PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 [74] 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Does TTP lock PCMs?
  2. P0122 TP Sensor Circuit Low Voltage
  3. Changed a few things do I need a retune??
  4. PCM reflash question
  5. efi live - lm1 hook up
  6. Map sensor problem
  7. How Do I Disable Traction Control?
  8. Will a hypertech programmer overwrite current tune?
  9. LC1 to efi live question
  10. p0507
  11. Anyone turn all your O2's OFF
  12. How to remove my computer
  13. WOT O2 Question
  14. Problem getting conversion started.
  15. injector tuning question
  16. Has Anyone Been Tuned By HP Performance Corvettes?
  17. 0 iac reading?
  18. Anyone else disable PE during LTFT tuning?
  19. megasquirt II on a 5.3
  20. I need a tune for my 97 ws6 transam in Houston, Tx????
  21. L 89 TPI Idle Problem
  22. Is a handheld capable of tuning highly modded cars?
  23. car shuts it's self off
  24. adjusting timing
  25. coils going bad?
  26. Resource for BigStuff3
  27. problems with HP tuners seeing VCM
  28. Engine braking when trying to coast.
  29. 98 SS won't pull more than 45-4700 RPM at track?
  30. advanced timing effect afr?
  31. Z28 wont rev past 3k rpm while driving!
  32. wideband sensor getting to HOT?
  33. FI tune
  34. HP tuners application key?
  35. Help me solve my 3800 stalling issue.
  36. No local tuners...who should i go to?
  37. Anyone know where I can get a tune for a TR230 cam?
  38. LT1 CPS SES-can it be defeated?
  39. Where is my Throttle Response
  40. 98 thru 02 Camaro PCM interchangability?
  41. VE table
  42. GMPP LS7 tune problems
  43. Tuning for 230+ cam
  44. What Do You Guys Think?.. Do I Need Another Tune?
  45. need a tune shop around mi oh or in
  46. LS6 TPS Signal Wire
  47. I am SUCH an Idiot!
  48. Best spark for mileage
  49. How do you delete Theft Deterrent Fuel signal from PCM?
  50. gears, tuning question.
  51. need help timing problem
  52. studdering
  53. AFR problem at rain
  54. Help with misfire, stumbling cylinder dropping
  55. can a accel gen 7 for LT1 be used
  56. need a tune!
  57. Will a vaccum modulator help he out?
  58. 2005 vette fan programming
  59. Do PCM's work for all cars/trucks?
  60. MT2500 Capability
  61. Strange problem, do I need a re-tune?
  62. Trans shift and tcc settings
  63. Mail In Tune / Long Tubes Question
  64. big stuff/aem/ ect please come in
  65. How to Get More TPS Volts?
  66. Running rich??
  67. No power to dash or ignition....
  68. M6 to 60e swap with COS3 & SD
  69. Have a tunning question
  70. Need Drive-By-Wire Help
  71. When IAT is unhooked it reads -39...how about modifying these tables for nitrous.
  72. Need Help Fast Please
  73. tr6 plug and colder?(issues)
  74. Odd problem I believe to be MAF related
  75. noob to tuning
  76. tuning 160* thermostat question
  77. Fuel pressure through fuel tank pressure
  78. E-mail order tune lol
  79. No crank after fuse box relocationH
  80. bad iac?
  81. usb-serial adapter cable driver problem?!?
  82. STS tune/log.... first day out!
  83. surge help
  84. mail order tune
  85. high idle while in neutral?
  86. Cold start idle w/ AC on problems
  87. Reset FT's not allowing PE?
  88. 502 ram jet ecu value?
  89. Need a good tunner in nw Indiana (or MI,IL if needed)
  90. trans od help with codes!!p0748
  91. What's the difference?
  92. any write ups ?
  93. Need help. code 171b,174b
  94. is accel dfi gen 7 any good?
  95. Tuning for Transmission Pressure
  96. Iphone obd2 scanner
  97. 09 G8 engine controls diagrams
  98. need quick tune
  99. Anyone have a EFILive 2 Bar SD supercharged tune?
  100. trans overdrive issue
  101. tps won't read 0
  102. Lingenfelter LNC-002 always active??
  103. 98 2 bar and boost tuning questions....using hptuners
  104. Tuning for 4.88 gears
  105. Engine Shuts Off at idle when hot.
  106. HP Tuner?
  107. can't see .hpt files?
  108. Running out of options(long post please help!)
  109. Best Mail-Order with H/C to break in new motor
  110. Vin change?
  111. whats the best tune u can buy to do it urself
  112. TCS problems
  113. Questions about Stock Tune on HPtuners Bin
  114. SCt HAnd held
  115. Tune from texas speed? ok?
  116. Any break after tune?
  117. Are aftermarket PCMs better?
  118. Injector Duty Cycle Questions
  119. No VE Tuning?
  120. 98 harness 99 motor and pcm
  121. LC-1 VS AEM Uego
  122. Please help!!bad tune? runs like crap
  123. When clearing an ses code, is it "turned off" permanently?
  124. Bird_of_prey
  125. wideband controller??
  126. EZ-EFI Self Tuning Electronic Fuel Injection ????
  127. Troubleshooting P0340
  128. no connection to interface OBD II checks good
  129. ls1 edit. help?
  130. does Knock sensor code revert timing to low tables
  131. my converter won't lock?????
  132. hypertech pp3 question
  133. hypertech handheld question
  134. oil pressure switch
  135. what tables???
  136. PCM swap
  137. new chip ideas?
  138. burn rear o2 sensors / tune
  139. very quick question about KR
  140. Can You Eliminate Knock Sensors?
  141. Computer mount?
  142. Help! Tach failing =(
  143. Race Proven Motorsports
  144. hp tuners in nw indiana CHICAGOLAND
  145. Vats
  146. ltft at 25 when crusing
  147. ls1 oil pressure sender unit
  148. Transmission tuning. what needs to be done?
  149. Bad Map?
  150. lsxtune/tunedbyfrost..... difference?????
  151. Returning to stock?
  152. Swapping TB's what issues will I have?
  153. Turn off all o2?
  154. idle problem and stumble on truck
  155. Recieved my tune from Ion (madz28) today and...
  156. Backfire issues......
  157. Which one?
  158. 1998 FBody Owners Looking for Chasis/Body Code Readers SOL!?
  159. Rich after Cam Swap
  160. 99 pcm on a 98 harness
  161. Stupid question-Will '02 LS1/A4 harness fit my '99 LS1/A4 ECU
  162. Idle and 60 pound injectors on hptuners.
  163. Does misfire detection work with Hptuners SD operating system?
  164. What are these wires for on PCM?
  165. Anyone know what gauge wire this is?
  166. HP Tuner Reading Different Car
  167. diagnostic connection, ls1
  168. Wiring Harness Headaches (please help ID wires)
  169. anyway
  170. codes c1232, c1233 & c1248
  171. My Nightmare!
  172. Do we all got respect?
  173. OBDI tune issues
  174. 3 bar map splicing
  175. Need tuner
  176. How to swap from 98 to 99+.. guide, sorta
  177. the tuning school
  178. high gear/rpm problem
  179. What to expect on Bolt-On Tune?
  180. Codes wont fully go away all three keep returning??
  181. 5.7L ls1 to 383 stroker tune timing question
  182. HPTuners Quick Help
  183. Need Help with OBDII Readiness
  184. wrecked t/a trying to re build
  185. Tuning specials!!!
  186. LT1 Hot cam fuel & Spark tables
  187. Cylinder balance test
  188. AFR Table for full-time Open Loop?
  189. need DTC help
  190. anyone try this yet
  191. Installing EFI live questions and problems
  192. Tach pulse for 3rd gen LSX
  193. Whats my best course as far as PCM tuning?
  194. Trooble Shoot Car wont turn on
  195. HpTunners Bin
  196. bad maf??
  197. Best o2 sensor setting codes
  198. Is my situation as grim as I think it is? C5 battery leak.
  199. LT1Edit Mailing List
  200. looking for good tunner in se michigan
  201. tuning low octane spark table.
  202. Need help with L76 Question!!!!!!
  203. Tune Locked - Need help
  204. anyone know of any good tuners in south texas?
  205. From upstate N.Y. with an OBD1 LT1 looking for a good tuner preferably with a dyno
  206. need gas
  207. General ECM Question.
  208. 2K rpm on the street, Iddle fin after 2 sec when I stop
  209. timing table help
  210. Car Dies at IDLE, and AC on
  211. Posted on HPTuners as well, but every bit can help. . .
  212. Handheld tuners vs Hp tuners software
  213. 210 to 160 stats tune
  214. Shift points?
  215. Running rich
  216. Misfire scan
  217. Mail order tunes????
  218. Wierd tuning issue on dyno
  219. When do you consider a tune done?
  220. Low Voltage in all 4 o2s?
  221. P0200 and P0332 and others.
  222. B4C Shift problem
  223. heads and cam and turbo, throttle body question
  224. HP tuners version question
  225. tuning HELP
  226. MAF wire grounding out?
  227. Alternator Problem
  228. Hypertech Power Programmer III
  229. Ran over RACOON! Now NO B2,S1 o2 sensor ACTIVITY
  230. Need to pass inspection in Texas
  231. In need of tuning
  232. manual override on A4 not shifting
  233. Newbie Needs Tuning Help!
  234. timing
  235. Throttle body causing p0121
  236. crazy lean @ idle then shuts off?????
  237. unable to tune
  238. need stock file
  239. knock sensor low input?
  240. P0342
  241. 98 Z28 99+ecu swap
  242. M6 to A4 swap?
  243. TPS readings
  244. Max Energy Power Programmer ???
  245. tune for supercharger
  246. New to EFI Live Tuner need some help plz!
  247. Will LT Headers & y-pipe set a DTC?
  248. Wide band bung location on header
  249. SLP MAF Maxed out!!! Need Options!!!!
  250. Bench tune needed if dyno later?
