PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 [164] 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Hand held tuner for cam?
  2. Corvette software into F-body PCM?
  3. How long tipicaly for RWTD to write a tune?
  4. G5X3 (and similar), care to share your Idle airflow, IAC park, and decay tables
  5. 1997 Corvette Programmer
  6. Check Engine Light.
  7. Harlan Shift light install problems
  8. High altitude Idle/MAP out of range problem
  9. EGR Removal and Timing Changes
  10. HP tuners questions
  11. NA timing tuning
  12. Drive by wire, and HPT. Help with TR220 idle tuning.
  13. Can U Reflash A Ecm With A Different Vin #
  14. Cruise Control not working?
  15. Code P0113
  16. LS1 Edit on a C5
  17. A/F mixture question
  18. how to keep idle out of closed loop?
  19. which route to go for self tuning????
  20. TCI SSF 3500 installed last night--Now Questions
  21. Turning off AIR completely in HP Tuners
  22. HP tuners tuning for headers and intake, where do I start??
  23. Car Won't Start
  24. SES/catalytic converter?
  25. HumpinSS....................................
  26. Reduce Timing with EGR Removal?
  27. knock sensor
  28. before and after tuning?
  29. Tuning for MPG?
  30. Autotap Help Pls.
  31. Reading HP Tuner Log
  32. What is the proper way to delete O2, EGR ect
  33. A/C on or off tables
  34. anybody got an hptuners file for a 98 with these mods
  35. Mix and match electronics for 6.0
  36. Why am I running Lean??
  37. Hpp3
  38. Excel Calculator for Gear based on Speed and RPM!
  39. Autometer Tachometer
  40. Help!! With Ls1edit!!
  41. got to tune with use of Innovate Wideband! thanks to Roman for driving my car!
  42. idle and cam
  43. when does injector pulse start
  44. TPS Code and Tranny issue
  45. map sensor was unplugged/ now strange>
  46. Anyone Have a HP Tuner File with the Stock VE Table?
  47. What WB to get?
  48. Pcm Help!?
  49. PE questions and modfying only certain g/cyl and rpm areas
  50. What should I change?
  51. Zo6 Maf
  52. LS-1 tuning just with LS-1 Edit?
  53. Cheapest place to get a DynoJet Wideband Commander??
  54. LS1Edit for holden ls1 Vehicle..
  55. Why no SES light?
  56. ifr and open loop
  57. HP tuner owners, help needed
  58. Bink, NoGo, anyone air/fuel change???
  59. has anyone ever seen an LS1 take 32 degrees of timing? Think I need some help!!
  60. what year has best pcm
  61. LS1edit VE tables vs HPtuners VE tables???
  62. Going back to stock, need reflash help.
  63. running a ford maf, on a GM/LS1 car
  64. Troubleshooting Code P0200
  65. What fan activation temps for 160 thermo?
  66. LTFT in the -24 range at idle
  67. Troubleshooting P0200 Code
  68. Just got my HP Tuners... need some help
  69. Need Help Please
  70. Need a copy of Ls1edit.
  71. newbie to tuning..just a couple of basic ?'s
  72. HP Tuners question....
  73. Will this hurt my tune?
  74. Lterms 25% Sterms 20% to 30% IAC 0 at idle
  75. Problem with ls1edit
  76. code 0315?
  77. Why should I buy a Predator? What can I do?
  78. HP tuners no response
  79. Stubble on decel and light throttle with 42.5's
  80. Downloading an Edit file written on a different version?
  81. Those with 42lb injectors....
  82. Hats off to Speed Inc.
  83. trans kind of slipping after h/c install?
  84. Idle problem HPtuners help
  85. installed a radix s/c.. no start
  86. Strange problem form 2k to 3k need some help please.
  87. what to expect....
  88. air bag light is on
  89. Need HP Tuner Help with Hot and Cold Start
  90. HP Tuners, disabling post cat O2 sensors..
  91. predator?
  92. Need help: Predator wont fix speedo!
  93. Knock Sensor
  94. can i add a 01 vin to my 98 edit
  95. Final question before Wideband purchase
  96. Final question before Wideband purchase
  97. What tables to change for Stroker engines?
  98. Open Loop/Cold Start A/F ????
  99. scanner, all maxed out at 24 paramaters?
  100. Tuner
  101. Wiring Problems Need Help From All!!!
  102. pcm and dyno tuning
  103. WOT but not in cell 22?
  104. help!! passenger side VERY rich, drivers side fine
  105. What's a Safe A/F mixture on a D-1SC
  106. What is the best wideband on the market?
  107. High Voltage 02 sensor???
  108. info on VE for big CI LS1s
  109. SES light came on
  110. Help...Several HPTuner questions?
  111. Help With SES Light
  112. Secondary VE Table
  113. cleaning wideband sensor
  114. HP Tuning Questions
  115. HPP3 questions
  116. knock senor problems
  117. P0335?
  118. Positive Ltrims feel quicker...
  119. Tuning questions
  120. Where is closest place to get my car tuned?
  121. Random idle surge, hangs high and automatic cruize w/90mm lsx 427, help please!
  122. How do i convert map sensor voltage
  123. ATTN Lou or Louis
  124. Mail Order tune question
  125. Just got HP tuners
  126. Question on ignition on stroker motor
  127. Tach stops working
  128. LS! edit ???
  129. How can I check for updates for my PCM?
  130. closest place to memphis to get a tune?
  131. A/F vs Wideband guage whats the diff?
  132. HPT: EGR spark advance correction.
  133. knock sensor help
  134. What Happened
  135. Innovate Motorsports Wide Band
  136. LTRIM part throttle vs WOT question
  137. shift points? w/predator
  138. 02's reading 940 spark 27.4
  139. HP tuners help
  140. I want to get a spare computer to get flashed for a new tune but how ?
  141. Setting shift point for 231/237
  142. P0153 code.
  143. fast system ... need help..
  144. Tuning tonight. Removed EGR with HPTuners...interesting...
  145. Tuning question
  146. change oil light on after I changed it what to do
  147. can I have my "AIR" code disabled in a custom tune?
  148. Diablosport Predator questions
  149. A4 cars with aftermarket trannies--inside please
  150. Few tuning questions for Turbo.
  151. Who has SLP MAF?
  152. Wide Band pre-release screenshots
  153. HI,1 opinion and 2 questions...
  154. HPTuner cable
  155. Scan logs, please decipher for me.
  156. Strange problem, need help pinpointing it (long)
  157. A few of my tuning issues solved
  158. Throwing codes left and right today- HELP, PCM GURUS!!!
  159. F.A.S.T. Cost and install
  160. Accel Gen 7 Users Inside!
  161. need help w/hpp3please!!!!!!!!!!!1
  162. deleting cags with hptuners?
  163. Tuning on a "load style" dyno vs Dynojet ?
  164. PCM Tuning for 383 Stroker and Nitrous!!!!
  165. Random KR. (screen capture)
  166. Help (Knocking)
  167. Help Me Please ! Dealership Srcewed My Car.
  168. Got some of my tuning issues worked out
  169. tire height???
  170. Lesson Learned! (I Think?)
  171. Does anyone have an injector offset table for SVO 30# injectors?
  172. improving performance with hp tuners over stock tune
  173. Just another Reasuring question about the HP Tuner
  174. Maf Question
  175. FAST or Gen 7...
  176. 18 volts?
  177. Tuning for 231/237 with Predator
  178. Trans Temp Guage acting strange
  179. Using Hypertech and LS1 Edit at the same time?
  180. computer tuners for...
  181. Where's the torque?
  182. Anyone have HPT for an '02....
  183. New to Dynotuning, whats involved
  184. What controls AC air/fuel?
  185. help plz!
  186. 02 help please
  187. Safe A/F Ratio for N/A ?????
  188. Do I NEED A NEW COMPUTER?
  189. 6.0 Tuning (timing) questions
  190. HPPIII Qs
  191. Code help
  192. tuning support software question?
  193. Anyone familiar with ACCEL CALMAP?
  194. Hp tuner LS1 edit list?
  195. Tuner for a 98 trans am?
  196. HELP!! bolt that holds the wiring harness on the pcm stripped...
  197. ?'s about wideband o2 sensors
  198. Hypertech 3 shift rpm setting
  199. How does changing the VE relate to A/F?
  200. SES Light..code P0430?
  201. Paging Nogo!!!!!!
  202. Re Calibrated MAP sensor to read Boost w/Stock PCM
  203. Dyno Tuning vs. Doing it myself
  204. Damn P0300 code Need some advice
  205. 93,95 ECM Same???
  206. LTFT Adjustment: Airflow vs Output Freq verses Rescaling IFR
  207. Questions about HP Tuner?
  208. Whats the best way to disable Knock Retard at specific RPM?
  209. Air Pump & WB O2 sensor
  210. Help Unsolved Misfire on Cylinder #5
  211. Flickering "Check Gages" light
  212. Edit software question
  213. a4 to th400 and custom tune...
  214. Attention all PCM EXPERTS!! Question...
  215. Help I got extremely low timing
  216. Tip-in KR
  217. throwing evap sys code, help please
  218. Tuning Help PLEASE
  219. Can My Tuner use His Edit If I have Edit?
  220. Wot tps sensor values
  221. 03 Wiring For Cluster
  222. how to hook up an oil pressure gauge?
  223. Best tuning software
  224. WOT spak plug Timing & WOT fuel curve
  225. LTFT Numbers
  226. What are these codes?
  227. What Does This Mean?
  228. LT1 with Tunercat...Can anyone help??
  229. Computer trouble!!!
  230. hp tuner or having a pro tune
  231. HP Tuners + Stock LS1 MAF or LS6 MAF?
  232. P0645 AC Clutch Relay Control, error.....How do I trick this out
  233. Low voltage o2 DTC
  234. HP Tuners - .bin mod question
  235. Just gutted cats wonderful check engine light on any homemade tricks
  236. Pro M
  237. anyone have any info on the zeitronix wideband? Looks very neat!!
  238. LS1 Edit........PLEASE HELP
  239. How much should a tune cost ?
  240. Finally O2's are looking better,tan not black soot.
  241. A few noob questions
  242. breather affecting A/F
  243. Tuning SVO 30# injectors?
  244. Where do I get LS1 Edit?
  245. TCI Torque Convertor and Tuning
  246. The 26 Mile Problem
  247. Where can I get my car dyno tuned?
  248. Can anyone with HPtuners take a look at my log?
  249. 2 step and codes
  250. FTC vs MAP/RPM (VE Related)
