- will a hpp3 for a 2001 ss work for a 99z28
- difference between atap, efi live, and ls1edit
- Please help, LS1 edit educated inside
- Can someone post the stock timing tables
- Can't get a successful read with LS1_edit
- Best O2 sensors
- LS1Edit - adjusting cold start fuel
- Atap and LS1 Edit>>>are these the only programs I really need
- Predator Worth the $$$$$ ???
- Flashing SES light and a couple quesitons
- P1626 Engine Controller -
- Hpp3 won't deprogram with harness unplugged from motor....
- Anyone have a list of all SES codes?
- First dyno running rich ???
- HELP...raising shift points on LS1edit
- LS1 Edit worth getting?
- Can you change shift points with power programer if car has been tuned with ls1 edit
- P0420 - is it the cat or O2 sensor gone bad?
- Torque Management w/ M6?
- Autotap or EFI Live 5 or Both
- Old Autotap question
- P1133 SES Code?
- New tranny equals rpm spike
- Atap stops at 14.6 on A/F guage?
- Programmer or Not?
- Need to find LS1 tuner within 200 miles of Atlanta
- Please HELP!!!!
- Can I just ad 30# injectors to my curent setup?
- if the car is tuned with LS1 EDIT.....
- Any wideband O2's or dyno-tuners in South Florida?
- Knock out box emails
- High or Low Octane Table which one or both!!
- Flashing SES
- ATAP for Palm
- How much will a new Intank fuel pump change my a/f ratio?
- Diablo ?
- question on autotap programs
- 98 Auto and Man. computer
- Diablo Sport for 98 F-Body
- OBDII Catalyst Test - How to get to 'Complete' Status?
- Tech 1 data inside...ECM data person needed!
- how long did u wait for ed wright tuning
- P0327 Code. Here we go again.
- How far can you adjust speedo w EDIT
- LS1 edit in NC
- What triggers knock reset?
- IAT richens or leans the mixture
- LS1 Edit Question...ASAP!!!
- EFI Live & Auto Tap Issues?
- Who has HPP and LS1Edit access for a 2002 (or 01)
- Question about some codes
- Diablo Predator
- tuning
- Auto Tap Palm Unit? Nay or Yea?
- How to pull Z28 ECM
- Help---LS1 making noise
- MAF is maxed out...suggestions???
- IAC Questions, Please Respond
- If my MAFT is set at 12% Base, what parameters do I change on LS1 Edit to program?
- Timing -v- Temperature Programming Issues
- Need help with misfire
- Highest safe octane rating to not harm sensors?
- thanks to Kevin Haggerty
- LS1 Edit tuners in NJ???
- SES codes
- Need help trouble shooting P0171
- LS1 edit and Autotap
- questions about ltrims...
- 6 point diff. between b1s1 and b2s1 on atap - why??
- hypertech
- Post your tuning parameters
- Speedo Correction
- 10.9 A/F Ratio Ed Wright Says Somethings Wrong
- In cold weather do I need to richen my car up a bit?
- Can Someone Please Help, Bad Hesitation Problem, Please Anybody
- Low Coolant light?
- If I know my GM injector part #, where can I find the flow rating??
- Bay Area Tuners?
- #8 Injector Fault with EFILIVE
- changing mass air sensors
- Logging info question
- Dyno costs??
- Spreadsheet of Stock vs Tuner MAF for SLP MAF
- Autotap (other scanners too) Troubleshooting
- Knock sensor 1 low imput?
- What to get ...
- O2 issues
- causes for misfire?
- #2 bank dumping fuel
- help with in on Beru Hotwires & plugs
- auto tap
- how to get an accurate in car A/F reading?
- Low voltage from MAF solved LOL
- knock retard
- Adjust A/F ad idle and part throttle??? (looked in user guide)
- Basic Electronics
- setting torque reduction at zero
- Tuning to pick up power below 4000rpm...
- Scanmaster help for LT1
- adjusting low and high octane timing tables....
- Help with MAF
- need help with LS1edit for '99 A4
- Bolt-on tuning
- P0251 code, O2sensor B2S1 high voltage, need help!!!
- Can't figure this code out???
- diablo installed
- Injector Offset table for Lucas 38s
- Which scanner?
- best place to purchase autotap
- Do u raise or lower the Fuel Injector Flow Rate
- Where can I get Helms Manuals for a 2002 F-body
- needing help bad
- Where to find 4.2 rwhp???
- can anyone help tell me what would cause a '98 to run this lean?
- Just ordered my DiabloSport Predator...
- WOT A/F Ratio depends what gear I'm in??
- My car is in theft mode?
- Interesting reading... OBD II possible scenarios OBD III
- How to delete TQ Management
- Would a dealer ...
- scanmaster, auto-tap, ls1-edit, which one?
- Found My Lost Timing
- O2 readings with 160 vs 195 thermostat
- Help w/ LS1 edit
- At what temp do I set my fan settings using LS1 Edit with a 160 thermo?
- Is stock A/F ratio supposed to be 11:1???
- HPP or Editting
- Ls1 Edit: Air Pump Coolant disable temp?
- editing hardware/software???
- Rear-end gear ratio change
- Going to a dyno on Monday...any pointers or suggestions?
- just got an auto tap
- misfires detected
- 02 output and part throttle a/f
- another resetting pcm ?
- AutoTap vs AutoTap enhanced?
- picked up my diablo tuner
- ever wonder if apexi unit would work?
- missing and backfiring help!
- Only 22 degrees at wot, with no kr. what gives?
- Can me and my father use AutoTap?
- A4 and LS1 edit
- Head Light Problem
- CAT Over Temp Feature
- LS1 EDIT
- Who is using FAST on an LS1?
- learning autotap
- P0327 Is pissing me off. Need Help.
- 28 degrees at WOT ???
- Warranty on tuned pcm???????
- Installed 3.73s, now slamming rev limiter!!!
- Experts inside, curious as to how car feels stronger with more fuel in tank
- What functions of LS1Edit do you actually use?
- F.A.S.T. Engine management on LS1
- Contact info for Ed Wright
- CAR IS DEAD!!!!! Please HELP
- Who can reflash my PCM to stock? (Besides local dealer)
- Hypertech Power Programmer III
- Major Dilema. Need opinions ASAP
- O2 Help PLease!!
- B&M shiftplus install
- ? about dyno run today
- Possibly a really stupid question......
- Tuning questions -- help a brotha out.
- Any opnions on the Venom 400 control module?
- Need a cpmputer reprogramed in Baltamore MD
- P0135/P0155 issues
- EFILive V5 is Great! Customer service even better
- P0327, checked everything and its OK?
- Minor Intermittent Misfire - (Ported MAF)
- Open Loop operation on a 98
- Does anybody have Offset table...
- MAF Ends Part 2: still have incorrect load calc and Ltrim's are messed up
- NON_LS1 based ECM problem, maybe common, need help
- question about idle coming down after foot removed from gas
- Timing?
- Just getting into the scaners and tuning.
- Why was my topic locked?
- Questions after LT Install
- Auto Tap scanning????
- Auto Tap playback???
- Started Car for first time in a week, guages did a "Sweep"???
- Any benefit to flashing PCM base code before LS1_edit?
- Should I worry about these codes?
- How to add 2-3 wot timing
- Matt Harlan
- I really need some help
- Having trouble reconnecting autotap after disconnecting
- Need help with tuning session tomorrow...
- P0358 Ignition Coil 8 Primary Secondary Circuit
- check guages ?
- CPU?
- Houston area?
- Ls1 edit isn't turning off code PO751(1-2 shift solenoid)
- resetting SES light
- Can you add fuel to certain cylinders individually with any of the edit programs?
- A4 to M6 Conversion- Computer Question
- EFI Live will NOT connect to my car through my laptop!
- I need help with this code!
- IAC, vacuum, and idle... Any ideas ?
- can ASR be deleted w/edit?
- hypertech or ls1edit
- wiring diagrahms
- 20 days after header install and car still not running right
- Wanted - MAF screen
- Hypertech question
- Edit tuning brand new PCM's
- Can you use Efilive with Autotap hardware?
- Buy LS1Edit or have it tuned by a Prof.
- What is the lowest safe idle?
- Ease or Autotap?
- Stock Numbers
- Please help me!
- Diablo Updates???
- EFI Live Bi-directional question: What happens if the connection is lost??
- Knock sensor Question
- Nasty (Dangerous) Surge
- Where to get LS1 Edit.
- should i remove smog punp
- 3300 stall program and driveability?
- wiring changover
- efi live
- P0420 w/O2 Sims???
- How to get rid of "Idle higher than expected" code.
- Lockup convertor in 3rd at WOT using Edit?
- Remove .... AIR, EGR, Rear O2Sensors > Will all these SES lights effect power?
- Add-ons to LS1 Edit???
- ls1 in custom rod?
- Deleting Rear 02's- What To Turn Off?
- How do you tune
- Fuel Injector Flow Rate Table Axis
- B1S1 very different reading from B2S1
- LS1Edit Adjust Knock Retard?
- is my autotap too old?
- Yet another Torque M. question(weird)
- Thumbs up for CARTEK.
- pounds of air? how much are you seeing?
- tuning a stock car is it worth it
- LS1 Edit
- Help please...voltmeter pegged out at 18
- O2 sensor output
- ~~~Need Edit Help~~~
- Can I replace stock O2 with Wideband O2 Sensor
- Factory reflash?
- computer pin outs
- Pissed!!
- ***Warning*** LS1 edit may not properly work on some 2001 LS1 cars
- Idle Relearn Procedure?
