAFT/LTFT help please!
- anyone from the chicago suburbs have atap??
- Delete EGR with LS1 edit or use LPE adapter and keep EGR on LS6 intake?
- Custom Tuning??>>>>>
- Besides AF and ignition timing, what else is there to tune?
- MAFT Questions!
- Auto Tap or LS1 edit?
- how to diagnose a bad knock sensor/circuit
- Where all all the o2 sensors located??
- LS1 Edit Problem
- Team ZR-1 John, how long do you need to short battery cables for PCM reset ?
- Scanmaster, Maft and going 155mph+....??
- Which wire to hook up A/F off 2001 TA
- EGR and AIR
- manual switch for cooling fans
- Scanning & Logging FAQ
- Evaporative Emission (EVAP) System Flow During Non-Purge ?
- Who here is in on the LS1 Edit GP?
- SES help, please!!
- P0430 what are the options?
- LS1 Edit users in TEXAS ??? readiness monitors???
- how to raise shift points on edit??
- Going to dyno Sat. Is it safe to use edit to lock car in 3rd gear?
- JET performance chip???
- anyone has pcm setup for 2.73 gear car with vig 3200 TC ?
- O2 sims failure or something else?
- Question on O2 sensors and Autotap
- LS1-Edit Software desparately needed...Help!!!!
- Flashing A4 computer to M6
- DTC P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1. Please help!!!!
- LS1 Edit Question
- need HELP!! MY service engine light just turned on and need help!!
- Need help with a decision
- How tough of a learning curve is it with Edit?
- LS1 Edit shift point questions
- dynoing and 02 sim SES
- Should I descreen My 85 mm maf?
- want to find out my timing using autotap. help please.
- O2 sensor switching parameters?
- TACHOMETER SIGNAL ON PCM
- ease seems to be no faster than autotap(ver 1.03)
- AUTO TECHOMETER`
- met guys at andys auto on saturday
- Breakin Up!
- if car is tuned in cool weather, will it run rich at the track in warm weather?
- Best Air/Fuel Ratio for a N/A car?
- Any "Octane Value" to Naptha?
- rev limiting in drive WTF????
- Custom tuning help please.
- Anyone have 98 LS1 edit software thats willing to help a friend out??
- Nearest Dyno and WB tuner Knoxville
- Keep throwing P0103 codes
- 02 sensor heater?
- Sorry paiN
- (Possible?) Wide band O2 solution using existing PCM
- Need idle relearn procedure for 2000 A4 car
- Help with LS1 edit please.
- Need Help... Please look inside!!!
- PCM Config
- Anyone have Desktop Dyno?
- Putting together an LS1 edit FAQ - need input on topics ->
- Another ATap ?
- Atap reading problems...help.
- ls1edit?
- finally got edit able to use my ed wright program
- Will a car run richer on the street or dyno?
- Dyno tuned car, O2's went down to 830mv!
- ANY ONE in New York with autotap and ls1edit??
- HELP!! Idle trouble after TR224 install
- Easy question
