PDA
View Full Version : PCM Diagnostics & Tuning
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Looking for suggestions on tune
  2. Bosch 868’s
  3. Holley Datalog viewer improvement
  4. Why are my fans on constantly? Holley EFI
  5. Needing an older version of EFI Live, anybody have an EXE to share?
  6. LS3 - MAF Frequency Fail High Setting
  7. Keeping fans on for a set time after car turned off
  8. Terminator X O2 heater circuit voltage question
  9. Building Twin Turbo LS3 w P59 / Flex Fuel
  10. Transient P1133 Failures (Tech 2 History) After SLP Lid Install & Trim Reset
  11. LS swap Idle Issue
  12. Another flex fuel enable problem post
  13. Looking for Tune - Lost Orginial
  14. Help Disabling Rear O2 Sensors
  15. Backfire!! Flame!!
  16. LS3 will not run
  17. 99 trans am, P0336 crank sensor code
  18. Accuracy/resolution- small pulse injector dutycycle
  19. Incomplete tune?
  20. LS1 Starts then Dies
  21. Code P101
  22. Tuner recommendations
  23. gen 4 e38 p023f
  24. 2006 Corvette Wiring harness
  25. I'm trying to convert to lambda using dynojet commander
  26. Understanding LTFT
  27. Tech 2 Clone - My review
  28. Unknown Mods C5 Tuning
  29. Misfire question
  30. Low injector voltage
  31. Summit Ghost can injection timing (try this)
  32. LS1 won’t idle correctly
  33. High Stall 4l80E Shift Pressure Tables
  34. Changing from a 2 bar to a 3 bar setup.
  35. Mild.Cam and Idle (no tune yet)
  36. Needing CYCD XDF for Swap
  37. Ls 2 blower timing msd
  38. New datalog analyzer for Terminator/Dominator logs
  39. PCM not commanding TCC lockup
  40. LM7 Crate Swap Lean and Stumble under load
  41. Vcm suite for mpvi1
  42. 98 PCM Questions
  43. Short term fuel trims hp tuner
  44. Pegging rich everytime I lift the throttle
  45. Operating system upgrade to 12212156
  46. C6 corvette with Vortec supercharger EO tune?
  47. Holley Terminator X max and LS3 boost sensor
  48. Start - No Run AGAIN
  49. How do you make the Aero Force gauges read boost correctly?
  50. segment swap 4L80 from 12613248 bin
  51. HP Tuner
  52. wired usb to OBDII dongle for PCM Hammer
  53. GMPP E67 vs Production car E67?
  54. Turbo 5.3
  55. LMF stock tune file
  56. Holley Terminator Questions
  57. ABS code reader for a '98?
  58. P0300 o2 sensor? LH9
  59. EBTCM time for C5 Corvette......Not yet!
  60. EBC-1 wideband error
  61. Tuning question?
  62. Does anyone sell tuning?
  63. Please critique my cold start to hot idle data log. I have a few questions.
  64. Lq4 Won't Idle
  65. 2002 Camaro Manual LS1 Stock bin File Needed
  66. Voltage "Brownout" During Cranking?
  67. Check tune
  68. using free software to tune out downstream o2 and evap?
  69. Wire crimping vs soldiering?
  70. High IAT - Pull Timing or Add Fuel?? Or Both??
  71. Enable egr
  72. tcc lockup transistor died in my pcm?
  73. Wtf is going on with this
  74. P0135/P0155 - Bone Stock Swap
  75. Reducing fuel smell in tune
  76. Car dying when rev limiter is hit
  77. Diagnose from the dealership doesnt seem right pls help
  78. E85 5.3 cold issues / afr lean at idle no content sensor
  79. Brain scratcher here. 2006 gto
  80. LS3 PCM in 4th gen?
  81. P01 1253017
  82. Low rpm tuning
  83. need help with MAF tuning
  84. Symptoms of a dying PCM or something else?
  85. No crank signal during start
  86. LQ4 Cam/Crank Waveform
  87. O2 Sensor Heater Circuit Not Working
  88. Current Tune vs Stock Tune Question
  89. 02 camaro 5.7 dies once put in gear
  90. Calling all tuners, diagnostic experts! Having issues, LONG read!
  91. Innova bi-directional scan tool.....
  92. 2014.5 Yukon Denali XL melted some kind of thing. Need Help!
  93. Issue with o2 sensors circuit (P0135 P0155)
  94. tuner in Kansas City or Topeka?
  95. CA Smog Implications - PCM Tuning - Gear - Change 1998 LS1 Trans AM
  96. In need of good crank cam correlation waveform
  97. Looking for some tuning help i think
  98. SOL on my C5s EBCM?????
  99. Ground Wire Issue
  100. Line pressure vs kpa
  101. Cannot get 2-bar MAP PID for P59
  102. Dyno pull scan, RPMs, Boost, TPS arent lining up
  103. Can I use a PWM - output on my Terminator X to control a fluid solenoid?
  104. Tuning. Manual Hold 1st gear question.
  105. Tune question returning to stock setup?
  106. Help To enable cruise control E38
  107. Tuner
  108. Replacement ECU and VATs Question
  109. Important
  110. Crazy Rich condition during EVAP canister purge activation
  111. Terminator X issues
  112. Thoughts on this tune?
  113. Crazy car driving me crazy!!!
  114. What does this O2 sensor data mean?
  115. Won’t start while hot
  116. Monitor won’t set
  117. Bad pcm?
  118. Viewing Terminator X logs on phone
  119. FIXED! Slow - Weak Initial Cold Start...Any ideas on how to fix that?
  120. Cammed 98z poor idle
  121. Cam sync issues
  122. Restoring A/C and Gauges with Dual PCMs
  123. MAP range?
  124. LS1 Data Logging
  125. E38 ECM compatibility
  126. No spark cyl. #2 LM7
  127. Ls starts and dies within 3 seconds, intermediate
  128. 6.2 LS3 prolong crank an knock code an cam code help
  129. I have a tuning question
  130. Hpt 4.0.6
  131. Inconsistent BRAF and IAC steps w/cold start vs hot start...data logs attached
  132. Weird acceleration without giving throttle
  133. Choppy rpm signal
  134. dynamicefi help needed please
  135. P01 Dual Electric Fan Conversion and Configuration
  136. Are all blue/green vortec PCMs compatible?
  137. Holley Terminator X no start, but runs great - pulling my hair out!
  138. '99 silverado 5.3 ECU/ECM/PCM on a '98 ls1 car?
  139. P0601 PCM code '98 LS1
  140. 2000 m6 to 1998 auto swap
  141. Starter cuts in and out
  142. Why PE ? Can't we just build the VE table to suit?
  143. need xdf file for 1998 camaro z28
  144. 5.3 L33 Rev Hang.
  145. Ideal EQ ratio for open loop base with e85?
  146. Cold start issues
  147. Assistance starting out tuning.
  148. 99 up PCM bracket
  149. Tuning is central Iowa
  150. TUNE REVIEW!!!!GEN3 TUNING PROFRESSIONALS/amateur
  151. Best OS for application
  152. **SOLVED** L92 Cold Start Bank 2 Lean
  153. Frustrated with rich/stumble/backfire issue
  154. Cheap oscilloscope for sensor testing?
  155. wtf is happening in my log?
  156. Cat efficiency test elimination?
  157. What needs to be changed when adding headers?
  158. OBD connector wiring
  159. Stall at stop manual trans
  160. P2135 can’t figure this out!
  161. Going from FAST 78 to 90 with 85mm maf and larger injectors
  162. Need someone to look over my bached dyno tune
  163. Need someone to look over my bached dyno tune
  164. Segment swap for timing under boost. Possible?
  165. Budget scan tool for crank relearn
  166. Chevrolet Performance 480 hp LS3 engine & controller kit
  167. Lean Pop and P1518
  168. 2010 camaro wiring schematic
  169. 5.3 Gen 3 Need help with tune
  170. Best Scan Tool
  171. Terminator X Bluetooth Module
  172. Power at injectors and coils , no spark??
  173. Misfire Help!
  174. LQ9 swap runs but has no power
  175. 5.3L LS - Tried bench Starting - Runs then immediately dies
  176. LQ9 decent idle but no pedal response
  177. Only seeing 25lb/min and 0.50 g/cyl airmass in stock LS1
  178. DBC Cruise control non-functional - tune related?
  179. DBW failure
  180. Tps voltage check and setting
  181. What's the consensus on the "BEST" o2 sensor?
  182. chasing P0300 have log files
  183. i think i got somewhere today the brickwall please help
  184. Ecu not communicating with transmission
  185. Logging oil pressure hp tuners
  186. 98 trabs am wont stay running after 00ecu swap
  187. AFR Spiking at idle?
  188. finally got some logs
  189. LS3 crate blowing #2 fuse
  190. Are handheld data loggers hard to understand
  191. Help!! #7 not firing
  192. Dyno shop recommendation in SoCal
  193. Can't seem to get pcm hammer to read or work for me at all
  194. Holley EFI Pro Dash custom ohms HELP
  195. Going rich on start up
  196. 98 to 99+ ecu
  197. Crank relearn procedure
  198. Tune advice to wake up tow rig
  199. Holley pro dash High beam signal
  200. anybody want to chime in
  201. Free Data Loggers
  202. High Idle Log EFILive
  203. New Fourth Gen F Body owner looking for advise
  204. Ls3 with 6l80e wont shift from first gear
  205. Wiring 4L80E to 1995 ecu
  206. ECM Issue on 99-02 Gmt800?
  207. Question for you electrical gurus
  208. Has anyone replaced the slide locks in a MX123 ECM Connector?
  209. need some input on tune
  210. Trans Pressure sensor issue
  211. 4L80E 'Soft Shift' Issue
  212. Tuning New Guy - Transmission, Wiring, or Tuning Issue?
  213. Need info/data on GM 60lb injectors please
  214. PCM Hammer Won't connect
  215. Cam position sensor low voltage
  216. P219a & P219b
  217. Very strange P0016 code after engine warms
  218. AFR setup.
  219. 2000 Firebird LS one
  220. Can a Holley Terminator X work with a F-Body gauge cluster?
  221. LS Will not idle no matter what
  222. 1998 Trans am tuning for cam
  223. E38 computer fuel cut, why?
  224. 403 stroker with LSA blower and HP Tuners
  225. FIXED! : Tach drops to 0 when accelerating
  226. Holley Dominator Air Temp Enrichment/No learn
  227. Lean Condition during MAF Calibration
  228. Just finished my first tune! What are your honest thoughts?
  229. Back: Hanging Idle and "Cruise Control"
  230. Only cylinder 5 and 6 firing.
  231. Can too high of advanced control on closed loop cause a misfire?
  232. LQ9 struggling to gain rpm going uphill
  233. Tow/Haul button capabilities?
  234. Stutter Step
  235. Tps sensor help!
  236. MAP trigger output possible from P59 pcm ?
  237. Scan-tool advice : INNOVA SDS50 any good ?
  238. Market for used MPVI Pro
  239. E38 compatible with 6l80?? (originally had 4l65)
  240. Remote tuning using a different car?
  241. LS1 dies at high rpm
  242. e38 PCM won't talk, HPTuners Detect Protocol Failure
  243. First Start up Gen 3 5.3 Help!
  244. Idle timing in park
  245. Base .hpt tune needed lq4 dbc
  246. Revved to 6600?
  247. Please help beware long thread
  248. obd1 vs obd2 tuning
  249. TCC Brake Switch Wiring - C10
  250. Engine dies in reverse - idle questions
