PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 [180] 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Request for information on Aftermarket ECM flashing and pos
  2. How to desensitize misfire detection at idle?
  3. TB drilled for cam, now on stock cam have bad drivability
  4. tuning after lt's???
  5. tranny not shifting right and tc not locking up right either
  6. SES Light
  7. LS1EDIT at TA Nationals??
  8. ECCENTRIC TIMING ON IDLE
  9. timing
  10. Any tuners in the house. Need some help diagnosing
  11. LS1 Edit problem. What went wrong?
  12. Is this an injector offset issue?
  13. Please help soon!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  14. more predator newbie questions
  15. Why do I keep getting PO 448
  16. Best place to buy Predator?
  17. Autotap or Ls1edit / Which to buy first?
  18. Predator Problem!!!
  19. Heeeelp, I think they're screwing me...
  20. Predator Tuning Problem
  21. WOT fuel help please
  22. Help with ls1 edit
  23. EASE, trans temp??
  24. air bag light on
  25. How to lean out A/F ratio in closed loop?
  26. Hesitation Problem, Need help
  27. predator newbie with dumb questions
  28. new LS1 Edit forums
  29. possible false knock?
  30. Dealer ship can not communicate with vehical??
  31. I am stumped!!! Help! *DELETED*
  32. VE table vs Tip -In
  33. tuning questions, best a/f ratio and timing?
  34. Ls1 edit and O2's
  35. LS1 EDIT / ATAP EFI LIVE CONNECTION ?????
  36. AutoTap question?
  37. Predator custom tuning
  38. Predator
  39. Don't know where to go.
  40. Need help with edit
  41. EFILiveV5 and Oil Pressure
  42. LS1 Edit - KR, COT, TC
  43. Bone stock autotap #s...weak? please opine
  44. KR help
  45. NEEDED : 98 F-Body PCM, ASAP!
  46. Traction control
  47. Speedometer help and edit
  48. throwing codes
  49. p0121
  50. trouble codes, P-1133 and PO102
  51. HELP!!!! service engine soon light
  52. P0133 slow o2 response
  53. How to tell if prev. owner had my computer reprogrammed
  54. LS1 edit or ed wright tune
  55. I need a stock LT1 dyno sheet!
  56. I randomly lose TCS after working with fuel system.
  57. quick autotap question?
  58. cam and headers....need a tune?
  59. Car running after 7 months.. just 1 code now..
  60. Trans shifting into 2nd way too soon, only at the track
  61. any ls1edit gurus in the Sacramento area
  62. PCM has wrong tire size????
  63. ABS and O2's?????
  64. Idle help
  65. need help tuning
  66. Power programmer around Lexington, Ky area??
  67. Who makes the MAFT?
  68. Need help ASAP. Having a prolem at 5k-5.5k, car breaking
  69. auto tap
  70. Paging Supercharger/LS1Edit gurus...
  71. Is the factory speed slow under hard acceleration?
  72. What has to occur to activate the Low Octane Table???
  73. PCM
  74. Need Help!!! ATAP, LS1 edit not recognizing computer!!
  75. 99 motor in a98. PCM Differences???
  76. cooling fan help
  77. Threw code P0135
  78. Two Guys Garage - Hypertech = 120HP gain?????
  79. Pic of LS1 Wiring Harness inside
  80. Does any one know where i can buy a new computer
  81. Temperature Gauge fix for '99 & up?
  82. How good is the Predator?
  83. Low octane spark advance & high octane...
  84. Car running weird... help pls
  85. Can i gain from dyno tuning at the bolt on level?
  86. Can you tune with a stock O2 sensor?
  87. Tach not working?
  88. Predator axle ratio change
  89. First Autotap log tonight, help needed....*UPDATED*
  90. question about using laptop w/ ls1edit
  91. 1998 Diablo Sport Predator?!?!
  92. gm's tech 2 and ls1edit work together?
  93. Knock sensor conversion on 98
  94. ecm or bcm
  95. Help car wont rev past......
  96. is that bad 1.7 KR
  97. Adjusting Ltrims... What table in LS1 Edit?
  98. Help me with this code my car threw....
  99. What is the easiest way to calibrate my car for my 4.10s??
  100. why did my fuel trims go down to -8 or more after gettin gas
  101. MAFT directions?
  102. Tuning Questions about injectors....
  103. MAFT, new vs old
  104. Need edit file for 427 stroker
  105. I need diagnostic help
  106. Do I need differn't Injectors?
  107. Will LS1 edit work on the LS1 trucks?
  108. Will i be able to use my EDIT with a replacement ECM?
  109. ATI P-1SC timing issues (LS1Edit)
  110. O2 Sensor Question - Values varying widely
  111. does any one have info on the flash chips??
  112. High IAC's, how can I lower?
  113. Help, car running like crap!
  114. Help Knock from nowhere (long)
  115. Serial to USB converter for LS1 Edit
  116. i think i might have detonation but i dont know, help me!!!
  117. Just thew a code...P0171 ...........
  118. ACCEL DFI GEN 7 FOR THE LS1/LS6
  119. Which AUTO TAP to get?
  120. P 1 133 what is this code? help
  121. I need somebody to ATAP me-Still getting High RPM ping
  122. Lost 5 MPH in the 1/4 Any Ideas?
  123. Car bogs when going into Closed Loop
  124. Newest LS1 Edit Version....
  125. auto tap and efi live
  126. heatwave and 91 octane gas equal no power
  127. Warm/hot start issues, IACs, and "cruise control" effect....
  128. Air/Fuel Thought for self tuning
  129. Buying LS1edit next week. Where to start?
  130. P0175..(System to rich bank 2)..HELP!
  131. timing ???
  132. fuels trims, when and how to read them
  133. Knock sensors How Much???
  134. Predator & Shift Points for an A-4 with 3.73's?
  135. Diablosport Predator
  136. LS1 Edit Cable
  137. Injector flow rate table with procharger ?'s--->
  138. predator on more than 1 car......
  139. PO 171-174
  140. Hiting rev limiter only with et streets...
  141. Part throttle l-trims neg.
  142. 581 lift cam, will I need a custom tune from Predator?
  143. Injector Offset table for a 2001-2002
  144. P0106 Code? MAP Problem?
  145. AFR at 14.6 how to get it down in edit?
  146. Rolling rpm issue
  147. Help me with P0200!!!!
  148. Update on my hard starting problems and more...(LONG)
  149. Need some help with LS1 edit
  150. Threw a Code: P0410
  151. Dos version of A-tap
  152. LTFT's won't come down....not making sense
  153. I think I'm in TROUBLE!!!!!!!!!!!!
  154. Where does the red 53 spark retard wire lead to?
  155. LS1 16pin OBDII dataport pinout
  156. SES light help
  157. Just installed HPP3 and now I have an SES light. Help!
  158. dyno tuning question
  159. Opinions on Auto Tap EFILiveV5 for LS1's
  160. PCM codes 1125, 1276 & 1278
  161. Info for perspective predator guys....(Long)
  162. predator tuneing
  163. PLEASE help me out with this weird misfire problem.....
  164. predator info
  165. runninwiththedevil
  166. OK I need to find a dyno near Florence SC
  167. Ported/Descreened MAF - Hurt performance?
  168. Anyone ever open their LS1 Edit cable up? jumpers?
  169. did carputing send me the right stuff?
  170. Big thanks to Javan with B & B electronics with help on Atap
  171. SHIT LOST COMM DURING PROGRAMING.
  172. LT1 EDIT - ANY ONE STILL USING THIS. I NEED HELP
  173. ? on wires
  174. P0327 Knock Sensor Low Voltage... help!
  175. Stock Throttle Body hole size
  176. Wat size drill bit for tb butterfly hole?
  177. Computer differences ?
  178. help,,,,,,,proplem after new plugs
  179. predator
  180. G5X2 tunning nightmare!
  181. doesnt shift right
  182. Adjusting MAF to 512g/sec
  183. Disabling TCC lockup function
  184. Need tuning help... getting LTFT's dialed in
  185. i need autotap help, car is running bad
  186. Just got Predator: any basic suggestions on adjustment?
  187. How to move Auto Tap file from PC to Laptop
  188. time 4 tuning, ATAP logs inside
  189. Injector Flow Rate vs MAF table for Fuel Tuning
  190. PE VS RPM Table Question
  191. Will cleaning MAF help my problem?
  192. DTC P0300 (engine misfire detected)
  193. LS1 EDIT
  194. Removing 02s entirely?
  195. All possible reasons for a cylinder not to get spark?
  196. Anyone know a good tuning shop in SoCal Area? *DELETED*
  197. does efilive give you acurate afr
  198. LS6 intake and Z06 injectors installed
  199. wiring question
  200. Predator Newbie
  201. ls1 edit and predator together??
  202. What does TEA use
  203. SES light???
  204. ?? about tuning
  205. Some one Help (Predator)
  206. 1371 code?
  207. Who uses ls1 edit near LA???
  208. O2 Test?
  209. Predator re-sell
  210. How do i get ls1 edit?
  211. Ken Kelly's phone number
  212. SES code, P0430 just after last weeks P0161
  213. Changing torque management?
  214. Anyone experience the P0801 code?
  215. My PCM went poof while using LS1Edit
  216. Idle Problem After Ported TB
  217. What would cause my interior light fuse to keep blowing out
  218. "Black box" questions....
  219. Thanks!! - VE table adjustment
  220. O2 sensors...what brand and where to get??
  221. paging Jim Wilson with the 03 z06 and magnacharger
  222. Is there such thing as "LS1edit archives"?? if so i need it
  223. How do you richen the car
  224. Tuning with EGT.
  225. Speed Inc dialed in my Z!
  226. Will it be safe to run new engine without a full tune?
  227. DETONATION!! & PREDATOR??
  228. How to reset HPP3?
  229. predator or hypertech III?
  230. Troubleshooting a hard start???
  231. Need help ASAP please!
  232. STFT and KR question
  233. SLP 85MM MAF - bag it?
  234. Predator problems
  235. Flashing SES light. What's it mean?
  236. what to change first?
  237. LS1 EDIT ??
  238. ls1edit newbie
  239. Paging Harlan ... got some electronic questions
  240. Sending PCM off for tuning
  241. LS1 Edit & converter slip
  242. What type of singal does the EGR looks for?
  243. How did you get your heads/cam car to idle???
  244. LTFT aren't moving on atap
  245. DTC 0420 code?
  246. Tuner near OBX, NC?
  247. Can I delete Knock Retard for good with Edit??
  248. Showing P1416?
  249. Slow PCM?? is that possible?
  250. Throttle Body Cfm
