PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 [202] 203
  1. IAC, cam and autotap questons
  2. I can't change my shift points
  3. ST3500 Shudder-Computer Program
  4. Car will NOT start with a certain Tunders PCM!
  5. Flashing SES Light -Any Experts?
  6. New cam, new misfire code, can I delete with LS1 Edit?
  7. Will I need a MAFT?
  8. PACE 85mm Calibrated w/ MAFT...how does it hook up?!!
  9. SES light...will scanmaster display trouble code?
  10. Help tuneing related
  11. [LS1EDIT] : Do PE/RPM and PE/TEMP Add ?
  12. Can LS1 edit disable V.A.T.S?
  13. Leaning car via RPM
  14. What to look for possible TM or possible KR?
  15. Need help tuning MAFT
  16. Tuning Needed?
  17. what causes DTC's P0135 and P0155
  18. quick autotap question
  19. Can the Airbag Light be removed with LS1-Edit?
  20. newbie question about spark plugs
  21. Someone please help!!!!!
  22. how hard would it be to put together a FAQ for this section?
  23. LS1 Edit,How do i calculate grams for fuel?
  24. Got a speedo problem....help.....
  25. How much to delete TQ management?
  26. req-ls1edit file from m6
  27. Purpose of rev limiter by temp table?
  28. 2 step idea using LS1edit?
  29. This timing advance scam on ebay
  30. Shift light/buzzer wierdness
  31. ohm resistor
  32. More accurate O2 sensors
  33. LS1 Edit Tires and Gear change?
  34. Does Atap and LS1 Edit use the same.....
  35. OBD2 Palm Scan tool????? anyone tried?
  36. Is this too Ghetto?
  37. Can LS1 edit delete the EGR??
  38. mystery solved ls1edit and locked ltrims
  39. Should I retard the timing tables for 250 Wet Shot?
  40. Idle relearn , car running bad?
  41. How much would you pay? In-Car wideband
  42. Code 420??
  43. more timing with positive LTRIMS?
  44. VSS Voltage
  45. A Question on Shift Firmness
  46. advance timing kits
  47. MAFT on stock motor
  48. Why does less timing and/or a richer mixture yield more torque?
  49. OW! MY BRAIN!
  50. OK PCM Programmers >>> "Tune My Stuff" Challenge!
  51. Going to ATap/MAFT Tune Finally. Help!
  52. Portland Oregon ls1edit
  53. Just installed a 2002 Z06 MAF into my 2000 LS1.. need the MAF Table
  54. atap logs for windows Are o2s bad?
  55. EGR problems with LS6 intake
  56. Ryan, atapped my car to see if misfires caused verter unlocking issues
  57. Anyone ever here or see this CPU tuning device that can supposedly be used for us too
  58. SES light
  59. Does Superchips lock their pcm tuning?
  60. wot fine..idle is waaayyyy rich
  61. Anyone else get code PO480-fuel tank pressure circuit?
  62. quick question, and please check to be sure i have the right idea for this...
  63. SLP MAF , MAF-T help
  64. LTERMS ?
  65. someone make a gramsPS to lb/min table
  66. Have LT4 cam/head porting/headers is quite noisy valvetrain now,,,
  67. My LS1 Edit trials:
  68. Anyone here good with generic analog Data Acquisition?
  69. Which parameters do "tuners" play with for cam changes?
  70. MAFT and idle question
  71. How do I get LS1 edit for my 2001?
  72. what can ls1 edit replace?
  73. Anyone know what the code P1416 means on Auto-Tap?
  74. question about 02 computer ports
  75. How to tune LTrims using LS1 Edit ???
  76. generally speaking, did 98 and 99 LS1s run a bit rich from the factory?
  77. Running Lean on new Engine
  78. Check Engine Oil
  79. Looking for '99 Stock A4 File
  80. SES light?
  81. which misfire setting do i use on ATAP??
  82. What exactly is TQ management? how can turning it off help?
  83. How do you reset .....
  84. Which Diag. Tool?
  85. Who sells LS1 Edit??
  86. PCM trouble Codes??
  87. Best(cheapest ) way to raise stock rev limiter?
  88. ls1edit- KR learn functions
  89. Anyone else had the "Haven't seen this file type, please send me a copy" error?
  90. can i use LS1 edit to lock my converter under normal driving above 35? or in OD
  91. Timing table on LS1 Edit?
  92. Help, please. Idle oscillates
  93. LS1 Edit - MAF Differences
  94. Hi vs Low Octane Tables
  95. ls1edit and knock sensors
  96. TM getting worse? WUWT?
  97. How are these ATAP #'s?
  98. MAF translater with custom tuning
  99. Does anybody have an idea why..?????
  100. Question inside.
  101. AutoTap question in here
  102. MAF translater with custom tuning
  103. Any performance impact from disconnecting IAC?
  104. Car is running rich...(MAFT help)
  105. MAFT vs. custom tune
  106. MAFT, LTRIMS, WOT, ahhhhhhhh
  107. help need info on computers?
  108. We need one of these.
  109. !!! 99 and 98 ecu compatible?
  110. Why is LS1 Edit so friggin
  111. LS1 Edit Injector Scaling
  112. PCM Relearn
  113. Any News on when the LS1 Edit?
  114. UPDATE FOR VER. 1.0.3 LS1EDIT??
  115. MAFT and relearnng
  116. WOW! m6's have torque management as well!!!
  117. ls1edit PE "map to enable"
  118. Q's on DIY programming with LS1 edit... and the PCM itself...
  119. ltrims?
  120. Has anyone here tried EFIlive's scantool
  121. how to improve idle with LS1 edit?
  122. Will C5 HPP3 work on a same year F-body LS1?
  123. Question about Emissions, PCMs, and LS1edit
  124. SuperChips???
  125. Hypertech on LS1 edit
  126. Converter Locking up to soon
  127. CAGS and LS1 Edit
  128. LS1 edit
  129. maft and autotap numbers help
  130. How do I delete traction control & other functions
  131. Will LS1 Edit solve Converter Lock up problems
  132. Converting a kilometer speedo cluster to a MPH speedo cluster
  133. pcm/ls1edit Ques.
  134. LS1 Edit 101 question
  135. "Big cam idle"
  136. Pcm was locked out?
  137. How to lockup my t/c early on ls1edit
  138. Man....don't know where to begin with LS1 edit!
  139. LS1 Edit for trucks
  140. HPP3 Tunning Question
  141. ANYONE GOT A FLASH FILE FOR SY3500 00 C5?
  142. T1 LS1Edit tuning
  143. Setting up SVO 30# injectors...
  144. ls1edit problems help
  145. Need PCM advice...help
  146. What can MTI do for me?
  147. Ordered LS1 Edit Today - When To Expect It?
  148. carputing contact #
  149. LS1 Edit - RWTQ parameter?
  150. Multiple LS1-edit order question....
  151. WTF are these "Locks" people are talking about???
  152. Computer not reading MAF, HELP could it be a wire
  153. High Altitude Tuning
  154. Help with electrical problems
  155. SVO 30# injector tuning
  156. Ed Wright??
  157. ordered LS1 Edit for 3 cars
  158. Deleting Rear O2 Sensors?
  159. autotap vs ls1edit
  160. ls1edit and turbotech
  161. '02 Programming options?
  162. Tuning help please
  163. Where to begin with LS1-Edit?
  164. AutoTap and Ed Wright?
  165. Need LS1 Flash for Stock C5 with A4 and 3:15 Rear
  166. Dynoing my 422ci ARE iron motor with LS1 Edit
  167. Power Enrichment?
  168. Interesting Idea from Miata Board, Harlan?
  169. Who does dyno tuning on the east coast?
  170. All this LS1 edit and EPA/copyright violations stuff has me confused...
  171. Posts by Red98C5, in regards to A4 shift points
  172. Will PCM's tuned with LS1 Edit still pass the OBD-II emissions scan?
  173. LS1 edit, missing files, please help
  174. New PCM, how much and where?
  175. Dead HPP3
  176. LS1 edit around Chatt. TN?
  177. where to order ls1-edit
  178. Deleting SES light???
  179. For those who have relocated battery....
  180. LS1 Edit ???? problems on one not the other
  181. LS1-edit and a bolton A4?
  182. Class action Lawsuit
  183. anyone else have this autotap problem
  184. Need a MAF table from a 2002 Z06.. or equivalent
  185. If you have LS1Edit do you need Auto-Tap?
  186. Installing LS6 non-calibrated MAF into LS1 engine
  187. Help--->> Going to the dyno with LS1_ Edit
  188. What choices do I have to bump up the idle RPM?
  189. Computer resetting?
  190. Computer resetting?
  191. The LS1 Edit learning curve
  192. Check my math here on A/F calculations
  193. ls1 timming
  194. how to tell if used hpp3 still has pgm???
  195. FYI: !TM fixes converter solenoid problems
  196. Get ride of MAFT & HPPIII and get LS1-Edit?
  197. ? on LS1 Edit
  198. Proper way to set the timing curves?
  199. WTF is a P0135 code? "02 sensor heater blah blah...
  200. PCM lockouts
  201. Correlation Between MAF Flow & HP??
  202. Please Help! How does someone remove the rear O2 signal
  203. EFIlive V5 VRS LS1 edit
  204. Tips from LT1 EDIT for LS1 Edit!!
  205. 1999, 2000 Superchips Miroturner for sale
  206. What is LS1 edit? Do I need a lap top for it?
  207. A-Tap vs. EASE....??
  208. Really basic question about injector duty cycle
  209. LS1 Edit flash files repository
  210. So if i put a cam in my car I can know Tune it with LS1-Edit?
  211. Hypertech Shift Firmness
  212. Hypertech Shift Firmness
  213. LS1 Edit on a bolt on 6 speed car? ANy gains?
  214. LS1 EDIT and Forced Induction?
  215. Still need Atap with LS1 Edit?
  216. Is this now the LS1 edit hotline?
  217. [LS1EDIT] : How to address this condition..
  218. New programs require battery disconnect...
  219. fuel cell questions
  220. Is my laptop to weak for LS1 Edit?
  221. stock to 42lbs need % for ls1edit
  222. Changing TCC with LS1-Edit
  223. Changing TCC with LS1-Edit
  224. [LS1EDIT] : Does WOT Mode = PE ?
  225. a tap help
  226. Weird tuning Question.
  227. LTrims - difference between B1 and B2 -- what are yours?
  228. Team ZR-1 - EASE ?
  229. LS1 Edit or Ed Wright? Any comparisons?
  230. Fuel System Question!!
  231. Hypertech + MAFT
  232. Combine HPPIII tuning with MAFT Tuning?
  233. Idle suggestions?
  234. LS1 Edit Questions?
  235. adjusting ltrims with LS1 edit ?
  236. Shift Points and TCC
  237. Hypertech problem - Big time!
  238. Anyone know about "Super Chips" in Florida?
  239. LS1-Edit for Converters
  240. How to read trouble codes with a tap...
  241. Exactly what to have done on custom tuning?
  242. Who is selling LS1 Edit??
  243. Lost HP?
  244. Hypertech Power Programmer III question?
  245. TPS enhancer ckt?
  246. Test Results with 4th version of code using LS1-Edit
  247. When dynotuning, are you folks leaning out fuel above peak tq?
  248. The future of programming...
  249. WB O2 Purchasing options....
  250. Hypertech Question
