- new to LS1Edit......could use some help...
- Where can I get my car tuned at?
- Richening up the car like an old carb. car?
- ATAP Reading Newbie...Please come inside ????
- EASE users come in!
- How much change in the Timing Advance ...
- surging with blower?
- MAF / VE Tables relationship found in service manual
- FYI for you LS1 Edit/Laptop guys without built-in serial ports....
- Tuning gains?
- How hard is LS1 Edit to use?
- Help!! What to do with a PO137 SES???
- how to remove top speed limiter?
- What do you know about LS1 timin tables?
- anyone exp. service VEHICLE dash light please come on down
- Who has seen gains fom pump gas to race gas and added timing NA?
- 396 Lt-1 36# injector offset ?
- P0131 SES???
- SES light=EVAP P0449
- EFI LIVE V5.0 capabilities???
- Where I can Buy the LS1 edit. How Mu$$$$$h
- hey all need help
- Autotap for Windoze 2.03 doesn't recognize IAC counts?
- AutoTap Analyzer for Access 2000+
- Am I running lean/rich with my mods?
- Do you recommend MAFT?
- Editing cold start with big cam
- LS1 Edit tune gone after warranty work?
- Editing the PE table with LS1 Edit????
- My new best with the Diablo Predator
- need some help please
- Running Lean and Rich questions
- Tuning Help.
- ATAP/EFILive to calc. times?
- Someone talk to me about MAFT's. Thanks.
- tuning after cam swap
- How do you eliminate missfire codes...
- How much $ are you paying for dyno tunning?
- Dyno and Tuning
- ls1 edit
- LS1edit near minneapolis?
- Predator.what are the correct fan settings?
- Autotap Analysis Excel File to try...
- Crappy gas milage discusion and ATap question.
- Raising the idle manually?!!
- LS1Edit WOT Hot Table Q?
- G-Tech meter
- Where 2 set shift points for best ET on a minor bolt on car?
- Can LS1 edit be used for....
- Too lean ?
- Injector Flow Rate Question
- ls1 edit requirments?
- MAF flatline at high Hz
- predator question
- LS1 Edit, What Operating System
- Can anyone answer me this??
- O2 Sensors .....
- Where should timing be?
- LS1Edit & Engine Displacement
- What is the newest verison for a MAFT
- How to lean the car out while cruising?
- need some advise on starting points on tuning wit h maft
- dynot tuning in SoCal
- Need Help to find prob
- My FAST system arrived at Cartek today
- LTFT Q...
- P0135 Code.
- Whats up with my rough idle? Threw code P0174?
- going thru o2 sensors like water part 2, almost have the problem narrowed down!!
- logged a 1st to 4th gear pass.....
- SES Bank 1 and 2 codes, What do they mean?
- SES Code
- Autotap data-how to use in Excel
- Lost my LS1 Edit tune??? Please HELP!!!
- Best Programer/Chip to drop ETAs
- LS1 edit flash files question.
- TB Bump Stop Fine Tune
- Skip shift and LS1 edit?
- Anyone tune for 50# Delphi Injectors yet??
- LS1edit near Pittsburgh?
- How do I delete rear O2's with edit?
- stock timing advance on a 02 car
- Paging BfB...and anyone that can help me with my questions.
- Dyno tune in St. Louis Area & other Questions
- 2.73 -> 3.42 gear swap...what do I have to change in LS1-Edit
- Anyone using N20 Tuner?
- what to expect from HyperTech Programer
- code p1153 bank 2 fuel control shifted lean? anyone?
- Codes for both knock sensors are on
- Autotap Horsepower and Torque
- I need LS1 edit!!!!!!!!!!!
- Dynorun?
- High octane timing table question for new setup
- 2000 Hypertech PP3 for sale on Ebay
- LS1 or Diablo Predator? Suggestions please
- Fuel Tables
- ls1 edit in nj
- Lean?????
- Autotap,EFILive and a laptop-First timer needs help
- Can the Preditor delete codes from PCM?
- what can i expect from ls1edit?
- I think i am confused.....
- Ls1 Edit in Michigan are?
- Stuck in WOT?
- Fuel cells questions????
- hypertech on an auto?
- Timing question
- SES and loss of power
- Does Chevy and Ponitac Dyno their engines?
- Friends car has 3 * of KR (how bad is it?)
- Need Help!! SES light is killing me...need adivce from the experts
- serviceVehicle lamp came on...help
- Aftermarket Cats And COT
- MAP 99-100 @ WOT
- LS1 Edit tuning services comming to Norris Motorsports Dec. 11th!
- COME ON GUYS, NEED YOUR HELP ASAP.
- Tuning after heads and cam
- What needs to be tuned on a cam swap?
- TPS TEC Throttle Enhancer for round TPS Connector 92-02
- Any shops in N.C. for custom programming/tuning?
- Fuel Injectors working at 106% duty cycle.
- anyone ever atap test a cold air induction kit?
- ls1 99 STOCK PCM AUTOMATIC
- help with tuning in H-town....
- ls1 99 STOCK PCM
- MAFT cabling question
- Buy LS1 Edit or Have my car Dyno LS1 Tuned?
- B2S1 at 1.005 at WOT... Bad Sensor???
- ? on Ed Wright tuning
- HPP3 For A M6
- I found the problem...how to fix it?
- Requirements for O2 Heater and Catalyst Test Completion?
- MAF, why mess with it? Need real answers
- LS1 LS6 PCM Difference??
- need tuning in stl
- Trouble with my A/F guage
- Best place in Houston for Custom Tuning
- HPP3 Tuning Questions
- hypertech power programmer
- can i replace the air pump w/a resistor & no code?
- Analysis of my A-tap after H/C
- OBD-II connector Pinouts
- Codes P0135 and P0155. HO2S Heater Performance Bank 2 Sensor 1
- 0 iac count? is there something wrong with my atap?
- VE table
- cold start, open loop
- Little help here, PCM tuning!!!!!!
- Adding headers, do I need custom programming?
- Newbie HPP3 questions, sorry
- Ed Wright or Maf Trans. ?
- Carputing's (Ls1-Edit) Customer Service
- What is the limit of scaling the MAF table on a 98?
- Question about EFILive V5
- My O2 sensors aren't showing up!
- Who does pcm tuneing local
- How to adjust COT on a car with cats?
- Calibrated MAF Sensor for Larger Injectors?
- Timing Tuner? Please Help!!
- LS1 Edit, changing Timing Advance?????
- Auto Tap RPM vs Timing Advance
- timing retard while spraying
- What is code P131?
- Newbie A-tap EFI live questions
- Predator ?
- Besides the sponsors, who is selling PCM tuning services?
- retarding timing?
- 3600 stall convertor, now do what using LS1 edit?
- ABS inop and TCS off after clutch install.
- LS1-Edit: Got Cable, now Where do I Download the Software?
- LS1 Edit and shift points for A4 "please"
- Just got odb-2 vehicle explorer... now what?
- JET Power Control Module (PCM)?
- Help with S-trim and L-trim
- Opinions on HPP3 on A4 cars.
- HPP3 on 02 and up opinions
- ls1edit, "desired shift time" question
- SES P0404 EGR
- Hypertech questions???????????????
- Cam Sensor location???
- **Removing MAFT question**
- Missing at WOT
- COTS ?
- WOT tuning?
- Does anybody have a clue as to why this happens?
- OBDII and autotap
- Idle Help
- LTFT's cruising avg. -3.1, MAFT set 15% rich Base 0 WOT. Good??
- What is Torque Management
- LS1 EDIT
- Bank 1 vs. Bank 2
- How to desensitize knock sensors?
- stupid questions about the predator, a/f stuff
- injector pulsewidth
- Removing torque management with Transgo
- OK, I just threw a o2 sensor heater code for an o2 sim!!! WTF?
- OMG! Just set SES light and pulled all the current, pending &Immature codes!
- How can I check O2 sensor with volt meter?
- Those with G5 cam and ls1 edit
- does a hypertech make a big difference on a ls1?
- Atap Readings! Need some advice!
- 1997 TECHLINE CD DISC 5
- HPP III with gear change?
- p0300 Misfire Code Urgent Help!
- SES back on???
- Odometer Question
- How do I change injector size and lean wot with LS1 edit
- predator tuning
- Why does knock retard kick in at exactly 4K RPM's???
- Clutch just installed, now O2 sensor SES light on.
- Add or Subtract fuel with new heads
- What are the four different timing tables for?
- MAF ends causing rev limiter problems?
- S. ENGINE SOON LIGHT CAME ON. what should i do? or whats it mean?
- dammit I am MAXING my MAF
- How to read MAF readings gm/s or by lbs?
- Would u recomend a Hpp3??
- pinouts on 98 LS1 PCM
- Anyone using LS1 Edit to make Traction Control off/on
- EFI Live PID's and Values
- P0747???
- Tuning a stock car ('02) does help.
- O2 Waveform with Autotap question
- ok I have just received ls1edit!!! how to download my PCM file first!
- O2 Readings on EFI Live Problems
- What tuning is required for a cam??
- G-tech Competition Performance Meter
- Lets talk timing, LT1 vs LS1
- delete egr? how (ls1edit)
- Dumb Question
- O2 READINGS!!!!!!!!!!!!!!!!!!!!!
- What should my iac counts be?
- New O2 sensors. Right bank runs leaner than left
- Autotap, EFI Live or Ease?
- I need help, no tiiming?
- Anythign to do with Cat Over Temp with a stock car?
- Stock 02 WS6, A/F take a nosedive after 4900 (rich)
- A/F and LS1 Edit??????
- Starting problem.
- Why do LTrims need to be 0 or positive if.....?
- Cool Weather....Time to retune!
- Those who think front o2 sensors are inaccurate, inside
- Line pressure w/ Edit
- OBD2 connection failed. EFIlive ???
- Anyone using ATap with Windows 2000?
- How to turn off rear O2s with LS1edit?
