PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 [187] 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. MAF sensor - ported or not
  2. need original files to set up my ls1edit
  3. LS1 Edit can elim rear O2's and EGR?
  4. Guage help please !!
  5. Emissions checked on the computer?
  6. How can you tell if the PCM is running the low octane program?
  7. need ls1 edid program files for 2000 camaro
  8. Anyone ever had an ASP Underdrive Pulley go bad??
  9. How to contact ls1edit crew?
  10. What does disabling AIR actually do?
  11. Help... Idle in "R" surges
  12. What can cure the shifting lag in an A4?
  13. Question about Injector Offset Table in LS1-Edit
  14. A/F gauge install
  15. Idle Help with 112 LSA Cam in A4
  16. Secondary AIR injection malfuction
  17. Knock sensor
  18. shift points with 28" tire/4.30 gear
  19. Can someone link me to LS1 edit instructions?
  20. Question about uploading a tune..
  21. Question about uploading a tune..
  22. Tuning a stock LS1 a waste of time???
  23. Adjusting LTERM's w/LS1-Edit
  24. Possible tranny/tuning problems?
  25. Bank 1 O2 readings way off, & LTRIMS won't move from 0
  26. Will I need to re program after installing an LS6 intake?
  27. Computer Reprograming in Michigan???
  28. What LT's require the least tuning
  29. PCM Reset and learn time.......?
  30. MAFT gains
  31. Will atap show bent pushrod or floated valve?
  32. Changed heads and cam, now have detonation .... lean condition?
  33. need a formula
  34. Good Tuner in Chicagoland
  35. Stock fans on an LS1 F-body...what temp do they come on?
  36. Great AFM Tuning Summary
  37. scan tools
  38. shifting probs in A4
  39. Need Custom Tunning in Indiana
  40. paging NoGo timing help?
  41. 85mm MAF's. Gains on cars with tuning?
  42. EFILive not connecting to PCM
  43. LS1 MAF removal, utilizing stock MAP
  44. Predator PE vs Spark Advance?
  45. Installed O2 Simms and SES light came back on after reseting the ECM!
  46. Timing tricker
  47. installing files
  48. tuning after header install
  49. tuning after header install
  50. when you guys tune via LS1 edit what do you change?
  51. Computer wiring question
  52. lterms?
  53. Cylinder #8 misfire after B1 cam install, please help
  54. Need some help -- car problem
  55. Cylinder #8 misfire after B1 cam install, please help!
  56. PCM forgetting LS1edit and Tech II programming?
  57. My Car is nuts.....help.
  58. Predator - MAF Ends
  59. Help programming for Siemens Deka 30# injectors
  60. LS1 ECM/BCM help needed
  61. Wiring Harness
  62. Dynabatt or Hawker/etc battery users...
  63. File for supercharged Z06
  64. Flow rate for 48lb. injectors?
  65. cruise control nt working
  66. Stock Rev Limiter?
  67. Amateur needs help
  68. WOT AFR after cam swap?
  69. Need Help!!!!
  70. MAF AT 140%,RUNS GREAT
  71. MAF AT 140%,RUNS GREAT
  72. where is the speed sensor?
  73. Knock sensors setting SES
  74. Looking for LS1 Edit in TN
  75. scanmaster
  76. reseting my PCM?
  77. Any updates on Tuner Cat availability?
  78. pcm tuning
  79. LS1Edit vs. HyperTech PPIII (and MAFs)
  80. Knock Retard Problem? Need some expert advice.
  81. PCM codes without scanner tool
  82. Does the corvette have a IAC?
  83. Auto Tap experts please help!!!
  84. 255mph shift points in Performance shift mode?? and other concerns
  85. Paging Matt H.
  86. does having a non VIN# matching PCM affect anything?
  87. HELP! all bolt ons no tuning.
  88. o2 sensor question
  89. o2 sensor question
  90. Stock shift points on a4, is it worth raising them?
  91. 01 M6 2 step wiring ?
  92. Can't get efi-live to connect.
  93. Maybe a dumb question, but where is the PCM?
  94. !ABS INOP Light...How?
  95. Any LS1Edit/Dyno Tuning advice or tips?
  96. HELP w/ LS1 Tuning Analysis 2[1].1
  97. negative LTFT-set MAFT to 5% lean?
  98. need to find shop to tune car!!!!!!!!!
  99. Need help choosing 2-3 shift extensionA4
  100. LS1 Edit Experts Please ,,, Tune for Cam in a A4
  101. Swapping trans to an A4 how do you program the computer?
  102. Trany swap
  103. What to scan with Autotap???
  104. Hooking up AF gauge... How do I read PCM PIN assignments?
  105. Can ls1Edit help this out??
  106. Ls1 edit and A4
  107. TB Bump-Stop Mod
  108. Timing Table setup for 150 shot
  109. what tunning is needed for a cam??
  110. where to download atap?
  111. small problems...
  112. small problems...
  113. Puting In 02 Ls6
  114. 3-4 aided shift with 6-speed
  115. Creating on an EFI Live V5 info site **Online**
  116. All Instrument lights coming on and off setting codes
  117. what sensor is this?
  118. 99 ss with ses light
  119. At whats gms/cyl flow rate do you make timing changes?
  120. How does the PCM just forget LS1edit?
  121. LS6 Manifold Question.....
  122. LS1 Edit- removing EGR AIR
  123. rotating the mass air meter change the A/F?
  124. IAC issue and surging
  125. Tuning with nitrous
  126. Tuning Question
  127. Speed Demon rocks..autotap software is a POS.......
  128. service engine soon light on
  129. LS1 Edit, Easy to use?
  130. LS1 edit question
  131. What do you log when you drag race?
  132. SES code solutions
  133. Experts needed for tuning questions.
  134. Unplugging IAT?
  135. "Service Engine Soon"
  136. converter problem
  137. LS1 TunerCat ........
  138. Wanted... AutoTap info
  139. Question about maf target number
  140. Consant 4 degrees of K/R
  141. How to read knock retard
  142. Early shifting problem, possibly cam related? Please Help.
  143. TCS, NO ABS, BRAKE lights came on after fill up?
  144. What type of replacement O2 sensors?
  145. Using edit w/Pace MAF
  146. MAFT causing car to throw codes!!!
  147. Who Makes High Output Alternators For LS1's?
  148. Timing?
  149. LS1 M6 into my 68 Camaro
  150. What kind of HP seen with Predator on 02 M6?
  151. Predator Tuning Question??
  152. Using edit after changing fuel injectors
  153. Compression ratio and optimum ignition timing
  154. LS1 Edit info needed....
  155. PE vs. everything!
  156. Cooling Fans Come On During Cold Start
  157. Guages Keep Pegging Out Why?
  158. please help mutiple misfire codes
  159. Tuning in Chicago?
  160. SES Light on... someone have advice?
  161. Jayson and MTI, Thumbs up on dyno-tuning!
  162. HPPT3 or Predator ????
  163. emissions equipment removed, how does the PCM act?
  164. speedo program
  165. speedo program
  166. The low coolant light
  167. Injector tuning
  168. Question for tuning experts out there
  169. how do you plumb in egr system onto ls6 intake
  170. if u do ls6 intake swap,what about egr?
  171. Hanging idle at stops
  172. Please help find a place nearby to get tuned !!!
  173. How helpful is autotap at...
  174. atap file
  175. Does the HPP3 work on other cars
  176. SES light
  177. P0171 P0174 Help!!!!!!!!!
  178. copying files
  179. 98-99 and up injectors=Can I swap to 98s ?
  180. Valet Mode???
  181. tuning for high stall convertor help
  182. 7.0 liter tuners inside please..
  183. could my SLP mass air be be my cause of running so rich?
  184. Would torque management be less of an issue for gear change vs. TC?
  185. What exactly does detonation feel like?
  186. What exactly is TM?
  187. Anyone running FAST or DFI 7.0?
  188. what would cause my car to throw this code?
  189. ses light
  190. How can i
  191. ses light
  192. Predator programmer special!
  193. O2's .850 and .860 too lean?
  194. Anyone had to re-tune A/F ratio after cutout install?
  195. Only % Readout from AutoTap ??
  196. Predator and a Granatellie Maf
  197. Bidirectional contols on EFILive?
  198. Tuning
  199. Turning off AIR
  200. Got some specific questions about the Predator...
  201. Can you use larger injectors than what you need?
  202. Running really rich.. Please help!
  203. p0154 code cause flashing SES?
  204. Can I buy?
  205. Autotap and checking OBD readiness monitors / tests.
  206. Help!! My timing is terrible..
  207. Autotap v LS1edit
  208. pcm removal
  209. HPPIII and stall converter?
  210. neat atap trick
  211. help plz in the a-tap .....
  212. Hole in T/B what size?
  213. I need information!!!
  214. battery removal, loose tuning?
  215. fuel economy???
  216. Octane rating and timing questions...
  217. Question about KR, AFR and Spark
  218. Header install and tuning...
  219. Which programmer?
  220. Which programmer?
  221. How do Fuel Cells corespond to the Injector Flow Table
  222. Air/Fuel gauge Vs. Autotap ?
  223. Anyone here use Thunder Racing "Mail Order" tuning?
  224. Best way to solve misfire detection problem after cam Install?
  225. Fastchips Tuning? asap!!
  226. Predetor LS-1 Edit questions
  227. needhelp with 98 firbird 6 spd. computer...
  228. Timing.......
  229. Anyone ever use Auto X-Ray?
  230. What are S-trims
  231. Question about LS1Edit
  232. EGR Block-Off
  233. USP problem
  234. flashing SES light
  235. any use in me getting the predator?
  236. Lower cooling fan T-stats
  237. Do LTRIMS really mean you are rich/lean??
  238. Lterms @ -13.3 to -14.8 while cruising??
  239. Are edit updates worth the cost?
  240. Need to find a tach
  241. Different versions of MAFTs effect what?
  242. Will somebody please help me diagnose a problem with my car?
  243. thoughts on A/F/R tuning
  244. Whats the leanest a/f ratio for tuning
  245. Tuning for Race Gas
  246. Varying o2 voltage at wot???
  247. Varying o2 voltage at wot???
  248. sanity check. ltrims AGAIN
  249. Buy 85mm MAF or edit out +20 trims
  250. predator
