PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. 5.3 with 4.8 pcm
  2. Break in tune
  3. AEM Wideband wiring question.
  4. HPtuners with Wideband or Tuning School course
  5. Another PNP Selector Switch Question
  6. 5.3 swap wont rev remove grd frm maf and works
  7. Considering a HP Tuners MPVI2 for 2001 Camaro SS
  8. 98 TA ECM, Harness, and trans upgrade
  9. 5.3 Vortec Stalling @ Idle
  10. Need help with 5.3L troubleshooting
  11. H/C Ls1 Climbs to 20.1 AFR?
  12. P0200 error.. listing issues in body.
  13. map sensor for ls7 intake
  14. P1639 code
  15. Gold box vs hp tuners with ac
  16. 02 WS6 MAF + Tuning
  17. I Need Expert Help.. Good AFR to Lean AFR.. Why..
  18. 525hp GM crate engine start but no run
  19. Need help with P0171 & P0174 on L31 engine
  20. tuner in upstate ny area or mail order tune info
  21. HPT Datalog marker tool
  22. Wideband placement - Holley Dominator - 1 or 2
  23. LS1 tach and almost stall problem
  24. College Station/ Houston tuner
  25. MIL issue: wont illuminate when ses triggered
  26. Timing falls on its face, logs say it’s not knock.
  27. MIL / Service engine light voltage
  28. Newbie looking for guidance: P0300 Misfire at idle/Supercharged
  29. Dyno/ tuning help
  30. Misfires on all cylinders no check engine light
  31. OBD II Scanner that read IAC Count
  32. 4l60e tuning
  33. A/C request
  34. Test-new to HP Tuners
  35. Moving IAC Target, Never Settles
  36. Seimens 60lb injector data
  37. Newbie issue - FITech ultimate LS fan relay
  38. Lookin for online tuning chevy engine
  39. Tuning Schools
  40. Initial Startup After Swap
  41. Newbie tuning question(s)
  42. E38 Injector Hard Limit
  43. msd 2 step
  44. Supercharger Start up Tune?
  45. P0200 Injector Open Loop - I'm stuck!
  46. Newbie 2011 Gen 5 Camaro
  47. Dwell and melting coils
  48. STIT # Keeps Climbing!!! Help!
  49. 08 lq4 in 2002 chevy silverado 2500
  50. Looking for a good tuner in Tennessee, Ky, Ala, Georga.
  51. HELP DEAD GOAT cant find ECM anywhere!!!
  52. VE tuning by LTFT
  53. AEM wideband
  54. I'm in HELL! HELP HELP HELP
  55. Is it possible for a dealer to reflash to stock?
  56. Can someone give me an idiots guide how to use an LM-1 with NON pro HP tuners
  57. T56 speed sensor question
  58. 02 Camaro. Died mid pull, now wont crank, no fuel pressure etc ..??
  59. MAF Dips @ WOT
  60. Don't know where to start...
  61. 1 Controller FI & Carb?
  62. MAF P0102 MAF ckt Low Frequency
  63. LS1 No Start
  64. 12216125 OS 02 Tahoe OS Link??
  65. Looking to buy hp tuner pro and a wideband
  66. VSS signal reaches PCM but no output
  67. Holley EFI PCM ( Dominator and HP)
  68. To ms3pro or not?
  69. What causes a change in AFR command
  70. 5.3 vs 5.7 vs 7.0 Fuel mileage
  71. Pcm output
  72. Need help tuning 5.3 in 87 Trans Am
  73. MS2 v Microsquirt
  74. Wiring Issue 99 Camaro LS1 w/T56
  75. 98' to 99' and up PCM question
  76. Poor Fuel Mileage
  77. Throttle goes over 100%
  78. 4L80E Shift Issues
  79. Hp tuner without pro
  80. swapping o2 sensors in the ecu pinout
  81. Help plz 4l80e segment swap
  82. PCM hack for per gear boost control
  83. Best factory OS for a P01 / 411 / 512kb PCM?
  84. Does anyone have any HP tuners sample files?
  85. Whats a good lap top for tunning
  86. LS7 Connect Cruise kits OBDII compliant?
  87. After-Throttle low Idle issue
  88. DOD Delete
  89. P59 missing channels
  90. 3 BAR MAP Giving me 109 kpa at idle
  91. Read oil pressure?
  92. PCM will not accept a tune and kills PCM.
  93. 4l60-80 tune. Really stuck
  94. OBD Codes: P1125 and O2S/ HTR
  95. 100 octane & 12.4 to 1 static CR
  96. Tuner help
  97. FID Injector Data
  98. Holley EFI 58 to 24 wheel
  99. 98 to 02 Fbody pcm swap issue
  100. Went TorqHead 24x Need Tuning Help (LT! PCM to GEN III LS!)
  101. 6l80 torque management
  102. Adruino RPM
  103. Question on mass air flow sensor
  104. P0102 MAF Signal and Voltage, Signal 9V ?!
  105. Non pre defined wideband setup I NEED HELP
  106. E78 tuning
  107. 11 6.2 dod vvt texas speed cam needs tune
  108. Dod delete issue?
  109. EFI LIVE traction control
  110. What tune for PCM and TAC to work
  111. 02 Sierra . Bcm blues
  112. Supercharged LT1 tuning options?
  113. Crate LSA - ECU Options
  114. LQ9 6.0 swap from 5.3 runs like a dog
  115. HP Tuner question
  116. Wideband Rapid Fluctuation
  117. Diagnostic check at start up?
  118. 2003 Yukon Denali MAF delete
  119. Need some input please
  120. LS3 Swap - Stock vs. Aftermarket ECU
  121. Can’t find anybody to tune my carbureted Ls
  122. Shooting flames..all in the tune?
  123. Banish SD 80 data
  124. Wont start
  125. Fuel Gauge Runs Backwards
  126. EFI tuning
  127. ECM been changed? Odometer reading ---
  128. Need a tuner for Mast Motorsports M-90
  129. red/blue to green/blue
  130. 01 Trans am ls1. MAC scanner shows fualt on all 8 coils ??
  131. haltech base map
  132. Need a tuner near Carson City NV
  133. Timing @WOT from idle
  134. Need help getting the correct PCM
  135. A/C airflow bump trigger ideas?
  136. DBW to DBC conversion
  137. How much fuel will I need
  138. Holley HP EFI Start-Up Tune
  139. Ls1 s10
  140. Help with LS swap
  141. Holley EFI in your F-body info (My experience and install)
  142. Camaro Not running right
  143. Idle on stand but not in engine bay...
  144. Sloppy stage 2 tunning
  145. rough idle and poor performance past 2nd gear
  146. No Ragrets ;) Anyone regret MS3 vs Holley EFI?
  147. Gen 5 boosted target AFR
  148. BCM FRIED! CAN'T FIND NEW BCM for 1999 camaro ANYWHERE?! PLZ HELP!?
  149. Please help, I'm at my wits end. Engine won't rev.
  150. fixing a corrupted 1996 Impala SS OBD2 PCM because of bad programming
  151. Trying to connect wideband to serial port adapter
  152. Mail order tuning, swap harness
  153. Which ECU/harness for LS3 swap turbo build
  154. Starting new LS3 stroker with stock LS1 CPU
  155. from blue/red connectors to haltech ecu?
  156. LS9 into C3
  157. Holley efi
  158. how many licenses I have in my JET tuning software?
  159. What happened to all the injector excels
  160. Read my log and tune....Newbie Blown Tuning Help
  161. Logging wideband via serial cable, how?
  162. The horrible P0307 code! Need help
  163. ASR OFF light always illuminated and switch not working (& other issues)
  164. What would you do next? Chronic Lean Codes
  165. HPT 4L60 to 4L80 With 1999 PCM.
  166. HP Tuner- Keeping You Informed
  167. Gear change
  168. Trans Adapt Reset
  169. gm tech2 on craigslist
  170. 04 GTO Magnacharged, knock problems
  171. Not shifting at WOT
  172. Gm e38 into c5
  173. Wont rev passed 5200 RPM
  174. Can you look at my Hpt. log
  175. HP support for custom OS for 98's ?
  176. Innovate wideband issue
  177. I'm at a loss... weird "stutter"...log file attached
  178. IAC in park
  179. TSP 228r cam help
  180. Wideband sensor help
  181. Closed loop poor performance. Open loop fine.
  182. Need answers to using Flex fuel on an Fbody? Come in.
  183. 5.3 to 4.8 swap 2005 Tahoe
  184. NEWBIE and need help with A/C idle
  185. Using pin 44 for reverse lights
  186. 6l90 controller
  187. p59 pcm cant log misfire with hpt
  188. P0303 needing help!
  189. Hp tuner
  190. Torque Pro, tablets and OBD2 adapters, oh my
  191. mpvi2+wideband when?????
  192. VCM update
  193. explain to me like i'm five MTT vs. main spark (hi + lo octane)
  194. Timing pulled on 2nd to 3rd shift!?!? Have tune and log available
  195. 1999 Firebird
  196. CKP Relearn for Swap application
  197. VSS input requirements
  198. Detonation and Backfiring Low RPM Help
  199. Feasible to create auto-lock from ODBII?
  200. P59 OS for 3bar DBW
  201. Limp Mode Issue
  202. Crazy ´99 Z/28
  203. PCM swap question, hp tuners
  204. Best Book for learning EFI Tuning
  205. Speedo help.
  206. 5.3 swap doesn't want to start
  207. Tuning help / guidance swaped g body lq4
  208. VE to Cranking VE table excel sheet
  209. HP Tuners MPV1 Not Logging All Channels
  210. O2 Sensors..
  211. 1999 LS1 Getting P0157 & P0481 & BATTERY DRAINING! NEWB PLEASE HELP!
  212. Any tech 2 gurus in here?
  213. Tuning of any kind, are there limitations on a 1997 PCM?
  214. Help! LQ9 Won't rev
  215. When converting to a SD tune
  216. Bricked the pcm in my 98 camaro
  217. Pegged at 8 degrees of KNOCK RETARD in 1/4 mile run?
  218. looking for help with hp tuners tune file
  219. 5.3 Random Misfire Code
  220. Email tuning experiences
  221. brake pads
  222. ECM and VATS concern
  223. C5 with 90/90 setup - return to idle issues, idle hunts in neutral when in motion
  224. Dyno fail
  225. need help with HP tuners, cold start up and dfco
  226. Silverado lq4 swap
  227. Remote start install w/alarm
  228. 0411 pcm can't read misfires on SD tune?
  229. Need help - Finally got a data log to post
  230. mail order tune
  231. Easy Smoke test for 0171 and 0174
  232. Loud pop at shift point
  233. 1999 2500 lq4 remote tuner hpt recommendations
  234. Bad ECM?
  235. HP Tuners users heads up
  236. Fires right up and instantly dies
  237. HELP! 2000 z28 ls1, getting p0171 and p0174 codes
  238. L36 Transplant Fighting Its New Home (Not LS But Could Use Help)
  239. Hp tuners vs holley
  240. Accel GEN 6
  241. 1996 Impala SS pcm not completed programming flashing?
  242. LS1 surging idle change cam or converter?
  243. MAP sensor reading 32kPa at idle... Heavy RPM Surge
  244. Need help identifying an e38 ecm
  245. EFIlive 1.2
  246. Hptuners Mpvi2 question
  247. 99 F body alt on 05-06 e40 ecm
  248. Misfire but no error. Please help!!!
  249. Help tuner says mechanical problems and engine builder says nothing is wrong
  250. 4l80e help (trans or torque converter slip)
