- EFI live gurus suggestions welcome
- Software
- Guaging intrest ACCEL Gen VII Class in Utah
- Car likes dying in the cold w/ th400
- Standalone TCM
- P0442?
- How do you know if a coil pack as taken a crap
- Car still doesnt shift into 3rd/D
- URGENT i need help with a hp tuner
- Any tuners near wisconsin or in wi?
- EFI Live Valet mode
- diablo sport tuner help???
- Need HELP car sputters really bad!!
- pcm retrofit? 95 s10.
- hp tuners turbo help
- Random cylinder mis fire and tcc unlock
- need some help with my car badly!?
- So I compared my AEM and LM-1 Widebands today.
- Programs?
- help please
- Crank Position sensor learn wont work, rough idle then stalls
- Replaced fuel filter, High idle
- innovative motorsports? anybody use it/like it?
- 5.3 in camaro
- Should I tune my Z28? (close to stock daily driver)
- Need '99 PCM Wiring Diagram
- OBD Codes?
- cam only tune issues
- 2002 Camaro SS - Need help with Predator shift options
- need a programmer for V6
- hp tuners what to set for my 408..
- 1bar map + no maf + turbo'd
- knock sensor?
- 7.24 Volts @ TPS
- tune question?
- cut out cycle off tps
- Need Experienced Tuner/Shop/Dyno
- Autotap Help
- Help! With a 0.5" smaller blower pulley now part-throttle is too rich
- Superchips needs beta testers
- Bin Files
- Stock Tach Problem
- HPT problem need help.
- ECU Pinouts needed for CTS-V
- BS3 A/F output
- I need HELP FAST!! Please read
- Instrument Cluster Issues
- m6 spark smoothing?
- major fight
- Anyway I could pickup more power with my tune 01 z06
- Just did diablosport tune on my bone stock ws6...
- Question about anti theft system
- LT1 Handheld Tuners
- LM1 wideband questions and opinions
- I will PAY whatever it takes to get my car perfect!
- Throwing all 4 O2 CODES 0131 0151 0137 0157
- Why cant MPVI Channel A & B load?? (Installing HPT issues)
- HP Tuners
- Abs Inop...
- programmers?
- LS2 oxygen sensor
- VE tuning '08 2500HD?
- Have an old problem that was never answered........
- Hey guys, need some help with SES codes
- Come visit us at the booth in sema, booth 21951
- EFILive new website and program goodies!
- Car won't go into PE mode?
- engine misfire
- Tuning for vig4000
- ABS INOP, ARS, Low Trac.....
- ???s on tuning PE w/HPT
- Why is my idle spark all over the place?
- FI, meth, and tuning question...
- Buying a car that wont start need help
- e85 and B3601, stoich
- Another idle problem
- Tune for a near stock car?
- Just got Hp tuners and a couple questions (tried search)
- Worried about spark knock
- p0133 and p0153 question but not normal
- tps sensor
- NEED SOME ADVICE ABOUT O2's
- Car noses over when tranny is under 140.. Why?
- Intermittent surging / bucking problem p0103.
- What separates "good" from "bad" tuners? Who are they?
- wideband af/r gauge mounting in car
- Little help please
- I have an XFI communication problem for the IT experts..
- Tach signal on 08 vette.
- KR maxed out on startup
- 98 + vats + swap car
- 1998 and TQ management?
- readiness monitors
- atlanta area
- car dies at 6000
- car cranks, but wont fire, possible tune issue
- HPT Guys Please Help
- ebay pcm any good?
- not shifting from 2-3 after tune
- mafless tune
- reading Problem ( LC-1 logwork & gage & EFIlive )
- {b3702}
- DTC, live data reader.
- 2002 Engine trans wireharness and pcm in 98 T/A
- Keep HP tuners or sell and gvet EFI live
- my computer and bs3=a pain in the A$$
- PLx to Hptuners Question
- Richen idle& cruise
- looking for a shop in my area
- Confused about LTFT tuning? using HP Tuners.
- Whats wrong....!!!
- Throttle response?
- Injectors offset voltage values
- My 1st experience w/SD tuning.
- Hot start idle is horrible..Please look
- Please help!
- shift light....
- Texas Sponsors Needed ASAP!!!!
- MAD PROPS to Vince at Trifecta Performance
- Dash taken out, body control module in alarm mode?
- -100% LTFTs?
- ???RPM gauge not working
- ???abs Inop
- Masport Tuning In Boca Kicks Ass
- O2 Sensor issue
- wide band
- computer
- ignition coil 7 control circuit?
- is it possible to use diablosport to....
- How to disable EGR in LT1 Edit
- Anyone used the JET verson of Tuner Cats??
- best tuning software for startes
- timing, masters of the LS please.....
- Want to add Cats, will it affect my tune much?
- LS6 Throttle Body Tuning
- Need CEL Code Help
- timing at Peak TQ and Peak HP
- v6-v8 swap (wire from pcm to allow all 8cyl to function)
- Just got my HP Tuners
- my roommate thinks this will work on his V6 Camaro
- TCS light staying off?
- Misfiring bad and throwing codes.
- What do our cars consider WOT?
- TCC slip/duty
- 01 WS6 Issues
- Tuning and headers ... my experience
- knock sensor questions
- tuning question efilive
- Help...5000 rpm shutdown
- Lean Stumble Problem - Tune file and datalog
- Warm start issue - what should my tuner be looking for
- maf question
- any1 in killeen or around the area with 99yr hptuners
- Can I has fuel? Car is lean... (scan inside)
- What color wire from Ignition Switch at Steering Column
- 2-3 Trans Clunk from Tuning? Can anyone check my tune for issues?
- 12.37 @ 113 last night...slight bog out of the hole...Tune/Log Inside
- Torque Management on a M6
- xfi tuning help
- Base hptuners tune questions for my 408 TT build..
- Help Logging....
- NOOB. thinking of purchasing tuning siftware.
- idle issues after new mass air
- where can i find a MAP pigtail?
- #7 & #8 not firing
- magnacharged 402ci random misfire code?
- Mis firing and bogging down
- FAST XFI LS2 T-56 Help
- Car nosed over after launch.. Anyone know why?
- my IAC position is 0 at idle after adjusting? need help.
- Silly question? Using E38 ecm without the VVT cam ok?
- want to richen my WOT mixture a little EFI Live
- big stuff 3
- intermitent lean (p0171/p0174) codes..
- Torque Converter Tuning help/write up additions...
- Washing Car=Check Engine Light On
- I need help IMMEDIATELY!!
- 98 EFILive tune help
- GM Drive Cycle monitors... emissions help?
- Reduced Engine Power Problem !!
- Tuners around central MN
- Search not working for me--problems with LT1/LS1 Edit and Tunercat with Vista
- ol sd tune vs. cl sd tune-opinions inside....
- any 98 m6 tuners in here? got a question...
- Dyno/ mail order/ or software?
- Do I Need a dyno to get a tune?
- Dyno Tune Gain
- car is way to rich need help
- Newb Question About Tuning
- GMPP LS2 compurter e67
- LM-1 and HP Pro Connection and Use??
- Installed new intake... problems
- New SES codes
- Hard Start Cold Or Hot
- hp tuners software for !!!
- Why is AFR off so much from bank to bank with dual wideband?
- Using an LS7/LS3 MAF Sensor with an LS2
- Stand-alone PCM harness for diagnostics and testing?
- STFT Super Negative....Then Super Positive After VE Changes
- dtc p0174
- Need some help w/smog tune.. PLEASE
- HP Tuners comes thru! THANK YOU!
- 365, 4l80e, COS3,2barmap efilive
- p0200 code...wtf!!!
- do fbodies use any kind of bus communications?
- Looking for advice 5.3l tuning, hp tuners
- Hp tuners and Autometer wideband Help!
- GM controller #19201861 tune?
- TPS code and high idle???
- part throttle miss, possible o2 problem?
- shift kit and diablo tuner?
- Ses Codes
- Vortech Supercharger/92mm FAST Intake/TB, 100mm TSP MAF, Tuning help needed!
- wide band hp tuner calibration off
- snap on scanner gets "no communication" from pcm
- Failed Emissions
- Buying Hp Tuners but have some questions
- LS1 (2?) Edit vs. HPT vs. EFI Live
- Do i still need a programmer...?
- 6.0l Cranks But No Start
- Please look at my Log and Tune - Files attached
- New to tuning,with MTI X1 cam
- tuning question
- Ls1 Edit questions <--anyone have answers
- VE Tuning at WOT?
- lt1 to ls2... can I use 98 pcm?
- AEM Wideband Controller
- What Gains have people seen going from 13.8 AFR to 12.7????
- start-up and into gear problems
- car keeps cutting off under light acceleration
- What would you do?
- H%C/Intake/TB install with codes
- Is 02 PCM pin out same as 99
- e67 computer
- 2 bar tune with 3 bar map?
- anyone used a 2-step on a classic fast system
- GMPP Computer
- Buying HP Tuners, what's the cheapest laptop I could get to run it?
- mass air voltage too high
- diablosport predator
- tuner cat help
- who on here has hp tuners come on in
- Does it matter that I'm using?
- question for the start up
- 5.3 with a gmpp intake and 4150 4 bbl throttlebody questions
- Why do people insist the throttle volts be .4-.6 range ?
- stumped with injectors filling up cylinder
- HP Tuners - Lean stumble when you snap throttle or even try to take off? Any ideas?
- For CL do you run LTFT or just STFT
