PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Reviews of straighline performance Plainfield il
  2. lm7 running lean only under load and bad mpg
  3. No injector pulse
  4. 5.3 base tune
  5. LS3 E-Rod vs Crate motor
  6. Vengeance PCM - New Website! Remote Tuning/Tune Review/In-House Dyno Calibration
  7. Motorswap not starting HELP!!!!!!!
  8. 52mm Shift Light
  9. Need a pcm for my 96 k1500. 411?
  10. Cold start issue
  11. Is there 1 piece of equipment that will flash a new Gen III & Gen IV PCM?
  12. Throttle Body Wiring
  13. Help with tune.
  14. 11.0 afr @ cruise
  15. P2101 and P1516 code at RPM
  16. PCU Problems?
  17. 4.8 base cam tune
  18. Airmass Calculation - Grams per Cylinder
  19. Help!! P0740 tcc solenoid problems
  20. C6Z cuts ignition then flashes locked symbol
  21. Ls swapped rx7, no voltage from fuel pump signal wire.
  22. Lounch control for LSX
  23. Tune for FPR pressure change?
  24. P0420/p0430
  25. Street or Dyno Tune - Which Is Better?
  26. Un-tunable ls3!?
  27. p59 flex fuel not reading alcohol content
  28. P0443
  29. effect of inncorrect wheel speed on tune
  30. 2004 silverado e fans hpt questions
  31. 09354896 pinouts
  32. O2 sensors/LTFT/STFT are jacked up
  33. 4L60e to 4L80e conversion tuning
  34. 6.0 LQ4 Cuts Off and On
  35. Any near York PA Good with Holley EFI wiring?
  36. Anyone have a ls7 maf hptuners file for 6.0 truck maf?
  37. torque converter pwm
  38. Anyone know how OBD works?
  39. What to expect from tune after lowering compression
  40. Wide Band Bung Location???
  41. Evap o2 heater emmissions not ready. Tuned
  42. Switch to a throttle cable? Need help
  43. IAC or TPS issue?
  44. 98 camaro v6 pcm swap
  45. Credit requirements for changing OS
  46. Flexfuel fuel e85 sensor fbodys camaro help
  47. Maf suggestions
  48. VSS Signal
  49. Inexpensive Opensource Flashing(Read is 100% working)
  50. Pingmaster Tune Review
  51. 08 Silverado MAF upgrade??
  52. Prom?
  53. Weird problem after changing injector data from sticky above
  54. hp tuner VIN swap
  55. 98 A4 Trans Am
  56. P0342 and p0343
  57. Soldering PCM Terminals
  58. LS3 in 1999 LS1 car need right MAP sensor ## and the rubber to hook them up.
  59. Any luck with eMS-pro?
  60. Certain distance between filter and MAF?
  61. missing over 40% tps
  62. Help. Rich condition
  63. Can't connect to 2 PCMs - help!
  64. Spark tuning on Mustang?
  65. Need Help 6.0 L96 Engine out of a 2014 GMC Sierra 2500.
  66. [SOLVED] o2 Sensor "Not Ready" Troubleshooting
  67. hunting down p0301 cause ...
  68. Advice please on where to buy program
  69. Anyone running an AIM Strada XMS Street Dash?
  70. 93 c1500 turbo lq4 wont start!!
  71. Anybody take a min and look at my tune.. wont cold start..
  72. How To Microsquirt your LS Engine: Video
  73. Removing MAF sensor from System
  74. Ideas for lowering my emission HC number?
  75. College Student in need of aid
  76. 98 pcm not showing 2bar custom os ????
  77. 0411 PCM to 00 SS
  78. lq4 swap backfires at idles
  79. Pre-LS tuning help
  80. Engine surge
  81. hp tuners unlimited year model
  82. Help tuning deatsch works 35lb injectors. No data available
  83. Holley global repository
  84. HP Tuners Wideband Problems
  85. Turbo build and some ideas on part spark/fuel
  86. Tuning lab in tx
  87. 02 sensor
  88. Smogging a custom tune, etc.
  89. P0420 code what option should I do???
  90. e38 swap (L20/6l90e) no fuel/spark condition
  91. Tries to start but won't stay running (after running fine for a year)
  92. PWM with 411 PCM
  93. O2 Sensor question
  94. 2Bar SD.... okay to Remove MAF entirely ?
  95. Tire Size Calculator
  96. LS1 PCM PCB, anyone have layout/files?
  97. My first ls
  98. Z06 Stops running shortly after warming up
  99. Holley Dominator Users (Fbody) come inside
  100. Is My PCM Dead? 98 Camaro SS
  101. 0411
  102. E40 compatibility with LS1 DBW Throttle Body
  103. Hosepower numbers
  104. Installing nick williams 102 with a lod speedworks intake manifold
  105. 99 ws6 temp gauge issues. Pcm correct
  106. which LS1B pcm to order??
  107. need Help Diagnosing My issue
  108. Please critique my tune -also- spark tuning question
  109. DBW to DBC: whits end with it. Help appreciated
  110. Looking for Opinions / Differences in Holley Dominator EFI - Holley HP EFI or FAST??
  111. help with 4l80e solenoid wiring for boost by gear
  112. Learn to tune your own EFI
  113. Dbw to dbc 6l80e ls swap classic car
  114. Misfire 3,4,5
  115. Minimum equipment to change fan on temp
  116. Bulkhead Wiring Connector
  117. Vehicle mileage in PCM?
  118. Torque and HPTuner at the same time
  119. 2011 6.2 L99 Camaro Engine with 2013 4.8 LS Silverado E38 ECM?
  120. Cam sensor issues
  121. HP: Anyone have install file VCMSuite-2_22_NoLC.msi for .NET 2.0 Framework problems?
  122. Speed density tuning questions
  123. Any tuners in north ga?
  124. Upstream 02 sensors flatline afr at 15.43
  125. EPC control
  126. lap top
  127. Are All E38s the Same?
  128. EOIT for Gen 3 and overlap
  129. EGR deleted in tune, getting Mode $06 failed test "EGR decel test" failure
  130. Gains from switching to Holley?
  131. 2 codes: P0106 & P0121
  132. O2 Sensor
  133. Is it possible to tune the low-octane timing table?
  134. Possible bad tune?
  135. Xer273 no tune
  136. 2bar SD Tune advice turbo ls1 deka 80# btr cam
  137. Walbro GSL392 Inline Racing Fuel Pump Setup questions
  138. 4l80 swap help...no speedo
  139. Larger Thottle Body Tuning
  140. LS1 big cam, hard to start, runs well after holding pedal down
  141. New injectors = very odd behavior .. what gives?
  142. [SOLVED] Annoying Codes P1635 and P1639
  143. Please review my HPT log files
  144. O2 sensors reading 450mv PSI Wiring Harness
  145. Auto Meter Water temp gauge install
  146. LM1 wideband
  147. holley VS MS3 VS ???
  148. 107 lobe cam
  149. car running rough at idle, evap code
  150. Will it make 400rwhp?
  151. Symptoms of Vats Not Disabled
  152. Logging External Sensors with Stock PCM
  153. Read and convert RPM with Arduino... how do I interpret the RPM?
  154. Tuner Questions
  155. e85 Addicts! Users chime in
  156. crank relearn
  157. P59 PCM.......does it work all systems normally
  158. "stock 5.3 swap won't run in cold weather
  159. Tune GMPP computer for boost?
  160. HPT vcm suite 3.6 anyone using it yet?
  161. Possible to repin factory rear 02 plugs to front?
  162. Map and other sensor question for ls1
  163. Help!
  164. LTFTs low at idle, high while cruising
  165. Crankshaft Position Sensor
  166. Dyno tuners in KC
  167. LS1 Swap/HPT - how do you flash a Yukon 411 with a Camaro tune?
  168. LSA engine swap, too lean!
  169. 1998 f-body speedometer calibration
  170. My 1st tune, need input please
  171. Lm4 running rich no codes
  172. 98 c5 going boost tuning pcm
  173. No pedal response LFX conversion
  174. New build: Looking at EBC & tuning and boost by gear
  175. Problem, after 10 minutes, with AEM 30-4110 and/or HPTuners (bad sensor already???)
  176. what is a good DCR range for BOOST
  177. LQ9 tuning help
  178. Need o2 sensors to run?
  179. Ignition Relay Circuit issue
  180. Stand alone pcm
  181. I'm back and need help with Tune
  182. 4.8 with a LS1 computer and tune
  183. Just swapped in an LSA engine, having some driveability issues.
  184. HELP. I adjusted the throttle body blade
  185. 1998 Trans Am PCM Swap to 99+ Computer
  186. micro squirt tps
  187. Lly duramax airbox and maf on 06 Silverado lq9
  188. Which C6 Z06 model year that has the fastest and quickest PCM?
  189. snap on brick upgrades
  190. EGR or Crank Sensor System issue
  191. VXDiag VCX Nano
  192. OBD2 - Oil pressure
  193. Lean/rich condition under cruising
  194. Ls Tunes
  195. 4L60E TO 6L80E Swap Help
  196. Dissaponting dyno results please advise
  197. Stock 12200411 PCM with EGR on 2002 Non-EGR 4.8. Any issues ?
  198. Cooling fan - LTFT oddity
  199. Dash or ECBM Issues
  200. 2004 LQ4 revs slow, intermittent low power, hesitations under load
  201. Connecting wideband to standard hp tuners
  202. P0307
  203. A4 > M6 Tuning out SES Lights with HP Tuners
  204. What's wrong with my Corvette?
  205. A little bit of KR
  206. lq9 stalling when stopping please help
  207. 98 TA, Shuts down between 6500-6700rpm
  208. LS1/6 Surging and Bucking
  209. Coolant temp sensor plug - depinning question
  210. Truck won't start - HELP
  211. Ls1 Leaning Out DESPERATE!
  212. Oxygen Sensors
  213. Ms3pro in 02 ta. Questions on factory harness and fues box
  214. Twin turbo 6.0
  215. Nova ls swap issues - starts and dies/will only start with throttle depressed
  216. ECM crank request wire
  217. Wideband in stock O2 location
  218. DBW pedal stuck(?) at 1500 rpm
  219. 5.3 lm7 with ls9 cam needs a tune.
  220. 6.0/4L80E swapped Trans Am shifts immediately into 2nd gear from a dead stop
  221. 06 GTO Check Engine Light, No codes.
  222. Stock tune not working anymore?
  223. Cluster interchangeable?
  224. C6 Z06 corvette specifications for converting it to direct injection?
  225. E38 park/neutral
  226. LS1 switch to Holley Dominator questions..
  227. Wideband tuning
  228. Android/Elm327 Pcm Flash App (LS Droid Read only released)
  229. Any issues? New motor old PCM
  230. Ls6 hptuner tune
  231. 4l60e Clicking noise
  232. Gen V L83 No Throttle Response
  233. Vats wont disable
  234. Tech II Database Connection Failed
  235. LFX swap questions
  236. Clutch PID for manual LS1B
  237. DBW 6.0 swap dies when coming to a stop, no VSS
  238. truck starts then immediately dies
  239. Painless 60650 Gauge Controller
  240. Tuning Advise… installing cam
  241. 6.2 L92, What sensor is this?
  242. SES light
  243. e85 and 4L80e P59 swap 99 trans am
  244. Tune says 2.73 gears, but car has 3.73 gears??
  245. Ws6 ecu
  246. Can i add a analog signal to retard the timing on E67
  247. P0300 & p0410
  248. Software transferable?
  249. Want to tune DFCO and timing to blow flames during shift: 2000 C5
  250. Calling all Holley Dominator / HP F-Bodies
