PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. OLFA table adj. in PE area
  2. an SD tuning using WB, is correct or not?
  3. LTFT RPM Boundaries
  4. BS3 Help
  5. sts trubo tune advice
  6. efi live
  7. bouncing idle
  8. Locked PCM?
  9. 97 PCM w/427 swap
  10. Vengeance is coming to STL to tune who is in, need 5 guys
  11. Vengence is coming to STL to tune who is in, need 5 guys
  12. High IAC Counts
  13. Any reason to buy the HSW Nitrous controller if i already have EFI Live COS5?
  14. PLX Wideband install
  15. A few codes that i need to know what they mean!!!
  16. Smog today in the hoe
  17. Got a question for you LC-1 users
  18. o2 bung lc1
  19. VERY broad tuning question.
  20. Question about wiring and Pcm
  21. any tuners in upstate new york?
  22. Have LC-1 Experience? IN HERE!!!!
  23. NEWB!!!!! :read:
  24. Need Help...
  25. Anyone know where G114 and S108 are at?
  26. Car Stalls Out
  27. is this the ls1 or lt1 3-5pin maf
  28. rpm indicator wire?
  29. How do I tell which Pin is which?
  30. Datamaster Log
  31. ls1 edit question non technicial
  32. ******Gettysburg Tuning and Porting Oct 15-20******
  33. 85mm MAF Frequency Tables
  34. -LS1 Edit- Is it worth it? What can it do?
  35. Friends Procharged '91 454ss truck
  36. a4 tuning with efilive
  37. Tune needed with LS1 Edit please help
  38. handheld tuner effect dyno tune?
  39. Computer issues, at the end of my rope. No Comm error...
  40. 0342 Code Help
  41. Yo wtf what happened to my ltft's GRRRRRRR here we go again
  42. Car Bogs after the TUNE LS1 gto
  43. Flashing PCM/ECM and warranties
  44. different LS1 computers
  45. Timing Adjustments for H/C
  46. 2 Bar map question
  47. 2000 Engine Harness to 2001 car?
  48. Which wire is for the O2 Sensors?
  49. Tune shops in KC
  50. Long time to warm up and stay running?
  51. 2002 A4 upshift issues/Want feedback on tune.
  52. Efi Live Beginer
  53. Where To Buy Tech 2 Gm Flash Card?
  54. Anyone have HPTuner contact number? Have an urgent issue
  55. can sumone tell me what the connectors are?
  56. P0102 is kicking my ass...suggestions?
  57. 2bar not working
  58. Auto Meter Wide Band???
  59. Just curious because I had a crazy idea. Is this possible?
  60. Used HP Tuners today
  61. MAP @ idle Diablo Sport
  62. Can I turn off p0133 and p0153
  63. OLSD idling help
  64. Can abs codes be deleted?
  65. Adding Fan control 411 PCM
  66. Installing an LM-2 Wideband, have question????
  67. wideband or EIO latency in logging
  68. question about boost/MAP/aeroforce
  69. IAC counts too low?
  70. Not doing a relearn, will is cause crank sensor to go bad?
  71. PCM tach output
  72. IAC steps Vs. effective area table in HP tuners pro.
  73. computer question?
  74. Losing the whole passenger side bank
  75. Which pin on the computer?
  76. Secuirity
  77. engine code p1637
  78. KR help
  79. bucking, stalling and rich when cold???
  80. 06' Pontiac G6
  81. ported maf issue
  82. Pro's running MAP system only?
  83. 2 bar map problem
  84. Small HP Tuner issue
  85. What the best shift timing on a Diablosport?
  86. 2006 dodge ram hemi
  87. Bucking issue still exists, need advice
  88. HELP AFR Issue!!!
  89. IAP table in HP tuners?
  90. sorry for the redundancy
  91. Where to buy?? PCM bracket
  92. Idle and surge issue
  93. New motor. Car cranks, but wont fire. What could it be?
  94. texas speed mail order tune
  95. Looking for a tuner in Oklahoma
  96. Simple HP tuners question...
  97. LTFTs Unchanged After Heads/ ARHs
  98. what should my AFR be at full throttle?
  99. Fuse Block Wiring
  100. will a broken brake fluid level sensor trip SES?
  101. Idle AFR ok > 1000 12.0
  102. Gm Tps
  103. HP tuners pro, where to find IAC steps reading in the scanner?
  104. knock sensor help
  105. do i have ETC in my car?
  106. Idle high while moving - m6
  107. I got troubles
  108. dynojet wide band commander kit
  109. Misfire question for the tech-savvy guys
  110. what are the advantages to speed density tuning over regular tuning?
  111. bucking fix (richen)
  112. Need 2002 PCM Pinout for Silverado 6.0l LQ4
  113. what tuner do i get
  114. adding more fuel on HP Tuners
  115. o2 sensor question
  116. hp tune rev limiter not consistant
  117. Need your help on problem.
  118. i need feedback on hp tuners?
  119. efi live tuing questions
  120. None LS1 Question About Water making 1996 Ford Contour Die
  121. Why is my idle spark so drastic???
  122. ecm
  123. Cars StartUp is Different every day
  124. cam / crank sensor pinouts
  125. Engine running Super Hot!!!!
  126. Reflash Pcm After P601 Code??
  127. PCM Controlled Shift Light
  128. Quick question about a wideband tune
  129. Wont let me license a file?
  130. Timing question
  131. Advice: OLSD or OLMAF
  132. "VCM Hardware does not match"
  133. Car popping
  134. How do you tune the 6L80E TCM which islocated inside the transmission?
  135. Lost A/C and coolant temperature at the same time.
  136. 5.3l LM7 to 5.7l what control system?
  137. Advice please explain to me the differance between a tune on a dyno to a loaded dyno
  138. Need Help With Rplcmt Vcm!!
  139. noob warm up O2 question
  140. need help. computer has no power???
  141. Misfire Cylinder #4 New PCM
  142. Looking to turn my laptop into a tech 2
  143. HP tuners and scaning non LS1 engines
  144. delete ALL air/egr codes?
  145. TunerCat file for turbo application
  146. Off topic help needed...
  147. A few tuning questions
  148. OK guys, how to transfer MAF frequency from a later operationg system?
  149. Tune my car to pass emissions?
  150. Anyone in West Michigan?
  151. HPTuner file for a cammed car?
  152. megasquirt
  153. please help with rev limiter or shift points
  154. Tune File??????
  155. PO327 & PO332, tuning problem?
  156. LC1 wide band question
  157. Map for FAST ECU LT1
  158. B1S1 02 reading odd..car bucking, surging, popping exhaust look at this scan HPTuners
  159. 04 CTSV "reduced engine power" ? HP tuners
  160. Running TSP 224R cam? I need your help...
  161. Ported Stock MAF Ends and Tuning
  162. New tuner says that I can use a 1 bar SD to tune real time.
  163. Need Help Repinning Harness on V6 --> LS1
  164. speed density questions
  165. Dyno Tune?
  166. Stock O2s trimming lean in closed loop
  167. throttle position controller 04 gto??
  168. Starter tune for mid 230's cammed TA
  169. HP Tuners 3 Bar Speed Density and EFI Live/Roadrunner generated file conflict!
  170. All Motor Cars at WOT - What Timing and How to Smooth?
  171. Car idle jumps to 3k when A/C is on
  172. High intake temperatures - ideas.
  173. Idle - Dies at stop, ok when rolling.
  174. Drive by wire to cable throttle
  175. need help finding nearby tuner!
  176. Fast Chips... can anybody explain this to me
  177. check engine light comes on and flashes
  178. "hunting" idle got worse with PCV valve
  179. Got a question for you tuners.
  180. Deleting codes
  181. Anyone using Edit with Vista
  182. SD tunning? how to do it?
  183. misfires
  184. Welcome new Moderator, TAQuickness
  185. 99 ls1 fbod - front & rear o2 the same?
  186. HP Tuners: Already have a license and asked to get another!
  187. HPT Standard vs Pro
  188. Deviation in logs for LTFT's
  189. Inconsistent shifting HP Tuners help
  190. no connection to PCM
  191. High Idle, HELP!
  192. Efi Live
  193. check engine light on code p1416
  194. Do I have a Tuning issue or a bad injector or 2?
  195. Need Help Asap!!!
  196. AEM Wideband display
  197. 98 z28 HP Tuned???
  198. LT1 MAP and MAF values?
  199. Help!! Car Wont Start. VATS?
  200. Flash PCM with DTC's set ?
  201. havent tuned in awhile some help please
  202. Question about shifting rpm vs mph
  203. 85mm MAF pin outs needed, please help
  204. Car broke down .. help with codes
  205. Which wideband for me?
  206. Does HP have demo software
  207. Help, somthing must be wrong.
  208. Knocksense KnocksenseMS for LS1 and Gen 3 Engines. w/ Megasquirt
  209. Gen7 or generic-EFI Idle tuning question.
  210. tune question
  211. Please check my calculations for injector tuning
  212. Show me the FTC's in the VE table
  213. What the hell happen
  214. Car knocks with Sensor unplugged
  215. Mail order tune - Should i tune for N2O?
  216. Need help with EFI live V2- AD input voltage
  217. Surge/Sticky Idle~Better to just start over???
  218. Heads/Cam/Intake chugging issues after tune!
  219. GM Mode22 PIDs
  220. Big Stuff 3: 2/3 step wires
  221. bad check valve throwing code?
  222. EFI Live Speed Density on 98 PCM
  223. bigstuff 3 problems
  224. Help ! no start on basic tune?
  225. fans
  226. I actually kinda regret getting a diablosport shoulda saved money and bought at hpt
  227. Tach setup
  228. what do you think hp and hypertech
  229. HPTuners: Decceleration is RICH, how to adjust?
  230. HP Tuners forum LAUGHS at EFI Live guys..
  231. HELP! trans acting up after cam install
  232. Tuning software question
  233. Help Efilive Wb ?
  234. Do you need a complete new dyno tune just to make it leaner.......
  235. Any good tune shops in Northern New Jersey?
  236. Tuners in Los Angeles, CA
  237. Bad PCM?? Still Misfiring!!
  238. Doug Rippie Motorsports = great people
  239. Houston Tuners??
  240. eldrabrock carb kit.. 4l80e wiring.
  241. problem with efi live
  242. Can this be programmed?
  243. EFI table #'s
  244. Motor will turn over but not fire
  245. 5 pin maf extension harness?
  246. TSP Torquer V2 Tuning Help. Need a BIN.
  247. transfer of credit on HP tuners
  248. Installed FAST intake/TB/injectors......won't idle
  249. I need a TUNER close to Arkansas
  250. code p1416 came up today
