- Do it all Standalone
- EFI Live 98 2bar sd base tune?
- o2 heater sensor
- Universal o2 sims
- changing pcm
- 382 Stoker Tune. Drives great. Looks funny.
- SLP Diablosport vs mail tune
- PCM Pegged out (MAF)...
- holley 950 help
- flooded parking lot....intermittant missing...codes
- what does adjusting impact factor do?
- lq9 silverado tuner
- Can someone help me with o2 sensor wiring?
- Need some Predator Codes
- Custom Predator tune, where to get one.
- wondering how much a tune will benefit me
- Time for a new tune?
- What type of tune?
- G8 GXP tuning
- Left bank ?
- Replacement ECM, rough idle?
- Gm uses microsoft
- Oil Pressure to PMC
- LS1 Conversion With Issue of Computer Pulling Timing after Running for a while!
- Random Cylinder Missfire Code
- knock sensors problems
- 8.1 Tuning and timing
- new to wideband stuff
- DTC code P1351 Help needed!
- '04 Vette 18:1 in CL, 14.5:1 in OL. Low dyno numbers.
- closest ls1 dyno/tuner to nashville
- tunning ?
- vortec computers..all the same??
- Holley's new EFI system?
- need to re-set RPM limiter
- stuttering
- tps problems .86 v to 2.79 3% to 56% tp%
- HpTuners Question
- Playing with lt1 and tunercat
- O2 sensor front and rear any difference
- Anyone have a tune for NA 402 with 9.5:1 CR? For 07 Vette?
- Tuning books for efi live?
- CONFUSED and LOST!!! please help, no start or gauges
- Pcm Pin Out Diagram
- Lt1 gurus please come in!!!
- Bad O2?
- ? about getting car to start better. highly modifed car.
- Changed bottom end to 402...car won't start
- tune problem, wont rev past 6100 rpms please help
- Turbo build tune???
- Got codes need help
- need best scanner which one?
- ** ECS mail orders tunes, still only $149! **
- Injector Flow Rate vs KPA...
- tuning in or around indiana? teachers?
- 93' z28 pcm communication failure?
- Weird decel problem?
- A/F super lean - dyno results...ideas?
- Help with dtc codes!!!
- Need help from tuners!! PLEASE
- Which Software
- Va Speed. We'd like to apologize.......
- Point me in the right direction for a tuner in/around CT for my Turbo LS2/350z
- datamaster transmission help
- Code!! P0801
- Megasquirt help!
- PE NA and PE Boosted target AFR?
- speedometer signal help
- LT1 Communication Timeout - Any Ideas???
- SES code P0118
- car running hot or not?
- Having some serious idle issues
- need help with wiring harness
- car randomly shuts off
- need help with MAF
- need internet for tuning
- timing ratard for nitrous (IAT)
- PCM/BCM data stream info needed
- LS1 blew up, now has a 5.3
- How many misfires are acceptable?
- fuel pump wont prime sometimes
- i need my rear 02's tuned out
- Lost and need some help on issues.
- gm asa cam
- Questions about chips.....
- LT1 tuners in here
- Need help car doesn't go into BLM
- megasquirt piggy back?
- SLP Diablosport tuner
- Wiring Question
- HPtuners help
- Wideband Woes! (AEM)
- no Tac signal - LSX swap / '91 Z28
- obd2
- Just finished my m6 to a4 swap, dies when i put into reverse or d
- Who uses the AEM EMS?
- Re-tune after another cam swap?
- converting 98 to 99 Harness and ecm
- silverado tune?
- only starts with battery charger
- Switch from Auto to T56..ECM Problem of course
- BS3 won't read cranking RPM
- Does tunercat & TTS Datamaster work on Windows 7?
- Does anyone have an ASA.tun file?
- no start got fuel got spark wtf?
- How easy was HP Tuners for you to learn on?
- Fuel Pressure 70psi after Racetronix Install?
- Good book for learning HPTuner software..
- ls1 ecu wiring schematic?
- Lean Spike Driving Me Crazy
- Random misfire help
- 98 pcm
- ls1 going carb, i need controller info
- rear o2's
- 2 pin oil pressure switch
- I need an FI starting tune
- Autometer A/F guage....any good?
- SCT Tuners...
- Are the M6 and Auto harness different
- Fuel level input Ohm Range change?
- help with tuning for new cam
- Couple of codes bothering me
- can you convert lbs/min flow into approximate horsepower?
- Hp tuners help
- The tuning school
- Identifying year of PCM and Harness
- Just a couple questions
- LQ4 with a 4L60e
- systems not ready
- please help tuning ls1!!!!!!!!!!!!!
- Dyno numbers seem low?
- Need a dyno tune in Pittsburgh
- loss of power,dyno show's lot of timing being pulled from topend????
- NEED OBD1 LT1 BOLT ON TUNE $20 to best one
- '98 LS1 PCM and '05 LQ4 sensors?
- IAC reading over OBD-II?
- Painless Perfect System
- HP Tuners:can't buy credits but want to license a new vehicle
- 80# injector tune?
- Are the plug ins the same for a 99up computer as a 98 fbody?
- Weird problems after MS3 install.
- Anyone have an MS3 bin file they would share??
- Where to get new replacement wire/pin for PCM harness??
- self tuning?????????????
- Fixing my wiring harness...
- Tool for repinning?
- General question
- How much could a real dirty MAF affect tune?
- Pcm conector pin holders?
- best tuner for a LT1
- Transmission shift point questions..
- Dyno Tuning at EPP with our Mustang Dyno and EFILive $600.00
- LT1 F body vs. Y body tune
- EGR connector?
- Shift RPM
- Max Timing for LS1
- Pcm ?
- Converting from A4 to M6 tune
- how to adjust transmission shift firmness
- 01 ZO6 Odd Idle Problem
- Adjustable fuel regulator and tuning
- Need some guidance OLSD tuning
- timing 40 degrees at WOT???
- FYI: Close gap on TR6, ran lean
- SCT X3 Tuner, Car Problems.
- 131 PD? What code is this?
- Running rich after temp drop!!
- Sd or MAF....
- switching PCM pins to run rear O2 plugs for front O2's.
- anyone use a cortex tuner on their f-body?
- locking and unlocking a PCM HP tune
- testing air to fuel ratio HP tuners or wide band
- MAF Voltage
- Anyone using the FAST Tuner?
- Closed loop temp?
- Max hp with 28.8lb injectors?
- Need to tune out egr on S-10
- Have 300 bucks to spend for what?
- Tuners that have tuned an elbow setup in here please
- PCM ?s
- Bs3
- fbody traction control - tuning for good launch possible?
- Code U1000
- BS3 w/racepak questions
- futral motorsports fixed my car
- JET power programer
- Got fuel lined out with lc1 wideband, re enable fuel trims, it pulls 7 % goes lean
- Anyone have a tune for the MS3?
- shift point
- HP Tuners pro or standard?
- Preogramming LC1 Analog Output
- re-tune for new intake manifold?
- 04 gto lean lean lean at idle until ST's jack it up to 14.7 finally
- tuning software general questions
- ECM/PCM tuning and switching platforms/ECM OS
- Change cl afr?
- Help,loaded funky tc file to 94 lt1
- HOW TO TUNE LTFTs
- how bad is it running lean?
- PCM Constant is killing battery, HELP
- ls6 wiring
- Problems accessing my PCM after TSP tune HELP!!!
- camshaft position sensor low voltage
- hp tuning school?
- throwing codes after long tube and exhaust
- no communication with diagnostic port
- guys that have run their wideband input through the AC pressure sensor, fan question?
- OBD1 code scanning
- AEM Tru boost help
- what to do after needing 80lb plus inj?
- Car surges when warm, breaks up under light acceleration, low on power
- Wont run with 2-bar tune
- computer issues in 01 ss maro
- Is a 99 trans am a Can-Bus set up?
- WHo does SD tuning?
- What causes this? STFT Question
- tuning question. help?
- Diablo Sport GM series II
- pick apart my historagram please
- anybody know why im getting constant knock? log inside
- Throwing a code
- Car won't go into cold start mode, ideas?
- emission codes
- would tune cause smoking?
- Wierd glitch at the dragstrip, could be HPT related???
- loose wire coming out of PCM... what's it for?
- High Idle
- 06 corvette knock retard
- sd tune for kytp project
- Custom PID HELP!!!!!!!
- will front o2s not switching cause constant open loop?
- 4L80 tuning question
- Want to cancel the BCM on a 1999 FRC Corvette
- Useing HP Tuners How Can I make my Coverter Lock up at Full Throttle Only @ WOT?
- need help WOT issues
- HELP!!! Need to pull timing using LS1 edit
- Startup trouble after flashing an SD tune
- Base XFI tune?
- Question about HP tuner & EFI Live
- mail order tune?
- Innovate Wdeband Problem - AFR=21.9
- Best tuner in Tampa area?
- Anyone for sharing 48lb. injector tables?
- finished cam swap today, need advice.
- 95 LT1 Firebird, Data retrieval?
- newb tuning ??
- Anyone ever hear of Late Model Throttle? Or West Bend Dyno in SE Wi?
- Looking for a new wide band, have some questions
- Question about running SD open loop
