PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. afr's and cat damage
  2. P0654 and p0748
  3. car not shifting right after gear install
  4. VE AFR histo quit working hptuners
  5. E85 mpgs. What are you guys getting?
  6. Using wideband output for PCM?
  7. pcm/dyno tune
  8. multiple missfire
  9. max hertz on a stock ls1 2002 maf
  10. pcmforless
  11. 2002 ws6 a4 wot issue
  12. descreening a maf?
  13. tuning injector help
  14. Did you tune out P0343 / Cam position sensor? Come in here, need help!
  15. ***~~~frost~~~***
  16. help installing a maf
  17. I have a p0101 code
  18. New dyno tune but won't run at parcel throttle. Help!
  19. Abuse Mode??
  20. 98 z28 torque management
  21. HP EFI tune/ output help
  22. inTune now supports lots of GM apps back to 1999!
  23. TB SS MPG with Tuning
  24. Looking for timing table for TSP 228r cam and 243 heads!
  25. NYS inpection FAIL
  26. DFW Tuner
  27. Trouble Codes
  28. Bank 1 Sensor 1 problems
  29. HP TUNERS offer
  30. Can anyone tell me what engine wiring harnesses are compatible with a 2001 camaro ss?
  31. does any of this explain bad mpg?
  32. Explain knock in my log
  33. Serial Number Blank, won't allow to reflash. EFILive v2
  34. Holley: I need Harness 558-309 for my setup ASAP!
  35. 2005 c-6 rear o2 light on ??
  36. Goes to 0 timing in gear, cause?
  37. Opinions on log. (HPT)
  38. Is my LS7 MAF in an ok spot
  39. Adapting AEM LS1 ECU in different vehicle
  40. Need help fixing these codes Please!
  41. speed density tune
  42. Long tubes ses light..
  43. EGR monitor for 2001+
  44. Is there such a thing as "most easily tunable" injector.
  45. Albany NY Area and surroung ares(BEST PLACE TO GO FOR A TUNE)
  46. bolt on car getting a cam install
  47. car wants 30% increase in VE after FAST intake
  48. Tune or o2 Sensors?
  49. Lean across board on warm start
  50. Why does the VE table change by itself?
  51. 04 ls1 engine management
  52. I want to slow it down
  53. Diablo tuner troubles
  54. Tuning problem - way lean everywhere?
  55. $2500 for 30rwhp????
  56. 02 into 99
  57. Help disabling my theft system
  58. Autometer Speedo VSS hookup?
  59. After street tuned, PCM no longer retards timing to 0 under deceleration...??
  60. trading PCM and harness, will it work?
  61. code: 1336 crank relearn ?
  62. put in a clutch that weighs a total of 23 lbs, car wants to stall (UPDATED)
  63. just did longtubes, used denso 234-...corvette sensors.now no communication to o2s
  64. Holley HP/ Dominator EFI Help Needed
  65. HP EFI Tach Wiring
  66. Knock after sitting in hot traffice 4.5+
  67. Car won't start after holley dominator efi install
  68. Arizona emissions fail***UPDATE**PASS!
  69. mail order tune for heads/cam/rear mount turbo?
  70. Gears for HPTuners.
  71. 2001 Camaro SS computer tuning and programming
  72. qestions about efans.
  73. Not detecting OBD2 protocol
  74. Question about non ethanol gas and tuning.
  75. kansas city area tune?
  76. 98 knock sensors vs. new type
  77. HPtuners EFI live Bluetooth support?
  78. edcmat-l1 tuning in Pittsburgh 5/18-22
  79. edcmat-l1 tuning in Frederick Md 5/16-17
  80. Tune in Park vs. Drive. vs. Neutral?
  81. Misfire count, knock retard. How much is too much?
  82. help with my 98 turbo ws6
  83. Holley EFI demo software
  84. 5.3 Turbo 2 Bar Siemens 80 Tune Question
  85. Knock sensor and missfire problems!! Please help!!!
  86. Idle issues with EFI Live and LTX?
  87. What is the differance!
  88. 80lb injector data base tune
  89. False knock?
  90. PCM bad?
  91. HPT erasing PIDs/histograms when they're unsupported.
  92. DFCO Not possible with loose converter?
  93. Newb question on wideband readings
  94. recommended tuner in colorado
  95. PCM gaskets
  96. 95 ls1 vats issues
  97. Tune and pcm relearn.
  98. Surging idle problem
  99. F.A.S.T. , BS3 or Holley EFI?
  100. Spark Correction
  101. msd 6ls install with stock pcm tuning help
  102. 08-12 CTS wiring diagram V6.
  103. F.A.S.T. Guys In Here Please
  104. what spark plugs are you runnin with your frost tune?
  105. How to reset PCM
  106. Whos using a Innovative LC-1 with HPT Pro?
  107. WS6 LS3 2002 A4 tune file
  108. why wont my truck start?
  109. LT1 tuner in Charlotte NC area?
  110. stock tune
  111. ODB2 Scanner/Logger Download?
  112. NGK AFX wideband and E85
  113. Heelp!!!
  114. need help on my car for tunning
  115. Wide band harness extension
  116. Is this burst knock? Log, tune and config inside
  117. Map sensor help Please
  118. Problem with skip shift electrical plug
  119. tune getting worse?
  120. EFI Live and HP tuners in same PCM?
  121. Need a tune
  122. Some surge with TCC Lockup.
  123. WOT issue
  124. Flashing gauges under acceleration
  125. Weird SES light
  126. low oil level light
  127. Email tuning, HPtuners and more
  128. Good Tuner in the NC Area?
  129. Sensors not completing cycle
  130. Can anyone review this HPT scan?
  131. Lc-1 wideband
  132. Why is my car knocking at randomly rpms?
  133. 0411 into 98 f body cradle?
  134. LQ4 with cam and more... but no tune :(
  135. why wont hp tuners read ECM?
  136. Help me identify this harness, 98 or 99+?
  137. new tune, no MAF ?
  138. GMPP controller
  139. holley dominator EFI does someone have a parts list?
  140. Yay or nay to dyno tune after just exhaust & intake? (LS2 C6)
  141. warren (ls1) to E40 PCM/ECM (ls2)
  142. 99-02 Harness in my 98 TA
  143. EFI live, 160lb injs, E85, resistors, only runs WITHOUT the fuel pump on?
  144. Will oil affect wideband readings
  145. hypertech question
  146. EFI Live COS ???
  147. Any mail order tuners not need the PCM sent in?
  148. Scan only questions
  149. Pcm for less tune
  150. wiring one fan off the stock PCM and harness.
  151. Ls376/480 Diagnostic??
  152. Wideband questions?
  153. RPM Surging at Constant Speed
  154. Need info on Tuners for a stock 99 ss
  155. DBW Throttle Body Response (hanging rpm)
  156. P0300 after heads/cam swap
  157. problems with swap harness and 411 pcm
  158. 0411 pcm reflashing
  159. Rapid Motorsports?
  160. O2's not switching properly..tune related?
  161. o2 sensors, where should they be placed?
  162. PCM Question
  163. Maybe a pcm problem??
  164. Tuning help!
  165. New to HP Tuners - 1st Initial Tune, Log, would appreciate some feedback!
  166. what programmers will work for my 98 ss
  167. Running a Cam untuned in an Ls3.
  168. 07+ E38 ECM OBD2 port wiring
  169. mod harness ecu trouble 4.8
  170. wide band o2 graph
  171. Where does this plug in go???
  172. New efi setup won't start - fuel pump relay kicks out '09 LY6
  173. loading a mail order tune
  174. Tachometer inop & can not retrieve DTC's
  175. anybody know what this box is?????
  176. Need your help!!!! Please
  177. OBD2 sensor readings for 2000 camaro z28
  178. Anyone using an Accel Gen7 with your LS?
  179. Bs3 dealers step inside
  180. Lingenfelter GT 1-1 cam tune issue..
  181. Lingenfelter GT 1-1 cam tune issue..
  182. Liscense Issue?
  183. Tune shop around north east Arkansas
  184. what is this???
  185. WOT shift problems
  186. Voltage on tuned out rear O2's?
  187. code P0507
  188. Engine grounds
  189. MAF fluctuation under WOT?
  190. EFI Live Main VE Table problems?
  191. bucking at low rpms
  192. Efi live v1 scan only worth?
  193. Tuners in Oklahoma?
  194. SD tune for FI?
  195. changing tires
  196. Frost vs hand held
  197. Car won't idle after new setup
  198. EFI Live, trying to tune a turbo LT1.
  199. efi live tune
  200. Is it ok to start car without MAF plugged in
  201. Can't install Flashscan V1.2 on new windows 7 laptop
  202. EFI Live - Abuse Management Table?
  203. using post cat oxygen censors as a pre cat?
  204. Which adapter to use for LS7 maf?
  205. Cam Sensor rewire LS3 in 98 Trans Am
  206. Does Holley Dominator use a MAF?
  207. I don't know anything about vehicle emissions
  208. help with ecu trouble
  209. So sick of smelling like my exhaust fumes.
  210. Just installed Brand new denso rear vette o2s and code p1133 pops up
  211. speed and odo wrong after tune?
  212. Remote tuning for driveability issues?
  213. Dedicated Scan Tool?
  214. MAF code with Speed Density tune???
  215. Basic tuning help and understanding for a noob.
  216. Tsunami Cam in a 347...(surging)trailer hitching, while at cruise speeds
  217. Which wideband with HP Tuners pro
  218. How much will a tune help me?
  219. minimal mod tuning
  220. New to ls1!!
  221. Split BLM headache
  222. holley dominator global tune needed, please help!
  223. Dies when coming to a stop p0101
  224. throwing knock sensor code?
  225. Wideband O2 Extension Harness
  226. What's your Cammed LS1 M6 idle at ?
  227. Tuning a larger TB
  228. serious problem and no one can figure it out.
  229. FlashpaQ tuning diablo sport
  230. My experience with idle tuning
  231. speedo question
  232. procedures????
  233. Just added heads
  234. Cam and headers. Got some codes?
  235. Can i start my new engine without a tune?
  236. Desired Idle for G5x3 112LSA and AFR 205 62cc
  237. Should I get a tune
  238. TBSS + 4L80E: TCM / File?
  239. Need base tune; hp tuners; 4psi; 60# injectors
  240. 98 to 02 ECU with EFI live
  241. Trouble codes inspection failed help
  242. 92-90
  243. Both fans, and removing AC?
  244. need help with P0300 and P0332
  245. Pro and Cons to Mail Order Tune Vs. Dyno Tune
  246. How to correct MPH??(HP)
  247. MSD 6LS Tuning on 408LSX
  248. DBW speed limiter
  249. What if I have normal injectors and flex fuel tune?
  250. No Spark..... No RPM.....
