PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 [85] 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. SES Light Flashing C0650
  2. Upshift question
  3. P0420 & P0430 Help!!!!!
  4. Damn p1153 code
  5. HPTuners Injector Pulsewidth Question
  6. blue PCM plug 2006 GTO
  7. Old school tuning assisstance needed...
  8. Stock 2002 Z06
  9. Speedo signal
  10. need a tune IMMEDIATELY!! please help
  11. Sticks in OpenLoop after PE
  12. Live scan for ABS INOP light
  13. PE or MAF for WOT Tuning On Stock Car
  14. If you had?
  15. efi live question
  16. Tuning VE question
  17. voltage drops while cranking
  18. LT1 383 fuel trims.
  19. Need some help about wiring up lean shutdown switch
  20. hp tuner?
  21. Random Misfire- Coil, valve spring, lifter???
  22. MAF tuning question
  23. bad tune or bad valvetrain
  24. E-38 Tach Output
  25. P1637 diagnostic results opinion needed
  26. Knock Sensors
  27. EGR tuned out
  28. HP tuners clicky clicky
  29. 98 questions
  30. Help......ses Light Question
  31. Anyone with LS1 Edit in Central Texas that can tune?
  32. Need Computer Help!!
  33. Changing idle speed; GM tech 2.... '98 ls1........Come in Tech 2 gurus
  34. Whats what? ECU's
  35. Code P0601
  36. innovate motorsports widebands any good?
  37. Reputable tuner in MD
  38. Wideband Questions
  39. Can anyone look over my logs?
  40. Diablosport predator
  41. v6 to v8 swap, ECU?
  42. 98 pcm and 99 pcm
  43. question about EFI live
  44. Tuning Gurus... something seem a little off to you?
  45. Advanced ecu questions?
  46. Wheel sensors
  47. O2 delete and state Inspection???
  48. o2 sensor delete
  49. questions about diablosport programmer
  50. WTF!! Does anyone fall for this.
  51. Narrow bands for use with leaded fuels?
  52. Question..O2 sensors
  53. Easiest EMS to use?
  54. Injector compensation question
  55. Need assistence with base E85
  56. need a good tune
  57. Preditor tuner
  58. HP Tuners issue
  59. Post up laptop mounting pics.
  60. Who wants to make $50? Need codes deleted
  61. Code-P0443/p0440
  62. Os sensor Help
  63. Best Tuner In KY
  64. Diablo egr delete
  65. VSS Help-70 Corvette LS w/Keisler 5 Speed
  66. Any tuning available for GM's new 09 3.6 V6 Direct injection
  67. P0719 code?
  68. High altitude tuning
  69. HELP! HPT not reading WB!
  70. HPT and altenator
  71. Fastest Stock Computer
  72. New PCM now receiving codes
  73. HPTuners and Oil Pressure
  74. HPTuners DTC Codes
  75. What scanner can read and delete pcm codes?
  76. Question about buying new ECM
  77. Couple Knock Sensor Questions
  78. Performance chip
  79. Maximum lb/min for stock MAF?
  80. EFILIVE help v.retarded high idle
  81. high idle problem?
  82. LS1 cam/stall - idling/sputtering after transport from NC to IL
  83. looking for a tuner in SW pa
  84. Dyno tune shop?Any1
  85. First time with SD tune
  86. how do you test the idle air sensor??
  87. EFI Live/LS1edit ???????
  88. P0133 and P0153
  89. optimum air/fuel mixture after long tube install
  90. two problems
  91. EFI Live ?
  92. DiabloSport with SLP custom tune
  93. closest dyno
  94. getting speedo to work with th400
  95. Which Wideband to purchase?
  96. Reflash and startup tune
  97. Car idles high.. please advice.. video & pics..
  98. plX sm-afr/dm100 box mounting
  99. PID list
  100. 2003 Escalade PCM -> 2004 GTO OS?
  101. LC-1 wideband issue
  102. Anyone with Ls1 edit near central Wisconsin?
  103. Car dies when enters "closed loop"
  104. COT for Magnaflow 59959s
  105. 5.3 Lean Condition Help?..
  106. ECM seals
  107. MAF dirt, rich or lean results and dead CATS?
  108. Can I 'tune' the position sensor on my DBW pedal?
  109. Truck won't start
  110. open loop with cats and tq managment
  111. Speed Denisty Tune on Dyno?
  112. Help Tuning Injectors w/Diablo
  113. help with RACE-TRONIX ls2/ls1 cam pos sensor adapter - no signal now :-(
  114. ECU Recal
  115. Tuning Nightmare Help
  116. H/C A4 Stalling after start up.... has been tuned
  117. MAF fluctuation at WOT but runs good
  118. MAF and VE almost dialed in... but...
  119. diablo tuning for bigger injectors?
  120. 4l60e Tunning for drag racing
  121. Deleted EGR codes still coming on
  122. Trex File, efi live
  123. Fuel cut off not making sense
  124. LS1 efi ECU swap
  125. lowering misfire sensitivity?
  126. Running Lean on Top end... MAF calibration?
  127. start-up/idle issues...imagine that?
  128. Tranny shifts to second when launching...
  129. Frost need ur help loose pcm connection/
  130. MAP sensor not reading properly...no fuel enrichment
  131. Fresh Re-build running on 4 cylinders?
  132. Stupid traction control.....HELP ME OUT!
  133. use tune from car on truck?
  134. Bung Hole Placement For Lm1
  135. Requesting a Tune file for specific setup
  136. Very low idle at start up when sitting overnight.
  137. Just installed Headers+ORY Need Help Please
  138. Rich Idle - Inj, VE, or ?
  139. I need help!
  140. L76 w/40lb Inj, Fuel rails and PSI Question
  141. What is the purpose of the DTC's not run Function
  142. TPS volitage
  143. Sudden no start issue, please help!
  144. Codes U1000 & U1016...what are these???
  145. plx wideband, just so i understand.......
  146. lt1 tune info help.
  147. For "research" purposes: setting OBD2 codes to "always ready" for inspection?
  148. Stopped Edit Read did I fry PCM
  149. Codes Deleted/ How long until thrown codes cycle out.
  150. P0402 COde
  151. idle reving and then dropping
  152. Which ECM and tune?
  153. Running rich?
  154. Need Help with some codes
  155. What order do you tune parameters?
  156. 1970 Corvette Conversion-P0452 Code
  157. 02 z w/charger codes p0140 and 0157?
  158. Fuel Gauge Fix / PCM Change?
  159. Freaking catalyst monitor
  160. FRIED E40 during full reflash with Tech2
  161. Idles 10 sec then dies
  162. Autometer wideband logging
  163. New GM Wiring harness?
  164. would the real tuners please stand UP ?
  165. Security Light! Help
  166. help i need a answer !!!!
  167. making the 2bar leap
  168. predetor tuner question
  169. OBD not communicating
  170. Factory PCM and FI
  171. NEWB tuning help
  172. Is there such a product or device
  173. map scaler
  174. map sensor e bar
  175. Unplug the MAF, car dies WTF?
  176. Help!
  177. 98 computer to a 99-02 conversion
  178. Electrical short not letting car be tuned? HELP!
  179. Need some input from the veterans (HP Tuners)
  180. New to drivability tuning
  181. 2 Cars Same problem, My cars Hate the track
  182. Nutty O2 oscillation. WTF?
  183. breaking up at high rpm.
  184. I Need A Harness!!
  185. 1-2 shift hits limiter with log info
  186. Tune for 5psi?
  187. 98 z28 programmer?!
  188. How much for tuning?
  189. high octane table to low octane table ????
  190. tons of O2 codes
  191. Same problems after new plugs and wires. Help!!
  192. % to change AFR??
  193. Hptuners Dropped Tune????????
  194. Laptop thread locked
  195. p0522 code. I need help!!!
  196. P0154 Code after Header Install?
  197. Professional Tune before N2O installed
  198. delphi and slp 85 maf calibrations
  199. Anyone know what happens when you disconnect just one O2 sensor?
  200. OBD2 to Laptop USB or Serial Connector
  201. how bad can tempeture effect ur tune???
  202. HP Tuners x/y axis question
  203. Lap top mount for F body
  204. P0757 How to shut off?
  205. Tune Question
  206. 2002 6.0 code help
  207. lc1 mounting/install
  208. MAP sensor cal for a 2bar 98 with HPT
  209. BigStuff3 experts - upgrade for 58x?
  210. U7198 Help!
  211. help with A/F gauge
  212. idle and fans tables, what is the best
  213. Megasquirt help
  214. need a help
  215. front 02's dead
  216. 3 bar sd enhancement
  217. HPTUNERS wideband
  218. Large LTFTs with stock MAF & injectors, why?
  219. Can you Monitor Fuel Pressure with HPT?
  220. Which one of these Actron reads real time to check for retard?
  221. Tuning with a handheld after headers
  222. hypertech?
  223. Sputters when warm
  224. Misfire question
  225. Need tuner or PCM tuned
  226. Computer Questions and HELP Needed!!!!
  227. Looking for help: Fuel trims maxed & Timing advance going nuts?! Stock engine!
  228. 99 computer in a 2000?
  229. LS1edit files online....
  230. Tapping for vehicle speed + throttle position
  231. Question for the Pros or anyone that has had this problem
  232. Camaro upstream and downstream O2 sensors are they the same?
  233. What the hell is this codes ?
  234. BCM help!
  235. Innovate DB wideband?
  236. Headed to get tuned! But before I go!
  237. Timing freaks out at idle
  238. After a tune
  239. hanging idle help
  240. quick question..
  241. Aeroforce Interceptor and Wideband
  242. Question: DiabloSport predator
  243. Does anyone Have a MAF Table for a Pro-M 85 mm Maf on an F Body?
  244. AEM A/F UEGO Controller Setup.
  245. olsd tune in cammed cars!? lean starts question
  246. Little transmission related tuning help needed
  247. Spark with KR help
  248. Turn P0300 code Off?
  249. 2006 LS2 wiring ?'s
  250. codes
