- Need .ls1 file for TR224 cam
- need flash for tr224
- auto tap : just diagnose, or edit as well?
- 160 thermostat cooling fan settings for ls1 edit?
- Oil gage going crazy.
- Got my EASE
- Anyone have SLP speedometer? Help.
- Rear o2's and what to look at in autotap?
- So can you tune MAFT with Scanmaster?
- DTC P0166......
- Please help, trying to get a big cammed 422 LS1 to idle
- HTPP for 2002???
- LS1 Edit - is there a database available?
- why am i so lean??????
- Does Ls1 edit use the same cable as Autotap?
- When to reset/disconnect battery??
- 100% + duty cycle?
- O2's different?
- 27 degrees of timing at WOT
- Need to know how to delete tq management
- PAGING KEN from Carputing...
- is there a way to reset hpp3
- Put Cruise Control back on, and now it won't work?
- Will LS1 edit work with windows XP?
- will TQ Management cause this while spraying??
- Could you guys point me in the right direction...atap file enclosed.
- Codes P0410 and P0412..... What do they mean??
- ls1 edit
- BO-RFA codes
- about KR and false KR....
- why is on 02 leaner then other?
- Cutouts and cam and headers???
- What the Heck! My SES light is flashing. Help Needed!
- tuned 382 stroker, can't lean out?????
- O/T - DFW tuners for trucks???
- Procedure I used to tune TC lockup and Shift Points with LS1-Edit
- Knock sensor
- Funny WB o2 Results...comments please
- Aint running right! Experts inside!
- All LS1 Scanmaster owners - I have some questions
- A great investment for the LS1/LS6 owner
- resetting codes
- LS1 Edit changed their minimum cpu requirments?? Will a P166 work?
- Tips for MAFT Tuning
- PCM Pinout for A/F gauge install
- Lockup for SY3500??? when? what speed?
- "Service Vehicle" light?
- Why Delete EGR???
- P0751 code and LS1 Edit problem
- What would cause randomly wierd/bad o2 readings like these at the track???
- Help with an SES light......
- Maf flow rate??
- PO135, PO155, AND PO137
- A4 Shift points
- ? about some SES codes....
- HPP3 shift points for A4 w/3.73 gears.
- guys, WTF is goin' on, im nervous but worried, and dont know what the hell im doin'!!
- Please Help with SHIFT LIGHT on LS1 engine
- Need help on SHIFT LIGHT for LS1
- Is there a retorque procedure for knock sensors?
- LS1 edit... who has it
- Need help indentifying PCM C2 connector block
- SES code 507?
- LS1 EDIT and Torque Converter????
- LS1 Edit, Can I use MAF ends with A4
- Please help with these autotap #'s after an edit!!!
- P0300 Secondary Air Injection code
- PCM Reset?
- Someone help me with my Ltrims!!
- Ltrim Spread and Variance? H/C Car?
- can yo guys help me please!!!?? regarless of how redundant this post might be???
- LS1 EDIT??? MAF settings?????
- Auto tap
- LS1 truck
- Has anyone ever switched from a M6 to an A4 (computer related)???
- Local guy says LS1-Edit for 2001's available in a few weeks?
- Can i do anything to not get any codes?
- What the F*#@ do I do now?
- I have a brand new "MAFT+" for sale if anyone wants it....
- How do I fix this code?
- Playing the Devils Advocate Again...
- EFIliveV5 vs ATap
- DTC P1336 Crankshaft Position (CKP) System Variation Not Learned
- atap codes with misfire
- Need misfire help
- P1153 & C1283 What To Do?
- Need Hypertech Help Asap
- Super Chips?
- speedo correction help
- TM solved yet?
- Atap on car shows one side rich, and the other not!!
- Need help tuning w/ MAFT & LS1 edit
- EFILive?
- Autotap & LS1Edit Data, need help tweaking
- Timing is WAY low. reasons why?!?!?!
- am I more lean that I should be?
- Exhaust rasp causing KR?
- A4 Performance Mode
- P0449 &P0552 Codes? Anyone else get these before?
- Retard timing via resistor?
- Do i need to reset computer?
- ok..i have narrowed it down some..need help still
- Got Ls1 Edit...what to start doing...
- Trans temp on Atap???
- GM TechII Tool?
- Will Adjusting MAF Table Throw Off PE Adjustments?
- LS1 Edit to prevent the 3rd to 2nd gear mis-shift in a M6?.
- When on a Dyno...
- Alright your diagnostic experts - why do I get P0440?
- Laptop Tuning Problems (non-LS1) -- computer help needed
- Dyno Chart: MAF and/or MAFT??
- Someone who knows ATap, LTFT's and Fuel Cells
- LS1 Edit - 'invalid file. checksum error'??
- how lean is too lean for o2's?
- need help car wont start
- Tuning after adding Ported Heads
- LS1 Edit???
- Harlen Shift Light Just Blinks
- Whats your Fan LSEdit Settings?
- startup/idle prob after cam install...and lean???
- Torque Converter Lockup and Torque Managenment
- Anyone heard of Power Reduction on a late model C5 Corvette?
- Dealer Reflash...
- SOS HELP!!!
- "SECURITY" light on dash
- autotap connectors
- How to????
- When you guys received LS1 Edit via e-mail...
- Need Help On Injector Scaling For A '99 Car
- P0161 and a SES light
- Ltrims Way Lean, O2's Lean/Rich, SES Light Code PO135
- How to tune for rich/lean in ls1 edit??
- unlock EW Tuning?
- am i doing this right? says i have 130% duty cycle on my injectors?
- Odometer question
- B1S1 "Insuffient Switching"....
- Hypertech Power Programer 3? is it worth it?
- How to do a Crankshaft Position Re-learn?
- How's my Dyno pull look?
- Was my car hpp3'd??
- Has Anyone had Both EASE and A-Tap?
- LS1 Edit
- $180 for a new o2 sensor!!!! You gotta be kidding me!!!
- How capable is LS1-Edit?
- MAF and MAP discussion..
- Traction Control Question
- Anyone use Desktop Dyno2000?
- Need Help ... LS1-Prog wont run on laptop!
- Need help on PCM replacement decision
- how do i use Scanmaster?
- atap? will a faster computer get you a faster log?
- Does Autotap software work with the LS1 Edit Cable?
- SES code P0704 what causes this?
- What PIN number for.....
- What part # Jet SCU2000 for '00 Z28?
- Why LTFT -6 to -2 ?
- What exactly is LS1 edit?
- ? on MAFT, LS1 edit, autotap
- Tire Size Change on Corvette
- SES code 1133 need help ???????????
- How High Is Too High... (Rev Limiter)
- Swapping Computers
- Anyone running LS1-Edit with WIN95 ??
- What causes this code?
- Explain the VE chart in LS1Edit for me.
- Ed Wright Custom Tunning Dyno Results
- Looking for Missing Power, Results of MAF switching...
- Received LS1edit cables but no software!!
- Code P0301. Has got me confused?
- Need ls1 edit file for A4 with heads/cam to begin tuning!!
- How to swap my TC-lockup from PWM to non-PWM ?
- LS1 Edit C5 Tire and Gear Scaling When?
- I am getting an SES code "P0300" more than usual lately. What could be the reason?
- Can temporary no rear O2 sensor code be fixed with ATap?
- MAFT for smaller MAF ?
- SES Light: ATAP Code P0135 O2 Sensor Heater Circuit
- Has anyone else 'lost' , a pcm with LS1-Edit ??????????????????
- Giving up unless I can get your help.......
- Ughhhh I just 'lost' a pcm when doing a program !!!!!!!!!!!!!
- C5 LS1Edit question.
- where can you buy a wideband a/f meter?
- Do O2 Simulators Make a engine run richer than The Regular O2 Sensors behind the Cats
- What are you guys using to run LS1 Edit?
- Ls1 edit year question
- What are LTrims
- Need more timing on 01 TA
- Help!!! - Tach isn' working, and car is Coughing and Sputtering
- Need some help with autotap numbers
- Fact or Fiction
- What effect does vacuum leak have on engine performance...???
- can I limit the WOT timing with LS1 edit??
- P1415,P1133,P0133 autotap log's
- Anyone use/run DFI?
- Code and no SES....Why?
- WTF is this...
- How to use MAFT and AutoTap
- Need Help with DTC 118
- PCM code P0404...help
- where is the nearest place ....
- service vehicle soon
- MAFT question
- Stock vs Mod --- Autotap Numbers Hmmm
- Check out Group Purchase section for AUTOTAP deal!!
- PCM
- LS1 Edit
- Scenario: swapping PCM's
- evap system test?
- ATAP needed for LS1 Edit and 2002 release date
- Is LS1 Edit for a newbie?
- LS1 edit question
- Running rich 13-12.7 AFR, Should i put in Hypertech tuning?
- Crankshaft Position Sensor??
- What should my fuel trims be running at (auto-tap)
- What pc speed is best for edit????
- Looking for an LS1Edit file from a 2001 or 2002 Vette
- WHY ME??
- SLP 85MM MAF + MAFT - Is it worth doing?
- Help with LS1 Edit
- which air/fuel gage is the right one???? 4375?
- What is code 113?
- Codes P0140 / P0160 - Post Cat O2 Sensors
- shift point settings...HPP3....
- PP3 question
- Having the car programmed this week - any suggestions?
- PAGING JULIO/CARTEK
- Can I use an M6 PCM in an auto car if???????
- Please help I got a P0327 code with atap.. Could that be my battery?
- Descreened stock MA made my car richer?
- MAFT Manual?!? Scanmaster Manual!?!?
- Help!! DTC Code 102 w/MAFT and GMAF>>>
- Any other tuners besides ED Wright?
- WTF!? LS1 edit vs wideband dyno
- 2000 PCM vs. 2001 PCM
- AF Ratio
- What should my IAC count be?
- LS1 Edit
- bad o2?
- How do I create a log file with Atap???
- Codes 1133 and 1153 after installing headers
- What does this code mean??
- *.ls1 files for a 99 C5 MN6
- Atap Error Code 14-52
- O2's Junking Out???
- Tuning ?
- P0327 code? I have replaced the knock sensor.
- SVO 30# Injector Tuning Issue
- LS1 Edit vs. Fastchips
- Figuring LTFT Averages
- If I set the MAFT base to 5% rich and the WOT to 6% lean will the difference be . . .
