- Predator on a M6
- PE/RPM table tuning
- flooding?????
- Injector Offset table - experts inside please
- How to dyno a A4???
- Base Timing Park ?'s
- "cruise control" effect?
- What do I need to delet codes??
- Tuning timing, need help/getting some knock
- Predator & deleting Torque Management
- Erratic dyno curves
- New Z06 w/FLP's EFILive log LTFT ?
- Are all four O2 sensors interchangable with wire extentions?
- LS1edit and turbos
- Anyone figured out why total timing is lower on 01 and 02's?
- P0327 how do I fix?
- Questions before purchasing LS1 Edit
- Trim tuning update
- Help with MAFT tunning
- MAFT & dyno time or Predator
- Wide Band O2 Logging
- Bad coolant sensor???
- DTC P0442 EVAP small leak, what exactly is this?
- 99 Z28 CLUTCH PROBLEMS
- Almost lost street race to LS1 with less power.
- Exhaust leaks and their effects on LTFT
- injector tuning question
- Idle
- Idle
- Idle hunt (searched, but found nothing)
- Low oil light won't turn off!
- evap purge/system removal?
- Idle issues solved!!
- Low mileage tuning question
- Hardware MAF Tuning / Calibration
- Ideal A/F is? And how to dyno tune it to perfection?
- Hot Restarts With C1 cam Suck!
- Lazy O2 sensor?
- My car is throwing codes P0174 and P0171, need some help
- Idles fine until i floor it then it idles high
- ls1 edit ?
- DTC P0704....
- Problem with my TCS
- Autotap help needed
- car has gremlins!!
- Idle Issues
- COT???
- A-tap Code P0122 Throttle Position, TP Sensor Low Voltage
- Ideal AFR at WOT?
- Predator....
- LS1-Edit: WOT Power Enrichment ??
- Any updates on Tunercat for the LS1?
- PCM HELP
- 02 WS6 cam car still having idle probs
- hpp3
- Need explanation of code P1133
- PCM serial number change?
- Who can make a file for me ?? need help please
- What timing for a 01-02?
- Predator Newbies
- Mas Air Sensor
- Alabama Area LS1edit Tuners
- Which A-Tap version to buy
- Has anyone thought of...?
- New to Autotap
- LTFT log help
- NoGo- You da man!
- wideband O2 placement. tailpipe vs. header collector
- Computer problems with aftermarket converter?
- PCM "Unlearned"???
- Can you turn ABS off?
- Where to set my rev limiter?
- Can anybody recommend any LT1-Edit Tuners in DFW Area?
- Ok, this one is a doosey...
- P0757, 2-3 Shift solenoid stuck on... What to do?
- Shift points with edit?
- Air/Fuel???
- Where to get LS1 Edit?
- Engine power while in open loop mode
- To edit or not to edit???
- LTFT +5 & +6 bad?
- So how many of you with Diablo predators...
- Is it possible to determine the A/F ratio from Autotap?
- HELP!!
- Please Help!!!!!
- Whats the sensor behind intake? Single wire coming out
- LS1Edit file for 2000 chevy Vortec 5.3
- Tuning pros: why not run the 85MM SLP MAF instead of ported stock ends?
- My diagnostic port and cigartette lighter doesn't work anymore
- air pump question??
- stupid experiment
- Deleting AIR pump without throwing a code by using a simulator?
- Auto Tap Newbie, help needed
- Couple of Diablo Predator ?'s
- Running Pig rich
- Need help with ABS light in the instrament panel.
- Who does LS1 Edit in Kentucky
- Everyone with ported MAF ends
- Can LS1 Edit Help Pass Smog?
- what is Torque management
- I'm stumped: Intermittent Flatlining O2's(over 1000mv!)
- All these idle issues I see on the board... Here's what I've done & tried...
- ls6 maf on a 97 C5
- Taking the car down to Diablo next week for Predator Dyno tune
- Idle hunt: to much timing or what??
- is it better...
- Removing AIR with no codes?
- Gutted the cats, what codes do i turn off for the 02's
- Cat Over-temp Question
- Idle Problems after 110lsa cam, make suggestions please!
- P0101? What do I do? ***UPDATE : PROBLEM SOLVED***
- Cam guys: whats the most timing you have added at idle?
- Can LS1edit help get my tranny line pressure steady?
- Did I get a bad Predator, or am I just retarded?
- HPP3 settings
- computer tuning
- Help!!!!
- How to reset the PCM?
- Quick Question: A/F Ratio
- Need a little help guys: Idle Air Control Motor Position in ATAP?
- #6 Cylinder huge missfires...
- LTFT????
- postive LTRIMS at WOT??
- when is reprogramming required ?
- How do I set the miles on my car to O
- Is is possible to change the O2 Heater Circuit temp range with Edit?
- Say i want to tune in speed density?
- Do I have to tune my car with this cam 224/224 567/567 @ 114
- Check it out->Will this help with our MAF tuning or tuning in general?
- Hows autotaps palm pilot software?
- service engine soon!
- O2 simms (millivoltage) vs. A/F ratio
- using atap, how can i tune my base?
- i need yalls help desperately with my knock retard
- Help to trace the problem P0174/P0171
- Idle timing and cam surge what MAP values to change it at?
- LS1 Edit...
- predator shift points
- Injector Calc. V1.4
- cam/header guys need a few answeres
- How do i raise my TC lockup MPH under normal driving
- ls1 edit
- Should i worry {lean}
- LTFT Sanity Check
- Autotap AT1 v2.10 install files
- Tunning, LS-1 or Ed Wright
- St and LT
- Hypertech Programmer
- WTF car still won't idle! EXPERTS?
- FAST Performance or Fel-Pro?
- What A/F ratio to run??
- anybody flowed 85mm maf vs stock?
- Trace Analysis Software
- O2 Sensor
- LS1 C4B Supercharged.
- Might have a problem
- Why doesnt the SES code translator work??!?!??!
- Predator and custom tuning
- Off throttle tuning LTFT
- Just ordered Predator, do I need Atap?
- Help With HPP3!
- New C&S Performance Standard Pricing
- intsrument panel acting up on start up...
- extra O2 bungs for tunning - what location is best?
- O2s ??
- need to get dyno tuned dont know where in south florida
- Why lockup TCC in 3rd during normal driving?
- Could changing battery reset or mess up the PCM??
- Are these LTFT's too rich?
- Need Auto Tap Advice
- Any way around major programming?
- Help With Tuning
- Cam tune
- Predator vs. HPP3 on '02 A4 F-body
- Rev Limiter?
- O2 sensor wiring?
- MAFT tweak induces KR?
- Rev limiter
- Factory Rev Limiter???
- Using ATAP to see if front O2 sensors are bad?
- HELP car will not idle right?????
- I think someone turned the miles back on my car!!!!
- OK have some electric qs after install of shifter
- Question About My Dyno...
- Is it too much timing or not enough that creates surge @ idle?
- LS1 edit and Hyppertech
- LS1 Edit tuning did on a 224/.581 disapointed?
- Anyone happy with mail order tuning?
- Need help w/ tuning after Bauer TB install.
- no need for MAFT or HPP3 if you use LS1 Edit?
- EFILive and oil pressure readout?
- Gained 1 hp lost 5#tq with new tuning (questions)
- PROGRAMING AFTER A CAM SWAP
- help with maf numbers
- Is bigger better?
- Some confusion about file editing with LS1edit...help needed
- P O300. What do I adjust to prevent open-loop misfire?
- A little tuning help please...
- Any one ever hurt your batt using hypertech?
- Lots of LS1 EDIT Q's Please help!!
- Wiring Diagram
- PEvsRPM table need it for the ATI SC!!!!
- need help
- LS1/T56 into 67 Firebird
- Can someone tell me how to retrieve codes of OBDI?
- Fuel problems
- LS1edit file for ATI SC!
- need help with A4
- LS1 Edit, Predator, Hypertech????
- LS1 idle quality
- Help! Why does this happen???
- A/F Ratio
- Ls1 edit - torque managment?
- Edit Settings for a 160 Thermo?
- Moderators, SOME ONE HELP WITH THESE CODES!!
- HPP III RFG Tunning question
- SES lights with new Cam install
- new CALMAP vs FAST
- Engine idles at 1800 after cam install
- Engine dies on quick accelerator release
- LS1Edit or wait for TunerCat?
- Quick deliver from Carputing!
- Which side of the car is bank 1 and bank 2
- Shift Firmness & Shift Time
- changing front knock sensor
- What is this Error CODE?
- Buy LS1Edit or dyno tune for new cam
- Injector flow rate table ?'s...
- What is Cat OverTemp Protection?
- grinding throttle stop- question on voltage?
- Can the factory ignition provide enough spark for a H/C car?
- nearest dyno tuning with edit is where? FLP?
- How are you A4 guys checking KR
- DTC-PO410 What's wrong?
- Autotap
- Who has LT1 edit for an obd2??
- How can you tell if torque management is a problem
- What can I expect from LS1 Edit / Dyno tuning?
- Advanced LS1_Edit topic regarding reflashes and power numbers
- CODE SCANNER
- AUTOTAP- LOSS OF COMMUNICATION
- Fiew LS1 Edit questions and tuning
- Does AutoTap read ABS DTCs
- Any info on rapid performance?
- Performance Chip
- P0440
- Delete BlackBox with LS1 Edit?
- HyperTech Hyper Screwed me
- HOW TO CHECK IAC OPERATION
- Help with appropriate idle speed!
