- Decreased Timing
- 90 degree bend right after MAF - Can our MAF's handle that?
- PCM not ready
- Shift Points after converter and gears
- Rev limiter Question..
- Is there a fix for the GMAF?
- What is LS1 Edit?:
- LS1 Edit What is it?:
- o2sensor
- diablo sport programmer question?
- Please evaluate, how do these numbers sound after tuning?
- Anyone know of good tuner near Bristol,TN
- Torque Converter lockup after gear change need some advice/help
- 98 alternator; 12 or 5 volt reference?
- timing goes from 30.5 (6089) -> 0 - >25.5 (4600) on 2nd gear shift
- Low coolant light is on, but it's not low ???
- Throttle Follower Airflow Decay - Throttle Cracker Airflow
- Ls1 Edit-should I?
- do i need a tune?
- Ok, autotap'ed my car, what does this mean...
- Trouble codes and performance?
- A.I.R & EGR Removal???
- Used HPP3 Warning
- Can EFILive remove the speed limiter?
- Accel Gen 7 work for 99 vette?
- Trouble Codes
- Anyone know the best price for mail order tune?
- ANyone know anything about the G Tech Pro meter adapter?
- What is the differences in the PCMs in the 2000 and 2002 Z28's?
- HP Tuners is now accepting orders.
- Adjusting the PE table for IFR table changes, need expert help!
- SES question
- Maft
- LTRIMS - 17.5 what does this mean....
- TB only shows 2.8V @ WOT
- Safe to run nitrous?
- Some questions about Scanners....
- Will i need Ls1edit?
- cost of gen 7 vrs FAST system
- What OBDII tool would be best for me?
- got codes
- were to take timing out on nitrous
- I need help with the 2002 LS1 PCM PIN Assignment?
- Knock Sensor codes, what causes them? Nogo?
- IFR table and effects on Injector Duty Cycle
- Stock MAF Calibration - Tolerances?
- Fast
- LS1 Edit ? about VSS
- Looking to buy Good Scanners or Software for Laptop?
- SES light help!
- Could knock be from not using a bilot bearing
- Security Lite
- affordable wideband
- P0327 code where do I start?
- A/F Problem.. Please help!
- Speed inc pcm tuning ?
- Would P0140 and P0158 codes kill my MPG?
- Torque specs on PCM bolts
- Is there actually a chip for an LS1?
- Throwing P0121 code and getting 5.8 voltage at WOT isn't referance at 5?
- Getting a tune Monday...
- Whats the ideal A/F I should look for?
- Installing a Autometer Tach?
- I need some LS1Edit advice.
- Gauge w/ Innovative Wideband?
- Where is the BCM Located???
- kr mod?
- a4 w 224cam + LS1edit wont idle when starts
- Anyone running a MAFT (MAf Translator) on a Truck????
- detonation
- HPP3 or Diablo?
- Anyone have an SES light after 85mm MAF install?
- Price range for LS1 edit
- need some help.... experts please read
- Camaroholic & other computer guru's-WTF!
- need assistance with fixing a code
- logging program for 98 Z and 98 C5
- Which one are you going to get, POLL, HP Tuners or EFI Live
- Can You Help me w/ my A/F ratio???
- Car Wont Start???????
- Delphi/Lucas 36lbs injector offsets?
- KR Problem & Timing?
- Hp Tuners??
- How do you turn off Anti-Theft?
- Maf Translator 02 Chevy Truck
- static 58psi, or vaccuum referenced tuning?
- Just dyno'd, have some n00bie tuning questions
- MAFT causing problems
- Salvage 2002 LS1 won't start
- LS1 Editing at the Track Questions
- HELP: M-80 like backfires when started cold and..
- MAF info--c5 forum don't know $#%@
- Predator Programing Help
- My car won't start...
- She only starts when she "wants"
- Emissions question
- Car running lean
- EFI live Help
- LS1 Edit question
- If you've already had the car LS1-Edited.....
- My LTFT's won't go to zero at WOT???
- P0342 Cam Position Circuit Low Voltage
- If my MAFS was bad would it throw a code?
- Why won't edit read?
- KR when I get off the gas. Any ideas???
- want the car to shift faster...(edit question)
- anybody have LS1 edit near me?
- explain this
- anybody use atap with a palm pilot (pda)
- Desesitizing Knock Sensors
- Stubborn Diagnostic Tests still “Incomplete”…
- Part throttle shift points
- tuning question
- !hpp3!
- what is going to happen
- Got Redlinez on LS1 edit by Jeff Creech at CAM!!
- Missing star connector ???
- Need some help with burst knock
- i think im lean? tuning needed?
- Questions on h/c car passing Ohio emissions
- adjust timing down low?
- Anyone with a ls1edit file close to my setup?
- What maf with a 90mm LSX
- Driveability Guru's...
- car won't start
- EGR and AIR delete
- LS1 edit help with ABS going off due to different tire sizes
- Disparity w/ IFR calc sheets and Edit IFR table?
- Stock F-body MAF tables / poly fit?
- If I don't use HPP III for power tuning?
- misfire problem
- Edit & line pressure?? (exhausted search)
- wide band commander
- camaro weight
- Getting 13 degrees of knock retard
- service engine codes
- Stupid LS1Edit Question on Trans
- Picked up HPP III/power tuning good/bad?
- Anyone use a ACTRON autoscanner?
- Misfire History ... Number counts then back to zero
- I need your advise on ls1-edit
- Tunning idle after cam swap?
- What do you think about these O2 readings?
- any way to clean o2 sensors
- who has had their car tuned by mike at norris motorsports
- Dyno tuning question....part throttle A/F issue.....
- i need help, dieing problem after WOT nitrous run.
- connector C105 question, 98, 99+
- Anyone been using the GEN7?
- Knock Sensor Question.
- AutoTap or EFILive?
- Serious help regarding LS1EDIT/PREDITOR????
- shift set with tuner.
- Which bank is which?
- Simple Question...
- this is shit
- max micro tuner
- P0135 - bank 1 heater circuit
- PE/RPM Change
- When braking lightly on dry road, ABS engages?
- LS1-Edit Version 1.4
- Is my pcm dead?
- VE Tuning Questions - Those in the know please come in
- O2 sensor bad??
- car wont run after th400 and 9 inch swap?
- X1 cam issues
- VE Tuning for boosted cars, can it be done using the 105 MAP reading?
- Whats the GM part # for O2 sensor
- tuners around charlotte
- ls1 edit
- Why won't my car shift at 6500 rpm with Predator?
- When does the stock LS1 computer stop reading
- Cleaning Electrical Connectors????
- Just got my Edit 1.4 update
- Anyone Else Have Tunning Issues With Tsp 231/237 Cam
- LS1 edit tuning in SoCal?
- Is this a programming problem?
- Hypertech Hacked !
- LTFT's Change After Pumping Gas
- Best place to find O2 sensors?
- URGENT - Problem with Predator PC Interface
- Need a cable for EFILive
- How hard is LS1 edit to use?
- does my lt1 car need tuning? it has heads and cam and runs like crap? help!
- can i pull codes with edit?
- VENOM 400 Vicious mod?
- qustions about autotap
- tuning required?
- Setting car back to stock ?
- Wiil It Idle??????????????????
- Threw a P1404...
- anyone with ls1-edit from west TN?
- Diablo Predator Vs HTPP 3
- Running lean on one bank......
- Wideband logging rear O2s, paging ChrisB
- MAF housing porting
- Nelson Performance Tuning
- edit wont hold changes?
- problems with hpp3
- Ls1 Edit Help
- EGR, AIR, Rear O2 Removal, and PCM Programming Question
- Another ve tuning question
- how much gain with a hpp3
- 2-1/16 wideband display
- installed built auto and new converter and now shifts 500 rpm earlier
- MAF Translotar Good Idea?
- Should i get it tuned???
- What causes
- Need help with code P0420
- can I control an auto with my manual trans computer?
- Damn car won't start!
- looking to professionally tuned my car with LS1Edit..sponsors??
- Selling a Timing Tuner/Nitrous controller
- Anyone have a 382 Stroker .LS1 file?
- Is the IAT responsible for just timing advance and not fuel trim?
- No more USB adapters?
- Setting P0106 MAP performance
- Car won't go into PE (open loop 2)
- Rwhp
- Which is correct A-TAP or EDIT ?
- Bad PCM
- P0200 Help Please!!
- Maft with Chevy Truck
- P0410
- maft with hpp3
- Dyno tune ???
- Help with idle on 98 Camaro
- Can Autozone reset PCM?
- if me and my buddy have edit
- 02 sensor??
- LS1 IAT sensor read the same as LT1?
- o2 sensor go bad ...
- Super Chip dyno what they sent me... Ls1 2002
- wtb Motec M48
- re-tune needed after LS6 intake install???
- maft
- 2000 C5 PCM Diagram
- General Concensus on Predator
- How to tune ATI @ 5psi on stock 98 /w no ls1edit
- maf translator
- What is the best WOT Air Fuel Ratio?
- anyone heard of a guy named dave viniger who tunes ls1's?
- What side is a Bank 1 and Bank 2????????????
- OBDll code PO430 Bank 2 1996 TAURUS NEED HELP!!
- SES Light on. Codes checked and...
- SO, is that a NO GO on the LS1 Edit instruction sticky thread? Seems like we need it
- Questions About the Tune in My Car
- Getting 3* of KR in third gear....
- AutoTap won't connect, Please Help!!
