PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 [167] 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Misses, surges, highway speed since lt's and Y
  2. advice on lt fuel
  3. Does 30k miles = SES light?
  4. HELP! SES transmission code - what caused it?
  5. can i send my PCM to someone to get tuned?
  6. Compatibility with non-Gen III TPS/IAC w/ Gen III PCM??
  7. Cam and Crank Triggers
  8. HELP ME BREAK 12s !!!
  9. Any pre-dyno tips?
  10. VE tuning after cam swapping...does anybody change the low-vacuum parts?
  11. LTFTs W/LGs installed. Guru advice?
  12. Predator Data Viewing ?
  13. Where to dyno tune in South Florida?
  14. This is bizarre...
  15. Speedo fix in a A4 to M6 swap.
  16. LTFT's, do they really matter?
  17. Can any tuners make sense of this
  18. my car bucks like a bronco
  19. spark knock and trans component slipping codes after PT4400 install!
  20. What is the difference between
  21. WOT Timing advance
  22. Need help with L Trims
  23. Rev Limiter Problem - In over my head (again...)
  24. cars still miss fireing HELP!!!!!!
  25. Auto tap cods help...
  26. Looking for an '02 Reflash in San Diego
  27. LTFT ? at idle and part throttle
  28. DTC 1416 manuf. controls aux Emis.
  29. Car backfiring after the shift @4K
  30. Bank 2 Misfire - the WHOLE bank
  31. How much timing to pull for spray........
  32. I want tps to read 99% at wot
  33. Tuning needed after ported TB?
  34. P0140 & P0160 h02 circuit codes...how to fix?
  35. Tuning to Eliminate Cam Surge and Hesitation
  36. What is the proper Air fuel ratios ??
  37. anyone installed a MOTEC plm in the car ?
  38. Anyone have .bin file for ATI, 42's,WB340 in tank,?
  39. MAFT Question
  40. Need Help
  41. Custom gauge cluster anyone?
  42. Post your editing tables here!
  43. Are local tuners in the NE tuning with HP tuners?
  44. quick help reseting pcm
  45. Little Autotap Question
  46. Mail Order Tune With G5x2?
  47. "Hand Smoothing" Tables in HPTuner or Edit question..
  48. Cold Idle Issues
  49. Somebody check my work & theory
  50. Hurt my tune or not??
  51. Banging rev limiter
  52. HELP - Cylinder 2 misfiring
  53. please help. idle/staying running problem.
  54. New Cam ... where to start w/ HP Tuners?
  55. How do you permantly turn off traction control?
  56. MAF Translators.....What's the difference?!?!
  57. G5X2 Tuning Question. KR problem!!!
  58. Vehicular Computer Accommodation?
  59. ? about predator
  60. HP Tuner- How do I set what paratmeters to scan?
  61. Whats the best way to compare 2 tunes
  62. Misfire and O2 sensor issue
  63. Hypertech tuner or nah?
  64. LS1Edit and 120 shot of Spray
  65. Deleting Torque Management...set max torque enough?
  66. WOT tuning
  67. Any Local Tuning Locations
  68. Problems maybe PCM related or Torque Management
  69. Can you check out my O2 readings? I think I may have an exhaust leak...
  70. Hp tuners "recovery" feature rocks.
  71. Which Tune option after cam install????
  72. timing problems fixed!
  73. Anyone experience heat soak problems.
  74. Best way in Tunning???
  75. Which edit tool???
  76. No MIL or No Error Reported?
  77. iac steps vs iac counts
  78. Programmer help
  79. engine harness
  80. Very slight white "smoke" on cold starts?
  81. '98 Truck PCM Compatible with LS1Edit
  82. EFILive 5 and Oil Pressure
  83. 1998 F-Body fan questions
  84. Is this common with 3.73's and a 3600+ stall?
  85. Anyone have an injector table for Mototron 60's?
  86. Stall Conv Tuning?
  87. Hooking up A/F gauges, few ?'s!
  88. Do any sponsors tune with HP tuner?
  89. LS1 dyno fuel curves
  90. Help w/ code PO 301
  91. 98 starter relay - any idea how it's grounded?
  92. MWAHAHAHA! They delivered my HPTuners a day early. God bless UPS!
  93. Car running rich..how to adjust on HP Tuners?
  94. wideband for rear o2's
  95. EFILive help
  96. Anyone know if you can log more than 10,000 frames in HP Tuner?
  97. Big Stuff 3 is out and available
  98. HP Tuner update has been released (v1.3.0)
  99. HP Tuner ??
  100. Predator Tuning??
  101. Auto shifting
  102. narrow injector pulsewidth?
  103. Best Scanning Tool
  104. Rev limiter KING !!!!!!!!
  105. blower car tuners - ve or maf tuning?
  106. What ALL can cause gas mileage to drop
  107. difference between 99 and 02 Pcm???
  108. Just Curious, has anybody "viewed" Hypertech changes with LS1Edit or other?
  109. Swapping over to speed density???
  110. Anyone betatesting EFILive Flashscan?
  111. A/F goes to 11:1 @ 5000 '04 Corvette
  112. Idle dip, rough idle, VE, Oh My! Need advice for HPTuners.
  113. HP Tuners VCM Suite 1.3.0 has been released!
  114. Does this look ok?
  115. Removed EGR. Experiencing some KR at part throttle
  116. Accel Gen 7 kits
  117. jumped 12v into coils fires right up...
  118. A theoretical sort of question, PE vs closed loop
  119. TCC and fuel consumption
  120. Where to get a tune, QUICK!!
  121. dyno tuning.....LS1Speed vs. FLP???
  122. Delete AIR with HP Tuners?
  123. Help! New Engine Will not Idle
  124. Why does my trans not downshift at WOT?
  125. programs????
  126. I'm in a bad place here. Need help
  127. Is it Worth it for Me to Buy HP Tuner at This Time?
  128. where to put fan temperatures?
  129. LS1 Edit and forced induction...
  130. Need Help Uneven Ltrms
  131. where to get custom diablo tune?
  132. hpp3??
  133. computer ????
  134. HP Tuners.....Great Product/Support
  135. LS1 edit help needed w3.73 gears and SS3200
  136. LS1edit,Fuel changes vs CID
  137. Service Vehicle light????
  138. SES Light Question
  139. Knock Retard??
  140. 02 Z28 ECM - whats inside?
  141. New cose today...0758
  142. can the Predator remove HPP3's tuning?
  143. Need a 98 M6 file.
  144. Computer Won't Hold A Tune...HELP!!!
  145. Problems after cam and header swap
  146. EGR tables in HP tuners?
  147. Can any VIN number be programmend into the ECU?
  148. lack of throttle (response) after idle
  149. need 99+ pin outs of gauge cluster
  150. cost of new PCM and dealer flashing????
  151. 02 sensor transition time malfunction code question
  152. Edit or HP Tuners for me?
  153. Which table to adjust Ltrims?
  154. KR Question PLEASE HELP!!
  155. Conditions needed to make A4 shift at WOT?? (HPTuners)
  156. Want to add Trip Computer to 2000 Z28 Camaro
  157. Idle problems
  158. KR question
  159. Vinci Handheld prgrammer
  160. VATS turnned off, car still wont start
  161. HP Tuners .bin file sharing...
  162. No O2 sensors on my Z
  163. just got predator,,got some Q?
  164. How do I fix this broken pcm socket?
  165. !AIR/LS1 Edit question....
  166. help with LPE
  167. Tuning issue w/ Predator-HELP PLEASE???
  168. A/F Ratio Quick Question
  169. Does anyone have LS1edit V1.4 for a 98!?
  170. anyone have an hp tuners .bin for a 2000 A4 vette w/ 3.15s or 2.73s?
  171. hp tuners "lean cruise" settings...
  172. unusual problem
  173. pcm case swappable?
  174. Newbie looking for some help
  175. how does hptuners compare to efilive as far as data logging?
  176. SES AFTER CAM INSTALL SOME Q's
  177. Need HELP- P0758 code
  178. Tuning do's and don'ts.
  179. CODE 0410 & 1133
  180. Predator say's......
  181. Need help with lt1 engine performance
  182. HP Tuner Opportunity....What to edit????
  183. slow PCM and shift light?
  184. Can MAFT noticeably affect VE (and idle) in a cammed car?
  185. how mcuh will ls6 intake throw off the air fuel?
  186. HPtuner for 98's
  187. P0121 and ASR help!
  188. REV Limiter stuck at 6200RPMs
  189. Can somebody explain the volumetric efficiency tables and what affects them?
  190. anyone get a ls1edit tune from Fbodycentral in MD?
  191. Edit links to specific engine types?
  192. HP Tuners Custom Tuning
  193. Lift are staying at 25
  194. whats the best chip or programmer??
  195. New cam/timing ?
  196. Should I switch back to a stock MAF?
  197. Pass side LTFTs almost always leaner than drivers side
  198. Misfire question
  199. Need part #'s for 99 Z28 rear 02's
  200. Auto Tap
  201. Tuning with MAFT after cam/shorty install...same as before?
  202. Pulled BAT SES off
  203. anyone using an impedance converter?
  204. Tuning responsiveness to fuel and spark TR224 car ?
  205. low impedance injector use?
  206. help with my tune
  207. Please explain the relation between ltft's and stft's and why they affect WOT fuel.
  208. Mail-in tuning
  209. Tips for Superchips owners w/3:73 new gears
  210. bad random misfires p0300
  211. Stop drilling those TBs, fix stalling without computer tuning...
  212. any wideband commander users out there?
  213. Quick KR questions
  214. Help!!!???
  215. Burnt the PCM
  216. What is the best thing to use to tune SC and LTH?
  217. Cat Overtemp Thresholds table
  218. Tuning LTFT w/ HP Tuners
  219. LM-1 Wideband & RPM Convertor purchase....
  220. where does the purple wire go?
  221. Basic question on LS1 edit - accessing tables?
  222. A4 unlocked dynojet files...anyone got one ?
  223. LS1-Edit question
  224. New codes how to fix?
  225. Tuning S/C and LT headers. Need help
  226. HPTuners, Explain Something Please
  227. ls1 edit
  228. HP Tuner or my car?
  229. HP Tuners "Invalid authorization code"
  230. Big dip in A/F on dyno while tuning
  231. Tunning
  232. Need some help after M6 to TH400 swap
  233. cruise controll problems, not working
  234. LTFT is -10.7 now WOT=0
  235. Check out my dyno please - am I running too rich
  236. Notes from FAST bank/bank standalone computer install
  237. Stock HPTuners file for 99 A4 C5
  238. Experimenting w/Autotap?
  239. Headers + O2 Sims = SES (Code P1133)
  240. Question for the cam people
  241. messing with custom tune (Predator)
  242. Help, do I need bigger injectors?
  243. How do I tune out lugging while coasting.
  244. Looking for PCM PIN for CAGS/Shift LAMP in Cluster
  245. Wierd P1514 and a P0101
  246. How do I calculate duty cycle from injector msec
  247. Car won't idle in open loop!
  248. Bigger injectors
  249. Tuning help please!! LONG!!
  250. HP tuners question re: A4, new rear gear and P1870
