PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. 160 Thermostat Tune??
  2. Ve... Wot?
  3. Speed Denisty Open lope tuning help
  4. What wires to the PCM tell it what gear it is in?
  5. Does anyone have feedback about PCMperformance?
  6. crank pos. sensor
  7. usb to i/o cable help
  8. Running with/without LTFT enabled....
  9. I am fixing to make some changes and need info on tuning software
  10. Idle issue when the car is hot
  11. LTFT Help
  12. Help..misfire on one cylinder and tried everything
  13. Tune required?
  14. EFI Live v2 98 transam pcm free licensing?
  15. HELP!!!!!PCM/BAT fuse keeps blowing
  16. need fast help, switching back to MAF from speed density??
  17. How do I go by doing this
  18. How can i get a screen shot?
  19. Several codes P0300, P0443, P0101, P1637
  20. 98 Formula - help with tune
  21. Need Location of Ignition Switch
  22. Why does my car surge when coming to a stop?
  23. USB to Serial adapter Vista x64
  24. P-1116 Code
  25. lean condition at shift points?
  26. G5X3 + AFR205 starter file
  27. LS2 conversion,, engine will not start
  28. I have a bad Miss Fire
  29. Trex
  30. is it possible 2 make 1000hp with gen3 comp?
  31. Vista???
  32. AEM wideband placement
  33. Anyone use innovative logworks for VE tuning?
  34. dyno/tune in indiana???
  35. Loose ground strap
  36. Just need ideas kicked around - tuning problem?
  37. Put on a SLP lid and now.................
  38. CL vs. OL questions
  39. 3400 stall how much do i up the shift points
  40. tricking the maf
  41. 85 Maf ?
  42. any LS1 tuners in the west tennessee area?
  43. Need help w/ starting!!
  44. LS1 edit software
  45. Electrical Help Inside
  46. I need a stock 04 zo6 corvette (Auto) file
  47. Misfire only at idle...
  48. 2 bar map and MAF on initial fire up
  49. ls6 efi live tune needed
  50. Any tuners here in Houston?
  51. SES codes help
  52. 98 ls1 auto f13 tune help!!! efi live
  53. Tuners in Arkansas
  54. 2-bar sd question
  55. Handheld or EFIlive for deleting 02 codes
  56. Any tuners in AZ?
  57. Open Loop/Speed Density questions
  58. Please help?
  59. installed slp maf,now running rich
  60. Advancing timing for idle and highway cruise speeds
  61. Keep on burning up dynotune wideband sensor!!!
  62. Can Efilive Delete Code P0332?
  63. Gahh!!! Someone look at my tune, and tell me if my car SHOULD run!!
  64. E85
  65. Chips
  66. .bin Files
  67. MAF tuning question
  68. Ford #30 Red Top??
  69. SES Light Code Help (I have the code)
  70. Wideband Lost its Mind??? HELP!!
  71. Proper seed for 2002 Fbody?
  72. SLP Tuned Predator Programmer Good?
  73. 1985 cj7 carb question
  74. Fuel system failure
  75. problem with reading ses light
  76. MS4 tune with efi live
  77. Tune question IL, Ross O?
  78. 98 PCM, HP Tuners or dyno tune?
  79. Any concerns about moving the MAF into a wheel well?
  80. 2002 6.0 Lq4 PCM fuel Enable pin???
  81. aem wideband
  82. Lm1
  83. VATS questions
  84. Tach problem
  85. Tuning info needed
  86. How long does it take to tune roughly?
  87. Po102 Code Help.
  88. Laptop Stand
  89. PE Tuning
  90. 98 comp question
  91. tuning ve with new hp tuner- issues in sd mode
  92. Would relocating IAT sensor on big cam help or hurt?
  93. Help me solve Kpa issue
  94. FI tuning question
  95. Tuner in SoCal?
  96. removing pcm!
  97. Lm2 Yet?
  98. p1416 help need to pass emmisions
  99. Should I do 2bar or 3bar tuning
  100. Couple questions
  101. Removed Air pump and now idle is weird LOOK INSIDE!!!
  102. Need help getting new 383 LT1 to idle
  103. Help! Car throwing codes
  104. Annoying lean spike help please:
  105. Interesting problem with stock tune
  106. No throttle operation DBW converted LH6 to LS2
  107. anyone got a tune for tr230?
  108. LTFT% B1 Problema'...
  109. Tach gets stuck on long trips. Electical or needle problem?
  110. Could PCM issue cause loss of 3rd and 4th gear?
  111. accel tps wiring to stock wiring
  112. Question about cold startup lean condition.
  113. Want to tell aftermarket fans to turn "OFF" at highway speed with A/C "ON".
  114. is it hard to learn how to tune?
  115. 98 LS1- issues when hitting bumps/ lights come on, car bogs and odo trip resets/hesit
  116. P1133 and p1153 Insuffecient switching on b1s1 and b2s1 oxygen sensors
  117. o2's acting strange
  118. Will the car learn to idle after cam install?
  119. some codes
  120. PCM Location Question
  121. Misfire problem unknown??
  122. Help diagnosing a problem
  123. DiabloSport II or Predator?
  124. Tuning Program Interoperability???
  125. SES light after AFR heads
  126. SES got 2 codes
  127. new tuner
  128. Reverse lockout wire up?
  129. Tach, Fuel, Temperature gauges not working, ABS inop, TCS OFF... HELP! haha
  130. Threw a code.
  131. anyone got a tune for 90/90
  132. anyone got a tune for 90/90
  133. Torco Mach 112 Octane Stoich point?
  134. Requestion HPT Tune for 224/.565 cam, please?
  135. MEFI4 vs stock computer?
  136. 94 lt1 turbo tune tuner cats help
  137. 99 LS1 A4 stock with Diablo Tune My Thoughts
  138. Sd Tuning And 5 Wire Maf Question
  139. Cutting out at track..
  140. Tuners in Houston Tx need some help
  141. Need advice...
  142. 06 e40 tbss vats question
  143. Need tune to drive after cam swap?
  144. BS3 / FAST alternator help ! ! !
  145. Crane/vinci tuner with longtubes and off road y pipe
  146. EFILive vendors, please step inside
  147. Newbie Tuning Questions.. a/f ratio? others..
  148. Anyone want to rent or loan me an LS2 benchtop programming harness?
  149. A4-m6
  150. knock sensor
  151. ls1 to ls2 swap. no tach
  152. any advice on lean codes??
  153. Speed Inc or FLP
  154. can anyone tell me!!!
  155. nitrous tuning
  156. SES Problem
  157. dyno Tune shop?
  158. Missfire - P308 and p300 switching
  159. SES P0410 need solution
  160. LM-1 and the predator....is it enough for a good tune?
  161. I'm getting knock only when I go into PE mode.
  162. Proble with plug under dash!?!
  163. burning up PCM's
  164. Can Cam Surge Be Eliminated With Hp Tuners?
  165. 99PCM w/ custom harness.didnt come with alt. plug/wire & I have 1...where does it go
  166. whats needed to go from maf to map
  167. 98 Tune
  168. Tunning quest
  169. Car starts but dies soon after - DTC P1637
  170. Big Stuff 3 help
  171. new tires = TC problem?
  172. Wiring differences between 98 and 00
  173. 01 ws6 wouldnt start
  174. HPT Ready to tune...???
  175. How far can the stock PCM go?
  176. Tried for first test drive but only runs for a minute at a time??
  177. Major problem....
  178. Ported Delphi MAF, dig it.
  179. E-85 Tuner around N.W. Indiana???
  180. Need some help
  181. LC-1 programming
  182. LT1 Base Tune For Boost
  183. some high octane ???
  184. HELP QUICK p0200 no fire or fuel????
  185. Do I need re-tuning if I change headers?
  186. 98-02 LS1 Granatelli MAF Sensors TUNING Q's
  187. What numbers should i expect??
  188. Any Tips on hooking up Lm 1 with efi live?
  189. At what point should injectors be switched out?
  190. OLSD and Emissions Test/Readiness Tests - can I pass?
  191. wait4me performance
  192. Wiring a LS1 to be a LS2?
  193. 2 Step Launch Control
  194. ls1 dies when load is put on the engine
  195. PO171 help
  196. anyone know about a b0022 airbag code?
  197. LS2 Edit
  198. Code P0443&p0440 Help!
  199. Bad pcm/diagnosis help?
  200. Tuning Question (Shift Kit)
  201. Question: how to increase knock sensor sensitivity
  202. Hp Tuner ???/
  203. tune info?!!!!!!!
  204. H/C tune issues question?
  205. Anyone have a tune HPT tune I can borrow??
  206. What tune for a LS6 swap
  207. Tuneing out SES codes and Aircare
  208. New motor and hptuners
  209. Screwed up MAF table affect WOT performance?
  210. can efilive or hptuners read trouble codes from other types of cars?
  211. Reverse Os Change
  212. Efi Live Vs Hpt
  213. changing tunes "flip chip"
  214. tunes
  215. somebody help me!
  216. C.a.t.s Tuner
  217. sct of predator?
  218. Tuners?
  219. Surging under part throttle...
  220. How much is the license to convert MAF to 2bar
  221. The dreaded evil P1416 code
  222. Why is my A/F reading 16.3?
  223. P0171
  224. Lm-1 - Hp Tuners With Eio Help!
  225. crazy idle cam only Ls1 ( log file )
  226. Is LC1 waterproof?
  227. Help Me trouble shoot my LC-1 Please.
  228. Whats a Good Tuner Program For Laptop?
  229. My car was tuned with EFI Live, if I get HPTuners, will I have to start over??? HELP!
  230. Injectors are not grounding.. where in the pcm do they ground from?
  231. Big Stuff 3 + 4L80e
  232. How to tune using HP Tuners Software...
  233. High RPM Banging
  234. OBDII connector not working?
  235. ls1 cranks, but wont start
  236. Idle problems after A4 to M6 swap.
  237. Idle problems after Converter install.
  238. ls6 hp tuner bin
  239. Gauges Not Working! Someone Help!
  240. custom wiring harness help
  241. P0327 code help
  242. tune/breakin new engine and clutch?
  243. NooB Q... Can a Mail Order Tune be Close??
  244. LS1edit file comparison help....
  245. Never noticed this section of LS1Tech. . .
  246. check this out please
  247. A/F question
  248. Disabling LTFT?
  249. weird idle. IAC? TPS?
  250. hp tuner question
