PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 [174] 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Hpp 3 reset?
  2. Does the PCM know what gear you're in? (6-speed)
  3. MAFless/speed density tune
  4. while cruising, converter comes unlocked?????
  5. Radom misfire in #5
  6. Lets Start a Sticky Thread on Emissions
  7. DAMN SES Light
  8. Easy way to get out of low octane fuel table?
  9. AutoTap USB with EFL Live 5 Pro
  10. MTI tune
  11. O2 Simm question.
  12. Adjusting ifr for new svo 30#er's
  13. Sparkplugs are red?!
  14. Jet Chip
  15. Jet Chip
  16. random missfire codes
  17. So, if you've got an intake leak that you don't know about, or a misfire....
  18. (98 LS1) Removed EGR with header install, A/F went crazy...
  19. open loop when?
  20. keep gettin o2 heater code?
  21. 02 Sensor appearance
  22. When I disconnect my battery car does not like to start?
  23. Complete/Incomplete OBD dianostic test issues....
  24. P0 135,152,302 Help
  25. O2 Sensor Voltages
  26. how do yall get inspection stickers.
  27. People who have cold start issues (FIX INSIDE)
  28. Dallas Texas Tuning?
  29. HELP! i cant get efilive to work...
  30. Fighting excess hydrocarbons
  31. EGT gauge?
  32. Rail vs non rail mounted regulator tuning
  33. help
  34. Reading a PCM with Edit
  35. A/F Ratio - ATap vs Wideband
  36. Another Predator Question
  37. Tuning Ltrims
  38. Can someone shed some light on MAFT please.
  39. How to lower IAC counts with EDIT, no holes...
  40. Random Misfire After Mac Header Install
  41. Anyone one put a Z06 MAF on a LT1?
  42. HELP with Air/Fuel Ratio Gauge !!!!!!!!!!!!
  43. 98 Trans Am, Predator
  44. Can EFILive and LM-1 work together yet?
  45. IFR scaling alone yields uneven LTFT's
  46. Two codes after cam/header install
  47. Is a LS1Edit tune worth it for my mods and 90K miles?
  48. Getting knock
  49. Maft tunning with a mac scanner?
  50. Running lower timing then tables show???
  51. Ltft's ??'s
  52. best tune in pa nj area?
  53. How did i fail PA inspection
  54. Interesting DIY Wideband
  55. O2s lower on one side @ WOT???
  56. What to look for?
  57. Turbo Timing
  58. diablosport or something else like it
  59. predator diagnostic question
  60. AutoTap problems w/ playback of log pass
  61. scan tool input.
  62. to tune or not to tune?
  63. DTC P0430 Catalyst low efficiency bank 2
  64. What is trouble code PO154?
  65. Insight to code
  66. dtc 0131 & 0151 fix ?
  67. MTI PCM tune?
  68. Accel Gen 7
  69. Palm Pilot Diognostics???
  70. why dont they make predator for 98's
  71. Flaky LS1 computers or somthing else?
  72. Will a Predator Work For Me?
  73. Tough LS1 PCM question, let's see who can get it?
  74. 2002 harness w/ 1998 computer
  75. Raising the rev limiter with edit?
  76. Cold start surging?
  77. High altitude tuning, any tips?
  78. new tranny and a P0121?
  79. Removing 02 sensors in LS1 Edit
  80. Low Input on MAF...What's it mean?
  81. Help having problem with Edit on my home pc.
  82. how to check codes???
  83. Cannot get EFILive to connect
  84. EFILiveV6
  85. Fuel Trim Learn
  86. Predator Vendor
  87. Reading Ability:Octane
  88. Is there a relatively inexpensive stand-alone tool for scanning OBD II trouble codes?
  89. Changed Rev Limit In Edit (But doesn't change)
  90. I've got this posted in Internal eng also, the link will take you there
  91. Custom EFI Live PID's
  92. does the ecm store odometer readings
  93. Edit forum
  94. EFILiveV6 and External wide band data ?
  95. Stock Program and 231/237 Cam??
  96. Looking to get a Predator
  97. Learning to use EFILive
  98. Harlan Shift Light Install! :)
  99. reduced power mode
  100. will EGR?TCS?cruise?=poor performance
  101. Need Help!! Car stumbling bad and setting these codes!
  102. LS1-Edit copy?
  103. dyno tune
  104. LS1 edit?
  105. What table is the best for riching or leaning out a car!
  106. so am I buying a cable, or software?
  107. Efi Live
  108. Need to buy new factory pcm or used one...where???
  109. Programming Question
  110. VE and AFR question
  111. LTRMs at idle
  112. LS1 Edit questions...
  113. atap & Edit questions
  114. My Ses Is Off
  115. Does Anyone know how to calculate injector duity cycle???
  116. Is there any way to get ATAP to take more data Points.???
  117. Auterra OBDII scanner
  118. Hyper Tech power programmer, worth the money?
  119. PC tune for tranny swap ?
  120. TunerCat Yet?
  121. Painting PCM?
  122. Bosch LSU4 and leaded fuel.
  123. Not sure what to think about this!!!!
  124. Any good LS1 edit/wideband 02 dyno tuning in midwest area??
  125. I ready to throw this damn predator in the garbage !
  126. I need Hypertech help asap please
  127. Tuning question
  128. P102 and 02 sensor Codes
  129. Dyno graph?
  130. Engine Reduction
  131. tuning for t-76 turbo
  132. Can diablo predator be reflashed once it has married a vin?
  133. Please explain...
  134. IFR and PE vs RPM
  135. Using VSS or PCM Signal to make simple digital speedo???
  136. how to make tcc release?
  137. I need a file for a TSP 231 237 cam in a Automatic.
  138. Intermittent PO327 - Knock Sensor, or could it be the O2's causing the problem?
  139. Would a mail-order tune be enough with this setup?
  140. programmer problems
  141. I keep setting a P0153!
  142. EFILive Bi-Directional Controls Question
  143. autotap ? cable dead. Any repairs/upgrade options
  144. what loging software should i get????
  145. Temp. Sensor voltages
  146. any use PCM For Less tuning
  147. L trims question.
  148. Need Help Fast Please with New Torque Converter
  149. Anyone have a predator for sale pm me.
  150. What serial port adapter?
  151. Can't get EFI Live V6 to work
  152. Misfire Diagnostics for Big Cam Cars.....????
  153. What does your big cam car (230+) read on the wideband at part throttle?
  154. just got autotap and a palm pilot
  155. Does anyone know the break down on Fuel Trim Cells?
  156. Installing new pcm..
  157. line pressure
  158. Please Help SES Light after header install
  159. Need Pillar gauge connection help!!!
  160. New board member--need help ASAP
  161. Tuning for short vs. long tube headers
  162. Happy New Year !!!
  163. Is Autotap Locked to a VIN?
  164. ACCEL Gen 7 DFI users how is it going?
  165. Troubleshooting OBDII
  166. Edit and EGR Question.
  167. ECU Programming Question
  168. Dash resets (odometer) on cold start
  169. Cant get Autotap to work
  170. Autotap results what do ya'll think?
  171. Why would an 01 Z06 be running in cell 22 all the time except on decel?
  172. What Predator Tune Does
  173. Tuning Question For The Experts (A/F Problem)
  174. Best place to lean out part throtle?
  175. Autotap HELP!!
  176. Atap to EFILIVE UPGRADE?
  177. lap top im my car??
  178. efilive cables and edit cables?
  179. TCS Comes on During Revving?
  180. Big thanks to FAST, Cartek, Speed Inc. and SS Racing
  181. GMAF puzzled
  182. Autotap
  183. Abs Inop/asr Lights Came On?
  184. car running really really bad! I NEED HELP!!
  185. studying up before I get edit is this info correct?
  186. How important is it to fix my BCM?
  187. Nitro Daves:January Install Specials
  188. P0654, P0748 and P1644 codes
  189. Any clue as to why a Z06 would only read 80% TPS at WOT?
  190. MAP reads 3.0V at idle and 70kpa what's wrong?
  191. Where is crank-trigger wiring at? Trying to install Timing Tuner!
  192. What does the fuel pressure vs. voltage table do?
  193. new ls1 edit version update?
  194. Air Bag Sensors
  195. can someone clear up these tuning issues...?
  196. Easy formula for dialing in WOT AFR by PE? Like it's at 11.8, need 12.5
  197. Santa brought me a predator for christmas
  198. Wideband O2 Setup
  199. knock/air fuel question....im stumped...
  200. Need to tune if heads are added later to cam only car?
  201. How accurate are the factory O2's? Do I need a wideband?
  202. Knock Problem
  203. Whats the proper way to adjust shift points?
  204. VE Edit Table and ChrisB's Log Analyzer (long)
  205. MAF vs Freq Table for 2000 Vette
  206. Opinions on Low octane gas
  207. MAF Readings vs. Horsepower, any rule of thumb?
  208. EFI Live Question please help
  209. $50 wideband?
  210. Want to learn more on LS1 Edit
  211. Can the Bosch WB O2 sensors
  212. Duplicate PCM Program
  213. 2003 C5 w/Traction Control issues at WOT
  214. dyno/ls1 edit in houston
  215. TPS compatability?
  216. My lights stopped comming on when the ebrake goes down at night?
  217. Cam Surging... please H E L P
  218. LTFT Tuning by mapping MAF hz vs. gms/sec vs. LTFT %
  219. Local tuners in bay area Cali??
  220. Should I upgrade to EFI Live V6? Stick with V5?
  221. HELP! Predator problems, car won't start.
  222. Got a question for EFI Live guys...
  223. I am not impressed with my Predator
  224. Help with Z06 Cam only tune
  225. Tuning with Cats
  226. ls1 headlights
  227. Tuning out the oxygen sensors completely...please help Pro's
  228. lowered PE and nothing happened?!
  229. Any one using E Dist Electronic Distributor
  230. New SES Code, P1336, Predator won't clear???
  231. G-Tech Pro
  232. EFILive question...
  233. M6 PCM in an A4?
  234. edit diagnostic file help
  235. Rapid Tuned Corvette takes SCCA T1!
  236. Other GM cars w/EFI Live?
  237. Edit v1.3 users, or those in the know???
  238. WOT timing at 19, what to look for
  239. Maxed out LTFT's at WOT?
  240. PO327 Knock Sensor Bank 1 - Which one is bank 1?
  241. Selling EFILive Question
  242. ECM Tuning in Florida
  243. texas tuning???
  244. can u
  245. Having problems connecting with EDIT
  246. Please help...ses codes
  247. Help with Predator
  248. Boosted settings with LS1 edit?'s
  249. IAC Air Flow with EFILive?
  250. Buying LS1Edit used..
