PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 [109] 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. HPTuners file repository...
  2. installing o2 sensor
  3. adapter harness ?
  4. Would you want a demo version of HPT?
  5. Data Logging a monorail
  6. need a little help!
  7. Diablosport Predator Tuning Help Please
  8. Heellllpp!!!!!
  9. Universal Injector spreadsheet
  10. Where do you buy more credits for HP Tuners>
  11. all i want are a few codes deleted... nothing more.
  12. ltft tuning clarification with predator
  13. Oil Change light and Diablo Tuner
  14. How to tune low LTFT's?
  15. How long can i drive on this?
  16. 5.3l Dod
  17. Wiring harness
  18. Car won't start
  19. Self Tuning?
  20. 97-98 or 99-02 PCM?????????
  21. can a vin # be input by hp tuners?
  22. Tuning the T-rex
  23. How important will a tune be for this scenario?
  24. Primary/Secondary VE table?
  25. help! lose in Rpm's. P0430
  26. Trying to get ls6 Grand Sport to run
  27. Tuning "by the book"
  28. Effects of Cats on A/F Ratio?
  29. Why is my timing retarded?
  30. Cheapest Diablosport Tuner
  31. 2bar SD w/ HPT: BIZARRE problem...please help!
  32. GM to Ford TPS
  33. Oil change light
  34. elec fuel press gauge not working properely?
  35. Please explain relays to me.
  36. Help With Codes!!!
  37. starting problem 1998 Camaro
  38. Tuning For Heads?
  39. paging Jesse bubb
  40. Please help P0305 Code
  41. PLEASE HELP newbie tune MS4 LS1
  42. EVAP and fuel level questions - yeah i searched
  43. Headers with Superchips?
  44. Ls1, SD tune, TURBO, N20
  45. Predator 02 sensors
  46. oxygen sensor question
  47. Wiring question???
  48. PE Explaination
  49. P0704
  50. 36lb Injectors Rich on Decel
  51. PE Fuel Multiplier
  52. ls2 tuning
  53. 1998 Os
  54. Just tuned with HP Tuners and a couple q's.
  55. guys running hp tunners
  56. Does anyone currently sell a 2 step?
  57. any mustang guyshere?need help
  58. shooting flames
  59. Just installed dynojets Wideband commander.........and have some questions???
  60. where is the ignition switch located?
  61. What is the best aftermarket fuel managment system?
  62. # for carputing
  63. Black Plugs (rich) S/D tune question
  64. threw 2 codes last night, shift solenoid A+C
  65. knock retard question
  66. Unsure what the light is!
  67. Please help me p0118
  68. Sensor ?
  69. Offbeat tuning question for you guys...........
  70. Idle Tuning - Helpful Info Inside
  71. 98 pcm ???
  72. 02 sensor hookup
  73. dynotune lc-1
  74. Injectors.xls file
  75. RPM tach signal wire???02 z06 vette.
  76. Signal to fuel pump relay?
  77. Vac Mod Tranny And Tuneing
  78. air fuel ratio guage
  79. weird power problem!
  80. will my car run fine if i get rid of a few things....
  81. HELP egr sim avalible
  82. Hp tuners- Car and truck question
  83. Tuning
  84. Need to 'cheat' on Economy run
  85. Wideband output to PCM?
  86. operating system
  87. P0128 dtc ?
  88. Wideband goin crazy after LTs.
  89. HELP! 548whp and low speed issues
  90. Diagnostic Port not working......
  91. How does the PCM know what 14.7 is?
  92. AIR code came on after boosting car...?
  93. Can some of you good tuners eval my dyno graph for me?
  94. HP tuner
  95. Ls1 in rx7 & Ls1 in 240sx
  96. PE enable rpm?
  97. Best tape/wire for wiring
  98. spark advance and race gas
  99. HP Tuners
  100. Mefi 4 Tuning
  101. Mail order tune info
  102. 2bar map voltage to boost conversion for custom pid
  103. HP Tuner - What needed to load SD tune?
  104. Need help with harlan 2 step
  105. Bs3 - No Spark!!!
  106. wideband with lead??
  107. EFI Live Eval file
  108. LS1 Sensor Question
  109. dyno tuned
  110. newbie to tuning
  111. help! my rpm gauge doesnt work!
  112. Where did you run your wideband wire of exhaust
  113. LS2 TB on LS6 engine
  114. truck will not go into PE help
  115. engine dies out after TC install
  116. ls1 tuned; now pinging
  117. New LT1/LS1/LS2 Jet tuning sofware
  118. Throttle-by-wire using F-Body PCM?
  119. Ugh! Need help with MAP PID in EFILive Scan
  120. ls1 edit
  121. best tunning software hp or efi live
  122. Do I need a MAFT?
  123. weird miss after long tube install
  124. Burst KNock??
  125. Spark tuning
  126. You have the .bin?
  127. Can someone please read an HPTuners file for me?
  128. PCM reflash to stock
  129. How do you reset the SES light?
  130. Which PCM for my 2002 4.8?
  131. cheapest efi live
  132. Hooking up ssi-4
  133. Passing emissions
  134. trouble codes at the track
  135. megasquirt and msd ignition box combined work great
  136. Wiring repair
  137. Reflashing with Tech 2
  138. Speed Density tuning?
  139. lean bank
  140. Tach not working!
  141. Blown 6.0 - tuning rules-of-thumb?
  142. ECS Dyno Tune / tuning software
  143. How much is too rich?
  144. New 403
  145. Gauge's going crazy??
  146. 1998 flash file
  147. Am I tuned enough for the dyno?
  148. switching tuning software, will I have any problems?
  149. Code P0171 Bank 1 Trim Lean
  150. Engine Sensor fuse
  151. Can I run a 2003 5.3 with a 2002 pcm?
  152. 01 f-body cam driveable on a 01 tahoe cam tune in a 5.3L?
  153. What can cause a flashing SES light?
  154. Car won't start. HELP!!!
  155. Coil pack
  156. Code P0171 Bank 1 Trim Lean
  157. car cuts off after 6000 rpms (??~!)
  158. ls1 crank trigger
  159. GLM is now proud to carry FJO Racing Products!!
  160. help my car is reading -39 degrees
  161. get in tuned or buy tuner
  162. Surges & Misses After Tune
  163. Fuel pump & tach issues- 1998 PCM
  164. Why is the factory PE table set up so RICH?
  165. How do you get rid of knock when converter locks up?
  166. 1,4,6,7
  167. IAC Steps
  168. Some quick diablosport questions
  169. why does timing retard
  170. TPS voltage
  171. Autometer Cobalt wideband
  172. Quick tuning question
  173. Need Service Bulletin for Cat Warranty
  174. ABS and TCS tuning
  175. stock lt1 with pcmforless tune
  176. Wideband question
  177. 93 Computer Tuning ( Turbo )
  178. LTFT Maxxed ?
  179. Part throttle efficency question.
  180. Some of my guages went out.. help...
  181. Thrown Codes on header install P0155!
  182. Clynlinder air mass WOT
  183. PLX>>>EFIlive problem
  184. VATS problems??
  185. P0300 and P1133 - PCM dependant
  186. BS3 tune help (car runs)
  187. Question.
  188. Powertrain code
  189. 02 sim or turner
  190. Whats a safe PE (no WB)
  191. SES light
  192. Mac ?
  193. Factory idle speed
  194. Shift point problems
  195. Efi Live Guys In Here
  196. Can I splice a new connector onto an O2 sensor?
  197. Cam Tuning Questions
  198. HPT-Lean B1S1 but B2S1 is fine?
  199. PCM forless
  200. Will I need to get another tune?
  201. 2nd to 3rd shifting > radical rpm jump
  202. idle hunt on decel and reverse...
  203. Got a weird problem.
  204. RTACS Pre-release v7.3.4 version available
  205. HELP: Anyone know if...
  206. PO343 Cam Position Sensor Voltage High.
  207. P0343 frustrated
  208. p1640
  209. no idea
  210. 2 questions regarding LS2 Edit
  211. VSS Question
  212. BS3 won't start looking for help.
  213. bogging out
  214. emission controls
  215. Header install, now I've got a miss bad!
  216. O2 Sensor Voltage
  217. air fuel gauge
  218. cynlinder air mass
  219. Spark
  220. Thottle Follower and Cracker
  221. Iac ??
  222. proportional fueling
  223. Taking car to dyno
  224. Simple LS1 Edit quetion
  225. Installed AEM wideband, have some ?'s
  226. code 42:ESC grounded problem
  227. Launch Control Questions?
  228. Removing Gorilla Chipz
  229. Spark Control
  230. wideband sensor placement?
  231. Anybody know where to find good write ups on LS1-Edit?
  232. Rick from Synergy is the MAN
  233. Anyone had this issue?
  234. lm-1 compared to autometer
  235. Car Died
  236. Hanging Idle
  237. P-0410 Code
  238. Stock or Modified VE table
  239. Mail order pcm question.
  240. KR on Stock Car
  241. No Start!!!
  242. where do i start?
  243. Whos your tuner???
  244. vortech ls1 tune help!!!!!!!!
  245. will it work
  246. Please help
  247. Why do we need DFCO?
  248. Throttle cracker table zeroed - I like it!
  249. Advantages of EGR removing?
  250. pulsewidths are bad and 1 not reading
