PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 [96] 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Looking for good tuning shop- Houston
  2. Tuning??
  3. Turbo Tune
  4. Predator help
  5. brake light/abs inop
  6. 97 Z28 P1641Dand P1642A
  7. Tuning Help
  8. How upload tunes on pcm with efilive?
  9. Tennessee Tuning
  10. 95 lt1 and tunercat?
  11. missfiring problem
  12. looking for tune Danville/Lynchburg VA
  13. idle issue
  14. MAF Bypass
  15. tuning help
  16. Efilive Help
  17. What MPH equals what RPM shiftpoint?
  18. Car won't stay running NEED HELP M6 - A3 swap
  19. SD tuning question
  20. Where to get a tune in Fort Worth?
  21. Looking for LT1edit guidance or good how-to links...
  22. PCM tuner purchasing help
  23. 3 bar, 1:1 FPR, VE, misc...
  24. Best Tuning Tool
  25. E10 Stoich?
  26. tune
  27. Finished my tune (with a lot of help from yall) Couple questions
  28. what timing should I be running(EFI live)
  29. HPTuners COS being logged in EFI LIVE
  30. Car tries to die at start up
  31. Please Help!!!!!!
  32. Lots O Questions mostly O2 related (w/ scan)
  33. hpt+ fjo wideband??
  34. Disable code -- impossible to complete diagnostic test?
  35. Battery power cut off switch.
  36. Programming the LC-1 for EFILive
  37. Jeremy Formato Tuning and Porting in Gettysburg PA 11/29-12/4
  38. Looking for Tunes
  39. New HPTuner...what should I do first to improve performance?
  40. What's the cycle for emissions testing.
  41. Tuners around San Marcos, TX area
  42. Installing PTB in a few days. What to expect?
  43. Is there a software ECM tuning package for 96 Camaro V6
  44. Backfires
  45. Selling my HPTuner Hardware & Software
  46. stft plus 4/ltft -11!!??
  47. ses p0141 bank 1 sensor 2-Help!
  48. Pinging - tune problem?
  49. Fuel trims at 10% or higher
  50. tuning shops near Spokane Washington
  51. The Big Question!
  52. 28-48lb injector tuning.
  53. HPTuners max timing issue HELP!
  54. Factory O2s off, commanded A/F, ect...
  55. ported maf ends or slp maf
  56. Knock sensor codes
  57. Looking for a stock C6 LS3 Tuning File
  58. LM1 and new system
  59. LS1Edit? Is it unlockable, if I locked it?
  60. surging idle
  61. p0300 help, log and tune attached
  62. wideband
  63. Adjusting VE table bigger cam/heads..values lower now at low rpm? Normal?
  64. Climate changes and SD
  65. maf wire shortin out?
  66. p0327 and p 0332
  67. Car keeps stalling when coming to a stop after FAST intake install.
  68. Just bought a SS...
  69. 02 sensor's bank 1 and 2 sensor 2 codes??
  70. instrument cluster help
  71. engine swap question
  72. please need your opinion on tune
  73. Couple of ECU questions
  74. LC1 wiring question
  75. is there a programmer that sits on your dash for an LS1?
  76. looking for ls1 tuner in NJ
  77. SD question
  78. Some help please with a Cam only ZO6 tune
  79. AFR 205 and Mamo Cam (224/228) tune
  80. A/F Ratio's compared
  81. HPTuners/replacement PCM...
  82. Stability Track Issue!!! please help
  83. Crazy ASR light!
  84. New product: Painless Perfect ECU
  85. Need Suggestions Please.
  86. Datamaster for AFR Data?
  87. Tune for shifting Help!!!
  88. Discussion about PE Modifier Based on RPM (B3618)
  89. Need Help!!!!!!!!!!!!
  90. falling apart?
  91. Tuning converter
  92. Fuel pump install causses rich conditon
  93. diablo tunning question
  94. LT1 scanning question
  95. Diablo Sports Predator
  96. Piggy back chip
  97. PIDs?
  98. LS7 MAF no reading HELP
  99. 02 sensor vote, whats better
  100. Please loOk at my log file 402 N/A
  101. What effect, if any, does spark/timing have on AF ratio?
  102. P0300 after heads, pulley, TR224 install??
  103. Injector tuning
  104. LC1 tuning with HP tuners
  105. what kind of computer tuining do i need
  106. porting info needed?
  107. Trouble Code p0300
  108. What's the exact EFILive IFR table for FAST 36#'s?
  109. Timing & CR on AFR heads
  110. F.A.S.T. programmer
  111. I know nothing!
  112. false knock driving me crazy.
  113. W.o.t Timing
  114. Vacuum issue???
  115. HPTuners for a 2008 Trailblazer SS
  116. O2 Sensors??? Confusion...
  117. AFR, MAF, WOT, and WTF!? Oh my! Help please!?
  118. Software for 98'
  119. Scanner doesn't work?
  120. I need a tuner.
  121. tuner needed in LA or TX
  122. Someone who can read tunes, tell me whats happening?
  123. hypertech power programmer 3
  124. How Do I?? LC1 to HPT.. Wiring and Calculations
  125. Superchips Model 2825 Flashpaq Tuner
  126. stupid HPTuners question
  127. Hypertech
  128. Need Help Please....
  129. Logging - what to buy
  130. Innovate LM2?
  131. IAT dead - no readings
  132. getting a tps code, whats the cause?
  133. question on 8.1l injectors
  134. Need Help
  135. Trouble Code Help Here
  136. Reduced Power Mode....................
  137. Need Injector Spreadsheet for 06+ GM Vehicles
  138. best way to upgrade 02 LS1 to LS3 from PCM point of view
  139. what is crank relearn?
  140. AIR blockoff plates
  141. Tune a LT-1?
  142. Cheap and easy efi for LS1/fox swap?
  143. O2 threshold MV for better/lean idle on LT1?
  144. IAC Count? What to do?
  145. what EGT setup to use?
  146. Need help
  147. ACCEL 4L80E programmable transmission controller
  148. Gauges problem revisited
  149. code 1345
  150. little black box?
  151. need tuner!!!
  152. need OBD1 tune on 95 Trans Am in Colorado
  153. Tuning - is it best with a dyno?
  154. Cleared Code Returns
  155. Rejected at Emission test....Tuning???
  156. Speedometer Incorrect: What Tuner should I get?
  157. Shifting Question
  158. what to change in a tune on a bolton car
  159. Hanging Idle
  160. Problem starting
  161. torque converter sluggish?
  162. got codes?
  163. SES error and inspections??
  164. P0336
  165. Tuning Guru's come in... 1-2 shift question, Screenshot within
  166. Xcal2 Problem on 02 WS.6??
  167. lost traction after I changed wheels/tires
  168. P0342 / P0343
  169. No Power
  170. car dies when put in reverse
  171. Just installed Wideband need Tuner DFW for a Touch-up Tune
  172. Tuning with a wideband- need help
  173. Can I adjust for moving idle speed?
  174. Can u tune out the 02 SES light w/ hptunners?
  175. resistor timing question!!!
  176. Need HELP FAST
  177. pcm voltage on egr sensor
  178. Maf problem
  179. car runs better with tps sensor umplugged
  180. Went to the dyno today
  181. Please give some kind of advice..will shorting a hot wire damage the pcm?
  182. Will I need a tune
  183. lenth of tune and problems
  184. Need help wiring up my 98 LS1 in my 1996 Z28. Thanks
  185. Does this make sense?
  186. HP tuner: SD tune questions
  187. problems after tranny swap
  188. How much tuning can be done on factory pcm?
  189. HP tuners question
  190. AutoVE nearly complete - observations and questions
  191. Is the painless powercom system any good?
  192. How do You Pass Emmisions?
  193. P0327 CODE, Any advice??
  194. Hp tuners
  195. The Worst Thing EVER
  196. Idle tuning? lean spikes?
  197. HP Tuner peeps come inside
  198. HP Tuners - standard MPVI vs Pro MPVI
  199. BS3 users
  200. Idle Air Control/tuning problem
  201. In stalling headers on 99 Z28 how do i delete A.I.R pump
  202. 98 Computer w/ nitrous???
  203. Ls1 Edit program question...
  204. Pcm problems or not?
  205. Greddy Gauge
  206. I need some pinouts of these 98 LS1 connectors (c100, c105, c210, c220, c230)
  207. 02' hawk failure to let ls1 edit attach.
  208. Need to make tune better
  209. Maf Sensor causing car not to start?
  210. What are the 98 boys using to tune
  211. 99pcm in 02 popping pcm batt fuse
  212. another tune?
  213. Bad engine computer? What do you think?
  214. Passenger side O2 sensor unplugged
  215. Anyone have a stock flash for a 1995 Formula 6 speed LT1 (LT1 Edit)
  216. HP Tuners throwing codes, help please
  217. Help with fine tuning a 402
  218. Can a newb use HPTuners?
  219. New o2s...still throwing bank codes
  220. When would you go to a aftermarket ECU?
  221. Loaded Tune on Sunday, Passed Emissions Monday
  222. someone plz help lead to the solution of this one:
  223. In need of 1996 and 1998 F-Body PCM Pinouts!
  224. How do you rescale fuel and spark tables for KPA greater than 100 (Boost)?
  225. gauges sweeping
  226. i need help with the predator
  227. Hypertech programmer ??? ??
  228. What to do????
  229. 1998 to 1999+ _PCM swap, TCS OFF after swap
  230. speed density tune with 2 dtCs
  231. Another P1637 story...
  232. ??Stalling after start up???
  233. Help with inaccurate speedometer
  234. dyno tune
  235. Mail order tune for a bolt-on/small cam car?
  236. TPS problems check it out.
  237. Tach tune
  238. possible tune needed
  239. Big stuff 3 needed?
  240. Maf or SD Tune >?
  241. 2 different maf's 2 different AFR's
  242. Car wiring issues?
  243. Any Variances running 60lb motrons ?
  244. car idleing questions cam 230 234 110+2
  245. Basic LTFT question
  246. Bouncing off rev limiter help!!!!
  247. is the hypertech programmer any good?
  248. Looking For Help/ Tuning
  249. Is Speed Density Tuning right for me?
  250. BS3 (BigStuff3) Sale at EPP!
