PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Delphi 60# Injector setup...
  2. Weird Problem - Electrical I think
  3. Coil pack Removal
  4. Weird Issue, going lean at WOT(Ls1 Rx7)
  5. Do I need to Tune if i change plugs?
  6. PO1416 - Secondary Air Injection (AIR) System Bank 2
  7. ls1 timing tuner nitrous controller and blower tune
  8. How do You Know when You have a Bad MAF??
  9. Speedo Problems Again.
  10. If I purchased an EFILive FlashScan V2 (Scan Only)
  11. Best SD tuner to go with for mail order?
  12. low voltage at o2 sensors??
  13. Tune For Intake/TB Bolt On
  14. idle issue...MS3
  15. what voltage for brake input for crank sensor relearn?
  16. whats this mean?
  17. 3000 RPM Idle, will not come down
  18. Ethanol In Gas
  19. Anyone use the Dynojet Wideband 2 ?
  20. HELP Code 171
  21. connecting air/fuel gauge, ecu pin nr?
  22. LS1 Wiring harness VS 5.3 Wiring harness
  23. Uncontrollable idle with A/C
  24. New tune?
  25. won't idle, cannot rev up?
  26. Can someone give me an estimate?
  27. bad knock sensor?
  28. LC-1 install questions
  29. Engine Light Keeps Popping up...Now im worried
  30. LTFT Question
  31. (hp tuners) What does the "non-active test write" do
  32. Any Local Tuners 361 area?
  33. Something weird going on
  34. Diagnostics of an LS1 Engine in a Malibu Ski Boat
  35. what determines a missfire
  36. sponsor that sell hp tunner look in side
  37. Programing 1996 LT1
  38. Map Bar ?
  39. Why Bad Gas Mileage?!
  40. SD or Closed Loop-MAF tune????? and why?
  41. crank learn/CASE in north jersey??
  42. Security light problem
  43. Quick LC1 ground question
  44. Need help with these codes...
  45. need help ls1 edit... converting m6 to auto
  46. tune repository for fast?
  47. Computer died before completing load of file
  48. A couple basic EFI questions
  49. quick qestion
  50. Few questions about my FlashScan V2
  51. Very easy question but Im a numpty
  52. No communication with ODBII Port
  53. Tune Required
  54. Question regarding tune?
  55. turbo sd tune?
  56. Knock Sensor
  57. tunercat datalogging question
  58. Please help me get started with HPTuners
  59. Quick Question regarding an issue with HP Tuners..
  60. help me flash the e67 ecm
  61. knock sensor pegged out after startup
  62. Bank 1 lean... Take a look at my log ( efi live )
  63. only real tuners please
  64. What wideband for HP tuners pro?
  65. high idle
  66. Air / Fuel Ratio?????
  67. Jesse (EFILive), FROST or joecar inside please
  68. Anyone Know How To Re-Program BCM
  69. WTF is wrong with my tune???????
  70. Any way to dial in stft?
  71. 60# boost tune
  72. Predator tuner O2 code deleting
  73. Controlling spark only with the LS1 PCM?
  74. what tuner to use?
  75. runs horrible in closed loop great in open LT1
  76. help with tuning a built car...
  77. Bad PCM???
  78. Whos running Vista with a new laptop? Come in. need help
  79. Wont stay running after rebuild! help me
  80. Lingenfelter 2 step issue
  81. P0200 on 408
  82. Need a tuner...???
  83. cat. overtemp
  84. Can i use my Fast Dual Wideband 02 system to run with my painless LS1 EFI harness?
  85. Race proven motorsports...
  86. what do these codes mean
  87. How can i tell what injectors my pcm is tuned for?
  88. Master EFI Tuner Book ?
  89. AFM (Active Fuel Management) on the Silverado's.
  90. Lean bank due to lifter issue?
  91. having ignition trouble
  92. FAST Flash programmer
  93. can anyone help with passing emissions!!!
  94. Converting carb setup to efi in my 68, want a crash course in what im getting into
  95. How to hook up a Tach to 98 Camaro?
  96. 1998 ECU to 1999+
  97. rear wheel speed erratic
  98. Car runs bad with new motor no power
  99. Anyone tune a Supercharged LT1 with TunerCat/Freescan?
  100. Scanmaster or Wideband????
  101. I just bought this computer for my 1998
  102. moates question
  103. possible 2 turn off the abs lite?
  104. timing question
  105. Backfire upon lifting
  106. Comp. Ratio on pump gas??
  107. HP tuners..anyone have a basemap for an LS2 cam only?
  108. HELP!!!!! P0200 Injector Circuit Malfunction
  109. Reverse Solenoid fuse keeps burning?
  110. p0122 code?
  111. GMPP Controllers and readiness codes
  112. There any shops in North Louisiana that can delete codes?
  113. startup without tune???
  114. T42 OS wrong for my setup?
  115. Codes remedy?
  116. question about tuning software
  117. Intermiten codes
  118. MAF to SD tune, using HP tuners, what do i need to change?
  119. GMPP PCm Kit narrowband O2's need wide Band
  120. dynotune question
  121. cam surge ?
  122. can the ngk afx be ran with a 2 1/16 guage?
  123. cam surge ?
  124. efilive b5910 spark ect
  125. Lt b1- lt b2
  126. where should i get my ms4 car tuned
  127. Possible tuning related backfire...please help
  128. PCM Question
  129. 98 computer swap.
  130. Anyone have a wiring schematic of the E67 and/or E38?
  131. Burst Knock and 98 pcms?...
  132. I need help
  133. Need Help - Injector slope and WOT
  134. Rough idle
  135. Rough idle
  136. hypter tech tuning- how to?
  137. Street/Dyno tune whats better?
  138. Flashing a A4 to M6
  139. LM1 tailpipe
  140. PCM part #?
  141. Multiple tunes on one PCM?
  142. Computer Fried?
  143. Motec MLS - LS1 specific ECU
  144. nate(elky498) fresno performance!! A++++
  145. timing at wot
  146. 100mm Texas Speed MAF
  147. IAT effect on afr
  148. Need Help!!!!!!
  149. idle is very rich need help tuneing
  150. absolute throttle position
  151. LT1 Edit File
  152. RPM limiter or some other way to limit power or speed?
  153. What timming should I be targeting?
  154. injector offset Vs. Battery voltage table
  155. What PID's to log for initial tuning?
  156. Tuning my own car
  157. Anybody use Autotap as a scanner?
  158. OMG, exhaust mod & VE table result....am questioning the effect on the tune
  159. Dyno Tuning
  160. car running rich suddenly help!!!!
  161. no start after heads/cam/intake install
  162. Cool Practice Tree download.
  163. AEM WB vs. Stock NB accuracy
  164. Can any sponsor help me with this?
  165. Speed Inc Dyno Tune?
  166. Timing at max tourqe vs timing at max hp?
  167. Anybody in OK that can tune for a resonable price?
  168. Bank 1 fuel trim fluctuations
  169. Can I drive without a tune after headers & intake?
  170. Idle issue after tune
  171. my 02 z28 has no buttons on dash for
  172. [b]tune gone bad?[/b]
  173. wont run after cam install
  174. wont run
  175. How high to rev the motor
  176. need my car tuned, im around louisville, ky
  177. MAF is bouncing all over? Can someone look at the log/tune?
  178. What can cause "False Knock"?
  179. advance ground into cam..... tuning question...
  180. 05 silverado tps/map/ REP problems
  181. My gears read as 322...
  182. Speedo not working, VSS replaced, still not working
  183. Idle won't stay at Stoich
  184. Cam position ?
  185. is my trans toast? *log inside*
  186. torque management
  187. Wont pass inspection...readiness test help
  188. PCM reprogramming
  189. In IL Need Tuner Suggestions
  190. Anyone with HPTuners and a CTS-V?
  191. What is concidered the best Wide Band to be used with HP Tuners
  192. Has Anyone Been Tuned By Simpson Performance?
  193. Possible to delete MAF?
  194. HELP!! wierd problem with my car tonight.
  195. Help!!
  196. Hand-held tuner with aftermarket MAF
  197. New Injectors and the tune...
  198. question about tuning LTFTs on HPT.
  199. map conversion
  200. t56 conversion etc. w/ tunercat
  201. Innovate Wideband Sale!!!
  202. megasqeuir boot control cant keep pressure?
  203. Are canned tunes safe/recommended for daily drivers or not?
  204. Major MAF Problems in '03 Silverado SS
  205. Application key does not work help..
  206. AF Ratio on Throttle off
  207. injector slope
  208. Can i do an SD tune without a wideband?
  209. o2 sensor missfire, need new tune?
  210. how to check voltage at MAF question
  211. F/S Hypertech Power Programmer III 98 Camaro/ Firebird LS1
  212. Truck PCM in F-body
  213. Coil problem, need help!!
  214. anyone in the bay area good with hptuners
  215. wide band question
  216. Launch Control w/ HP Tuners?
  217. 2002 engine harness question
  218. Tuning For Torque Management
  219. 98 3.8 PCM reprogram to Ls1?
  220. LTFT and STFT
  221. Turbo PCM4Less Calibrations Question
  222. what is the target a/f on a supercharged car
  223. tuner locked my computer
  224. A couple of wiring questions...
  225. FS- Do you need a laptop for tuning. Step in
  226. Need Help IFR tables for 60# s/c LS2
  227. best deal on lc1's
  228. Methanol on a DD
  229. Slight Tuning Issue
  230. Reading deleted codes...
  231. Can a Fast Classic box be run fuel only using a tach signal?
  232. looking for tuner in wisconsin
  233. 2 step activation wire?
  234. can I use the GM VATS system?????
  235. Torquer v2 idle tuning
  236. F/S LM2 Wideband
  237. code p1336 out of no where
  238. air/fuel ration
  239. Seeking advice on mail order tune/engine break in
  240. Tuning available for 98 WS6?
  241. No Narrowband Signal
  242. Tuning out traction control?
  243. COT Enabled or Disabled
  244. P0108 and two other o2 sensor codes
  245. Multi spark ingnition control
  246. Idle issues with carb LS
  247. Pleaseee help , trying to get car running with diablosport tuner
  248. recalibrating speedometer....
  249. 240/242 with 580 lift cam, 2K WS6 stalled auto
  250. Quick question
