- EFIlive V6 and/or LS1edit work with LC-1??
- LC-1 problem but no response from Innovate
- Check Gauges???
- where are the LS1edit files
- could carb cleaner kill a mass air sensor
- Tune myself??
- looking for .bin
- Re-flash with Edit M6 to A4 switch
- pcm injector drivers
- How will my car run with 28" tires and no tune?
- Crazy knock count??
- Anyone have a HPtuners bin file for a 408?
- No Fuel / No Spark Bank2. Bank1 Normal
- Fans turn ON/OFF not like I set it???
- Is this a tuning problem or vacuum leak?
- Starting problems?!?!!?
- ASR turned off, but car still responds like ASR is on.
- timing tuner instructions
- Cluster Problem
- Cam Guys Help me understand why my tuner played with Park and Drive Spark Tables
- HPT A4 Shift question with 3:73 Gears ,Rpm=Mph?
- heat soak
- Timing issues
- injector questions
- is my ltft/stft/Ve table close enoug? (SD mode) cant get much closer
- What A/F is good at part throttle?
- emissions
- Smoothing VE Table after SD Tuning With FlashScan?
- Anyone have a LS1Edit or HPtuners file of a tuned G5X3 car? or something similar?
- Swaping bad PCM with locked LS1Edit
- Removed Air Fittings But????
- Maf ???
- Ses Light went on please help
- MAF tuning
- Help! Im running lean!!
- Need help making my car driveable (just put big cam in!)
- Scanner Problem......
- ls1 edit problem w/ procharger
- Any Help Appreciated
- Electronic boxes under the dash
- Dyno Video
- What scanner can read live data?
- can't read or write to vcm pleas help
- Tuner in Seattle
- look at these screen shots of the o2s, are they ok?
- any one willing to delete some stuff for me?
- my car wont idle after startup
- SES light knock sensor?
- Peak torque tuning
- Need advice getting street legal in CA
- Baffled... Bank2 extremely lean Bank1 normal
- Major hesitation issues in a 98Z
- Please help...somebody sell a VATS bypass module?
- map sensor??
- Misfire no codes.
- Open Loop Question
- service vehicle light for oil change- searched to no avail.
- Fuel pressure loss-Can it be in the tune?
- Supercharger Tuning
- 94' and 95' PCM swap for programming?
- Where to tune
- dynamic airflow spikey at idle, rpms vary
- Wideband location
- Help! Car shifts incredibly rough! in SD mode
- High vs. Low Impedence Injectors...
- Where did Soundengineers MAF Work Sheet go?
- copys of tuning files
- Help: car runs way rich all the time except WOT!
- Knock Sensors
- loosing power
- MAF Spread Sheet and Excel Question?
- Tuning for headers-HPTUNER?
- 2 Bar Map part # needed and any info with it.
- Crane tuner
- Anyone tried a Ford or Dodge VSS?
- Will I have to reprogram after Injector Swap?!
- Innovate Wide Band Controller Sale!!!!
- pinging with 93 oct
- Is MAF used AT ALL in open-loop?
- scaling IFR table
- LS2 Predator: Coming soon (RWTD gives FREE custom tuning w/ purchase)
- NEED A TUNE>>>HELP
- WTF -closed loop?
- Predator
- LS2 Predator programmers coming soon!
- SES Light???
- Questions on Battery and PCM ground
- what kinda gm/cyl are you seeing
- Closed Loop SD Tune
- Will a tune help this?.....
- Ecm won't reset?
- Dead car - P0300 random misfire, no start
- RWTD has ordered HP Tuners 2.0!
- Supid asshole code, need a hand
- HP ReTuners, VE Calc, RW Dyno, Performance Analyzer
- What to values do you expect to see?
- Different Forum for LS2
- Low, Low Voltage, barely making spark???
- shoud i get my car tuned?
- How about a Repository for us using FlashScan??
- Cams and tuning
- car dies under boost????
- Got Wideband Readings with Dyno yesturday
- 6 speed having issues with idle and A/C
- Wide band mount with STS?
- Crankshaft position sensor problem??
- po172, and po175....
- New Brake Lines now Service Vehicle Light
- retune after swapping injectors?
- 2-3 cylinders down.Any answers?
- LS2 tuning out yet?
- Gauges (RPM, Fuel, Temp) dropping to nothing... where to start?
- Retune after Cam Install???
- LS-1 edit and FMS 42lb injectors
- Tuning question.
- 8.1 injectors and strangness
- fuel pressure question
- Using A Diablo After Tuning With Ls1edit?
- specific connector under pass. side dash...
- Logging Under SD Question??
- vette vs f-body pcm
- Missfire Missfire and MORE Missfire
- HPT cable
- setting IFR
- can i get some help with these fuel tuning problems please?
- PCM reset after catback install
- "Service Vehicle" and ASR lights on
- can you lose a tune???????
- Codes
- P0300 misfire WTF!!!
- Is this strange, or is it me??? (LTFT Related)
- installed LS6 intake getting P0443...
- Help w/ throwing codes P1133 & P1153
- another ses code
- Is Hypertech jerking me around?
- Do 98 F-bodies have torque management?
- EFI Live guys inside please!
- motor breaks up at 2500 rpm at cruise
- Car is a major gas hog, can I correct this in my tune and where??
- New laptop and HPT
- HPT Removing the F-body REAR O2's
- Oil pressure signal...does it go into the pcm????
- Why Dynotune?
- Flashing light at startup.
- tuner drilled a hole in my tb and messed with the screw!
- speedo problems after gear swap
- simple MAF question
- is there any way to adjust how fast STIT changes?
- AFR 205's installed now tunning with HPtuner ????
- Question on swapping files between cars
- Stock LS1 engine tune
- LS1Edit any way to convert A4 PCM to M6???
- is FTC 19 idle? getting knock
- changing gears
- PCM not sending out Engine Speed (tach) Signal???
- LS1Edit cables - UBS Vs. serial ports
- Log Ltrims-LS1Edit+diagnostic beta patch??
- Who can test my stock engine harness?
- Flashing SES light on deceleration....what does it mean?
- Under what conditions does the A/C get turned off?
- Still cant figure out idle tuning
- What tunning software to buy?
- what years are alike?
- read/was told to raise PE map with a cam, technical explanation of why please?
- Fuel added during WOT - LTFT?
- Thank you Redline Motorsports! [Dyno #'s]
- Question on IFR changes for new injectors..
- Cylinder Volume, skew performance??
- Accuracy of WBO2 in open headers + 110 race gas
- I need a lot of help
- Hp Tuner Customer Service
- Real-Time Vehicle Dynamics Processor
- Need Help!
- Short and Long Trim Fuel question
- Custom Wiring Harness...
- Are these any good?
- Easiest/cheapest way to detect knock retard?
- Proscan
- Getting your cars idle back in range 101: first few steps
- what system i need if i wanna run mid to low 9's
- Time to start her up...
- still having start up issues. come in and help me out, i need ideas
- 10* knock, WTF?
- EFILive/Flashscan Guys - No More MAF Spreadsheets?
- Have trouble with codes
- still getting kr, but my timing is higher than what i set it at???
- Coolant low problem
- does engine temperture reading effect engine performance
- what effect does the IAT have on the engine performance
- running lean, weak fuel pump?
- question for those adding part throttle timing?
- Hypertech power programmer?
- Anyone used LC-1 with FlashScan??
- Diff Year Bin Files
- logging LTRIM readings - OBD-2 software
- can a GM tech 2 tested be used to adjust timing
- Where to run wideband wiring??
- Help!! hot and cold idle problems!!!
- Philly area W/ 01 HP tuners?
- Aftermarket engine management dilemma
- hanging hot start idle + ls1edit question
- complete noob to tuning
- Stays in closed loop at WOT
- Excessive Delay in Receiving HPT enhanced Interface
- A question about HPT Scanner
- SES light flashes at idle with AC only
- HPT A4 Tranny Shift Question
- Blinking SES NEED HELP ASAP!
- Where Is Chris Marsh When You Need Him
- 3 Graphs of AFR DATA in REAL WORLD
- Inspection help
- Equus/Innova OBDII C.A.N. Scanner?
- No signal - rear O2 sensors - LS1Edit fix?
- correct me if im wrong...
- EGR/AIR (limp home mode?)
- Transient fuel tuning
- Possible TM issue?
- Constant high idle when moving off throttle..
- Misfire SES....
- tuner in SE michigan?
- Can someone look at this Autotap file if my car and see if everything is ok??
- Mysterous flashing check engine light
- Does flashscan have the ablility to unlock a PCM?
- last few logs got kr when giving gas at stand still?? what to do?
- Idle Sticks at 2000rpm
- Help: PLX M-300 Wideband
- tuning question
- advanced timing timing too high?
- Someone check my tune for me
- Speed Density Tuning Ready to Take Off????
- Generic air-fuel ratio gage with wideband?
- Ve OK, Now MAF?
- Porting the Throttle Body
- O2 Flatlined? Bad sensor
- What are you using for a scanner
- Ls1 Edit or HP Tuners
- Quick disconnect resistance concern
- sputtering under light load
- 42 LB f. iNJECTORS AND RACETRONIX 255L/H
- Car won't stop starting
- working on a new timing table, need some opinions
- LTIT Slow or immobile need input...
- Cant get the TPS Voltage to reset to zero.
- Tuner Experience At Dick & Connies in Clairmont
- HP Tuners Customer Support Rocks!
- Idle tuned prior to MAF or doesnt matter?
- o2 sensor info please help
- when entering numbers for iac park airflow, how do you find the right values?
- once in closed loop, airflow at idle goes up?
- Wiring harness available to run stock gauges/etc with aftermarket engine management
