- Odd MAF reading...
- making a standalone 4l80e controller from factory pcm
- Frost mail order tune on a heads/cam car?
- Flashing ses, no codes?
- Car hits rev limiter with Frost tune now. Help
- Timing under boost
- Retune for tire size?
- Idle Tables and Tps voltage problem's
- LS1 Parameters Normal??
- PCM corossion. How can I clean this up? Pics inside.
- What OBD-II scanners have data logging for knock retard?
- Thanks again ryans performance machine!!
- Injector scaling chart
- Diagnostic/datalogging software?
- gauge for lc-1
- Help with HP tuners
- Best Fuel Management for Twin Turbo First Gen
- email tuning??
- for those running xfi with any kind of injector..can i see file?
- anyone running two fuel/tunes
- P0174/P0300/P0171 codes....
- Bought a 5.3 Silverado, pcm is locked
- LS2 MAF Sensor & Harness Pinouts
- dyno tuning link
- switching from EFILive (custom OS) to HP Tuners, but want to save tune
- Question!!!!!!
- 5.3 dbc 2001 harness on 2006 dbw ?
- Possible bad computer?
- EFI live boost timing feature
- iac probs/ high idle...tb doesnt want to close...
- Need to spend money
- timing vs altitude
- Best spot for iat sensor?
- dyno disaster
- E40 ecm (p0689)
- No Speedometer. Please Help!
- 00 F-Body 2-3k RPM Part Throttle Sputter?
- Best O2
- Switching from 90mm to 102 speed density
- Versitial wideband easy in and out
- Rev limiter
- Fuel trims and 102mm tuning
- Code PO 0128 idle air control?
- 2003 LQ9 serial data A/C
- tuner C.A.T.S. users come in
- N E 1 ever tuned for Jakes Transbrake?
- 98-99+ pcm, what to do with low oil sensor?
- what type of tune for a cam?
- frost tune?
- 2001 Vette Throwing Multiple Lights
- CTS-V Electrical Trouble
- 3 day old 02 sensor carbon caked, car runs like crap? HELP
- Bigstuff 3 crank reference
- IAC vs the hole in the throttle body
- Car wont start after cam change
- Diablo Predator Worth it?
- Does the ECU need oil pressure or water temp?
- idle seems rich
- Crank No start/then start and runs fine??
- Tune safe after changes to drive to the tuner?
- tuning question
- Lower idle rpm. What is cheapest way?
- brake,abs and tcs lights come on
- IAC are slow to go down after stopping
- 102 T/B problem. Voltage to high code tps
- Misfire help. need help interpreting HP tuners logs files
- 6.0+Tourqer V2 cam= Idle searching/stalling
- HP tuners questions
- 2010 Camaro Tune Question
- My OBD2 port isn't functioning?
- Diablo predator
- Need a stock .tun file. 2002 Trans Am A4
- FAST to LS6 Intake Swap, tune ????
- samaurai with a 3.4 swap tuning?
- Change from HP tuner to a freely programming controller
- HP Tuners Unable to Connect
- Will P0300 or P1133 cause a rich bank?(pics)
- Central Illinois Tuners? Suggestions!
- lq9 stock tune
- Car wont crank, lights ect.. all work
- SD tune IAT sensor location
- Denso o2 sensor wire question
- tuning concerning o2 sensor location
- Steps for adjusting E85?
- 80# injectors
- Master EFI Tuner (book)
- Looking for a tune
- 5.3 won't start, ideas?
- got the car dyno'd, had a weird problem though...check it out..
- Pacific NW Tuners
- 99 trans am tachometer help
- New injector issue
- Engine Power Systems
- O2 sensor help.
- LT1 tune ?
- HPT + Stock ECM + LC1 = GOOD?
- rough idle and misfire in tailpipe
- Poor Driveability after cam install = Bigger hole in throttle blde?
- Need help quickly please
- Mail Order Tunes
- Codes p1133
- Suspended plates beause of emission prolems, help!
- threaded iat sensor
- P1516 set after tune
- quick tune question
- driveability of tr230 cam without tune?
- which pcm to buy?
- Msd? Digital7plus???help.
- Ecm not responding.
- Effects of High IATs???
- Help w/ H/C/I tuning
- Tuners near Atlanta GA or Chattanooga TN?
- Newbie needs advice,thinking about getting HP tuners!
- So really, if your 2001 WS6 was...
- lq4 swap
- Tuner around North Mississippi
- Help: LQ4 retrofit mod/tune
- Tuner near NORTHWEST OHIO
- Lost Ground in Starter Circuit wiring in 71 Chevelle LS1 conversion
- Code help
- O2 sensors turned off in tune...bad?
- Backfire issue
- '98 LTFT + STFT questions
- E85 454 LSX Trans Am, need help idleing
- torque converter lock/unlock
- cant keep running
- Looking a good tuner for my c5 408 car
- How is wait4me performance for dyno tune?
- 3bar Map sensor and computer
- Oil Pressure monitoring with HPT
- Knock Sensors Toast After Washing Engine???
- Knock sensor? LS2 block with LS1 computer
- Tuner around Clearwater to help with 3rd gear lock up
- tune with diablosport trinity or shop
- Ls1 computer in 97 lt1??
- 2000 PCM work in 06 LQ9?
- 2 bar map 12615136, 2 bar OS, can't get p101 or p102 (only p103) HP tuners
- Swapped motors, no spark, BCM going nuts. Help
- Problems loging AFR using AC switch Wrong PIN maybe?
- Sensitize LS2 knock locations.
- Car ran fine, drove fine then died...now it won't start.
- Replace AEM wideband sensor or get a differet wideband?
- MAF or no MAF
- Tuning my '98 with HP Tuners - Timing questions
- Reflash EFIlive over HPT tune????
- PCM Help
- How do I determing what base idle air flow values should be?
- Help! My daily is down. 2007 Silverado died while driving.. won't start now.
- info on ls edit software
- Aftermarket ECU
- 98 trans am bone stock with 4000 stall hpt help!!!
- benefits of a Mail order Tune vs stock?
- Scalar?
- cam and stall
- P410
- chasing a misfire
- Does removing A/C cause a fan code?
- Tuners Help !!!!!!!!
- Etp 215 results
- Wideband fails with E-cutout
- frost tune?
- Diagnose LS1 with a diagnostic tool
- Fuse Panel Pictures
- injector tuning
- Thumpr Cam tune with video
- Cable colours for injectors (Crate LS3)
- Can I get some input on a baseline startup tune file for my turbo trans am
- What does pcm monitor?
- Random Misfire Problem
- HELP! Problem with throttle response.
- randome cylinder misfire code only on the highway
- anything peculiar here? comparing my tune vs stock and a bit puzzled
- E85 Tune
- Cat Delete
- Autometer Tach wire 98TA with 99+ pcm swap
- HP scanner not detecting/clearing DTC's?
- Getting rich codes (p0172,p0175,p0101)
- LY6 trouble code Please Help
- Is there any good books or DVDs on how to Learn HP Tuner?
- Need tuner
- Best price?
- 02 Z28 Stuck in open loop???
- 98 tuning question
- Help with KR (HPT)
- what do you all think of this tune?
- TBW TP% problem please help
- tune and cold air suggestions
- fuel trims at idle
- Poor fuel economy and code p0157
- Tune without fast 90/90
- Losing Fuel Pump Realay Signal
- LS6 Tuning
- tuning without knock sensors
- Need to get started data logging
- LY6 with LS2 throttle body and E38 ECM ??
- help early shift after cam/tune
- P0122 TPS circuit low voltage (immature)
- libgenfelter launch controller issues
- 2001 silverado 4.8L code p0404
- PCM bricked??
- Instant start up rich? First few seconds.
- installed 8.1L maf sensor on 2001 t/a
- slp7196?
- xfi start up programs and tunes?
- I broke my oil pressure sensor, read more inside...
- Anyone played with Injector Timing?
- crate ls3 idle issue only when not moving.
- 97 LT1/T56 Complete Swap into 72
- Anyone ever had a wideband read wrong?
- Weird issue after turbo install.
- Just wanted to ask a quick question
- Maf help please!!!
- Having a hard time
- 408 Crank sensor problem HELP!!!!
- 98 to 02 harness swap
- car wont coastdown
- Horror story
- P0430 and SLP Cats?
- Need an Email Tune for Hp tuners...
- pcm and harness questions
- PCM replacement ???
- EFI Live questions
- I'm BAAAACK!!!
- Desired shift time?
- HP Tuners question
- Need help with AC causing stalling
- Anyone looking for a great tuner..
- Complete newb with tuners, help?
- 1998 F-Bodies and HPTuners
- Bolt C6 Z dyno Results (big ups to Frost!)
- 3k stall, low rpm knock!?
- Autometer speedo and gmpp trans controller
- Anyone have a ls7 maf hptuners file for a ls1 car?
- torque management how to turn off with hp tuners
- Throwing the 1336 code, help!
- Timing and afr
- annoyance with local tune shop
- A little information on 0411 Fuel Segments and a 98 Fuel Gauge
- Dual tune with EFI Live?
- Mail tune issues.
- Back to stock operating system in HP tuners on c5 vette?
- PCM and harness confusion???
- Tuning question
- 02 Z28 Dyno time...need advise on tune.
- fried my ECM: HELP!!
- what is the difference in ls1 and ls6 stock tune?
- 04 cts v6 tuning (post cat o2's need to be deleted)
- Adjusting ECU for 2 pulse per rev VSS
- Diablosport upgrade questions
