- Auto harness & PCM work with an M6?
- Looking for good tuner in the Jersey area
- No data link from pcm to OBD
- 5.3L Into a 98 F-body. Do I need to do anything with my wiring or ECM?
- P0200 code what next?
- Just finished installing a 2K LS1 motor, need some tuning help please!
- Mis-fire when warmed up.
- Air Fuel Guage
- Holley dominator wiring
- Trying to get dialed in with WB need formula help with LC1
- FAST 102/102 tuning issues
- Looking for LS9 injector data for LS1, going in tvs1900
- tune for extra pcm
- Help! Tuner is lost!
- flashing pcm to different year
- Low Load Low RPM Ping But No Knock Retard
- Which Table In EFI-Live To Adjust For Hanging Idle
- VERY confusing misfire issue!!
- 2002 Trans AM Tuning ?????
- "Unable to locate VCM" error in HP Tuners
- turbo c5
- Ls1 tps tuning
- LS3 416 Tach quit working now surging????
- Wanted - Tuner near Nashville
- P0113 wiring issue not in connector
- Best Brand to read AFR on HPTuners
- 2 bar map question
- 3 codes after 4L80 swap
- Help flashing a tune HPTuners
- trying to think of a speed based output in stock pcm to control solenoid
- calling Don (slowhawk) or any other tuning specialist
- Help With po336 Please?????
- New to tuning
- Tick performance dyno tuning
- HP Tuner 2-bar SD - can you add MAF?
- Anyone running s2(android) tuning apps?
- Hell Just Froze Over
- Knock at WOT--FALSE KNOCK???
- Bad IAC??
- GREAT SERVICE edcmat-l1 hitechtuning.com
- Critique my 5.3 turbo tune...mainly timing 2 bar SD HPtuners
- DiabloSport dspI1000, DiabloSport inTune Touch Screen Tuner
- turbo c5 wot knock
- efi live v1 trouble
- Car Miss-fires above 50mph
- AFR sensor placement?
- mail order tune??
- Holley EFI Dominator Questions
- need a new laptop for tuning
- Tuning in Twin Cities - Rear O2 Delete
- hanging idle and car wont idle at target idle
- Ls2 l77...
- Cars/Cags Lamp Pinout, 99 F-body
- Cammed ls1/t56: sudden lean and high idle conditions
- Sct programmer
- Need help ses light cuts in and out pin loose on ecu
- looking for help on STFT and LTFT normal readings
- efi live help
- FAST 90mm: going to redo idle tuning, tips and tricks welcome
- gen IV problems.
- tuning books
- Multiport Retro-Fit EZ-EFI Questions
- 99 z28 no start
- New e-testing?
- 99 ss problems
- quality of autometer wideband O2's for tunning?
- Need tuner in Delaware area
- Carb back to EFI
- 2 issues: Lterms frozen at 0.0 and -3.1 cruising and running WAY hot.
- Re-Tune?
- HPTuners....adding percentages across the table?
- changing intake
- alter tune for 100mm MAF
- How much timing advance on a turbo LS2?
- Does E40 ECM works with a 2001 5.3 (24x) Motor ?
- 98 Chevy prizm hesitation
- Predator
- Trouble codes for low 02 switching with brand new sensors
- Effects of larger intercooler on VE and AFR?
- Need Some Bin files
- surging issue after MOT and cam install
- *UPDATE* 4/17/13 4L60e No 3rd Unless Selected?
- Tuning in Salt Lake City Utah
- HP tuners - 5.3 timing table vs LS1 timing table
- New tuner need help
- Tuning with individual EGT!
- P2135 Code
- 4.8 vs 5.3 computer?
- PCM question
- Idle Timing with Cam?
- Efi live
- speedo not correct after gear change
- Engine swap/pcm compatibility question.
- 98 to 99-02 harness??
- Tuned to run too rich?
- Tuning question
- A/f ?
- (Video) What does this surge/stall issue look like to you?
- new tb/intake+wot=p0123?
- Displacement On Demand
- vats-passlock
- Is there any digital gash gauges out there ?
- Holley EFI use with stock gauges
- Can I tranfer a tune from my 98 speed density to a 99 with a Maf
- battery disconnect bad for the ecm?
- Tune questions
- Would a frost tune fix this?
- Tuning maf vs speed density
- Ls1 gauges sweeping
- High tps voltage with nw 102 tb
- Ltft bank 2 help
- Problems after shift light install
- trouble shooting codes p0174/p0171 and others
- Need best hp tuner person in the alabama area
- Need tech help - Want to convert CSFI injector controls to LT1 injectors
- Help, MAF Issue?
- PCM Not Seeing MAP Output
- help no start no spark
- Contact help, frost?
- Does this tune make my plugs look fat??
- Looking for tuners?
- Help need tune Huntsville Alabama
- 95# injectors help with efi live flow rate table
- EFI live ?
- Hp tuners sale?
- Question about emailing a tune HP Tuners
- looking for a tech 2 scanner
- Curing the "reduced engine power" TAC issues.
- Moving HP tuners to another computer
- best ecu for twin turbo project? 24x reluctor
- wideband o2 sensor help!!
- Need help for my 05 GMC?
- Buying HPT - how long did it take you all to "pick" it up
- 99 5.3 tsp problems
- Misfiring, please I just want some opinions
- 5.3 Tune help
- help with my setup!!!
- A/C Compressor control PCM?
- Tuning drop throttle response
- keep changing ve table but no difference 2 bar turbo
- AEM wideband issue
- 1996 Z28 Built with 24x conversion Need tune
- Max VE for an stroked L76?
- Battery Died While Reflashing, Now PCM Is Locked
- Need help mail in order tune C5
- Need help Tuning my new LS3 Xim please
- Changing back to stock MAF
- Can you switch ecm from one cammed car to another?
- Reading AFR using LM1 & HPTuners...having problems!
- Bank 1 sensor 1
- swaping tunes via hpt
- can you have switch activated maps?
- P0118 two times in one week even after replacing ECT
- LS1 denotation in low gears only...ideas?
- What else could cause Fuel trims to go high and O2 sensors to read lean?
- O2 sensor not working HELP
- Engine will not start
- cat-less engine light tuning
- can i adjust shift points with intune?
- High RPM idle; Ive about had it!! Arg.
- P0200 & P0121 codes need HELP!
- Bought a 2001 5.3 LS & 700R4 but no computer or wire harness. Which one do I need?
- Tuning after mail order tune?
- what tables to change from 5.7 to 6.0
- c6 m6 reasembly
- Fixed p0102 now running worse, HELP!
- Ls2 408 fbody firing and fuel problem!!!
- DBW help!
- WOT AFR very rich from what commanded AFR should be.
- TOTAL OBD & ECU Auto Diagnostics (TOAD)
- Thinking about switching to a 2 Bar MAP Speed Density Tune
- 71 camaro ls1/4l40 swap to t-56
- Need wiring help!!!
- Bone Stock 2003 zo6 - 96% duty cycle
- How Do You Adjust Idle Airflow Using EFI Live?
- Any advantage from a Frost tune on almost stock ride?
- LS7 card style MAF and tube info
- How long does C6Z PCM retard timing for knock?
- newb question
- bad tune? p0300
- Question on a frost tune.
- No start Hptuners vats?
- 4.8l Dyno mule
- Diablo tune for Procharger?
- Tuners near valley forge Pa
- I need a 6.0 4l60e .JCL .BIN or .CAL file!
- Ls powered gen 1 cutting fuel
- what am i missing??
- Does anyone have an HP Tuner in the DFW area?
- 99+ pcm swap tachometer issue
- Ls1pcm will works on ls3 engine?
- Need help ASAP please!!!
- DBW WOT problem
- Figuring out wiring of harness
- Which wideband a/f gauge?
- tuning please help!!!
- Help with these charts
- Ls7 swap in f-body
- Mail in tune
- Need help figuring out wiring harness/pin outs on plugs
- Computer help on 98 Trans Am!!
- Tune needed if changing thermostat?
- Input Needed on Honeycomb for lS7 MAF Sensor
- Slight Surging
- button on automatic shifter sticking
- ARH Wide Band Bung Location
- WTB: HPTuners Suite (pro) with at least a couple credits
- Could a Reputable tuner give me a moment please?
- Hypertech questions
- Greer Performance in Ft. Wayne Indiana
- need help wiring an SES light
- H&P Performance Offering Tuning Solutions in the midwest!!
- ECM flash?
- Temp gauge signal??
- Knock Sensor Location
- 6.0 tune for Jet DST?
- hp tuner question
- New tuning/turbo fabrication shop in iowa!!
- Air Fuel question
- Finally some good data for Siemens 60lb Injector
- cutting wires
- Will scaling 200lb inj from 60lb inj be risky?
- RPM/Engine will Not Respond to Pedal, CAM Tune E38 HELP!!!!!!!!
- Gas Mileage Question....
- Tune all of a sudden running lean?
- Car turns over then dies after starts
- 2001 Pontiac TA
- Hitting the next gear problem
- Tire height wrong in computer?
- Looking for the trigger wire for LS-3
- 5.3l swap... HELP!
- Tuning for Hanging Idle
- ls1 wont run
- what is the best AFR for 12.5 cr engine ?
- Full tune or monitor?
- P0300 Code Can't figure it out
- Time for a tune or not?
- First Start Tune Recommendations
- Problems =\
- First time w/ EFILive, getting knock retard?
- how much timing are you guys running with CR less than 10.0:1? Chime in plz
- Power band
- How to test for VSS signal
- TPS WOES - Getting pissed
- Adjusting Map Offest
- innovate lc-1 wideband ???
- Innovate Wideband Installation
- Tunning 4l80e
- tuner near middle tn
- Holley hp efi enough for TT 5.3
