PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Aftermarket harness pinning...
  2. 98 z28 drivetrain/harness into 00 z28
  3. 2004 harness for tach
  4. Wiring harness
  5. My first LS swap 6.0 4l80
  6. 2009 Pontiac Montana sv6 3.9L BCM problems?
  7. Secondary Air System not ready - ECU reflash fix?
  8. LTFT Maxed At +25 - But No MIL Light. Why Not?
  9. no start timing mess
  10. A/C with Holley Terminator Max?
  11. 2000 Trans am is bogging
  12. 4.8 cam and injectors, idles, dies in gear
  13. 24x torqhead and hptuner questions
  14. 2nd WB on Dominator
  15. Tuning VE - 0411 12202088
  16. EFI Live Could Someone Look at my Log
  17. HP tuners..Controller Unlocker: timed out
  18. 02 ECU & harness and 2006 5.3 engine??
  19. Electric Fan Not Working E67
  20. TunerPro RT Logging Questions
  21. Does anyone have a list of DTCs to turn off....
  22. Convert a camaro tune to a truck tune?
  23. 2005 4.8 W/Turbo - Got it started
  24. best harness?-lq9, t56
  25. Intermitted engine shut down - non GM computer
  26. Pcm and engine issues
  27. Pcm Connectivity issue and fuel relay click
  28. E38 lsx454 cranks no start
  29. 4 degree KR (false) after a nitrous pass
  30. Bye Bye O2
  31. TunerPro .XDF for Throttle Mapping
  32. Stumble at low load
  33. Engine Stall Problem
  34. DIY Timing Pointer to confirm timing for your LS
  35. EFI Live adjustments to VE don't seem to have the expected results
  36. Tech 2 Chinese Clone
  37. Throttle body cleaning and computer
  38. 1998 T/A- no injector pulse after LQ4 swap
  39. Codes after header install
  40. 6L80E T43 TCU 2007-2009 OS Change Successful
  41. Match a PCM to my swap - 16220610
  42. Which value to trust?? HPTuner
  43. Mufflers and tubes.
  44. Getting mass airflow and knock sensor code at same time.
  45. Tech 2 Needed
  46. Help With PMC Codes firebird formula 1995
  47. Whats wrong with my tune?
  48. Injector upgrade??
  49. New engine starts and dies
  50. Smart spark with ls9 cam in 5.3
  51. Deatschwerks Data Actually Good?
  52. Low Impedance Injectors
  53. O2 heater circuit error
  54. What scanner for 1995 firebird lt1
  55. P0200 passenger bank dead. Pulling hair out
  56. MSD 6014 for ignition while keeping 411 PCM for fuelling?
  57. Carbed 5.3 and use 0411 to control 4l60e?
  58. need help with my tune
  59. Gen V L83 P0340 P0341
  60. Erratic Idle and stall
  61. Microsquirt 24x to 58x
  62. Turbo Car Wont Idle on 2nd Start Up of the day
  63. Open/closed loop sensor issues
  64. Reman ECU Strangeness LM7
  65. Lean spike during PE
  66. Fried PCM in 2000 WS6?
  67. 2005 5.3L Lean Codes
  68. **VIDEO INCLUDED**Car won't crank or fire and gauges flicker
  69. e38 pinout diagram
  70. P0325/P0332 diagnosis
  71. Tutorials for Basic and Advanced HPTuners Now Available!!!
  72. e38 or e67 with my 6L80e?
  73. DBW - TAC Module Troubles - LS Swap - NEWB
  74. Gen V E92 ECM Failure?
  75. 96 Lt1 in my IROC with 4L60e, hard start, running rich etc
  76. LS3 controller with LS1 knock sensors
  77. Holley Dominator Software+laptop for a rookie
  78. Cylinder 6 Misfire
  79. 90's LT5 swap using 0411 ECM
  80. HP and torque setting
  81. MAFS with 4150 TB and MPI
  82. 2000 z28 ls1 no injector pulse
  83. Diablo Sprint Issues CEL Clear Command
  84. Cutout tune
  85. injector data #12561462
  86. Standalone datalogging issue, HPTuners
  87. New Harness, New Problems
  88. Lt1 to ls swap
  89. Help with 6k rpm blip - Holley datalog
  90. GM gen 3 auto to manual conversion
  91. Determining an intake restriction on a boosted setup from logs
  92. Tuning VE table below 15KPA
  93. Help with Cold Starts
  94. Tune problem or engine problem?
  95. EFILive vs HPT question...
  96. Tech2 question for the GM gurus
  97. Extrapolated LS6 HP/TQ Curves, with Data
  98. Holley HP EFI 550-603
  99. 2010 Camaro SS SCT email tune
  100. 05 CTS-V AC not coming on after tune.
  101. russ k idle config question
  102. 1996 WS6 T-Top Coupe LT1/T56 ABS light
  103. Holley Rev Limiter in V5 questions
  104. Noob Tuner Needs Help
  105. The Cam Isn't even THAT big
  106. Holley harness ?
  107. Is it in my tune?
  108. 98 trans am need a base map tune.
  109. 5.7 Vortec O2 sensors reporting accurately?
  110. 50% fuel trim..... Please help!
  111. 98 camaroz28
  112. My new tuning laptop
  113. 1998 trans am. tuning help
  114. Getting P0341 and P0342 need some ideas
  115. DBW wiring questions
  116. 2004 ls1 gto 4l65
  117. Ecm fuse blows
  118. Tuning out maf sensor
  119. Odd data logged to/from PCM, Gen iv e38
  120. E38 Safety mode!
  121. New build - mail order tune by Frost for break-in?
  122. MAF Performance Code, 05 Tahoe 5.3 -> 4.8 swap
  123. 2000 Camaro with os 9381344 .ads or .adx file????
  124. PCM will not do the relearn procedure. 1999ls1
  125. Diagnostic HELP PLEASE
  126. Street tuning only, can i improve upon this?
  127. MSD 8913 install in fbody HELP!
  128. 2018 Sierra 6.2 Stock Tune
  129. P0641 Code E38
  130. Tuner studio virtual gauges?
  131. help with 2 bar OS and 2 bar map.
  132. 2018 Camaro, write VIN to New GM Global ECM
  133. Loading injector data?
  134. Hp Tuners; correlation between Inj# & the Physical Cyl # - One bank Dead rich issue
  135. 2002 ls1 lsa supercharger wont idle. Remote tune$$$
  136. 99-02 z28 camaro pcm swap
  137. currently running a msd 6ls box with FI
  138. Car won’t start and idle after fast install
  139. 98 t56 bird speedo reading twice the rpms
  140. New Orleans area tuners
  141. 98 SS Rich at Idle but not with A/C on
  142. PCM problem.
  143. Which side is the pink ignition wire for an MSD dis tach driver?
  144. 4l80 Tune issue
  145. Central Florida who are the best LS3 tuners
  146. C6 Z06 - LSX 454 Big Cam Idle and Cruise Tune Help
  147. Pcm injector 1 pin
  148. Cam sensor and crank sensor voltage less than battery voltage
  149. Timing ?
  150. Crank Sensor voltage drop test help
  151. ‘01 LS1 running rich/misfire only in bank 2
  152. Where did the horse power go?
  153. Crank sensor cutting out intermittently w/random misfire
  154. Ls3 motor Backfiring when you let off the gas
  155. Oxygen sensor monitor not ready on E-Rod ls3
  156. Which wideband for Hp Tuners???
  157. Help with Holley EFI Boost - Log and video
  158. Looking for a tuner to check out my PCM
  159. still getting knock sensor codes after replacement
  160. Car ran then died and melted negative battery post
  161. Fuel pressure reading "stuck" at 57.9psi
  162. HPVI-2 bluertooth hp tuners
  163. 2006 6.0 (LQ4) crank & cam sensor voltage
  164. Mobile Tuners
  165. 4l60e TCC not connected - does work when connected
  166. TCC Questions
  167. 2005 corvette MAF frequency Dropping out on HPTuner Log - car running rough
  168. Performance at night vs during the day
  169. JET DST software exe
  170. 6.0 P0336 error code
  171. Need ProEFI help with LS1 to LS2 knocks sensors.
  172. Random misfire code advice
  173. Down on power with H/C/I
  174. 6.0/80e-Tuning issue Once Re-Started When Hot.
  175. Please help p0171 and p0174 codes
  176. How much is too much timing with boost?
  177. ECT (Spark) ADDER adding timing when zeroed out?
  178. CA SMOG DTCs ...???
  179. tuning for mixed race/pump fuel
  180. 411 swap from 97 black box
  181. Ecm pulls timing in 3rd
  182. 3.Gen Camaro LS1 Swap - runs rich, smells like fuel,
  183. Code U0107 and related issue, maybe?
  184. 2004 P59 Drive by cable cruise control issue
  185. Black box 1997 Z71 to 411 PCM
  186. diablosport i3 platinum HELP
  187. Very rough idle cold starts after sitting
  188. 2000 t/a m6 bin file needed
  189. TPS help needed
  190. Need help diagnosing OBD port comm failure
  191. V6 Computer
  192. Why do I have knock retard?!
  193. Bidirectional Scan Tool
  194. Car went dead
  195. Cranking fuel trims stock LS1
  196. T460e
  197. Help with race car idle
  198. 0411 Swap Throttle Problems
  199. Can AEM 30-0334 be used on a non bus car?
  200. What wideband for MPVI2?
  201. Torque management tables
  202. Dealing with lean condition after cam swap
  203. 2002 5.3 can bus questions
  204. hard misfire, but no codes
  205. Intake restriction 100kpa to 80kpa
  206. Slowly learning - critique my dontbsme tune
  207. Reworking 2010 Express Harness
  208. No Spark on Bank 2 (2,4,6,8) LS1 Swap
  209. HP tuners mpvi pro still sellable?
  210. Torqhead PCM base LT1 tune question
  211. Ls2 btr stage 2 cam, fast 102 baseline ignition map
  212. Ls1 stalling
  213. injector bank 1 not firing
  214. 4.8 to 5.3
  215. Flex Fuel Tuning Guide
  216. 02 z06 max rpm tuning
  217. conversion flash
  218. HPT 4.4 case learn?
  219. Intake Manifold Pressure is Constant
  220. HP Tuner Logs
  221. P59 parasitic draw issue
  222. New, to me, truck with tons of KR no matter what fuel
  223. tuning an L83
  224. P1545 and P1546 after AC compressor swap
  225. Injector duty cycle
  226. Injectors won't pulse
  227. Turbo 400 behind 5.3
  228. Goes lean when warming up.
  229. STFT and wideband in disagreement
  230. Tuning software
  231. Extremely Rich @WOT
  232. Chasing a part throttle knock before boost.
  233. Street tune fueling
  234. Knock sensors
  235. What do you have to do to drop a 2008 gen 4 long block into a gen3 engine bay
  236. AFM/vlom tricking computer?
  237. Hunting idle trying to diagnose
  238. 5.3ls
  239. 411 pcm
  240. Ls1 LOW mph troubleshoot
  241. Exhaust diameter and air fuel question
  242. Heater Circuit Codes on BOTH O2 Banks after Fresh Build
  243. Crank/Distributor Signal-LS1 PCM on Gen 1 SBC
  244. Idle issues
  245. Transmission slams into gear from park to drive. Which tables to adjust?
  246. p59 ecu TAC issues i cant resolve, Please Help!
  247. Stalling with load while engine warms up
  248. Do Tuners Generally Change Torque Converter Settings?
  249. No trouble codes and doesn’t start
  250. GEN IV BCM OS flexibility?
