PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. PCM limited to 8k how?
  2. 5.3 in s10, blade style maf ???
  3. Wideband test pipe ?
  4. rear 02 sensors
  5. Turning stuff off via HP Tuners
  6. LS1 in 95 Trans-Am runs for 2 seconds and dies..
  7. HP Tuners Standard version without Wideband
  8. EFI Connection 24X
  9. help with a tune
  10. Need to get OBDII (dash side) port? Where to buy?
  11. P1639
  12. Help with VE tuning....log and tune inside
  13. NGK AFX Powerdex with NTK sensor standard?
  14. I think I have a bad tune!!!
  15. LT1: Timing Curve for best performance?
  16. Texas Speed MOT or Frost MOT???
  17. Have you guys seen this - Dyno-Shaft On-Vehicle Dynamometer
  18. Clearing unnecessary codes forever?
  19. A few tuning questions for my 67 Nova wagon
  20. 5,000-6,000 miles a year, street car, sea level all year round.....SD tune????
  21. Any input on this tuner?
  22. The NEW inTune is shipping this week!
  23. Diablo Tune out AIR
  24. Why is my motor running lean
  25. HP Tuners MPVI Box
  26. Rough engine idling question
  27. Fan tuning question
  28. North Alabama Tuner????????
  29. "Attached PCM's serial number missing"
  30. LQ4 misfire issues
  31. O2 sensors tuned off
  32. vci number a4 to m6
  33. HP Tuner scaner, what can I scan on a Gen 3?
  34. Dyno Tune Near Nashville/FTCKY
  35. After Tex Speed Pack. 1 install on my Automatic Ls1, running weird on OD and Drive
  36. holley HP EFI short install, and a little how to
  37. EFI Live - New Tuning Tutorial question
  38. truck ecu on fbody question
  39. ls1 edit??? need help
  40. p1683 code
  41. th400 tune question
  42. Help with identifiying HPTuners MPVI Version
  43. Manual to Auto?
  44. Does anyone have injector data for trick flow injectors?
  45. EFIlive Cylinder Numbers???
  46. Help! There's a unicorn in my engine bay, somewhere
  47. 97 or 98 Fbody PCM into 97 Vette?
  48. 4L60e -> th400 tune?
  49. Lean at idle
  50. Mefi4b harness
  51. P0740 & p040
  52. A4 to M6 swap PCM tune
  53. problems with tuning shift points!!!!!!!!!!!!!
  54. how important is ifr on a speed density tune 60lb siemens
  55. best tuner for 98 pcm
  56. Mail Order Tune
  57. 07 Heads/Cam/Stall A6 with up-top shifting issues
  58. edcmat-l1 tuning in Fredrick MD Dec 2nd
  59. Which E38 PCM & Harness to Use?
  60. good efi tuners where are you?
  61. need a stock 95 auto bin file
  62. Blown fuse problem
  63. LY2 BCM bypass
  64. Self tune with diablo for cam?
  65. EFI Live Spark tables can someone explain?
  66. Help using Crank Trigger with LS3 and XFI
  67. Tuners are you using narrow-bands to tune?
  68. whf happned here? log inside
  69. Fan coming on when engine is cold
  70. New design 4L60E has different electronics 2008+
  71. IAT harness
  72. How much will i gain??
  73. Wideband stopped working
  74. How does O2 respond to misfire?
  75. Tuning with a MS4
  76. EFI live questions
  77. Do i need a tune?
  78. bs3 files being hidden / locked
  79. 6 speed auto/T43 support now available in Trinity
  80. Diablo predator tuner
  81. Throttle Body Oscillating on ls6 drive by wire
  82. EFI Live license?
  83. Which Computer should I use
  84. Bricked pcm?
  85. New to tuning...
  86. XFI vs. Stock PCM on a hybrid turbo car...
  87. timing with boost and E85....
  88. P0420 Sets At idle only
  89. Question on Pcm Swap...
  90. Speed Density Tune for Turbo motor?
  91. Best dyno tuner near Nebraska
  92. new to the tunning side of thing what one would you buy for a lt1 24x conversion.
  93. Beware: Chuck CoW is trolling LS1 Tech....
  94. Help: VSS wiring?
  95. tuner
  96. A couple tuning questions
  97. edcmat-l1 is a tuning guru!
  98. Need to find a good dyno near southern AL
  99. Fighting through some idle tuning, any ideas?
  100. Good LS7 tuner ????
  101. P0300 code, can't seem to get to the bottom of it.
  102. lean condition @ wot
  103. Help with idle and start up Fast 102
  104. Current applied to MIL PIN
  105. Another $500 Dyno Tune....
  106. mail order tuning - how this can work?
  107. BS3 IAT Question
  108. tuner pro rt and revlimiter?
  109. excellent Dyno Tuner in the Lower Mainland Vancouver Abbotsford BC Canada HP tuners
  110. So the wife & I are driving along. . .
  111. So I've decided on hp tuners but will it work with all my cars?
  112. How does the mil work on an Ls1
  113. Anyone have a bin file for G5x3 114?
  114. who does the best mail order tune
  115. Downloaded HPTuners Demo...
  116. Cams and tuners and other add ons
  117. Keep LS2 GTO VATS for Security, Cruise and A/C
  118. data logger.?
  119. Help me with my datalog results!
  120. C5 Codes
  121. Diablosport InTune taking orders
  122. Can the OEM setup run without MAF?
  123. Dynojet Wideband 2 narrowband simulator
  124. Different year F-Body, different PCM??
  125. Crank sensore help. 58 to 24 tooth
  126. Anyone know where this tuner is??
  127. New to tuning on LS engines
  128. Car disappointed on the dyno and now throwing P0300?
  129. p0300 rain today.
  130. Low Elevation to High Elevation
  131. help!! looking for a tuner
  132. Repositioned MAF to a better location. Will this affect my tune??
  133. Help with LS1-Edit programmer
  134. turbo tune
  135. Need some help with these codes P0332, and P1133?
  136. Laptop died while downloading from the pcm...
  137. Phone Apps For Diagnostics?
  138. Suggestions for mail order tune
  139. P0440. Need help!
  140. Setting up LC1 in EFI Live
  141. Am i going to need a need a tune?
  142. Idle issue on cammed LS1
  143. Need a tuner
  144. installed pcm, won't run
  145. Misfire codes common with cam only car with no tune?
  146. Has anybody tuned for economy?
  147. T56 to 4L80E tuning
  148. How to "turn off" knock sensors???
  149. Need Help with E85, HP Tuners & a NA Motor Tune
  150. In the numbers? Nailing down a hesitation problem.
  151. Racetronix impedence converter connectors?
  152. maf tuning problems .. slp related ???
  153. Mild annoying idle issue
  154. Base tune for 2000 trans am m6 with bolt ons and tr230 cam
  155. please HELP I want ls1 programing file
  156. In the market for a tuner
  157. 2010 6.2L L99 Camaro Engine swap Jeep, speedo reads 158 MPH
  158. E85 tuning and opinions for dd...
  159. Boosted application LS1 PCM or Truck PCM???
  160. Tuning question from new guy
  161. what do i have to do to change my pcm from 98 to 99 or newer
  162. AEM's new Infinity-10 Standalone
  163. So Cali tuners?
  164. looking for someone to tune my 6.0 ECM
  165. High Idle problems
  166. Crazy signals 454 LSX HP Tuners
  167. AKM Cable issue
  168. EfiLive PID questions.
  169. Operating system conversion issue HPT
  170. L92 only starts once per flash
  171. Wierd issue need help!
  172. Computer tuning with the 4L60E. help.
  173. Not making power on nitrous
  174. How to Read code with Aeroforce?
  175. ecu swap?
  176. LS2 9s impala computer trouble???
  177. LS computer compatibility
  178. help no gauge power or diagnostic power lights flash
  179. HCI LS1 only making 423rwhp/381rwtq
  180. EFI live tuning for new injectors, couple questions
  181. LS1 with BS3 won't start
  182. Question about SD tunes
  183. Pulling Timing with HPtuners
  184. P code and Idle/IAC help
  185. 98 LS1 won't run P0102 and P0506
  186. Anyone tuned their VortecMax?
  187. Where is a good sd tuner around the St. louis area?
  188. Forged 347 First time start up problem???
  189. can we activate DoD when we want?
  190. MAF problems..NEED HELP
  191. SES light help
  192. need help no tps or map voltage
  193. Need Advice with innovate Products
  194. Can I use the diablo predator to load a decent tune on my car
  195. SES Light. PO157
  196. Dumb as a hammer, fast as a snail
  197. PCM From Motor Swap
  198. high maf frequency code on a 98 camaro
  199. Low threshold after o2 delete
  200. HP Tuners and EFI Tuning book offer
  201. HP Tuners Special 4th quarter offer
  202. Will HP tuners tell me if cam sensor is bad?
  203. 99 SS won't run
  204. getting idle right with HP tuners
  205. lean when hot?
  206. WTF.. Please help me with Warm Starts
  207. Has anyone reflashed an entire PCM from EFI live 1 bar
  208. EFI Live, Rich at Idle correction...
  209. Electric fans with non fan PCM?
  210. AEM Wideband Question.
  211. Emission Question
  212. Anyone know a place for free obd2 software
  213. what tuner???
  214. My tuner says get BS3
  215. strange 2-3 shift issue. rev limiter from a dig, shifts fine from a roll.
  216. Auto Meter Tachometer install on LS1 12200411 pcm
  217. XFI and XIM or EFI Connection 24x?
  218. searched but no answer. P0174 code help.
  219. Installed LC-1 w/ serial connection but EFI live not reading signal
  220. Low power at high rpms, slight missing feeling in mid range
  221. Holley Domitator EFI users
  222. car is misfiring after powershift datalog inside
  223. where/how to learn HP Tuners?
  224. car starts and immediately dies, not VATS
  225. Air Fuel Ratio Questions
  226. wireless driod engine scanner $45. legit??
  227. 02 volts - Good? Bad? Indifferent?
  228. Where did my brake light go??
  229. crank relearn procedure wont work
  230. PCM identification
  231. Need to fix, wrong OS loaded on my pcm
  232. Disimiliar header primary temps
  233. No TPS Signal Help!
  234. low rpm hell!!!!!
  235. Plug heat range vs Altitude
  236. LSX PCM on Toyota 3UR-FE V8
  237. 98 ecm on heads/cam car idles high - sometimes
  238. EFI Live Real Time Tuning
  239. Tech2 questions
  240. Noobie injector question
  241. Looking for stock numbers
  242. Pro's c and Con's of going with speed density tune
  243. Need speedo recal for 4.10 gears, who do i go to?
  244. Issues with Start Up
  245. 1998 z28--need advice-lq4 swap--wiring questions
  246. 411 ECM Power
  247. Do you guys use ignition boxes?
  248. p1336 "ignition system or missfire"
  249. Slow throttle response Fast102
  250. Anyone have a hp tune similar to mine?
